View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Will ej struts work on my ef?
- si cluster into cx speedo cable issue
- Aligning a Crx hatch, why so difficult?
- Map sensor may have took a dump.
- 91 civic hatch (multiple issues.)
- Ef9 front lip??
- H23a vtec swapped crx no start?? Please help
- Hesitates/misses just started today
- 1st gen crx steering wheel to 2nd gen
- 90 Si Hatch Head is smoking bad what to do now
- 88 civic dies when givin gas
- What gaskets are these
- Ef Sedan
- third 4 door im happy
- 89 cvic hatch b16a swapped misses and stutters
- D15B6 What 1.5 short block can I use with my top end
- A/C Compressor Rebuild Kit
- in Japan vintage civic parts ?
- Need some help! 1991 crx si b16a JDM clutch replacement
- Recommend me some car audio!! (Crx)
- Help!!! Low offset on a ef?
- 1990 Honda Civic help needed
- 89 civic lx turn signals malfunctioning but hazards work
- TPS Replacement question...
- not sure were to go from here b18a1 help
- Help! Failed GA Emissions
- Sway Bar Bushings
- Warm start problems 1991 crx si.
- ZC Motor Problems
- D15b2 crx dx rebuild or?
- RUSTY CRX PROJECT
- The usual poor-man spring question...
- 89 crx cluster issues
- need help with block mounting bracket
- Old and tired SOHC ZC (Non-VTEC) Rebuild or sell?
- 1990 CRX HF Front Spindle Question
- CRX B20 Speedometer not working
- shop cant aligne, 91 si hatch.
- B18a1 auto cov into Ef swap help plz
- DIY : Installing the aftermarket keyless entry to 89 civic si
- EF Build.
- OEM honda parts numbers.
- d16a6/b2 going bad ?!? need help.
- ECU code 4
- 88 civic want start
- 88 ef hatch smoke help
- Has anyone ever seen these CRX rims?
- finding the right ecu help!!
- Help!! May have ruined my engine!
- crx sunroof
- Post your exhaust system ebay/OEM/HKS or w/e
- Repainting 89 civic?
- 89 EF D16z6 Pulling and dying issue
- 91 CRX DX w/ B16 Radiator Fan Relay wiring help! **PICS**
- 1991 CRX missing under load after warms up
- b16a ef wanting brakes
- Power, battery/ground issue
- Where can I find 91 civic wagon axels ?
- B16 S1 Transmission Failure??
- EF wont start, Found acorn nut in floorboard
- This guys crx build!!
- 91 civic si intake manifold HELP
- Crx seats in hatch
- Question about abnormal wear on headgasket..h22a turbo.
- AIRTEX WATER PUMPS ??????
- 1991 crx si seats replacement where do I find them???
- Ls crx si rad fan help
- 91 Civic Si b18c turbo swap ecu problem
- 89 ef obd1 converted b18a1 ~trouble starting~
- 91 civic si motor swap.
- Poor Man's Universal $20 car alarm system..which relay?
- CRX HF blown motor rebuild
- D16a6 Running rich
- Parts?
- Questions about Certification of Lien Sale
- Civic Si OEM Leather Seats?
- fog lights
- Where do I find a .PDF of a 1991 Honda Civic DX Sedan Owner's Manual?
- Do all new mufflers have 1/8" holes on the sides for venting?
- B series turbo crx si
- is this a Fusible Link? Does it look ok? how can i test it?
- What missing part goes here (1991 Honda Civic DX Sedan)?
- 1988 Hatch Issue
- How Can I Tell If A Fusible Link Is Bad To My Fuel Pump? 90 civic dx
- ex caliper bracket autozone part number
- D15B Vtec Swap Parts Question
- 1988 Crx Si with B16A2 temp switch and fan switch wiring
- PICKING UP MY "NEW" EF/ED3 TOMORROW
- 89 crx si. B18c gsr swap.. Running problem/help!
- tranny leaking
- Mini Me Vacuum Lines
- Need suspension advice for 88 DX
- My 88' Crx si not running smooth!
- Lowering spring on B series EF question
- Wilwood master cylinder.
- 90 civic si idle issue
- OUR 90 Civic is in the Shop
- 11" brake upgrade on the track!
- NEED Help ASAP molding
- Looking for D series BSFC info
- Diamond Racing Steelies on EF Si?
- Question concerning Alternator connection
- Inner tie rod removal help
- d series.
- MPFI swap needed for Skunk2 IM?
- b16a sat for about 8 years in a crx that was garaged
- vtec still work with d15b7 dizzy?
- B 20 Ef swap Question
- B20b 90 civic cranks but no fire
- fuel sender out of firewall hitting TPS sensor
- 91 Civic Won't Start After Rebuild
- RWD mid engine CRX!
- Over heating and brake problems..
- Ef hatch spoiler/mid wing.
- 1989 crx si best steering rack options?
- Axle Install--Interesting Problem
- Ef 9 spoon sports rad , fan won't engage and top rad hose gets hard and full of air
- solid cel, but runs
- h22a4 Civic ed6 build
- Hatch removal- where is the connector?
