MD, CRX Build Thread
Old Sep 27, 2015 | 04:57 PM
mrsmartness's Avatar
Default MD, CRX Build Thread
Hello all, this is my build thread for my '90 CRX Si, purchased around 8 years ago, started restoring it- and then kids happened... so here it is 6-7 years later coming back out to play (I had stored it in a sealed container on my property while building my house).
I managed to push it into my garage and get everything sorted back on some shelves so I can start the fun part. Here she sits in the garage...
More updates to come...
BTW, this thread is open to comments... I got thick skin. lol
I will post questions, etc as I have them, appreciate the help in advance.
Old Sep 27, 2015 | 05:00 PM
Freemananana's Avatar
Default Re: MD, CRX Build Thread
Is it a proper cage? Looks half decent. The primer is probably going to need work after being stored. What kind of motor/performance plans do you have?
Old Sep 27, 2015 | 05:10 PM
Got the cage 8 years ago from a local guy in PA, he does custom work. It was a good design- however when I was installing it I decided to change the back strut tower bar portion to connect the towers. I felt like it would provide more support.
The welds need some work, but i'll get back to it shortly.
As far as motor- I got myself a 04 RSX-s that i pulled the k20a2 from, right under 90k, ran great. I plan on leaving most of the exterior OEM, and using the JDM front i purchased years ago.
Here is the drivers side mount shot, fit was perfect, but then again Hasport usually is.
Got the bay cleaned up, mounts welded in and ready for some test fitting...
Old Sep 27, 2015 | 05:29 PM
After dropping the K in for the first time, I had some hitting on the rear crossmember... had to remove some metal to even get it mounted.
After taking out about a half inch it fit!!!
So, before properly bolting everything down, I am going to make sure all my parts are here, or I need to order something, so I started mocking up or bolting on the needed accessories to get the motor to turn over...
I was able to grab the Hybrid shifter box from another MD k20a member, said on the site no cut install, but I wasnt happy with the fit so I cut the factory hole larger to make sure it mounted perfectly.
Also grabbed the Hush performance hydro conversion kit and started bolting it together with my pedal assembly. Props to Hush for the very nice how to videos and product!! Thumbs up.
More to come soon.... thanks all
Old Sep 28, 2015 | 07:33 PM
kayONE's Avatar
Looks good.what color you painting it?
Old Sep 28, 2015 | 07:36 PM
Sticking with the OEM Frost White, it was the original color- love the look.
Old Sep 28, 2015 | 07:56 PM
kayONE's Avatar
This thing is gonna be a monster when its done
Old Sep 29, 2015 | 08:14 AM
I sure hope so, thanks bro...
Got the traction bar and axles in, K-Tuned traction bar kit gets an A+ from me, shipped well, quality parts.
Hope to get the wiring finished and battery moved inside so i get fill her fluids up soon.
Old Sep 29, 2015 | 08:44 AM
hondatuner020's Avatar
Great build progress!
Old Oct 12, 2015 | 07:19 AM
Not much progress photo wise, got the rad mounted, and everything wired up... going to start her up this weekend hopefully and check for codes.
HondaJDMLife
Jul 25, 2014 04:43 PM
408wdy
Appearance Build Threads
244
Sep 14, 2013 07:54 AM
thevtecnician
60
Dec 18, 2011 06:07 PM
OGMatt
46
Nov 20, 2011 12:00 PM
91 crx savage
Oct 14, 2010 03:40 AM
