View Full Version : Honda CRX / EF Civic (1988 - 1991)
- HELP! Motor revs as high as it can after swap!!
- crx sir hood?
- Wtf! My Ignition Wire are Getting Hot and Start's to smoke.?HElp?
- Electrical problem, no dash lights, need help.
- Aftermarket Transponder Kits (anti-theft)
- what head gasket to use on a d16y8 head on a d15 bottom end???
- Someone requested EDM crx-VT wheels from me, but I lost your email.
- Brake lights not working?
- wtb: 88-91 civic sedan cluster w/ rpm
- Irratic Idle
- wtb: integra center console for 91 civic sedan dx
- d16
- ***HELP ME FIGURE OUT THIS WIERD PROBLEM please***
- 88-91 honda civic crx si
- greddy turbo timer install
- 89 Civic Si tail light
- White Noise ( scary )
- Running Rich and idle issues...D16A6
- New to Honda, have some CRX ?'s
- are koni RED shocks any good?
- 91 CRX (B18C SWAP) FOR SALE
- b162 swap questions??? different trannies to choose from...
- eg bumper on crx?
- how to identify d series lsd tranny
- 01-03 civic hood
- zc ready to drive but motor wont get gas
- Heater control JDM
- klunking
- 91 civic Problem - main relay replaced
- removing headlights/corners
- Seats question??
- is this price worth it for a 91 si hatch
- climate controls
- ecu change
- Zc/turbo
- How to tell what AXEL is going bad..
- CAN U PUT A 99 SI CIVIC FUEL RAIL ON A 90 CIVIC HB SI ????
- Acura Disc brakes on 89 Si rear???
- Let me see if I have it right (questions on ef parts/motor swapping)
- Help tracking a car that was sold to someone in VA.
- rad fitment?????
- What is the best thing to do to a B16a?
- 90-91 cluster in 88. ANyone have picture of plugs after rewire?
- I hate WINTER!!!!!!
- Boomslang harness problems?
- help window issue.. 00 civic si 50k
- Master cylinder/Booster swap?
- frame bent!!!
- Need some TE-37's ?
- Opinions needed on small problem I am having
- b16a radiator help
- Cold Start prob?
- what your top 7 best show and go CRX 2004?
- will ma high flow cat pass smog testing in Texas????
- ok so im confused on my foglights connection
- CIVIC HB AND CRX PARTS 4/S
- SHOPPIN LIST FOR a D15 build...
- 88-89 Civic HB Si parts needed!!!!!
- *Help* Reconnecting all the wiring in the engine bay
- today i got my exhaust B.A.R. certified and.....
- My new transmission
- Im buying a B16
- FS: 90 CRX DX
- Injectors not firing....what's going on?
- LoOkiE here
- b16 swap (speedometer)
- Legal Swaps for a CRX in California.
- MSD 6AL
- cluster
- Windshield Washer Trouble
- eg front *springs* on ef?
- Manual steering has a personality?
- can bad axles cause wandering
- hasport hydro conversion
- Need 91 CRX seats in NC
- Thought this would be the best place!
- obd-0 po3 ecu into ef obd-0 z6 motor????
- cleaning headlights
- How do you keep water from getting in the spare tire well?
- gs-r swap...vtec not kicking in?
- gsr cluster wiring
- California BAR'ed CRX's: Intake Question
- Car not starting? Im stumped!
- help getting my struts off.
- fuel pump
- distributor question. just finished d16a6 into my DX
- rough idling
- Transmission
- Si 5th gear
- D16 MOTOR?
- if i put a 88 crx si head on my dx would it fit and would the HP increase?
- c pillar bar install
- need help with my 87 civic...
- Just what is JDM these days?
- interior fan problems
- adjustable shift linkage???
- 1989 Honda CRX Rear Brake Drum
- Should I replace my TIMING belt?
- 87 integ in muh 89 HB
- Flywheel question (stock or lightened)
- Coolant Boiling In Overflow
- H22 in my HB
- DX axles on an SI transmission
- how much boost?
- DOHC ZC SWAP Not Starting
- eave location
- What Engines came in the 88-91 CRX?
- 1988 crx si rear swaybar vs 1991 si hatch rear swaybar vs usdm itr rear swaybar vs ST
- b16 crx o2 sensor wiring problem
- Do you think I will need a AFC?
- 89 hubs work with 90-91 crx si axles
- zc cam gears ?'s
- vtec activation
- JDM Sedan guys: Sidemarker placement specs?
- Powdercoating...
- Stuttering and hopping on B16'ed EF
- Pulling Transmission Question
- PM9 ECU?
- jdm one piece head light, tried searching
- What is the stock cargo cover "SUPPOSED" to look like?
- The end of this particular CRX...
- Overheating
- ZC Tranny with what axels????
- is Skunk2 muffler loud?
