View Full Version : Honda CRX / EF Civic (1988 - 1991)
- d16a6 timing sequence
- Custom B-series A/c brackets who has them?
- Wiring Diagram for JDM B16A1
- what should i do to this car ?
- please start, why wont you START!
- Heater/AC Controls
- Wiring obd0-obd1 jdm d15b into 90hatchback si with conv harn from jdmshit
- Project CRX B16 Turbo pics. by AutoSonic
- help waterleak
- twin crx
- car shuts off when A/C is full blast WTF?????
- steering wheel? which is compatible with 90 hatch???
- Picture Request. B series EF with turbo
- painted dash. can you get it off?
- Need Help...Si Distributor
- my neighbor backed up into my crx !
- ek9 master cyl. and brake booster for a rear disc swap???
- B18a in 90 dx Wiring Help--Searched!
- 90-91 cluster in 88-89
- INSTALLING ECU
- b16a help!
- Which motor mounts?
- rear Si badge/emblem on Hatch???
- wiring help
- crx brake lockup problem
- How to hook up Apexi V-afc controller?? Searched
- help!! stuck axel!
- EG or EK mirrors fit an EF?
- homemade turbo?
- Brown Top ZC
- Wiring up my friends MSD RPM switch where do I get the Relay for it?
- Parts for rebuilding d15b2 dizzy
- Upper Strut Bar question...
- Crossmember radius bushing....replacement
- Wrecked 91 CRX w/B16A swap...what's it worth?
- ****rear std seats from a 90 civic hatch great condition cheap***
- ??? About Injectors
- Dash pot for the throttle body
- B-Series shifter bushing question
- Problems: Rear suspension and Brakes
- where to get a b18 a or b in san diego
- glass pack guys.. any 'tip' suggestions ?
- B18C, S2 IM, EVAP purge solenoid location, is mine ok?
- Headlight issue!
- Another CRX bites the dust....... =(
- I need ideas for the license plate on my 91 rex
- European model CRX...
- mount ? important need answers quick jdm d15b into 1990 hatch si
- 85 crx hf
- Removing Dead Pedal
- CRX only starts 1/2 the time. Whats going on?
- So I traded my crx for a del sol...
- new motor running like crap
- shifter sticks when cold
- FAQ: Tranny Tech Article
- Funny Lookin CRX (what a shame)
- 1st Gen CRX headlights
- need help throwing codes 5, 6, 15, 16, 20
- Honda 85 CRX SI engine removal
- tranny: is this normal??
- y8 manifold ?
- broken valve cover bolts
- axle options?
- b16 piston or stock??
- B16 IM on Z6 Head for CRX 88SI mini-me
- ZC with Auto!?!?
- crx swap advice. b16a, d15b or d16z6?
- axle's
- where can i get a honda-tech sticker???
- Need help
- I HAVE A CRX DX 1989 I AM TAKING THE TERMOSTATE OFF NEED YOUR HELP SINCE YOU HAVE DONE IT THANKS!!!!
- jdm d15b into an ef
- Looking for automatic D15B vtec ecu..help!
- gutted out rear interior with speakers still in tact? (crx)
- i just got cell code 23 (knock sensor) wheres a good place to start?
- what parts can you put on the ZC???
- My Tranny is fucked up help help help
- no compression in middle two cylinders!!!!!
- '90 CRX Si: shinies in the oil
- 1990 Civic Si Hatch
- WOULD A H22 OR H23 TB FIT ON GSR SKUNK2MAIN...THANKS... HEARDITFIT
- CTR OR ITR CAMS FOR GSR
- B16 knock sensor prob..help plz!!
- Off to Iraq soon
- d16a6 year?
- Cams Cams Cams :)
- s afc
- Front bumper removal?
- mpfi related ?? done!! but need answers??
- Pics up: Sparco seat finally installed in 88 hatch.
- weight of my 1989 crx hf kinda disappointed
- TDC on Z6 head
- Gauges ?
- I need a Cat. to use...
- Help! Installing 2nd Gen 'Teg Seats In 89 DX Hatch!!!!
- ZC having truoble reving- also throwing codes
- question about CRX DX heater hoses with a B18C
- starter kill .....which wire is the cranking wire?
- Suppliers for custom ready to fit converters, for hybrid applications?
- do spoon/mugen rad caps do naything worth buying?
- Code 17 (vehicle speed sensor)
- help please, driveablity problems
- bad rotor changed it and now b16 a in 91 hatch won't start help!!!!!!!!!!1
- Dist Rotor and Distributor Probs... HELP ME!!!
- A6 block + y8 head = wich head studs?????
- b18b vs b16a full swap into crx
- What might as well be replaced?
- Timing for dummies, I need help
- need help on b16 piston
- the truth about weight: let's set the record straight..... b-series swap, etc...
- ls swap in crx
- Need help removing alternator out of a 87 CRX
- BUMPER LIGHT HELP... wich ones are longer?
- Premium gas d16a6?
- Apex VAFC
- Motor swap in a 1st gen or 2nd gen?
- What engine is in an 1987 CRX?
- fitting a Y1 LSD in a S1 tranny
- ECU change neccessary for ZC swap in CRX Si
- car making noise
- Mini Me, You Aren't Completing Me!
- gsr b16 head?
- How Do You Guys Wire Accessories. Im lost
- LOOKING FOR 94-00 INTEGRA CONSOLE & ARM REST
- wiring harness diagram for a crx hf/ b18a1 swap
- 94+ teg door panels in eF??
