View Full Version : Honda CRX / EF Civic (1988 - 1991)
- d16z6 swap trouble
- Rev limit
- CRX distributor
- wtf!!!!!
- Oxygen sensor trouble code...I need help!!!
- lower CR on DOHC ZC using PM6 pistons?
- will obd0 ecu work??HELP asap
- Website question?
- opinion?
- Need OEM drivers side seat for 91 HF, what to order and where?
- b18a1 swap into a ef sedan-*ac question-*
- Read If you have a Wings West kit...
- bumper support question
- Who has a Recaro seat in a 89 hatch?
- B16_Madman Are you in here?
- 3rd gear grind - replace synchro or gear or fork?
- is 1991 civic si obd0 or obd1?
- Do I post as Del Sol or CRX
- 1991 civic si owners. need some help.
- what is your average fuel mileage? Civic 4 doors Only please!
- Factory stereo connections
- omg what engine is that!
- new civic owner
- Which engine would be better?
- 1990 crx si project
- WTB 88 EF HB Side Moldings
- Mugen ground wires
- no vtec
- cost/performance
- WINDSHIELD adhesive removal
- Check this out!!
- anyone keep dx master cyl. w? rear discs?
- Going to the state ref need advice
- SHould I buy this rex?
- B18A1 What manifold will fit?
- '91 Crx + B18c (Type R Motor {JDM})
- Cheap places to find Honda OEM parts in Long Beach, CA
- high speed braking, fluid amount.
- Ok D16A6 block... Y8 Head.... just clear this up
- weird brake problem...any suggestions
- Need help with a choosing a catalytic converter in cali
- Aluminum Door Panels?
- Another problem
- 1987 b16 swap
- need to figure out what colort to paint a crx any good websites
- what do i hook this plug to? (pic inside)
- questions bout swaps
- trying to figure out the best engine please help
- how do i post my car for sale ?
- b18b into 91 si
- Clutch Adjustment
- Will AC mount from Si work on ZC?
- Whats up, im new!
- where to buy OEM replacement molded carpet? keep in mind i'm CHEAP
- Roll Bar Questions.
- who has the Ground Designs 2000 12 piece CRX body kit? - help!
- Another down EF and the most annoying things to replace.
- B18A swap Qs. pls help.
- Trying to find some old friends... Anyone remember this pic?
- JDM EF9 Cluster
- Centerforce clutch out of EF into a B18 can it be done?
- where's ur Tach mounted?? Pics Please!!
- removing lowering springs and addind a coil over kit
- Anyone dealt with this business?
- Speedo needle
- ZC in a day...
- LOOK OUT IN SACRAMENTO.car stolen
- Can someone post a pic of a b16 and d16 IM gaskets together please?
- What is the advantage...
- tps
- RAGE PERFORMANCE/ NUFORMZ HOT ROD CRX-JAMES'S EG HATCH
- Civic Si Skipping and spitting back
- paint
- how do the rear speaker mounts hook up/
- crower stage 2 camshafts h22a
- EG/EK radiator in a 90 civic si with a turbo d16a6? how well will it work?
- EF SIR Front End & Hood Issues!!! HELP!
- RHD Drive Crx. Should I Try To Import One?
- My car wont roll, please help!!
- B16A1 exhaust woes.
- which seatrails????
- cant stop
- 4k Idle. B16A1. =(
- b18a1 swap done just need to know something
- What would you do? Time for a swap?
- Bad ECU.
- How big is the fuel tank on CRX Si 1991?
- 90 civic 4spd and 89crx hf knuckles and hubs same?
- Thanks for yesterday, now i have a question.
- CRX won't start, but was just running.
- What Ignition Wires should I use?
- intake mani
- header b20vtec in ef
- Are these injectors obd1 or 0
- HEAD GASKET
- how much hp does a ls vtec
- DC ceramic 4-1 OR 4-2-1 header for D16A6???
- i need help how do i become a regular member
- starter wont turn motor
- conversion harnesses for obd0-obd1.... what ones do i need???? was i told wrong???
- Seats/Interior
- stupid VAFC 2 question
- Help with rust
- ZC Research
- Does anyone know what THIS IS??
- WIll any dizzy work?
- PM6???
- did EF SiR civics come in a dark green? if so what is the paint code or something close?
- how to wire up an obd1 distirbutor to 0bd0? who knows?
- anybody think i could get this 00 si greddy kit to fit in my rex?
- How did you mount your battery? PICS
- b16???????????
- Quick question
- muffler bearings
- ok so I get the stuff from a pwr window/lock car Now what
- need pictures of Azure blue green painted civics? or any darkish green civics?
- D16a6 Did this come in any other cars other than 88-91civic/crx???
- MPFI ? have searched please help
- CRX DISC BRAKE SWAP QUESTION!!!!!!!!!
- Please HELP!!!!!!!
- Exhaust system : from the cat back.......
- How to clean the EGR Valve
- 85 crx convertible on ebay??
- D16a1?????
- Roll bar pictures: 89 CRX check it out.
- Muffler bearings?
- 89 Civic Si - radiator/fan - ?
- Wiring up JDM Guage Cluster--difficult?
