View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Car bogs and runs like crap below half tank
- Need help on engine harness terminals
- b7 swap wont rev past 6k
- No throttle response when trying to resume throttle...?
- help with my climate control
- My Hatch Build
- HOPE SOMEONE CAN HELP ME
- Stage 2 cam d15b2 where should i set my camgear at?
- Radiator support panel....help
- suspension swap
- 3500 rpm what?
- LS w/ b16 cable tranny.
- Mil spec military grade connector??????
- dsm injecters on an mpfi swap
- 86 crx
- ED7 Cluster Light won't switch on.
- ef SiR front end question
- Oil sump plug o ring
- Should i buy this Ef?
- Insight to ID of PL3 cable tranny needed ASAP
- Got more stuff for my d build!!
- Bogging off the line, flat spots in powerband, code 1
- EF9 Fuel pump help!?
- ef hatch pops fuses when key is turned to prime fuel
- battery light wont turn on
- My CRX not so fuel efficient...
- Apexi Turbo Timer Install Help???
- DPFI to MPFI swap write up, this one accurate?
- Heater not working properly
- White Smoke After MPFI swap... Head Gasket?
- CRX Si, B16A1, Y1 LSD, Greddy SP2, Eibach Pro Strret - I need advice!
- Yet another cluster swap question...
- Is there a difference in hydro & cable clutches?!
- My d16a6 build part1
- civic hatch i gotta couple ?s
- Cannot get axles back into transmission
- 15x8 +20 offset work on an EF?
- 88>97 rear drum interchangable?
- crx ss brake line problem
- back again for the very first time!
- The Hunt for Discontinued Parts Thread
- wagovan winter beater build
- New to the forum.
- Need to know how hatch struts install on '90 Civic Si.
- * How RARE/Valuable Is The 1989 Civic Si Interior?? *
- Car is jumpy like no fuel after downshift
- 90 wagovan starter grinding
- wheel help
- crx bumpers on si hatch?
- Gr-2 Kyb Shocks on Ef
- Dpfi fuel pressure regulator
- Hello from PA! (Very PIC heavy!!)
- crx whinning noise when i shift
- Sway bar and shift linkage issue
- Gauge Cluster Compatibly
- EF parts for sale
- 1st Gear pops out
- Purchased Mishimoto hoses for my 90 Dx. Where do these hoses go? *IMAGE*
- EF9 VSS where to buy? or alternative?
- 1989 Honda CRX DX auto to manual conversion
- what i need to complete f22 swap into ef civic?
- Help needed with fog light install
- whistling sound?
- stereo shuts down, and head lights dim when break is applyed, where to start!??
- rhd manual rack
- 91 CRX dying after 10 minutes
- optional center console
- 91 EF Suspension HELP!!!
- Sedan transmission
- will a z6/y8 gasket fit into a d15b2?
- Tail lights
- Need help finding the right timing belt for a 3rd gen DOHC ZC??!
- finally using my honda-tech account
- My DD - 1990 Civic Dx
- how to properly clean a spoon sports air filter?please help :)
- Code 16. My hatch wont start.
- Possible to tell what oil?
- b16 swap-clutch very hard
- CRX ebay exhaust, pretty nice
- strange problem with hesitation
- What MPFI sensors are on the back of the IM?
- Fault Code 15 CRX with B16a1 swap
- ref b18b1 ef 90 civic
- 90 Civic Si, CRX Front end;)
- b18 tranny question
- 88-89/90-91 si???
- 88 Rex Si build
- Determining ZC generation?
- crx rear disk convertion...
- 1990 CRX speedo cable
- Backboard from hondaEF3
- Looking for discontinued 91 Crx door weatherstrip
- Toe out on the front
- 88 Rex Si Overheating issue
- WHere can you buy engine harness plugs OBD0 MPFI
- dohc zc swap questions?
- Installed Valve Seals on opposite valves should i put them back? intakeoexhaust ect
- B series swap shift linkage.
- Voltage issues on '90 Civic Si.
- Post links to your build threads here!!
- does code1 mean replace one O2 sensor? or both?
- need help with steps for replacing steering knuckle/hub ??
- Can I mount a plow on my EF?
- Maps Sensor question
- Long tube headers?
- Bought my EF and it doesn't run anymore
- how to convert carborator to fuel injection
- Performance Exhaust for an ef sedan?
- What Strut forks work with the EF?
- Generic DPFI throttle cable
- door question
- 91 Dual point bog, sputter issue, STOCK
- car wont start...
- 90-91 sedan dash in 88-89 hatchback?:
- warning lights wont come on and computer doesnt have power
- 1988 CRX DX, Fuse 12 (15A) keeps blowing
- crx with d15b7{problems}
- EF rex suspension disassembly problem
- my dirty french EF with B16 [EVO8 turbocharger]
- my 91 si wont start please help
- Harness question
- temp. and gas gauge not working.
