View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 1991 Honda Civic needs you help please..
- H22A Type S
- EF9 Lip?
- 89 wagon shop manual pdf?
- hardwood in place of backseats.
- oil pressure
- rev limiter chip
- icm stands for?..........
- Da master cylinder and booster problems.
- Trans swap =)
- 90 crx si stumbling
- 88-89 Integra Axles into B series Civic
- '91 LX auto bucking and stalling
- 91 crx Si with dx hatch or sedan fenders
- Jdm F20B in my 91 std hatch
- ED6 Dimmer switch Wires
- EF8 and Ef9 j's racing front lip, same fit?
- 86 crx as first honda project ?
- 89 CRX door is making light clicking sounds
- ??? any one with axis og oldskool ???
- How to replace the cloth insert of your EF door panel
- b16 S1 cable trans in ef ! need help
- New project build
- crx revlimiter @ 3k
- Radiator Compatibility
- Looking for 88-91 crx or hatchback hood.
- d16a6 91ef-me
- Cable to Hydro
- will a '90 Si fuel pump / tank work in my '91 Si
- Ls into ef
- EF Five Lug Upgrade
- crx wiring help
- which is the best on fuel
- 88' hatch with b18a1 and b16 cable trans
- Car Dead! Strange Problem!
- mrchaos' 1990 CRX Si Build Thread
- b18a1 swap in ef hatch wiring questions
- d15b7 into CRX. d15b1 harness being used and modified
- d16z6 mini me build questions
- 1990 HONDA - CIVIC WAGON 4WD help please..
- I WANT MY MPG
- 89 Honda civic hatch no cat!!!!
- crx main relay / electrical problem
- b18a1 short in wiring?
- Need to know what harness I need for my d15b
- Key Won't Turn - Confused, Help Needed
- OBD1 LS Engine Issues
- What exactly am I missing from my front end?
- Honda Civic Putts Along!
- CRX climate control problems
- conversion to front drum brakes
- Mud Gaurd compatibilty
- 1990 EF With B18 Won't Start The First Try (Please look, detailed)
- turbo supra map senser need help
- RACEPAK'S B16 WAGON BUILD....
- 91 hatchback gas
- 1988 crx si GSR
- confused on parts number
- 90 Civic: Brake question
- 91 civic dash lights not working when headlights are turned on
- crx sunroof stuck
- 91 civic issue
- Car will not start, only sometimes when it is jumped
- d16a6 w/ Y7 head timing help!!
- Blue exhaust after having plugs replaced
- ignition timing q's
- How to change a d16a6 timing belt?
- Trying to solve hesitation/misfire under load at WOT...
- CRX no start! Did I miss anything?
- Civic / CRX rear upper control arm compatibility
- new block. old head. low compression
- alternator wont fit? b16a swap into ef hatch
- not being able to rev pass 3500
- 90-91 leaky tailights
- Looking for pointers and info on which swap to choose for my 91 civic sedan
- Can someone help me with ECU code interpretation
- Loose steering column?
- b18a1 trans-what goes to this?
- code 43, Bad mpg, BAD Fuel smell
- can't figure out how to install stock coin box thing exactly ?
- Clutch acting up unsure of what it is
- Starting issues
- D15b7 motor with a pm9-4 Head
- LS CRX WONT START :(
- 2ndGenPower's Build/Bubbly
- Fog light help!!!!
- 1990 crx si light problem
- C313 connector problem
- 1991 civic issues (alt,tach,radio)
- DPFI Shorty Intake no Tandem Valve
- D15 Questions.
- Y1 vs S1 Cable Tranny
- NEW CRX NEEDS A MOTOR
- Gauge cluster issues when warm
- how come my interior dome light & clock on dash both don't work (90crx)
- gasket question
- AC gurus for a 90 CRX SI?
- NEW CRX OWNER
- question about turbo manifold-b18b1
- '88 or type r LCAs on '91?
- mpfi swap code 4
- Rear bumper find
- code 7
- ZC Camshaft Valve Lash adjustment?
- Quick Clutch Question
- can the idle be easily adjusted in a civic lx 1991?
- b20 vtec wanting to turbo need help...
- what alternator are you using (d series) guys
- 91 civic si seats in a 89 civic s1
- Overheating- death on Honda blocks?
- integra cluster into crx?
- crx wont start....
- honda wagon
- jdm headlight retro
- searching wires and such
- CAI question!!
- custom CRX ram air headlight intake
- Interior Question..
- Wiring diagram... can anyone help?
- Long nights, empty wallet, mad wife...and it was worth it :)
- EF H2B can you post your rides
- 91 civic si 3rd brake light
- Best Throttle Bodies For DIY ITB?
- new valve stem seals, which is which?
- obd0 to obd1 help!
