View Full Version : Honda CRX / EF Civic (1988 - 1991)
- ecu questions!!
- ne1 with a Suspension Techniques sway? did I install my endlinks correctly?
- Flat Paint Rusts Your Car?
- how to change center bore
- who needs fifth gear anyways! (tranny help please)
- ZC / NA Build-up Questions
- suspension Question on CRX alignment!!
- Why is my CRX suspension still bouncing?? Please help.
- Calling all Swaps w/ A/C.........Turbo?????
- crx hf with a moon roof ??
- which route to take, NA or BOOST
- WTB throttle body.
- curbed, bent, and need help
- Few rebuild questions, Z6 + ZC + Y8
- WTB: Universal Muffler
- Tranny question ?
- Anyone have the website for the Diy Cai..
- Spring I.D. (inside diameter)
- cost of an LSD
- 90si rear control arm compatibilty
- Help quick please!!!
- speed bleeders for my rex?
- problem removing fuel rail on d16a6 intake manifold
- my b16 dyno plots...two different dynos...take a look.
- ahh my tail lights keep goin
- no sprark
- Fastbrakes...?'s
- Intakes that fit the REX w/ B series?
- rear disk setup(rubbing)
- zc love help me
- my pics
- CRX Si seat into Civic DX?
- What to use for tranyy fluid?
- Anyone have a Phantom grip lsd???
- Brake dilemma
- seat belt warning bepp
- Snapping swaybar Brackets on my 89 SI Hatch, HELP!
- Need help with the alternator ground...
- jdm b16a swap help
- How do you tell what kinda motor it is?
- What year Acura steering wheel?
- eg suspension(struts & springs) in ef....
- Suspension issues with B series engines in 4th gens?
- centerforce... good clutch?
- vx timing belt partnumber
- dpfi-mpfi
- Std Tran to 88 si Tran?
- on a 88-89 teg where is the ecu?
- how fast is a crx si
- Amsoil or Schaffers motor oil?
- what kind of axels are these please help...
- [I] [B]Front Motor Mount Insert[/B] [/I]
- vtech wiring in crx si
- tps sensor question
- what happens with PCV not hooked up? (mpfi conversion q's)
- Help blew up tranny
- need new, quieter, exhaust
- My brakes went out today
- What size is my HF sway bar?
- this bolt is stuck somebody help me quick!
- Wire harness lay out
- zc pistons in a d16a6 crx si engine
- Gas tank lid ??
- Having problems with my b18a1 swap
- anybody has a ZC helms manual???
- Lip for Mugen kit?
- Gas filter, Where is it located
- going to do mini me...is this the right way?
- Please help me with my civic!!!!
- KYB AGX crx si rears into 91civic dx??
- ball joint on crx????
- 90-93 Integra rear disc on 89 CRX Si
- question on the SiR cluster
- R1 Coilovers
- Nu Image
- Just rcvd my b18c
- How to test an LSD
- HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Si Front Lip: Better Painted or Not?
- Anyone like the Sedan Steering Wheel better?
- Which transmission does my CRX have?
- crx motor swap
- Help please i need torque #'sss
- mini-me swap
- driver side harness
- 88-91 windows all the same???
- lower control arm question (89 crx si)
- i think my clutch exploded
- b18c swap: 4-1 or 4-2-1 headers
- are 88-91 civic rear windows interchangeable?
- My speedometer needle melted off ....WTF!!??
- average weight of a complete D16a6 Bottom end.
- How long did you wait....
- S-AFC on a 90-91 civic si
- Exospeed.com shirts just finished. Check them out.
- Transmission Woes..., Any tranny guys out there?
- Timing an 89DX....
- 88-91 Civic S and DX (PM9 and PM5) ECU Rev Limits?
- Realistically - What is my setup worth ($)
- tps sensor
- Where to get tires cheap?
- what is that rattling noise?
- 1990 crx dx with d15b2 block and d16z6 head
- where is the best place to buy jdm itr pistons from the web
- Need a website for LED supplies
- Does your B series rear mount hit firewall?
- b16a in a crx coolent hose questions
- Nice, tucked CRX possible?
- other ef civic sites
- LED dashboard...
- Need Help. removing gauge cluster
- what size tires/rims are you runing on your crx?? pics are helpful
- will a pr3 ecu run a d16 si motor
- will some these hatch pieces fit my rex?
- How do i know? (Steering)
- ys1 w/OEM LSD or S1/J1/YS1 W/Quaife what should I do
- Driverside mirror?
- Another Brake question
- ALL motor guys....
- engine light on
- Should I sell my LX?
- tociko 5 way strut settings.what should they be?
- no canadian flag?!
- CEL 14 help?????
- radiator fan help
- Team Dynamics Pro Race 1 - 15x7 - Clear Perfectly Spoon Calipers
- anyone ride with?
- light azz rims
- Axles.. civics ans what not..
- Madison, WI Salvage Yards?