- tach wire
- questions about vtec-e
- need advise on what mod to do next
- 17x7.5 wheels fit??
- A/F Ratio Gauge install.
- when does a b16 stop making power
- rad fitment
- new toys
- wiring problem
- Salvage Yards in OC
- would this work to make money?
- fuel pump wire???
- MSD on a ZC
- Halo Headlight Problem
- Help with my race setup
- obd conversion walk through's?
- Part number needed badly! Please help...
- Battery Question
- Zc dohc question!
- automatic to 5 speed swap
- selling my motor :(
- Ebay seats
- thermostat question...
- OBD 2 Dizzy on OBD0 Engine harness.....question
- mpfi fuel lines
- ITR, CTR, or P30 pistons for LS-vtec
- Anyone have the jdm ef doors with pics?
- One quick question about suspension.
- Need some good advice
- Automatic Swap
- Guidence step by step?
- mpfi vacume lines
- DA mirrors on an EF
- Air conditioning in 1991 Honda Civic DX
- front bumper removal (searched)
- help quick.
- best motor for a crx?
- Lets talk distributors
- Alternator problems?
- Ef 4 door - opinions - photos
- DX and Si distributor...how to tell apart?
- headers
- crx b16 turbo w/ ac??
- 89 4-dr tranny swap
- removing rear washer fluid squirter
- Mugen vs Energy Suspension
- b18b1 dyno/pics
- New drop zone struts, anyone heard of them?
- Pearl White Paint. Paint trim anyone????
- Aftermarket foglights on hatch
- CRX CF hatch?
- mpfi problem???? yes i searched! so dont be calling me an HT n00b =P
- Front Brake Question
- obd 0 dizzy
- Can you do Cable to Hydro Swap on a D-series Block?
- Cable Vs Hydro Transmission in EF
- !!!!!!!!!HMO!!!!!!!!!!
- **STOLEN** 91 CRX Si San Diego, Ca
- assuming my speedo cable froze then snapped last nite???
- CHEAP POWER
- HeadGaskets
- Things to look out for when buying an EF or CRX
- weight differences?
- weight differnces?/
- Brake pads
- Will a 90-91 integra PCV valve fit into a first gen B16???
- CRXD16a6 zcb/ock/z6head/CRXsi advice needed !!!!!!!
- Y8 IM, dx harness ????
- D16a6.zC.z6 build advice&Criticismneeded !!!!!!!
- Reconstruction title, anyone ever register one, or buy a car with one? let me know!!!
- Y8 IM on my dx ef HEL!!!
- Can I use a Civic Si 1/4 panel piece on my CRX?
- Opinion on Halo headlights (please post pics?)
- ZC or D16 into '91 Civic Si
- Any way to fix broken speedo?
- wiring purge cut-off solenoid
- shuddering/popping when braking...
- Brake pedal goes to floor.....
- crx / civic differences?
- How to distiguish type of crx?
- need help cluster wont light up .PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!
- JDM D15B OBD0 Distributor
- Remand Clutches..? Any good?
- bisimoto clearance.
- lowering the 1st gen crx
- wiring car from 86 d16a1 to zc
- seatbelt light
- Would this work?
- orange wire????
- rebuild zc too stock specs
- tach install problem
- crx lateral force ratings?? JDM and U.S. anyone?? .82 G's?
- EGR valve on d16a6
- cat bolt length (spring side)
- coils slammed with Tokico blues
- Going to see State Ref. tomorrow for exhaust. any tips H.T.?
- Engine Help
- Good Asking Price?
- 91 civic lower starter bolt?
- How to...fornt sway bar?
- Reasonable price
- HELP, I THINK MY IGNITION IS JAMMED!!
- More graphs of my Dyno run.
- obd0 to obd1 conversion car won't start help please
- Best way of removing axles
- Crx B16 Serpantine or Alternator belt
- buzzin sound comin from my injector ???
- colour of this mugen crx can any one please help?
- my 90 civic hb Si - is shootin rusty water out my tailpipe??? is it normal or what should i do ??
- searched. what cams can you put in a d series
- speedo not working
- k teller 2.5 exhaust piping kit for 91 crx???
- A1 B18 tranny and clutch questions
- heater not working where is the thermostat located?
- ****anyone have pics of a oem crx sir lip on a usdm crx? not cf one
- ZC'd RT4wd Civic video
- 1/2 Rad Install. Crx overflow? Stock wiring? Slim fan.....??? QUESITONS!!
- custom rear seats.... I can make you one too!
- WTB WTT: I need 88-89 front and rear seats
- seat belt problem
- rev problam?
- Main Relay help?
- does a 94 acura integra GSR engine fit a 88 crx DX?
- 99 civic SI engine on a 88 honda crx dx
- diasppearing coolant, any ideas?
- Dc integra brakes on my 89 crx si?