- Car Shuts Off after Driving
- obd0 gauges to obd1 ecu
- Help!! Right turn signal blinks faster when I press the brake??
- *PIC* Help me run a proper power wire to fuel pump
- loosing coolant and oil
- Need help hybrid crx ls engine
- pm6 ecu schematic diagram not pinout
- Brake caliper play. Is it normal?
- ef hatch cel light is driving me crazy. Please help.
- restoration parts
- dpfi coverted to mfpi and h22 swapped. cel doesnt work?
- Suspension questions and help needed.
- 1991 civic hatch...need an Air Conditioner expert :(
- EF Single Cam jittering, HELP !
- 89 crx main relay click every 10 secs after chipping
- Flash code 91?
- D15 rebuild help
- 90 Crx si 1st gen b16a clutch cable questions
- D15b2 minime questions?
- Please help with CRX build!
- 90 throwing code 1
- need ideas on front mount fitment
- New Toy 1991 dx
- My CRX wont start
- custom made carbon fiber lips?
- o2 sensor cel
- D15b2 question
- d15b non vtec head gasket part #
- WHAT DOES EF STAND FOR???
- How long for a spilled gas smell to go away?
- radiator fan question.
- Help finding gasket.
- Help with Rywire
- what's a good alternative replacement for a jdm 1st gen b16a tranny
- ecu troubleshooting question
- ecu question
- Tips for a stubborn head gasket
- can you install a cruise control in a crx
- OBD0 B16a to OBD1
- Cluster working then DEAD! VSS code
- strong engine head bolts
- Hardwiring temp and tach gauges?
- headlight problems
- has anyone used leds for headlights
- CEL light 88crx
- strange temp gauge issue (stock d15)
- skunk2 ef suspension.
- Anyone here thought of plasti-dipping their car?
- 91 Civ hard to start when warm key off/on works
- No AC
- wont start when gas needle close to E
- B-series Swap Mount Comparison Discussion
- cluster questions for the gurus
- EF GSR/SIR hydro trans swap help
- 1990 ef civic 2 way evap valve help!
- I NEED HELP ASAP DPFI TO MPFI OBD1
- 91 civic ecu question
- Bolt specs
- automatic accord engine into ef wagon
- Having starting problems ...HELP
- How do I Install cruise control on B18 Civic Si?
- 1990 civic hatch
- A '91 EF's Second Chance (4 Door Rebuild)
- New to CRX! Need Help.
- 88-89 to 90-91 crx dash quick question
- Help!!!
- 1990 Civic STD questions, new guy.
- REMOVING HEATER A/C, & RADIO SECTION????
- Replaced Blower still no real air movement from vents
- obd1 b16 swap in 90 crx si
- AC compressor stopped engaging after dash swap..1991 EF civic
- hard brake pedal feel help!
- Ef b16 help
- 91 civic dx, hard to start after it sits for 24hrs
- Vac line ?'s and GM map sensor vac source ?'s
- Fuel pressure randomly drops from about 40psi down to 20psi
- Removing speed sensor
- Best option for ~1-1.5" drop on crx?
- 91 civic hatch 95 GSR questions
- d15b1 block/y7head timing
- 90 EF sedan lx OBD0 swap need a little wiring help
- how to take the pistons out of a d16a6?
- 90 EF sedan want to take some weight off.
- need some help!
- Stupid Question
- Clutch lurching when dumped
- B16A in EF sedan
- steering rack? Si VS non-Si
- anyone have a link to a 89 civic maual
- B Series in EF ??
- My new ef sedan project
- Cylinder sleeve question
- Ef Civic Si Del Sol Seat Swap DIY easy way!
- May have to part with the EF
- Weird issue with caliper mounting bracket bolts.
- 91 CRX Si Restore / DD
- shift linkage problem or transmission issue
- Ebay CRX Mats - 1 New set
- Cutting shock tower.
- 89 civic si
- QUESTION ON CODE 15????
- low voltage setting off radar detector?
- clutch cable question
- Anyone know where to find 88-89 hatch fender, door and 1/4 molding?
- 89 civic ef starting issue
- engine won't come out
- 91 crx hf b18b1 swaped help
- i need 40520-SH9-003
- OBD1 in EF ?
- Oh, just another clutch/trans question..
- JDM EF3 Si Build Up
- starting issues help please
- Brakes wont lock up, little stopping power...
- Dx to Dohc zc motor swap.
- high idle on ls
- 1991 Honda CRX HF
- Strange O2 Sensor Issues
- HELP with EF 4Door
- interchangeable injectors on 89 hb
- B16 dizzy differences
- Need Help. Broken hood latch!
- 89 Crx dx/Dohc Zc running lean
- turn low beams off?
- 90 civic dx fuel pump wont start already replaced main relay
- code 43 and 14 ef with ls
- C702 and C402(KE) pinout
- d16z6 tear down
- 89 civic wont start help!!