- Problems with EF civic. Help!
- Body kit?
- Different car wont start...1990 dx hatch
- JDM Front End - No JDM Rad support. Can this be done?
- my doors rattling. what could it be??? HELP!!!
- CRX seats in to civic brackets?
- B20 CRXs?
- check engine light PLEASE HELP
- Question for anyone who has a b16 swap in...(RE: clutch cable)
- Woohoo! HASPORT motor mounts for hydro tranny to be released soon!
- kosei k1s don't fit!!
- Too much fuel got in. Need help ASAP
- dx and std difference
- Need 1990-1991 CRX SI Engine Wiring Harness
- what should the bolts on the pressure plate be tourqued to?
- help i cant swim!!
- Engine Swaps for EF ??
- ZC head bolts???
- can anyone give a definate reason ???
- 4gen seat compatability thread - please read
- B-Series tranny guide help
- ???Seat fittings????
- Do I need this plug???
- on a 92 ls what to i have to do to make it fit a 88 hf crx?
- Need to convert my 89 JDM SiR to 0bd1!
- y8 manifold with obd-0.
- Injector Upgrade -DX
- Your first swap?
- tranny fluid for jdm b16???
- front bumper support removal
- help with my LS
- Camber kits??
- major shaking ......
- weight diff between 85 and 87 crxs
- Rear Crossmembers from 89-90
- Huge favor to ask, need pics....
- Cheap place to find B16A1
- need help on zc tranny install in crx
- going rate of interior panels
- will hf axles fit in a si tranny?
- rear quarter panel rust work?
- 1/4 mile times on b18a1?
- need axel help !!
- my rear-mount battery hit metal, what now
- crx hf to b18a 88-89 what do i need
- seats
- good project on ebay: $1000
- Need help asap.. puttin tranny on ZC, clutch wont go in
- vacum question si>ls
- Where to get tein kit rebuilt??? HELP!!!
- b16a swap sputtering and being a jackass....
- check engine light came on...reads code 16 (injectors). what?!?!? =)
- Header Question??? on B16
- Lots of Dyno Charts, d-series, b-series, forced induction
- what throttle cable bracket to use for the y8 manifold swap?????
- Automatic EF's
- removing tranny - someone really needs to tell me these things...
- help crx newbie!!!
- type R into 90 crx
- check engine in reverse?
- Crank pulley tool for EF's??? Would the 92-95 tool fit?
- so will a si,dx knuckles fit on a 88-89 teg axle?
- NEED AN ENGINE !!!!!!!!!!!!!!!please help
- need pics/diagrams
- zc, pm6 vs pg7
- Any 4th gen dxers with a jdm b16?
- would you hate me if i put miata rims on my rex
- this site would be good if...
- free APC gauges to anyone who can give me a definite answer....
- JDM DOHC ZC engine
- Z6 sohvtec CAM in a Y8 head ?
- I'm a newbie, humor me... 91 Prelude seats into 90 civic dx h/b?
- internally stock B18C CRX DYNO charts!
- attention MD/VA/DC rexers
- since i dont normally check in this forum: i have jdm ef parts 4sale
- seats that sit lowest in a civic hb EF
- Can slottoed rotors be turned?
- Clutch system lube points?
- Seat brackets question...
- corner lenses
- dash conversions
- Detailed instructions for MPFI swap? (everything besides wiring)
- zc in 89 crx dx
- cheap place for Brembo Blankst and hawk pads?
- Civic Dx brake Question
- starting my b16 swao in the rex...tonight! Help tips?
- Anyone in here have a rear crossmember for a CRX??
- help with sex
- Rear Sway Bar for 89 Civic dx
- Someone broke in and stole my system and stuff
- Quick question about clutch cable adjustment
- Fuel pump for my 88 crx si
- Turn Signal Problem
- stock rubber or urethane bushings?
- Am I getting a good deal?
- i need a quieter exhuast?!?!
- Question about running boost?
- jdmb16a1 swap problems/////HELP?
- Left over plugs...helpl...
- rear disk swap for $150.00
- Taking a trip to the junkyard, anyone want anything ?
- problem with b18
- setting ignition timing
- Which bushings??
- Which O2 sensor is Primary?
- Anything I could use from 90-91 HF motor on my ZC?
- What is the SPECIFIC difference between the 88-89 HF vs. 90-91 HF ?
- 2 Lines on S1 Trans
- D16Z6 dizzy on a D16A6 head question
- WHAT???d16y8 intake manifold on d16a6!!!!!!!!!!!!!!!!!!!!!help
- 88-89/90-91 Fenders
- [FAQ] How to: OEM HID's into 9006 housing.
- will hf axles fit zc tranny?
- problems starting 88 crx si
- B16 maint. ?
- clutch cable adjustment
- whats a good suspension set up for a 88 crx si?
- what is the best ecu for a zc dual cam first gen?
- Help me my car wont start!!!!
- b16 from hmotorsonline..
