View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Hatch Interior Cleaning/Restoring
- 91 std/mini me not running
- seized rear brakes
- A new chapter to my CRX (56k Stay Away)
- Help, please! EF hatch engine lurching
- CRX B16A Swap question.
- 'Red' '91 Si OEM color question
- honda part question
- why does my car idle high? does anyone know?
- 88 CRX black widow body kit
- Swapping an d16a6 88' engine into 90' CRX SI ("FICV ISSUES?")
- B17 Transmission
- d15b vtec soleniod
- my project hatch
- BARO sensor?!?!?!?
- tire fitment?
- need help cant find code
- raidator fan wont come on when hot
- '90 Stock D15 DPFI Need possible Idle help
- What I need for ZC Swap
- ep3 civic si cluster into a 91 civic si. help
- Rear Disc Conversion Alternative
- CRX - Driver's Side Shock Tower Harness ??? *HELP!*
- Quick A/C question.
- Tranny grind questions
- Joining the club
- Crx dash w/ hatch cluster prob, and blinker problem
- Please help D16 idle stuck @2500rpm
- hard to find oem decals and badges, post'em
- i need help with my lsvtec crx
- How hard is it to change the timing belt on a d16z6
- JDM Door question
- rocker assy torque specs
- Which crank pulley? Y7 in 91 EX
- supercharged and Turbo'ed
- 91 std brake upgrade help needed
- OBD0 to OBD1 CELs 9 and 20
- Dohc zc issue
- b18c1 in crx questiones
- Lip question for the EF
- lhd to rhd upper fire wall(windsheald wiper motor area) question.
- Switching places? Radio and Climate Controls
- ZC wont start
- DOHC ZC PERFORMANCE
- CRX SiR OEM color options?
- PLEAE SOME ONE HELP ME!!
- ef sedan frame and tranny question
- Post your steering wheel/quick release set up
- Could use help diagnosing.
- How important is honing when replacing rings?
- A/C into a CRX
- D15B NON Vtec won't start... timing issues
- d16z6 Help!
- wrong section..but im curious..
- d16z6 wont start
- Downpipe Gasket ZC header
- My honda.. Bogging.. Idle.. HELP
- re-routing the piping on the ef
- motor harness issue
- roof rack
- 90 Civic B18 Questions - HELP
- crap from exhaust :(
- CRX post clutch replacement won't engage, move
- Transmission Fluid? (Motul)
- Wheel well rubber lining/molding - Remove or keep them?
- HELP! overheating problem, reservior tank
- Good to be back.
- 89 crx mini me no fire
- d16z6 help
- mpfi problem
- 3200 rev prob. and Crank Sensor?!?!?!
- cant rev past 3100(limp mode)
- Back-up lights work only SOMETIMES?
- Jaime 91SiB18
- JDM Headlight Swap
- Motor mounts feel like they are broken in me 88 sedan
- under drive pulley noes ?????????
- what is a clutch cable used for?
- Just bought a EE2
- new skunk2 shocks. help!
- front lips that fit on ef 4dr
- Timing belt annoyances!
- firing order
- new ef doors
- Why cant i find a crx in a junkyard?
- strangest thing ever!
- Brake pedal goes to floor
- having alittle problem
- crx rear disk help
- Is this a stock engine for CRX?
- Sharing some '89 DX Love and What You Want
- Knocking and pulling car on passenger side when turning???
- crx with a d16y7
- Starter Problem? Hydro Fidanza Flywheel on 91 Civic Wagon RT4WD?
- crx si MC and booster upgrade
- DX/Si/Hf Rear trailing arms the same?
- 1990 crx dx mph guage stopped working
- crx climate control in civic swap
- obd1 conversion cel code 9
- brake issue
- Brake lights stay on, but only with headlights
- Thread size of outer nut on axles?
- jumper harness
- 20 code 0n my91 civic pm5 1.5
- 1990 Civic Auto surging in top gear... Help please!
- Single cam Tranny #'s & Differiences
- panoramic mirror at Walmart for 12$
- Illuminated Sunroof Switch?
- dpfi to obd1 no start :(
- MAP question
- Chargespeed..... Knock Off?
- ef fuel problems
- ef sounds like a misfire
- bov question...?
- curios about ef tail lights
- Anyone with pics of sir front with eg mugen lip?
- ZEX DRY to WET CONVERSION?? POSSIBLE???
- another dpfi to mpfi no start!!!!
