View Full Version : Honda CRX / EF Civic (1988 - 1991)
- oil recommendations?
- dpfi-obd1 mpfi ?
- 93 b18a1 into 88 crx si
- Full-Race traction bar not fitting...
- traction problems
- ef rear disc swap hub bearing issue!
- What are rare Wagon / shuttle parts?
- Dash swaps
- No Brake Lights
- crx 88 si trans with 90 dx axles?
- y4 head on a6 block?
- d15b6 in ef hatch wiring problems
- b20 turbo manifold
- My new EF :)
- AC experts, question.
- High idle after mpfi swap
- EF sedan Ebrake cable for rear disc?
- Will a Civic ashtray fit in a Crx ashtray slot?
- Ef foglight identifying need help on this
- Alternator help!
- 91 Hatchback speedo question
- 91 civic si ac compressor prob
- clutch safety switch
- HELP!!!!!!
- 88 CRX Si With a 90 CRX Si Engine Harness
- gas mileage car
- Force Fed Racing Project CRX
- seatbelt beeper doesnt stop beeeping
- New Member, New Car, New Problem
- EF9 square fog lamp differences? helppp!
- Question with injectors
- hard to find si
- 91 Si breakin clutch.
- Rear bumper support (CRX)
- How-to Crx Hood Prop Rod Mod
- will 91 crx seats fit in 89 crx?
- Help figuring out what mounts I need.
- Problem starting my ed
- all crx's share same brakes correct?
- Seatbelt and door ajar light
- How can I improve my headlights?
- ZC + 5SPD L3 Tranny How can i figure out what axles I have...
- Car cranks but doesnt start?
- Bogging Issue
- what Obd0 dist. will work on a d15b vtec w/b16 obd0 ecu?
- Lookin for EF widebody pics
- new to honda, need some knowledge
- Custom Sunroof - Weather Stripping Help
- And now... it still won't start...
- 91 Si is ALL over the road! Front end shakes/ Pulls
- need some info on front end body parts.
- 91 ex throttle cable question
- B16 header clearance in '89 hatch
- 91 hatch swap problem
- Oil pressure gauge
- efcivic timing issue
- no lights in cluster or running lights, blowing fuse ?
- best route to go...help...opinions?
- 90 civic std pass side mirror help!
- PLEASE?? Rear Bumper Removal 90 Civic Hatch
- crx vacuum lines
- rear seats
- rear disk brake conversion
- B16a CRX muffler
- are 88-91 civic hatch tail lights the same.
- need help identifying bolt
- Vacuum Line
- ive never seen gas go so quick
- Car wont rev past like 3500rpm
- Ball Joint/Tie Rod help
- obd1 conversion (trying to wrap my brain around it)
- obd1/2 Block into EF
- 2010 EF meet IE caravan
- rookie question...
- Mirror/Trim Restoration
- Crx Front end onto a Civic ef hb..is it possible?
- CRX toe adjustment replacement
- My 1990 Civic Hatch Si has been involved in an accident
- New here
- Head Bolts
- HID kit?
- city lights in ef
- My baby 1990 Si Hatch has been involved in a head on
- good price for prelude fogs
- CR-X Si and Civic Si seat bolsters the same?
- EF8/EF9 power steering pump relacement
- CRX turn signal problems
- d15b turbo with mpfi swap????
- another window regulator ?
- My CRX
- No Power 2 My Ignition Switch
- cluelessss
- dohc zc loosing spark
- rear disc conversion on a ef hatch....
- my 1990 crx project
- OE CRX Muffler Replacement
- 1990 honda civic hatch base 4spd awd conversion?
- i need testamonials
- +++ Car won't turn over! Checked everything, need help!+++
- 91 civic hatch ZC build/questions
- civic si leaking water inside.HERE ARE SOME PROBLEM AREAS
- 89 CRX no Start
- Hood won't close shut
- AC harness under dash where does it plug in?
- Just bought LS B18b1 Need Advice
- My new hatch!!!
- To buy or not to buy... (89' 6spAWD Wagon)
- 90 Civic Hatch/ BRAKE Problems
- bottle cap in gas arm?
- Tach
- my car wont start...
- 89 civic fuel pump not turning on
- Need help. A/C wiring 91 civic Si
- hasport efstk mounts
- top dead center sensor?
- Anyone done a Integra tail light conversion?
- D15B7 Help
- ZC Distributor Questions and Sugestions
- help w/b16 swap in crx
- crx wire tuck what are these 2 plugs
- 91 civic sedan coilovers question
- Converting obd0 to obd1
- New to EF's
- '91 DX OBD0... CODE 13?
- CRX with swap obd0 code 6 coolant temp help!!