- wrecked my car.....i need help
- 89 flywheel on an 88?
- Eg style smaller radiator?
- JDM SIR front bumper question
- 1989 Civic Si - Timing Belt?
- Dropzone camber kit??????
- Mugen twin loop on crx
- removing discs off a Si
- Rear disc brake conversion
- More power for daily driver (on the cheap end)
- ef8 jdm door visors
- How change the color of dash boards?
- vtec vs. turbo ?
- How do i change the engine mounts?
- So what would it take to convert to pwr wind/locks
- damn! need more storage places
- 91 Civic LX Air Conditioner Problem
- skunk2 or y8 intake manifold
- CRX advice.....about to buy one.
- 89 accord shocks on CRX
- Dash Swap We Need To Clarify This Once and For All
- Catalyc converter
- I'm just getting into hondas dont know all the diffent engines please explain to me
- HELP!! Was i given the wrong engine??
- head gasket?
- getting my rex soon whast the best place to find bodykits and other things?????
- Painting Roof/Hood/Hatch Black
- Stock ZC vs. Stock Si Fuel Economy
- Injectors for 90 Civic SI.
- Pressing out bushing
- prelude fogs? anyone
- Camber Correction / Lowering Undo
- Seat question
- 98 CRX Si (3 door) Gas guage sensor location?
- Stock LX running rich, please help!?
- help on changing MTF and axles
- EXPERTISE HELP NEEDED PLEASE
- PROBLEMS w/ B16A in 90 Civic HB
- replacing faded mouldings
- a/c bracket?
- Need Help: Fender Removal
- Need to know what kind of hubs i can fit on my ef?
- For those of you who installed power folding mirrors?
- Help! i need a Vacuum Hose Diagram ASAP for JDM b16A
- what is the best looking body kit for a 91 civic?
- I need wiring schematics: 1990 Honda CRX DX
- intake manifold clearance / B18C1 in CRX
- i almost hate my CRX..someone help please
- ef8 jdm fog lights how much do they usually sell for?
- B18A into a 89 CRX Si
- changing entire harness for mpfi
- ZC DOHC DISTIBUTER problems
- what cars to get intake manifold from ? (mpfi swap-searched)
- "Skunkworks" CRX springs.. spring rates?
- ls ?
- car wont stop ground issue i think???????????
- crx exhaust on a civic
- Aftermarket parts for JDM ZC
- North Jersey/NYC EF owners ** junkyard with power windows spotted**
- if i get a ZC and Turbo engine in a 88 crx will I need new engine mounts
- PLEASE
- New crx?
- Decent price for 96-00 HX wheels and old CRX Si wheels?
- LS swap
- help figuring out Dashpot/Purge cut-off valve?
- Will a d15 exhaust manifold work with a d16?
- out with D15B2, in with D16B6 - couple easy questions.
- which axels?
- Putting a D1678 in a 91 CRX Si
- 88 crx suspension possible to swith to 89-91?
- How to read ecu codes with OBD1 conversion?
- Car Will not Start.. help needed a.s.a.p.
- NEED HELP MY FIELDS SFC-VTEC CONTROLLER IS ACTING WEIRED ON MY B16A???
- asdad
- HELP HELP HELP car will not start!!!!!
- clutch problems
- DOHC ECU question?
- Does the JDM ZC civic hatch come with a different front end?
- JDM side skirts for EF
- SOHC ZC DPFI...doable?
- Water in spare tire well hatch...... taillight gasket?
- got some new pics today of new stuff!!! 1989 crx hf b18c1 update pics!
- ok.... b18c5r into crx that currently has a d15b in it, need alot of help.
- problem with a door wraning light lamp
- ANY real EF8 with traction control arms like Z10 or Jimfab ?
- electricle problem? (i suck at spelling)
- is macco or earl schieb paint job ne good?
- Chicago Motor swap help
- rex wont start .. possilbe dizzy prob?
- type r steering wheel
- y8 manifold into a A6
- Anyone have the skibby on where Noah is? CRXPO
- 89 crx dx doors
- 1/4 on sohc
- Quick Engine question
- Anyone have the Neuspeed rear 22mm Swaybar?
- Proud new owner....
- auto to manual conv. need help plz ????
- where can i get a momentary push button?
- Two MPFI swap questions. Please Help :)
- ls into crx si
- B16a
- 91 CRX Si D16A6 to D16Z6
- Possible Stolen CRX in MD
- brake problems
- Crazy Storm. Engine Light On!
- FREE CARFAX.. HURRY BEFORE IT EXPIRES...
- Stock Si swaybars a bolt on?
- car wont start need help
- b16a2 in 88 crx, car is obd1, cable tranny, code 17 = vss, need help!
- b16a2 need help with the AIT SENSOR!
- what ECU
- Skunk 2 megapower exhaust vs. thermal r&d???
- 90-91 4 door seat belts
- Rear Seats in CRX's
- GSR shocks on 90 civic??
- mysterious sunroof
- please help with timing???
- Spindles to use in my hatch
- Wanna Build A D16A6 for F1, *Already Started* Need Some Advise
- kteller.com exhaust kit question
- QUICK ? PLEASE HELP