- stock b2 cam lift?
- CRX'S ONLY !!!
- D15 DPFI getting 12mpg
- engine swap info
- d15 swap help
- Ef hatch front lip question
- Wont Start
- mpfi swap, extra hose and extra plug
- 89 CRX. I need help!
- Shift linkage counter weight
- Tps problems...?
- oil feed line question...
- pedal assembly
- unidentified disconnected wire
- Distributor clicking
- CRX w/WW kit what size Mesh
- lighting question.
- d15b7
- Tire size question
- squeak when accelerating/decelerating(?)
- Mayfly's Build Thread
- mpfi double check
- QUICK QUESTION BOUT JDM/USDM FRONT END!!!
- my crx setup.
- automo.to feature
- heater problem!!
- Tein Springs
- whats the hottest inside a turbo engine will get in degrees?
- New ground effects kit
- NEED some HELP
- fluid in pass. wheel well
- best spring and shock setup for 91 civic with b16
- PR3 obd0 ecu grounding knock sensor ???
- iphone vtec
- Fog Lights wiring?
- help help my crx wont start
- b18b1 swap problem`
- Running a D16y7 but with all my obd0 stuff?
- b-16 in ef
- D16Y7 intake manifold
- Got a question?
- Does Anybody Make Carbon Fiber Bumper?
- tps, iat, iacv wiring question
- EF9 power folding mirrors question
- Transmission cable/hydro EF gurus needed
- JDMkid413's ED7 build thread
- hydro cluth question
- 91 4door wont start
- D16A6 bogging, lack of power after new clutch installed
- ef9 b18 rear mount problem
- Burning oil
- gsr swapped ef several problems HELP LOL!!
- 91 civic 4door build
- HF-SI- OBD1 wiring conversion HELP!!
- need help with my 90 civic ef
- MY VERY LOW BUDGET 4 DOOR BUILD
- Video Tech: Difference between VTEC and no VTEC
- Help with my mini-me swap...
- wheres my ect switch?
- cam-gear key way keeps snapping
- DPFI-MPFI on Auto DX Shift lock won't disengage
- Smog Repair, need help
- breakin the new motor?
- swapping suspension from 95 Si to 90 CRX Si
- turbo dohc zc
- Code 15 missfiring no power..
- help lol
- dual exhaust on an ef??
- Odd PING issues - pls read
- back pressure hollowed cat
- skunk2 cam guide broken
- questions about EK enging swap to EF
- Sheared cam gear
- Need help with motor choice
- [FAQ] Honda Civic 88-91 EF Sunroof Visor Deflector Hardware Dimensions/Measurements
- inner tie rod removal...
- K swap in an ef
- need some help with fuel pump on ef hatch
- are crx and civic hatch crossmembers the same??
- compression issues
- back brakes
- Got fuel, but no spark.
- rear disc conversion questions?
- hey guys !!
- i need HELP!!!!!
- ef motor swap and what i need to get started
- my new/first ef
- obd1 distributor question
- frunt knuckles to use?
- what bumper cover is this???
- Help: 5spd conversion on my ef
- HELP!
- battery keeps draining
- 88 hatch turn signal wiring help
- anybody got a write up on installing complete A/c
- Timing Off Rev Related
- 1989 Honda Civic Brake Problem
- charge!!!!!!!!!!!!
- want to see demand on replica usdm and jdm fog light brackets for all EF's
- engine harness interchange
- Need help with an electrical short on the ignition system.
- my 1990 crx si
- Need some help with the rear seatbelts on my 88 hb ef
- Cant Get B16 TO Start NEED HELP!
- Mugen spoiler brackets.
- beginner question, CV boot torn
- Dash light tail light headlight problem?
- Problem with CEL 6????
- Hello Everyone
- Help on a h22 swap into a ef9
- new here with my EF2 25x s-limited
- D16 CRX mini me head swap info
- Weather Stripping
- trying to find some JDM "89" style tail lamps
- Problem with TPS sensor. Code 7.
- question reguarding dx vs si roof caps
- what can i do for my d15b
- Basic transmission/clutch issue?
- Best Engine Swap ?
- Sad Day for my REXY =[
- Redline for New swap?
- dpfi to mpfi extreme rough idle HELP!!!
- New from Georgia
- trunk floor cover
- Tie Rod job
- hellppppp
- Might have a bad transmission?
- front clip.. how?
- got a 90 crx si shell
- quick motor build question plz help.
