View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Interior Swap Q
- crappy paintjob.how to remove!?
- covering timing belt?
- New cat. conv & failed CA smog
- diff between hasport vs place racing mounts
- RWD Civic hatch? Yup!
- how do u install a jdm bumper on a sedan??
- humming noise from speakers
- what do you think
- D15B1 with bad head gasket. should i do a MINI ME swap?
- Aftermarket Temperature Gauge
- 89 Civic CX Specs?
- A little Compression for the EF!!!!
- what torx size are these screws
- 88 crx hf wiring harness help
- EF wont start if weather is to cold!
- 91 si hatch motor
- How do YOU break in your engine?
- timing belt help
- D7_62's DD Build
- b16 bad tps? and axle noise
- DPFI 90 crx dx Help! Odee Bogging
- ECT water temp sensor... need some help
- wheel bearing?
- NEED HELP WIRING DECK IN 89 SI
- Auto trans question
- Wagovan bumper on 88 civic will it work???
- Help with CEL code 9 after obd0-obd1 conversion
- ek rear seats
- pm5 on d16a6????
- Mudflap/Mudguard Question
- Lower control arm and wheel bearring help plz
- Cooling system help
- Integra caliper swap question
- Finally put carpet in my car!
- UPPER BUMPER SEALS
- My first BUILD thread.
- Rear Speaker pods
- Question plz dont flame
- What to do with my taxes???
- Okay HT I need Some Help
- stock intake fitment
- a6/z6 mini me high compression, won't start, no spark
- D16A6 starting problems
- D15b6 HELP!?
- 91 civic problem cold start
- cable Speedo cluster Questions
- ANOTHER MPFI swap question. Wire Harnes...
- Will crx door sills wit the clips fit on a ef hatch?
- sprint springs
- 89 crx fuel line leak
- Car never warms up
- 91 hatch sunroof
- 1991 CRX si d16 to d15?
- crx thinking about buying?
- B&M short shifter question crx
- Fuel pressure. But car wont start.
- Idle Flux - tried simple tips and tricks??
- really need help
- Will this all fit ?
- CRX Dash in 4 door???
- 1990 crx hf D16Z6 swap hydraulic clutch help.
- civic electrical problem
- Will crx carpet fit in a ef hatch?
- mpfi swap help?!
- CRX: Rear Bumper License plate holder rusted off. Please help
- seat question
- How To: Cover your CRX/EF armrest with EK fabric
- can anyone find a diagram for a crx si
- Fuel??
- D16A6 issues
- 91 civic hatch leaky sunroof.
- Ef to DC2 Intake
- d16z5 bearings
- How to remove rear seat?
- Torquing head bolts& Timing
- Interchangeable Door Locks????Ef hatch
- has any one ever...
- d16y8 running on 2 cylinders need help
- d15b2 build
- DOHC Zc Throttle body w/ Z6 Intake mani
- DA front lower control arm on a EF hatch
- ef sedan
- Rear defrost not working
- std axles with 5 speed?
- 88 civic bumper lights
- EF8 SiR axle problem
- B16a VTEC wiring questions.
- cam seal, b16
- 1989 civic running rough
- Crx ride question
- tranny gearing question?
- Peicing together a stockish D16a6 have some ?'s
- Pics of my new and soon to be old 90 si hatch
- idle question while braking
- '91 dx hatch d15b2 timing belt, alt belt + valve lash adjustment
- dust ring
- Fuse help! 91 sedan
- vitara y8 running on 2 cylinders
- just got a wagovan
- ef power window help
- '97 Civic SOHC non-Vtec Throttle Body.
- 1990 crx not starting...fuel prob.?
- A few guage problems (electrical)
- Ef hatch wire tuck help!!
- EF headlight swap
- b18a1 code 12 fix?
- 91 civic hatchback help
- OBD0 D15B7/Z6 mini me in EF
- 91 crx si with b16
- Air Cond Clutch?
- 4 door hell of it
- would a bent valve do this?
- MY--88--STD.--Civic build
- New owner having problems, no spark
- 1990 Crx si turns by it self
- ef sedan front bumper ?
- s2000 gauge cluster in a 91 civic si
- 91 civic pls help
- 1990 Honda Civic DX Project
- Reverse switch ground wire?
- Help! What is the name od this color ?
- need help starting my 91 dx hatch
- the EF nightmare continues
- parts for engine
- dizzy plug n dust cover
- 6000RPM and a loud pop and sputter?
- 91 civic pls help
- My 90 D16Z5 CRX
- 91 CRX Vent Visor help!