- FREE COILOVERS!! Help me Install them, *PIC*
- Swap information needed
- 1993.5 DC2 suspension fork or eye type?
- speedo not working
- Loading a motor from the bottom SUCKS.
- z6 swap problems, general info please help.
- Need Help on Radiator???
- HELP--MY CAR GOT STOLEN
- Cam Swap
- question for a noob, what is ls-vtec, how is it different from vtec?
- Ef stuff for sale 11" brakes, LSD tranny, and more
- milky colored fluid in transmission (help)
- crx swaps
- B18C1 in CRX w/ Hydro ITR tranny
- does the 88 HatchBack Driver Side Window fit a 90?
- Vacuum Diagram??
- Broken exhaust on 89 Civic LX
- OBD??
- crx camber kit problems
- A d15b swap problem.
- Mirror question *SEARCHED*
- Good place to find MUGEN Body kit????
- Looking for a 88-91 JDM CRX
- FOR SALE 90 std civic rear seats cheap great condition
- ZC
- hmotors lists to different types of b16a swaps which ones do you guys buy?
- On route to a hybrid beast!
- b16 oil pressure
- type of suspension
- doing sohc vtec swap, use z6 throw out bearing or a6 throwout bearing
- Dead Pedal
- Need help code 21 keeps turning on when hitting 5500
- Tranny Question
- My CRX feels so loose and unstable.... Where do I start looking? Help!
- HELP. Axels splines don't match brake rotors
- Name this b16 part! (with photo)
- help with alittle problem
- First Gen CRX experts
- color Q?
- Cluster swap, no tach for a cluster with tach on a 90 civic hatch std, can i pop out and pop in?
- tachs jumping, cars sputtering, car keeps dying please help
- jdm DA rear seats into ef??????
- CRX center shifter console
- main o2 sensor question
- bumper support
- green91's project hatch... 56k take a nap
- took out A/C system - worth selling ?
- B16A FRONT MOUNT
- Rsr Ex Mag for EF
- code 6... wtf, wont go away. Could the ECU just be sh#t?
- valve clearance question
- should i paint my new rotors
- HELP, Car slipping out of gear.
- broken timing belt, pics of valves and pistons, advice needed
- CEL 1 and 2 when it's hot out.
- AAHH starter and tranny problems!
- NEED HELP WITH VACCUMM LINES FOR GSR MOTOR INTO A 90HF crx!!!
- Multi point to dual point - many pics...any help
- d16y7 pg7
- need to know some info on D16A6 and D16Z6
- ZC Motor and heater questions
- ¿?where is the best place purge your nitrous setup.¿?
- tapping noise at idle, help!
- Oooohhhh My Plans, will it work?
- help me my car is actin a fool
- misfiring mayhem
- 4G4D questions...
- What battery for my B18?
- Any Full-Race.com turbo kits on B-series swapps?
- 94' HB d15 into a 89' CRX SI any ecu probs?
- OLD CRX>>>BUT ITS DOPE>>>
- BEST SWAP/CONVERSION FOR CHEAPEST PRICE!!!!!!
- What does a wide body kit do?
- 4wd conversion: 89 crx
- 88 civic dx 4dr. questions
- ls vetc what does it take???
- cool but cheap mods.
- emission station in NJ
- newb timing question'
- Another lame CRX Si Seat Question
- pic request: first gen teg bumper on ef?
- 89si interior with 91si engine harness.
- Door pockets on a '91 Civic
- PLEASE HELP Looking for REAR MAIN SEAL PLATE for ZC BLOCK/NONVTECH/1.6DOHC
- ZC into DX alxes questions
- clunking sound when i step on brakes
- foriegn object fell into D16A6's timing cover while running. Result-> Bent Valves on CRX
- 88 si trans (clutch) question
- suspension stuff done :) pics
- Swapping Hatch 91 CRX Si to 88 CRX Si NEED HELP!
- P28 ECU 5spd or Auto
- Throw out bearing return spring?!?
- Lets compare B16's
- Running custom brake lines...fittings, bending, flaring etc. Help me out PLEASE!
- spark plugs for zc???
- What dash would fit in a ef9 hatch ??
- Wiring help
- dead spot on 88 crx dx .. around idle
- bushings going bad ? wtf ? 88 crx
- 1990 civic hatchback failed emissions test, its putting out too much NO2
- To take out the cat, or not to take out the cat.
- were can I get a d16z6 head
- pic?/"FullRoyalSportBronze" C10's on a CRX(white preferably)??
- Could it just be the ecu? All sensors/wiring is good. Still codes.
- Where would the EGR Valve be located on a 1990 Civic Hatch?
- Need help seperating tranny
- Brake prop. valve causing uneven left/right front distribution ?
- Automatic Transmission Problems
- ZC Turbo???
- help right now please
- main relay buzzing please help!!!
- Wiring harness
- h and r race springs why does my car sit like this
- AEM or UR
- 1st gen B16 idle adjustment screw...
- Roll pin installation
- Rad hoses w/ EG half rad?
- b16 swap in my crx. what can i keep?
- help: i need a stock airbox for a 91 civic for smog so cali
- head swap
- 88 crx rear LCA's? what aftermarket ones will fit?
- stupid crx question
- power windows and locks for crx
- fuel rail
