- can someone identify these injectors please?
- Why do U have 2 bang the sidewall for a B on a US EF while it fits right in 2 a J EF?
- Took my SOHC out last night (PICS)
- Performance cams for Lambda- car?
- Wiring Problem NEED HELP
- i need part(s) for my bumper
- need to find a certain wing!
- calibrating tps sensor help??
- ls/vtec or boosted zc?
- EF b series mounts question... Yonoka brand
- Thread Pitch and Size of the banjo bolt at the fuel pump...
- b16a swap ?'s need help!!!!
- cheap parts finder
- motor swap questions
- will a 88-89 crx front bumper fit my 91
- what ecus can i run on a 1st gen rex
- idle pressure drop.....
- gray ef with side moulding
- radiator
- coolant line question
- Question about the D16y7
- $400 for a d16 z6 full swap?? GOOD? OR BAD?
- help at installing car stereo
- $400-500 for a d16 z6 full swap???
- side moldings
- Code 4 on B16 please help.
- getting ready to boost
- Throttle body question
- constant speed problem
- uh oh.. OBX LSD problem
- Free Gifts *** Totally Legit
- speedometer problem
- How to put a/c in a CRX that didn't have factory a/c?
- confused on building a b16 help
- 88-91 Civic Hatchback REAL-JDM (right hand drive)CENTER CONSOLE for sale!
- 91 crx hf w/ b16a1 & bolt-ons VS 98 gsr w/ jdm itr b18c
- motor qustion?
- CRX Oil Pressure Switch
- b18c1 into a 91 crx si
- PM8/PR4 and Code 13
- B16 Crx Clutch Probs.
- Just got a 90 civic DX...Any ideas??
- help please!!!!
- bike racks on crx's
- Another "Should i buy this CRX" post....
- question about flex point on crx
- Body Kit Question, Crx to Hatch.
- FUCK HONDA-TECH
- for sale!! 2000 LS rims and tires
- 90 hatch for sale---York, NE
- b16 to d16
- any info on H22 swaps in 88-91 hatch
- racing seats - need custom brackets
- Thanks For all Suport!
- Integra to CRX parts swap
- Custom CRX cup-holders!
- Anyone see this yet? 2006 Si (not ef related)
- Good trade ??????????
- Reco: Struts for lowered Civic
- What Motor
- which sensors can be reused in obd0 to obd1 b16 manifold
- Need some quick input....please help
- car wont start
- wire for rpm sensor
- my sohc project log 56k maybe
- Need help putting my new Tokicos together.
- Motor won't start.
- help asap
- Another question on a Honda Hatchback 1.5L upgrade
- wings west bumper measurment request
- CRX bumper blinker lenses.....
- is there a difference between 88-89 and 90-91 crx si pm6 ecus?
- JDM...USDM......
- Upgrading a '91 Civic dual point to a 2000 cylinder head & Multi-point HELP
- need help bad
- Need MPFI pics
- 90 Civic HB Burnout *vid*
- question about zc dohc bottom ends and regular sohc bottom ends ...
- power seats??? or whats lower?
- crx gauge cluster help
- Clunkiness in suspension-Help plz
- wtb: d16a6 distributor
- Couple of Questions???????
- Hf black box map sesor, replace with si for b16? (can't search for Hf tried)
- stock 3spoke crx steering wheel vs civic hatchback dx wheel
- What O2 Sensors from other Honda Engines can I use on a D15 DX motor?
- needhelp please
- Light blue crx
- 88 HF converted to 91 Si...need help
- sorry im turnen eg
- i bought two z6 tb but they are different?
- Stolen and recovered
- No power/spark to Motor.
- Question about HF hubs?
- vtec woes
- b16a swap is long and tiresome
- Why is the 88 CRX lighter than the 89
- HELP ME ANSWER SOME HEAD SWAP QUESTIONS....
- Quality coilovers that will give decent ride comfort
- OBD-1 trouble codes
- 95 Integra Rear Seats Fit EF-Hatch????
- Old post help... can't find it... searched and searched.
- mini me build question
- HELP with fuel pump
- b18c vs ls/vtec pros and cons
- Quarter Panel Patches???
- Fuel pump needed for CRX
- About P28 ecu's
- Hat/Shirt Concept... Would you wear/buy it?
- Crazzy Vibrationnnss!!
- knock from right rear wheel
- Help the newbie again please...!
- 15b1 mount up to an SI tranny?
- what ecu do i need
- Why is this complete camber kit so expensive?
