View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 1990 Honda Civic wagon automatic smoking
- AC in hatch b swap Question
- New o2 sensors on a '90 crx
- Easy / cheaper engine swap
- 1990 Civic Si Hatch, Rust Free, Unmolested. Build Thread
- D16 Vtec no non Vtec motor
- ATI Super Damper Keyway Question
- Looking to Sell EF Hatch B18 Recommendation
- Honda 1991 crx
- MPFI Swap, MAP/vacuum and coolant routing help
- Looking to due performance
- EF9 Honda Access Parts Catalog / Part Numbers?
- D16Y7 Mini me help
- B18b swapped crx appears to be siezed?
- Autopower RollBar 4pt
- Exhaust
- Can I pan swap blue ef seats?
- What to do for 3rd brake light?
- Fuel pump not priming
- "Unit-02": '89 CRX Si - The Journey from B16 to K24
- 1990 civic burning oil? Been sitting for 13 years. Please help
- Any reliable source for CRX Si parking brake cables?
- EF Rear disc conversion
- 91' LX mini me swap?? need knowledge bad.
- 1991 Ed hatch crank no start
- Stolen RT Wagon help...
- Clutch & input shaft bearing replacement - Cranking, thud-sound
- Rear main seal / torque converter question
- EF Hatch Roof Molding Alternative?
- What engine bay harnesses are compatible?
- PM6 ECU Code Help
- 91 crx dx no crank or relay click
- Wagon j swap awd?
- new crx owner
- CRX Music Video PNW
- Turboing a D series engine
- My heater and radio only work in accessory mode help a girl out please
- Does EF 4 door sedan fits in ef hatch?
- Starter housing cracked and broke !
- Saving an 89 CRX HF, plus a parts car
- Mpfi swap
- Has any one built a d16a6/z6 mini me for boost
- D15B2 water pump pipe/hose question.
- D15b2
- 1990 Seatbelt Warning Light
- Crank position (4 blinks) after b swap in 89 crx dx
- 1990 Civic rough idle at stop
- 1988 Crankshaft
- CRX Si Sunroof Bump Stops Print File
- 88-91 CIVIC COMPLETE WIRING DIAGRAM
- Engine harness questions (along side a D16Y8 swap)
- What D series dizzys work with the D16y7?
- Wire tuck confusion.
- Difference in main harness
- My $200 '89 Hatch Thread
- P28 to P08 issues.
- CRX HF D15B6 engine design data for rebuild
- JDM EF SEDAN SUPER EXTRA. CARB ISSUES, PLEASE HELP
- EF8 front lower control arms and sway bar swap
- 1990 Honda CRX DX Auto. Trans. swap to Manual Trans.
- 91 civic si trunk lock jammed
- 1989-1991 Ef hatch/Crx Obd0-Od1 swap 2021!
- EF CIVIC STARTING ISSUE (Alarm?)
- Help identifying severed wires
- Replaced blower motor dan resistor on the 88 civic
- 89 civic sedan last plug with no connector
- Idle inconsistency: ideas for diagnosis?
- rear hatch reflector replacement
- Obd0 to obd 1 swap
- EF GSR SWAP REAR T BRACKET
- Front wheel hubcentric rings don't fit
- How To Check ‘90 CRX C.E.L Codes
- obd1 and mini me distributor on d15b1
- 91 Civic hatch with strange blinker problem.
- LED Headlight Bulbs
- 91 civic auto to manual and bseries swap
- D15b/Z6 head swap issue HELP!!
- '91 CRX Transmission Replacement
- Part removal help? Rear wiper and hatch shocks.
- 1990 Honda CRX Vacuum Seal Leak(?)
- Radiator Shroud Grommets?
- EF Build - Compatible Parts?
- Parts request
- Engine question
- 90 honda civic hatchback instrument panel quit working.
- Decisions, Decisions....Upcoming Wago BUILD
- Fuel pouring out of filler neck after fill up
- JRSC D16A6 Set up question
- 1990 Honda CRX going through an LS swap!
- MAP SENSOR QUESTION???
- ED Civic AWD conversion?
- Oil leak on front of D15A3. Where's it coming from?
- 1991 D16a6 swap Timing issues in 90 std hatch
- Idles at 1000 rpm’s
- Rev limiter
- D-series cable/hydro transmission gear swaps
- D16Z6 Swap to EF - Slight Confusion on MAP Sensor
- Help dx to hf/si wiring
- Civic Gl d16 swap.
- 89 civic died after flooring it
- 185/65R14 Tires on 1991 Civic DX Hatch
- Whining noise from timing belt area
- 1991 crx dash lights
- 1988 Honda crx hf
- ICU burnt. 91 std hatch
- Clutch issues with brand new clutch
- Chasebays harness
- rocker arm oil sensor
- Fuel lines and external pump
- No spark (wire harness a bit messed up)
- B16a CRX si exhaust manifold O2 sensor issues.
- 88DX D15B MPFI/VTEC conversion questions
- Passenger side dash/chassis harness plugs
- Lobes in Park and reverse- 1990 CRX base model
- Obd0 A connector 2 different wire color schemes
- Wheels
- 1988 Civic DX Hatchback Starting Problem
- 1990 CRX base model parts
- Motor compatibility
- CR-X Mirror Connector Terminal
- walbro 255 blown fuse
- D16A6 water pump
- Windshield frame rust and leaking
- 88 CRX With a D16Z6 swap
- obd0 and obd1 d series distributor compatible parts?