- b20 turbo?
- Dual exhaust?
- k20a3 in 91 ef
- My header ground clearence sucks help!!!
- Towlie's ED3 build!
- quick wire tuck "yes/no" question
- 89 civic
- car died.. main relay makes funny noise
- 91 civic si headlights not working sometimes
- Need help! ASAP
- Exhaust Questions
- crx shaved bay fuel filter options.
- Low idle, sputtering,& burning oil HELP!
- Dizzy/ECU compatibility
- GSR Cluster
- clutch or tranny? :(
- need info on ef steering wheel
- 91 Si Hatch project
- D15b Starter HELP!!!!!
- Best brand of OE replacement parts?
- Where can I find this?
- 1989 Honda Civic Dx Sedan won't crank.
- 90-91 crx si seats
- Crx tucked half rad
- how could my new timing belt snap?
- the rare ef2 round fog question....
- B20 questions
- d16a6 p29 pistons questions
- STD, DX, SI Differences
- Ef swaps.
- CRX Brake lights don't work
- mugen 4-1 header fitting.
- just another question?
- Need to know the proper routing for front brake lines.
- first honda crx build
- Map Sensor Help?
- NEED HELP....
- ROTAS BR 13X8 4mm offset 67.1mm bore
- new throttle cable..
- emissions issue need help asap
- b18 crx nothing turns on
- Walbro 255 Fuel Pump Melts Wires?
- Timing belt problem
- DPFI to MPFI; new TPS.
- Engine at idle is bouncing between 1000 and 1500 RPMS
- aftermarket 88-91 CRX tail lights
- jdm b18b dizzy question
- d16a6 sputtering, burning oil
- can i put the jdm bumper on my 91 civic ef usdm
- obd-1 pr-3 ?
- Proper seat pan swap 88-89/90-91
- e85 can u do that on a honda??
- 90 crx seats ???
- if you had a fuel leak....
- Exhaust fitment issues
- WTT tattoo work for crx rad support?
- Swap questions?
- crx parts, please help!
- 90 civic dx with a b18b1
- Hasport modified engine harness
- Anyone ever heard of these?
- '89 CRX SI build!
- Transmission not driving when warm help!
- OH check it! my heater produces.. NO HEAT! =O
- D15 head on ef block
- Zc help
- '90 SI running really rich?
- B16 cable trans leaking from right axle seal
- ef and crx window question
- d16z6 bogging under acceleration.
- Steering issue...
- B18a swap in ef not turning over
- Exhaust leak--issue
- ed6 with da mastercylinder cusco strut bar?
- Can i use a ZC thermostat in my d15
- 91 Civic B16a Swap fouled plugs
- Suggestions needed Gonna start an a6 build
- sunroof
- swapping sunroofs??
- Ef hatch with crx cargo deck?
- What year had different spline counts?
- gospeed's intro/build thread - CRX Si action
- Camber kits. What're you using?
- 1991 Honda Civic DX Hatchback Spindle Problem - Please Help ASAP!g
- d15b2 exhaust manifold
- NEED EF PARTS FOR INSPECTION! PLZZ HOOK IT UP
- Ebay Experiment; Suspension On the Cheap
- Whirring sound after replacing water pump
- 88 hatch
- ~*Full Size KOYO*~
- Shattered Crx Hatch Glass! Help!
- d16B?
- d16y7 swap help?
- 1 wire to 4 wire O2 sensor
- Hatchback Door Swap
- Speedo Cable Clip at Rear Engine Mount
- Wire Tuck help please.
- JDM B16 alternator cross reference
- dash instruments going crazy car driving weird
- D15b vtec head swap
- 1991 Civic Hb DX with a B18b1 swap?
- Help needed for Rollcage I.D.
- Sub Frame Removal Question
- Broken 89 Civic SI Seat pan - what will interchange?
- Noise that my EF is making (video)
- Cable to hydro tranny mounting question.
- coil over adjustment
- Trans wont disengage
- 89 crx keeps blowing coil
- Rear Hub swap
- '91 Si
- my 89 ef
- New Ef Owner.
- Good purchase?
- why tha **** is crx waistin more gas tha a v8? wtf!
- Buying a CRX w/ Swap
- My first EF ever :) build
- difference in o2 sensors
- Best damn smart phone app i've seen
- ? about cold idle
- 90 si EF randomly wont start?
- Tranny shaking??
- Who makes aftermarket hatch struts?
- Motor wont heat up, runs retarded and waste my gas!!!
- d16z6 header on d16a6
- Help me diganose my oil leak/burn please
- Won't Start Post!!! Lookie, please!**
- eg intake tube on.ef?