- Aluminum strut bars vs carbon fiber
- Traction Bars??
- Zc tranny in a b16 block
- dx and si spindles the same?
- i need help with wiring a si motor in my dx crx help me plez
- RHD CRX HELPPP
- Wierd Electrical Problem
- blox intake mani??
- Turboing a 86 CRX Si
- ZC parts
- pointless pics
- Having A Problem
- axleback exhausts for crx
- Best Ebay Air Intake System Fitment for Crx B16?
- whats the difference???
- Spark plugs
- Fs: 1991 CRX Si Parting Out Cleveland
- how much money do you have in your car?
- Injector Cleaning Services
- dohc zc crank
- im looking for ef parts
- crx front and rear lip
- Need major help, searched no luck!
- Intake manifold
- CRX Trouble
- Topspeed header question
- LS CRX... need 91 LS Vacuum Diagram!
- 1990 crx o2 sensor
- I might be picking up an Si or is it?
- Aftermarket sway bar for 90-93 integra fits crx?
- Intake Idea
- '06 Civic ready to unveiled at Chicago Auto show
- my motor swap
- installing a really really loud air horn in my civic lx
- crx broke down. possible timing belt slip?
- b16 oil pan the same as b18?
- New to Honda in general.
- differences
- B16 trannys.... Y1 or S1.... LSD?
- What suspension to go with
- hatch spoiler
- Smog help needed ASAP
- Are engine codes the same for EF and EG's?
- Friggin clutch engaugement?!?! (Searched)
- another one of those "whats my crx worth" thread
- under dive pulleys??
- What timing belt .... DOESNT FIT
- new suspension?
- 90 CRX wont start....
- IAC plug?
- my hatch
- ef 4dr in honda tuning.
- pls help mugen twin loop in crx
- adjustable fpr???
- Bseries cam gears on a ZC?
- crx SiR
- crx hf rear sway bar question
- OBD0 to OBD1 help
- initial timing 91 si
- Front lip
- b18c1 in a 91 hatch....
- I noticed something today......
- driving in oil seals for b18a1
- B16A Integra XSi?
- d15 in a 88 crx si already searched
- Whats a nice asking price for this.
- mini swap vtec no worky
- Rhd crx how to start import
- Resonator intall $$ & feedback
- ECU ERROR CODE 20 !!!
- code 15?! i checked it via the helms way and still have nothing!
- Are they the same?
- ? about 98 cam gear.
- Good rim size (already seached)
- B16a swap tranny problems
- Tsudo caback exhaust for crx?comments.
- Missfire(searched)
- BBK Throttle Body ?'s
- if IACV is disconnected will it create bad gas mileage
- Will a header from d16z6 fit ZC CRX?
- Odd electrical starting issue...'91 LX 1.5...please help
- EF Lips
- oil in park plug holes.
- B18c wiring
- I want VTEC!!!
- What should I look for/avoid in a CRX?
- code 20 electronic load...bad idle
- parts i need for my car
- 2 wire plug above MAP sensor
- JDM S1/J1 Trannies - Who Sells Synchros for Them?
- Can someone help me...
- My 1st hb
- brake warning light
- searched: Rear Sway bar hardware
- D16Z6 head on D16A6 Bottom end Help
- right rear window got busted out
- The good ol days..
- code list of a b16 ecu pleaz(code 18)
- what ecu '90 crx
- b16a ef wiring prob
- EF owners and thinking
- ex to si climate control
- BROKEN WHEEL STUD...help..
- 89 CRX w/B18B what header to get!?
- crx engine
- civic si hatch
- white smoke n civic
- 92-95 axles in an EF
- CONTROL ARMS??
- EA body mods
- Trying to remove flywheel
- anyone know how many cc's the dsm 1st gen non turbo injectors are off of a dohc eclipse?
- Vtec no workie
- oil jet
- B16a head LS Block
- help with bseries swap in 99-00 civic
- What do u think?
- need b-series tranny
- i haven't in the ef forum for a long time, but a recaro for sale
- replacing timing belt
- Injector help (56k beware
- TEXAS 650HP CIVIC
- site for b series?
- d-series turbo for a zc
- help on motor swap choice
- UR Single belt conversion Pulley
- sound padding on the floor of my 91
- Claying D16Y8
- What other shifters fit in a crx?
- 02 sensor which color is which?
- Zc price on the streets with no tranny???
- Cat back exhaust
- Unusual question - importing a motor from the States
- Camber kits....
- head bolt reuse?
