88 CRX Si Cranks But Won't Start
I recently purchased an 88 crx si as a project car. My plans are to swap a k20a type r motor into it and do a full SiR conversion on the exterior and interior. Anyway i would like to get the D16A6 running sound before i pull the motor. I just replaced the distrbutor cap and rotor, battery, spark plugs and wires and it will crank but not start. The owner before me rigged up the fuel pump and spliced some wires outta the fuse box in the bay so idk if that might effect it starting (the pump gets power and works ). Need some help. Thanks for looking.
Yo. We need more info.
Get air, fuel and spark at spec timing without vacuum leaks
then the car will run. The best answers to your questions are your own.
Got her running.I checked all the grounds and rewired the fuel pump so there was no rigged spliced job. That seemed to do the trick, she starts just fine now!
HBK
Oct 19, 2010 01:51 PM