- Motor swap ecu questions
- Need Help
- question on making z6 wire harness
- What color should I paint my EF hatch?
- seat swap
- ls swap in my ef ?s
- stock seats
- 91 sedan shell interior cleaning.
- 88 civic hatch speedometer
- Supension Help!!
- Cold start issue???
- rare ef hatch bumper?
- New injectors , still getting code #16~
- multiple misfire=(
- bad trans or bad linkage?
- any philly peeps want some wheels?
- Trying to BAR my Civic SI. Need Help?
- replacing rear hatch lift struts
- Car start to die when i give it gas..
- question about buyin z6 timing belt cover
- 91 civic steering rack
- obd1 eg complete wiring harness in a ef
- code 17 cel
- 91 civic hatch ls swap
- Grounding point...
- Compression Loss
- Weird problem with my EF
- 91 civic obd1 codes
- Stock Engine
- can i use a stock b18 solenoid in replace of my b16vtec solenoid
- 1990 civic cranks, won't start
- Questions regarding Safety Recalls
- help:front bumper bracket same?
- b18a1 crx poor mpg
- Ef sedan b18b1 obd-0 code 1.
- New Guy!
- [CRX w/B20vtec BUILD THREAD]
- Electronic coolant valve?
- ef9 cluster speedo works but no odometer
- new to the honda scene
- CEL Code 6 and 14. ECT and EACV. horrible cold start idle. fixed.
- 1991 crx SI fuel pump issues
- my D16A9 (EUROPEAN) - D16ZC build...
- front right turn signals dont work . WHY?
- Need help with climate control removal. 1989 civic si
- Preparing for a H2b swap for my '91 hatch
- Engine swap
- $10 to whoever figures out this dash wiring harness.
- Overheat/Coolant leak issue
- What Is My Green Tea CRX Worth?
- ef parts.....
- WTB MINT ef hatch
- Brake hoses/lines Questions about fitting sizes
- Best Sway Bar Kit to get????
- sway bars in efs
- zc fuel injector wiring harness!?
- Current draw
- Help needed! - EE9 B16A1 with Y21 Hydro
- CRX Si, Shift linkage won't fit on new transmission
- civic type r 98 top fuel gearbox
- code 22. need help.
- d15 auto ecu to d16 auto ecu ?
- 88-91 Honda civic disc brake conversion
- Idles low on cold start, fine after 10 seconds
- Anther lame noob here
- crx dx dpfi to mpfi b18a1 only runs on cylinders 2 and 3 ?
- Dohc zc
- More DOHC ZC ECU questions
- Stock D16A6 Custom Bisimoto V2 vs SMSP 4-2-1 (SCCA STS)
- Innovative Mounts warranty questions
- Which ones??
- running problem ef hatch
- 91 honda civic dx 1.5l d15b2 backfires in intake
- Official EF Civic CRX - Alternator thread
- CRX ecu
- 1990 SI Hatch - HELP NEWB
- does anyone know the amperage for the relay misuba RC-2201
- ctr pistons in a ls??
- Splash sheilds behind rotors yes or no
- Intake Manifold Question
- will crx rear interior fit 89 hatch
- Need somoe Exhaust guidance/advice
- crx sometimes starts...sometimes not
- EG Intake Manifold/throttle body on d15b1
- Getting close, need any fuel injector replacement tips
- I'm astonished by this guy's custom work
- Jdm b16 cable tranny issiue.. not able to put into gear very often.. Bad tranny? Gear
- smoking bad after head gaskets, 2 CRX DXs
- CRX Resto/Build
- Change cluster
- D16a6 build
- Lowered cars and freeway grooves.
- DOHC ZC. Please help..
- Speedometer issue
- b16a on b20b bottom end...Help
- how to remove air scoop?
- 90 EX sedan with weird Driving problems
- A question about distributor removal
- oem stock casette player
- 88 ef civic ls/vtec starting problems?
- Alternator B series?!
- Putting jackstands on all 4 corners of EF?
- Catch can pressure issue!
- fuel problem!!!!!
- Not getting Fuel!!! Replace relay, pump, filter!!! WTF!!!
- ef fog lights
- b20 ef hatch problem
- crx LS low idle
- Fender bolt issue
- Turbo crx wont start
- Need advice on my (broken) 91 honda civic dx hatchback
- 91 civic si master cylinder need info asap plz
- Help!! RHD door panel can fit to LHD switches power windows for 1990 CRX
- 88 CRX Mini me issues.
- Need a part number: 90-91 EX brake master
- mini me tapping, lifter possibly
- D15B2 DPFI Manifold line broken?
- Main relay problem
- planning to swap head
- B18 block with a ZC head????
- random cel 16, one injector not working, then working...
- How To Remove Relay??
- Looking for passenger side hole
- mud flaps
- Wiper Relay? Switch? Need some guidance
