View Full Version : Honda CRX / EF Civic (1988 - 1991)
- mufflers on crx
- lower ball joint
- interior question
- My Car is running weird any ideas
- WILL A CRX 90-91 BUMPER FIT IN 88-89 CRX??
- temp switch.
- computer transfer so you can have hondata??
- 3 point strut bar on crx??
- upgraded lower ball joints?
- where does vaccum line go from the bov
- cv joint/ propshaft
- CRX clutch - stock clamping pressure?
- CEL /ECU Light is solid
- 94+ LS hydro to cable questions
- PW0 with sub harness. help please.
- JDM ZC SOHC in an 88 Wagovan?
- 94+ LS swap questions
- takes 4 or 5 times for car to start
- help! obd0 to obd1
- New to the site....
- H&R coilover spring identification problems. Which front/rear?
- ef problem??
- Civic Tune up
- Why would anyone want anything but an 88 CRX
- another where can i buy thread. searched.
- J30?
- request for pic: civic si wheels (99-00) on ef8 or 9
- 91 dseries vtec help
- exahsut for b16 in ef
- dpfi to mpfi wont start help please
- BITCH PIN!!!!!!! LANDLORD'S GARAGE PART 2 (TO TOW or NOT TO TOW)
- Is this a good deal?
- Need a quick help and Hint
- New O2 Sensors on a obd0 b16?
- What One?
- If i converted the HARNESS WIRES
- EF PARTS HELP!!!
- Help: Choosing CRX LCA's
- help with bumper fitment
- black top or blue top?
- I got the shakes!!!!
- v8 crx?
- b16 swap
- my EF won't start, it cranks but wont start
- dpfi - mpfi conversion question
- need help with zc
- MY FIRST GEAR
- b16 wire harness needed
- Car dies on me, then starts up in the morning (has happened 4 times so far)
- ECU issue?
- dumb question '91 crx hf
- clutch cable stretching
- Im stuck with those wires..anybody help me out??
- Questions about tire size on a EF
- Car wont start
- Beep, Beep, Beep. Door buzzer driving me insane, please help!!
- sohc v-tec swap in an 89 si..
- Little help
- hmmmm ZC engine info needed
- asr eg subframe reinforcement brace into 90 crx fitting
- valve relief question
- will a bolt in roll bar do anything?
- honda b16a
- **NEED HELP ASAP!!!!!***
- how to make engine zc use for drag race 1/4 mille
- Plastic tip on fuel injectors!
- Questions about my d16z6 with my SI trans...
- help, finished wire tuck now code!!!!!
- is it worth it ?
- i need help
- Speedo problem
- radiator flush..pls..help
- What to do?
- seats.. help!!!!!!!
- crx headlight queston.
- About to purchase a CRX...what to look for?
- Body Panel Question
- Yet another Tranny question!!! I have 24 hours before landlord tows my car out the GARAGE!
- PaulK's project log - UK VT
- Civic '90 sedan engine swap
- B16 SIR in CRX HF
- DOHC zc
- need to know what color and paint code this is!!!!
- need help fast
- 88 DX Sedan rear disc swap brake cables ?
- alert-light use as shift light?
- please help
- b16 ef
- hello im new to the site just thought id introduce myself
- b series tranny bolts
- motor mounts for 94 ls motor swap on 89 rex??
- fuel filter dilema
- P28 for a DOHC?????
- brakes are STUCK, I have no idea...please help
- 88 crx si with dohc zc turbo help
- where to order moldings?
- Gas Gauge Still Not Working
- USDM Front bumper w/ Password lip?
- axle nut size
- VTEC-E?
- alittle help?
- rear disk brake conversion cables
- motor mount bolts snapped.. is it fixable?
- NEED HELP A.S.A.P.
- need new radiator? opinions?
- Short Throw Shifter
- hf questions
- alternator bracket
- My axle BROKE (driver side) Im trying to get it out! WON"T BUDGE FOR SHIT!!!
- Just Replaced alternator Belt NOW MY CAR WON"T GET ANY ELECTRICITY!!!!!! HELP!??
- RHD EF8 conversion, wiper question
- Soooo Hard To Find...
- crx no fuel!!!
- Additions to CRX Hatch Leak & Hatch Squeak FAQs
- junkyard dog
- What a/c bracket do i need?????
- Will a EF suspension work on EG
- 91 si motor removal
- My CRX Battery fuse
- Is it possible to test compression on a d16a6 while it is out of the car?
- Dash Harness swap 91 into a 89 clip problem
- rear lower control arms?
- How to tell year of ECU PM6???
- 88 crx si suspension help!!!
- ecu ????
- crx dx o2 sensor
- b16 timing belt tensioner, should I replace??