- trans issues
- Which should I build d15B2 mini me or SOHC ZC?...
- small wiring question
- TRANS PROBLEM - Manual goes into gears with out clutch pedal ?????????????????????WTF
- dpfi to mpfi zc in a wagon question
- D16Y5 in CRX Si A/C question
- HELP ASAP!!!: DISTRIBUTOR QUESTION!!!
- motor mounts melted?
- need help doing a ls/vtech need help
- NO START
- Quick questions
- selling it, tired of replacing axles
- no spark ARK
- ZC or B2 Block with z6 Head???!?!?!?!
- Replace valve stem seals now no power and running rich
- 88 crx si tranny questions & b2 to a6 questions
- Official EF foglight picture thread
- ep seats in and ef
- need help crx wont start
- half radiator question.
- Drag CRX coming out of retirement...
- Need some help from the pros, electrical gremlins ftl
- let's see how you cut your panels for rear strut bar
- calling all gurus - code 16 - running rich
- d16a6 swap with y8 head, now a whinning noise, what is it?
- eg forks on ef
- AC problem
- Need Seat rails for 91 dx
- distrubitor question
- Complete DC Consol Install In 89 Si Hatch
- Help please??? Wont go into gear.
- ecu troubles.....
- 89 SI Hatch Wire Tuck Questions
- new crx build
- Hooking up heater controls
- wiring harness
- OBD 0 CEL code 16
- Driver Axle to long.... PLEASE HELP!!!
- Click... click... (Start!!! for the love of god start!!!)
- What's the problem here ????
- Please help...
- Stock 91 sedan, Crank-no start, Key on-CEL stays on, no codes, no clicks. Info inside
- short or ground problem?????
- missing a piece?
- mini me boost???
- broken valve cover bolt D15b
- Single cam 89 integra, help please!
- Is my 86 CRX totaled?
- need help with a cel
- Coming Soon Fully Built B18C with a GT3076R
- *Searched* exhaust Q's
- EF SQUAD
- quick release opinions?????????
- 91 hatch cel and No power
- 1991 Crx Rebuild/wire-tuck/paint
- help..
- SOMETHING IS WRONG WITH MY BRAKES?
- i need a definate answer to a ef bumper question
- Can You Switch the Seats?
- dpfi iacv problem
- New bumper?.... new ef...
- ZC Clutch
- Radiator Hose Adapter
- New to HONDAs need performance help
- hey H.T guys !!
- Brake Switch Problem
- 90 si b18a1 in it subframe cracked what should i do
- help me identify my ys1 tranny (out of car)
- swap wont start..
- Tranny/axle problem...
- My CRX won't start
- need you opinion on door panels
- electrical problem with 89 4 door swap.. please HELP!
- CRX Si Alternator
- searching for wiring diagrams for EF8
- Searching for my old EF Hatchback *NEED HELP*
- rear driver wheel crooked
- 88-91 sedan hood into 91 hatch
- purchasing idle air control valve
- D16Y7 in 91 Si wont start
- 1991 CRX Si - Cranks but won't start.
- Pressure Plate Differences Hydro vs Cable
- need help, ready to torch crx
- Looking for a Civic 91 Complete wiring Diagram
- hood release broken
- Lucky13 91 CRX Si build
- TAIL LIGHT FUSE KEEPS POPIN FROM BAD MOUNT
- temp. past High...help
- My new bench seat sportin, mudflap draggin, EF sedan!! with pics!
- axles
- no start !!!HELP!!!
- GRRR fuel tank rust!!!! Sell me your parts, need help
- Blown Head Gasket
- Very Serious (but probably stupid) Problem With My B16a1 Swap...
- My New B16 Hatch
- camber kits or adj ball joints. which is better?
- interior panels
- missing clutch cover. is this the right part?
- HELP DIZZY....
- overheating after ZC engine swap
- EF 4 door loss of power while driving. Help?
- Help with tire size
- Auto B18A1 (from 90 DA front clip) into Auto 90 DX hatch? Searched...Help!
- First Build
- Stopping power
- Main Relay Question:
- lights in gauge cluster went dead?? - 90crx
- Project under 1200
- Back bumper...
- HELP! Cruise control and cig lighter both died, no power
- compression
- 89 hatch with si block? What?
- skunk2 or blox intake manifold?
- New guy with a 90 hatch
- reverse lights not working
- rear camber
- OBD1
- How much would you pay?
- Ef tailights
- 90 Civic Dx No Start.....
- ls swap in 90 civic help
- knock sensor/ b16
- dc2 suspension on a ef?????????
- Dropping gas tank.
- D15B VTEC w/Random hiccup/hesitation
