View Full Version : Honda CRX / EF Civic (1988 - 1991)
- turbo kit for b16 crx
- convertable crx?????
- Integra DC2 seats in a CRX (search down)
- How much?
- QUICK QUESTION
- B16 SWAP ISSUES: where do these plug in?
- b18a1 into civic
- anyone know of a site that gives tips and how to do body work?
- Rattling Muffler
- search is down and i need help pretty quick with omnipowers
- wiring diagrams
- Tranny Leaking still....
- How do I remove my 4-door rear bumper?!
- ITR sway bars
- 90 civic zc swap from hell
- will 92-94/94-01 eg/dc shocks fit an 88 ef hatch?
- Swapping out doors, need help removing door mounted seat belt, window handle and lock...
- noob
- crossmembers interchangeable?
- Vtec problems-16a-91 hf crx-
- door mounted seatbelts
- MACHINING SPECS(MINIMAL RUN OUT)ON A D15B2 HEAD
- need help w/ 91 DX
- Need help ASAP
- intercooler piping
- Damn emissions!
- 90 Hf A/C in an 87-4dr?
- D16A8/9 Into a 89 crx si?
- engine still cutting out
- I need an overdrive gear 5th gear 5500 rpms sucks help :(
- crx oil problem
- Aluminium oil pan for d16
- What Trannies Will Fit
- D16A8 - EURO MOTOR (ROVER) ????
- dohc zc intake manifold.
- 88 crx and 99-00 si rear disc
- no spark, good dizzy, neeed help
- Who makes the DOHC ZC parts? (searched)
- Should I spray my 88crx si wheels flat black? Yay or Nay?
- engine ?????
- my baby, stolen!
- Civic '90 DX wont start
- radiator
- Weight
- will a oil pan from a d15b1 fit any other d's??
- What's the lowest weight you've gotten a EF hatch down to?
- My $7 90 Civic Std Hatchback (sort of a rant/bragging rights)
- 1991 civic fo do Lx camber install
- Car is Bogging and leaning out. Help!
- help with car not starting
- muffler bearing ?
- rotor no come off
- CAMZ FHO A SOHC VTEC N.A
- Breaking front bearings(replaced, and broke again???)
- 92 civ to a 88 crx front end switch
- CRX DX engine problems...
- How to mount ITR seats in crx??
- Steering Wheels????
- b16 helms manual for everyone!
- Dealership Seatbelt Replacement Question! Do they mind mods?
- LX Sedan Steering - rebuit manual or rebuilt power?
- OEM Honda upgraded radiator that drops in a CRX
- TO SHIM OR NOT TO SHIM??????
- where can i get a CRX frame chart?
- Civic Si exhaust same as Dx?
- can anyone find out what part numbers these are?
- My new bottom end ... Do i need to break in?
- clutch question for a zc motor/si tranny swap?
- Another Main Relay Problem
- Cranking with jumping RPM
- Quick question....about o2 sensor replacement.
- Need some Advice for d16a6 Swap ASAP
- pr4?
- Which motor should i keep in CRx? B18b or B16a
- stock headers or crushed dc?
- pm6 = code 4 pg7 = no code?
- My Project 1991 CRX HF with B16 Swap
- 90 ef b16a to b18c
- Transmission/Clutch Question
- dohc zc into an hf..
- JDM ZC front end??
- gsr block 4 sale!!!
- Code 13
- camber kit adjustability: Progress vs Ingalls-also what suspension parts to replace while I install
- new clutch
- What do yall think of this set up.
- mahle piston vs weisco pistons
- Molly pistons??
- Anyone have a write up for a mini me swap for Dual point to multi port?
- my car was stolen!!!!!
- Where's the modified duckbill style wing EF?
- eg manifold fit the ef?
- What seats fit a wagovan?
- help with brake lights!!!
- fuel pump question...
- Tensioner??
- oem tails
- TWM's on B18c... what filter
- Is it a bad idea to cut some of the shift linkage off?
- DOHC ZC pistons?
- Does anyone know how long Hmotorsonline takes to ship and how much?
- b16 rod bearing
- "One mans trash....
- Go fast, or be comfortable?
- What size will fit?
- 1495$ for b18a
- Squealing like a pig! Timing and/or alternator belt problems
- car wont start
- Exhaust Problems
- Fitment question with OMP front strut brace????
- Hello just wanted to say I am new to the site and hello to all the crx owners
- Back Preasure..? Needed?
- Motor mounts need opinions
- another ecu CEL question
- How do i take off my steering wheel??
- Does this sound to good to be true
- B-Series engine weights
- OBD0 TO OBD1 QUESTION ABOUT SPEED SENSOR
- question on installing driver side window
- I got an Exhaust LEAK // ARGH // What should I do?