- VTi cluster wiring diagram? 90-91
- MPFi Swap w/ z6 IM = High Idle??
- LS V-tech in a Nutshell Please
- search not found
- *****HELP HELP HELP HELP HELP*********
- Bodykit and Bondoing Question.
- CEL #1 o2 problem
- how to make a b18a1 in hf fast help
- Whatcha' Think?
- has any 1 tried to swap cable for hydro including peddal asembly
- NEED radiator....please help
- Stripped Rear LCA bolt
- Civic for a new home. FWD -->
- d16y8 into an OBD0 car?
- CRX guys help me out
- 3 Questions- D15 to B18Crx - Crank Pulley, Alternator & Axles
- sorry bout the big picture but how would you run this?
- Header Clearance
- Lower control arm will not budge! What to do?? what to do?? Ball joint is on there like swimwear!
- How have people dropped weight on there ed civic hatches?
- JDM Injector
- my b20/vtec, build thread
- Honda/Acura injector flow rates?
- anybody done a obd2 swap for a crx
- ball joint replacement
- Need help on ef??
- EF drag racers [tire question?]
- ecu question
- WTB:::: EF-2 Civic Sedan front filler piece, and driver-side headlight
- DAMN near impossible!!! seat rails
- Idle Problem
- pulley replacement
- Check engine light???????
- 90 SI UNDERDASH HARNESS INTO 90 LX
- CRX question help please
- template for 16V wing.
- Noob: Pr4 in a d15b non vtec
- connecting rods d16zc or d15b2 which is stronger
- axle HELP searched....taking my tranny out...Pic of what I need to take out AXLE!
- 88 crx suspension
- help with assembly!
- are 88-89 si h/b rotors the same as 90-91?
- 92-95 civic ex cluster = direct swap?
- honda tuning build
- Guage lights inop!!!
- Help With Buying My CRX
- removing tie rod
- Battery died while driving
- making my car reliable, suggestions please
- Overheating!!!!!!!!:(
- Swap Question
- state referee!!!!!! aaaaaahhhh!!!!
- Need Swap help
- Help: Non-Rice aftermarket exhaust
- d16z6
- How do I test the ICM/igniter/coil ?
- Anyone know how to take rust out of a carpet?
- d15 vtec questions
- replace pulley ?
- 90 crx dx wont start, please help
- any us 4drs or hatch
- b16 head vs gsr head question
- del sol seats
- not start when car is warmed up
- b20b mods?
- b16 excess wire
- p28
- royal purple synchromax in b16 cable trans also 10w30 question
- need head
- Passenger Rear Brake Drum Dragging
- caliper kit instal no instructions?
- did i put my x drilled rotors on the right way?
- flywheel
- Fresh Z6 Build and Swap into EF SI.....HELP PLEASE **VIDEO INCLUDED**
- tie rod ball joint
- GSR or LS V-tech
- Got an update on the K24 CRX tonight on Speed Scene Live net TV
- just got my first honda
- B16 water pump big problem!!! HELP!
- MPG on 100 octane
- crx heater hoses to b18c
- 89 civic si canadian model??
- Special Projects Motor Sports -RTA Spherical Bearings
- Idle issue
- headlight help... how to take it off
- rpm jumps in the morning
- Si tranny- 35mm or 40mm?
- Sun Shade for CRX rear hatch window
- Bolx intake man. on eg with B18c1
- Help with -8an fuel line fitting
- Transmission: Take out and Install B-series Step by Step would be Nice HELP PLEASE!
- crank work
- CRX TURBO!!
- foglight ?
- code 20
- Question about CRX/Civic engines.
- will these rims fit??? 15x8 4x100
- d15 block with a d16 head ported and polished with an SI cam and a stage2 clutch with a nos 75shoot
- Transformation
- KDW 2 OR AZENIS?
- Ef fuel problems 1990 civic hatch std
- Ef 4dr H22?
- si or dx?
- 91 civic Si B18A1
- wtb 15in honda wheels
- suspension for my '91 hf HELP!!
- 91 hatchback rear LCA ?????
- D Series EF BUILD of efkrew91hatch*...check out the thread and pictures
- dizzy qust?
- ef seats
- died and won't start
- noob ECU question
- CRX Steering
- Rim Fitment For Honda Civic Ex Coupe 95'
- no start
- High idle rpm (cleaned a valve but dunno if its right one)
- Car wont start in the rain???????
- Dr side sill garnish 85 CRX
- crx b16 dizzy question obd0 to obd1
- ef fuel pump removal.
- This Is Why You NEVER Order From http://www.hondiscountparts.com
- EMERGENCY HELP PLEASE!!!!!
- electric load detector