- crx swap questions
- Tranny fluid question
- my 89 crx si gets really squirly on the road?
- rear camber problem
- 91 ef hatch si!
- d15b in crx
- new on crx project
- Auto To Manual Conversion
- 88' CRX DX Manual, Shuttering when accel.
- 90 CRX HF battery light
- rear beam
- MSD Stumble when hitting V-tec
- S2000 Master cylinder and brake booster
- Winter tire sizing help.
- What fuse boxes/ICUs are interchangeable?
- My clutch keeps blowing up
- Broken Door Check
- HELP!!! EF AUTO TRANS ISSUE!
- Fastest EF in Malaysia
- CRX b16 pr3 code 1......
- EF not going over 75
- b18 tranny question
- replacing fuel tank on CRX, how to get old gas out
- need help
- check out my new creampuff!
- need to redo seats
- my car wont start please help
- I got a 88 CRX Si yesterday
- Engine turns over but won't start. Weird hollow noise.
- not all of the instrument lights are coming on
- Found my LEAK....
- electrical ?s on a 90 sedan
- mpfi tps same as dpfi??
- F-series swap GIVE ME YOUR KNOWLEDGE
- d16a6 wagovan
- New Here
- Oil pump for ZC motor
- oil pan insolation
- c pillar bar question
- how to install vtec controller
- b16 running on 3 cyl n lots of white smoke
- Z6 head swap
- Molding Removal Question
- D series shift linkage pin work in B series trans ???
- HELP D.D. FUEL Gauge not Working ?!?!?!
- Random misfire at idle/acceleration
- EF Hatch Starting issues. OBD0 to OBD1 Conv. w/P28 .....Help????
- red ground wire?
- 4x4 crx
- valvejob/spring compression job questions
- Car won't start....
- Sway bars: Suspension Techniques or Eibach?
- re-introducing myself to the game
- dx to si help!!!!
- No start; No codes, even when sensors are unplugged!?
- Timing a CRX frankenstein (88DX w/a 91SI head) HELP
- obd 1 injector
- 89 crx Ground points?
- The adventure of passing emissions: idling issues after thermastat replacement
- Timing belt questions
- HID's when turn on makes idle splurge?!?!?!?!?!
- Rear mudflaps?
- CRX D16A6 Mods?
- HELP lower ball joint snaped *pics*
- my build thread (: aka blues clues
- LOCK YOUR HONDA/ACURA......ITS NEW YEARS!!!
- how to put on a clock in a std ??? Pics inside
- gas tank question
- drivetrain is seized up... need help!
- crx dp to mp help
- Mishimoto Radiator in 90 CRX si: Won't Fit?
- Headliner removal.
- MPFI swap question - Throttle Cable.
- any krex on here??
- Biggest engine swap possible on DX chassis
- Phantom Grip LSD install B Series transmission.
- Rear power windows in hatch?
- dizzy question
- Code 9 No.1 cylinder position sensor
- Upper Control Arm Stud
- carpet removal
- 91 ef si dash in a 91 crx si
- ef9 si hard start
- hit and run! hood wont open!
- car wont start
- d16 Starter Wiring
- DOHC zc , which one?
- no indicators, and top half of dash lights
- racing slicks
- heater core replacement
- 94 GSR tranny question
- 91 civic hatch dx with crx si dash/gauge cluster wireing help
- HELP!!! 1990 Civic Sedan W/ 94 GSR
- Springs
- 91 civic hatch coilovers
- crx 88-89 to 90-91 front bumper swap
- 89 Dx hatch wont start, motor questions
- SI Cluster or After market Tachometer
- NEED A DRIVER AXLE FOR B16 SWAP ON 91 HATCH SI
- 1ST GEN B16 OIL PAN
- obd1 injectors on obd0 setup?
- how do u take off the glove compartment ??
- Car won't start
- all ef's have double wishbone suspension?
- Honda B16 vss
- Swap Opinion...
- obd0 ls distributor on a 96 ls motor?
- Front Camber
- Help On 91 1.6L ZC JDM SI motor...LOTS OF INFO
- Need Opinion on Engine swap
- Swapping T-bar
- Mpfi manifold question
- no power
- Ef hatch mirrors fit ef sedan???
- b16a or h22a???
- Identify Eibach Springs?
- My 92 CRX resto (Aus CRX)
- MPFI Rail question?
- Everything that can go wrong, will go wrong...
- Advice for a Newbe.... 91 HB DX D15B2