- EF Hatch coolant gauge wiring
- 1991 EF Dome Light Issue
- 1991 rt awd swap into 91 crx hf
- Need CRX taillight logo measurement
- Injectors
- Rear hard brake line
- Sylvania led Options info
- 1989 civic d15b vtec help
- New 1990 Honda owner here
- Odds of successfully using D16B5 bottom end with JDM ZC SOHC head
- Universal Fuel sending unit on Crx?
- Help locating B series spark plugs wire groomets..
- LED Gauge lights suggestions for my 91 Si Hatch
- Steering rack play, replace or fixable?
- 89
- Hood dents, do they come stock?
- Scam Waring 1991 CRX SI special edition in Burlington
- 90 DX hatch failed start after starter change
- ignition wiring question. 91 ef
- Fuel feed removal at firewall
- 90 B20b Honda Civic ex won’t idle
- Booster Delete Master Cylinder Size
- D series non Vtec to D series Vtec swap
- Code14 then code 16 on my 1990 Honda Civic hatchback! Help!
- Is this a ricer wing?
- 90 SI hatchback fuel level sending unit?
- 91 ef b20b obd1 intermittent inop. Cooling fan/fuel pump
- Interchangeable main harness
- Cabin Air Filter Retrofit?
- Wet spark plug
- 90 ef need a new ignition switch housing
- 1991 civic si running rough and dying
- Passenger and Driver seat swap Sedan
- CRX Fuel pump hanger return hard line size
- 89 Civic SI Speedometer Cable Removed
- 91 CIVIC HATCH BACK REAR DISC CONVERSION
- Electronic VSS
- Best Track Cage Setup for $1,000 total
- brakes upgrade question/help.
- Need help with wiring 91 civic si
- Problems Honda ef swap d16a9
- 88-91 Civic Hatch Dash Light Dimmer Switch Teardown
- 90 Hatch running lights/parking lights not working
- 90 civic dpfi swap from 87 crx si mpfi
- 91 civic Innovative Pro series traction bar install help
- 89 honda civic
- Thought I’d share my (it was only supposed to be a head gasket) daily sedan
- 89 si trans 91 dx question.
- Wiring issues
- Engine not returning to idle
- 91 Civic DX Hatch - B swap axle won't fit
- 91 civic d16z6 turbo breaking up 6k help
- Ek mini me build issues (Help Plz)vtec and more.
- Wagon & Hatchback Trunk Latch
- civic ed ef hatch vs sedan
- 91 Civic Wagon 4wd auto
- interchangeable SDN door question
- B16B Oil Pressure at startup
- B16A swap, high idle
- 1.3 litre EF
- D15B2 Y8 Head mini-me ARP head studs
- Ecu help (Canada ont. GTA)
- 89 CRX Dash cluster
- Unhappy CRX. need help
- Code 17 - Vehicle Speed Sensor - Cannot use
- crx alarming noise
- compression test procedure
- FNG looking for suggestions.
- Glass color
- Head comparison
- 1990 DX wago rear brake conversion
- Full build and engine swap.. Help! Rookie!
- B13 to main relay has no power
- Engine swap which too put in and where do y’all trust buying the engine from online.
- crx mysterious brake fluid leak
- CRX rear disc conversion / Parking brake cable
- B16a Pressure gauge reads zero
- D15B CRX Differential Issues
- AC high side routing
- 91 ef hatch b20 obd1
- Idle Dies - 1990 Civic Hatchback D16a6 MPFI
- 91 civic overheating problems
- Hatchback body parts compatibility question
- 91 ef hatch. Low noise performance exhaust?
- Honda Civic 1991 1.5L
- CRX: Replaced Transmission in D16Z6 Swap
- Dohc zc swapped crx has no dashpot?
- TPS has 0 volts
- Window Regulator Fixed for 1991 Honda CRX HF (PN: 72250-SH2-A23)
- JDM b20, sacked suspension.
- Power steering form EK
- questions before possibly buying a 91 CRX Si
- Honda crx 1987 alternator problem.
- Different series ICMs in OBD0 distributors
- Help LS/VTEC newbie here CRX HElp!!!
- PROBLEMS FINDING AUTO TRANS SOLENOID
- B20b4 swapped ef hatch
- Replaced cluster, speedo needle not working, temp gauge accuracy Q's
- 92 jdm crx radio wiring
- Speedometer Cable
- Obd0 crx sir connectors
- 1989 crx si
- D16 Engine rebuild shop recommendations...
- USDM climate control in JDM crx
- mini me, mpfi, obd1 swap at the same time
- Broken wire in harness?
- Honda Factory Stereo Options
- Body harness connector Kit
- Set perfect timing
- D16y8 swap on a 1990 civic hatchback ef
- which lugs to use on Integra LS mesh Wheels
- Questions about removing the oil pan (Oil Pan Gasket Replacement)
- 1991 Honda sedan OBD0 code 9 sputtering at 2k
- OEM EDM seat heater buttons?
- Standalone ignition for an EF
- Single cam Vtec question
- 89 civic random culture and sputtering till shuts down
- Throttle body options for d16y8 manifold
- Hesitation when accelerating
- LSV Swapped EF - ECU Wiring Mess, Help Requested Identifying Things PLS
- Honda Access Rear Garnish (Indiglo)
- Passenger axle over tightens
- 90 Hatchback Inner Tie-Rod Removal Challenges
- Right front wheel sticks out more than left side
- PIC REQUEST: US Wheels Star Series 021 on EF Sedan
