My d16y7 bad idle
Old Sep 24, 2015 | 04:15 PM
Jr Hickerson's Avatar
Default My d16y7 bad idle
My 91 civic ef will start and idlelike crap.when I give it gas it bogs down and cuts off. I have been told its the timing off by a tooth is that the problem?
Old Sep 24, 2015 | 04:18 PM
thatseemslegit's Avatar
Default Re: My d16y7
For a question like this, i would redirect you to this section of Honda-Tech.
Honda Civic / Del Sol (1992 - 2000) - Honda-Tech
How long have you had the car, any previous work done? Anything replaced, installed?
Edit: my bad i misread that it was a 91, this is the forum specifically for those years as well. https://honda-tech.com/honda-crx-ef-civic-1988-1991-3/
Old Sep 25, 2015 | 07:58 PM
Former User's Avatar
Default Re: My d16y7 bad idle
What ECU are you using to run the D16Y7?
Old Sep 29, 2015 | 11:59 AM
CRXyes's Avatar
More like why would anybody run a d16y7 PERIOD? Especially since OP could have used the same engine management with a D16y8 (ahem, VTEC)
Old Sep 29, 2015 | 12:03 PM
CRXyes's Avatar
Check ignition and cam timing with a timing light. If there is excessive backfire when it's running, etc...could just as easily be a bad sensor or a bad bearing in the distributor.
Is it throwing any codes?
Old Oct 1, 2015 | 05:19 PM
91EFDaily's Avatar
I had the same issue when I bought mine. Car bogged BAD when giving anything more then roughly 30% throttle. Timing was off by quite alot. Just pulling the upper timing cover off will let you know how off it is.
Old Oct 2, 2015 | 10:10 AM
CRXyes's Avatar
well, gl then.
Jesse Mejia
Mar 27, 2017 08:34 AM
dealwithit
Dec 24, 2010 01:54 AM
derrik52
May 1, 2010 10:52 PM
fastsmurf04
Feb 28, 2010 11:51 AM
dougshatch
May 24, 2007 09:53 AM