- lift points on my CRX
- LS Cable Transmission in CRX Question.....NEED HELP NOW!!!!
- ecu trouble
- for sale dc headers 4-2-1 carb legal fit b16 b18 b20 i had them on my gsr
- re: b16 bogging?!?!
- Well my set-up is complete for now
- Help please: d15b vtec-e vs d15z1
- simple question?
- Quick questions about trannies
- "FREE" parts "NOT FOR SALE" 91 crx si parts here "NOT A CLASSIFIED"
- Steering is Jerking..anyone know how to fix it?
- big brake conversion on my ef?
- b18 88 civic problem...b18 has EGR?
- ef civic jdm front
- jdm obdo dist and 91 integra cap & rotor
- Exhaust noise. . .Possibly peanuts
- del sol rear discs on an 89 civic hb???? I want to know!
- h4h head lights?
- Coilovers ?
- K20A3 or K24A1 for crx
- stock 89 hf won't rev up and i'm clueless
- What would i be running if i put a jdm h22 in a 89 hatch dx?
- looking for a b16a1 swap
- HELP
- My progress log. 89 hatch
- replacing timing belt and clutch on b16...pull motor or not?
- Eibach Pro-kit, alignment needed?
- where to buy weatherstripping for CRX door?
- Need help identifying wires, etc.
- sir exhaust
- question
- NEED helP with PRICE
- EF Power windows...
- iDLE aDJUST ON B16A1
- Im feeling this hatch...check it out
- Fuel pump is flakey, help me
- Problem w/ my JDM conversion
- totalled my ef hatch today pics jdm front
- Anyone buy a OEM front wheel bearing lately?
- is this a good deal?
- my car just started sputtering
- Need help with erratic idle
- b series mount problem
- prothane total kit
- Window Visors? whos got em?
- 2001 civic LX trouble code
- body
- auto tranny engine swap
- Seat help please
- Another stolen CRX story...
- knock sensor?
- How fast is a z6 in a crx?
- fule help
- car wont start crx si
- what's fair?
- crx b16 swap no fuel
- 4spd to 5spd in a 91 civic hatch?
- Ebay RHD ef9 JDM
- Mini me swap on a 1988 honda DX EF D15 carburated. Help!!
- 90' Crx with JDM B16 Motor Mounts???
- Help my co-worker
- side molding - where can i get some
- d16y8 questions
- VtecKidd Project Log 2.0L LSVTEC *Stock 88HF to NA Street Car*
- b16 not starting has fuel and spark
- fluidyne radiator for 89 hatch si. smallest size part no?
- sir front converstion
- rear brakes? 88 4 door
- Aem hybrid intake??
- 1989 crx si with DOHC ZC won't start throws code 6 and 8....
- ls swap into 90 hatch
- CRX Seat Belt Conversion
- Are EF trannys housings interchangeable?
- which distributor?
- tranny& clutch
- question
- Price for a Y8 Head
- rhd crx ecu ? need help
- Used CRX....What to look for?
- Putting timing belt back on
- Cable trannies
- Hood cable to much slack (not broken)
- WHAT FRONT LIP IS THIS?
- help w/ this bolt
- ANY BODY BAUGHT CIVIC TYPE R LSD OFF EBAY
- FAQ thread - Need opinions, thoughts, ideas
- hasport wiring for ef
- b-series swap into 4WD wagon
- skunk2 inlet manafold wont work
- OBD0 -> OBD1
- ef 91 sir brain??
- CRX b16 dizzy wiring?
- D Series internals questions
- Putting On Coilovers
- My Car Is Over Heating!
- Sad Sad Day for an EF :(
- intake fitting question??
- EX/LX Owners: Cruise Control Question..
- Need a pic of the undercarriage of a CRX
- what injectors fit the b16???
- what should i do wit my 91 hatch
- 1991 si timing marks???
- CivicSiRacer I have a question for ya.
- help with the 89 civic
- how much hp does a zc sohc non vtec
- Looking for some molding for my ef.
- Idling Weird, Help!!??
- My Turbo Project Is Finally Done 56k GO AWAY
- b20 question
- NEED ADVICE ON CHOOSING MY ECU SETUP! HELP!
- sohc ZC cams
- N1 Turbo muffler
- HELP!!!!
- Wich combonation would you go with?
- Headlight idea?
- Filters
- wiring DX-SI
- pointless as hell question
- 95 gsr motor in a 91 si hacth, will it work?
- D16z6 internals in D16a6 or D16y8 or vice versa
- where is the main relay on 1990 crx?
- Stupid things I did today.
- is it worth 500?
- thermostat ground
- bad news for now good news in about 3 weeks
- z6 in a 1990 DX
- gasket set for a dohc zc?
- quick oil catch can question
