View Full Version : Honda CRX / EF Civic (1988 - 1991)
- is this a front mount intercooler?
- Header hitting the ground....HARD
- CRX carbon fiber doors????
- obd0 d16z6 into crx hf
- Quick Question: Prelude Fogs
- need a good race what would be where the time??????
- Is this legal?
- 1989 Civic Brake lights not working...is there a switch near the brake pedal?
- 5 lug
- searched and need a lil more help.. 88std /z6 motor
- Filter question?
- just thought it was funny as hell
- 90-93 DA sway bar fit 88-91 crx???
- rear disc brake question
- Metal frame in lower portion of CRX dashboard
- Crx obd0 ecu prob
- Problems w/ y8 IM on D15B help please!!!!!!!!!!!
- well bye bye tranny
- N/H: I PUT MY MOTOR IN TODAY BUT HAVE A PROBLEM
- think this did damage?
- HKS Sport Exhaust
- dpfi to mpfi to OBD1 vtec
- which relay is mounted by the pass. headlight??
- Help!! Do they sell adjustable upper control arm for a 91 dx crx?
- Engine clearance
- best clutch
- stock si front and rear sway bar???
- pressure plate and flywheel question
- Manifold Vacuum routing, stop PMing me damnit!
- Coolant Leak From Intake Manifold on 90Si!??!...WHAT!???
- need si wire harness diagram
- installed gauges, now dimmer doesnt work on center consule
- Tonights new K20 crx plan :) :) Click here need some advice (-(-_(-_-)_-)-)
- jdm sedan 1piece headlights in a hatch
- CRX Clusters?? DX?? Si??
- My spark plug wire is melted!!! WH?#@!!?
- vacume lines
- H22A EF8 CRX
- need radio code
- PLZ HELP!!!!!! check engine light wont blink when when jumper is in
- crx si with b18b
- GAUGE CLUSTER QUESTION!!!!!!!!!!
- b16 turbo a/c manifold
- homemade cold air intake?
- best place to buy engine?
- Should a head swap be scary?
- Popping when i turn
- b16a trans non lsd cant find clutch to fit 24spline...not sure if s1 j1 ys1 it is obd0
- Hf to Si
- ZC DOHC or B16?
- radiator fan keeps blowing fuses, shorted out?
- Tranny problem!!!! Went to acura nothing went to honda nothing someone help me.....
- obd0 pinouts and wire color, need asap.
- Running engine without valve cover question?
- AFTERMARKET STEERING WHEEL QUESTION!
- 10sec EF STOCK D16! 27 PSI!!!!
- Idling low
- Register Box?
- weird stalling problem after a DOHC ZC swap i did last night please help asap
- Tranny code-s3-which model?
- battery light
- my crx b20b swap
- How much for mpfi swap
- Only starts when cold...
- valve clearance & valve stem seals
- antenna help
- CRX Different Seats?
- Engine swap motor mount question!!!
- Ha ha ha people will sell anything on ebay.
- brakes locking up
- B16A is almost done, but just question about wiring up tech & A/F ratio
- DOHC ZC or SOHC VTEC
- Searched-LS swap wiring
- YET ANOTHER IDLE PROBLEM
- I'm 6 Feet tall .. will i fit in a EF civic hb with Del Sol seats?
- SOHC VTEC Spark plug wire routing
- 90 hatch Si, wiring....(you already know these are stupid questions)
- Warm Start - Car Bogs n Shuts Off (TE ng55, gm 3 bar) WHY?
- what tire size and brand
- 205/50/16 tyres on EF
- integra lip on ef sedan... pics!
- GSR Cams in b16a.
- 88 door panels on 89-91 doors
- NSX brakes wont fit
- Throwing code 1, help
- need help. d16z6 swap vacuum line routing
- B Series mount question!!
- charcoal canister???
- CRX Ignition prob 2
- Can 225/50-15 work on a crx?
- Quick question on rear seats in an EF
- obd0 b16a CRX vacuum diagram/pics HELP ME!
- 2 Questions
- D16A6 help!! Eratic idling/tach reading etc.
- H23 intake and throttle body
- transmission shifter forks
- should there be more?
- Just bought a 89' CRX!
- Question on leaking radiator
- tire width...
- GSR with hasport mounts
- any one have that link to the how to with pics on making shift linkage?
- Pick one of this engines!
- DA rear brake swap
- Car acting funny?!??! need help!!!
- Need with with EACV wire colors
- battery relocation in sedan. what do i do with this part?!?!?
- d16a6 oil control jet
- throttle body or dashpot ?
- Rotten Smell with smoke, Help!!
- what is the widest 15" rim for ef
- B18b swap axle replacement...
- my car just randomly dies....WHY!!!???
- b17 install in to 89 si
- CRX 87 and CRX SI 91 compatibility Q?
- d16a1 turbo?
- just got 91 civic si...Can i put a jdm d15 vtec head on? whats involved?
- obd-0 color help
- can it be done ? 90-91 si gauge cluster into a 89 civic hb ?
- coupla problems
- part number help please!!!!
- Can you put jdm 4x114 in a crx?
- CRX Engine Swap
- o2 problems
- simple ef questions
- p08 intake manifold
- is the fastidle control valve used on gsr
- D16 Oil Leak!....... Please Help.
- Turbo D16 Sedan - how to roll with AC
- identify this sensor....
- E-bay ss header
- Help Getting car started
- Holy CRX Exclusive Parts Batman!!!!
- need name of exterior pieces
- what is this?
- CRX Turbo front bumper options
- cable to hydro
- finally got it to crank over, but now another problem (fuel pump)
- RHD Importation From Canada
- fan problem... help
- Rear speakers? Brackets?
- Anyone In Louisana??
- CRX 88-91 Sway bar bushings 18 or 19mm for front? 15 or 18 for rear?
- JDM to USDM Cluster conversion
- FMU, VS. TURBO EDIT, VS. CHROME
- 4 speed
- Traction bars for CRX Full Race, Avid, Innovative....
- i need all honda tech wiring wizards to come togather on this one!! please help
- Any EF owners in South Gate, CA?
- clutch help
- front crossmember removal
- rad.
- Obd1 Dizzy Question??
- Heater Core/AC Question
- Advice: sell dc2 and get '91 DX hatch?
- VIN Plates
- my tranny went bye bye! :(
- Tranny Help
- TUNING DEVICES PLEASE HELP...
- megan racing exhaust tip wat size piping should i get? HELP IF U HAVE A EXHAUST
- d15b vtec octane requirements/ rev limits?
- Connector for Corner Light Bulbs?
- What performance mods should i do on my rex?
- fuel regulator?? what does it do?
- Swapped Si Electric fan not turning on....
- Continued with D15b2 Help, Pic Request
- seat replacements?
- NEED HELP!!! CAR DID NOT PASS SMOG
- Timing belt tensioner
- antenna
- lowering my car
- b16 stuttering problem please help!!!
- CRX front end on hatch?
- What is the ARP part number for the d16a6 headstud kit?
- Wire Tuck Questions.. Do i need this piece?!??!
- head bolts healp
- D15b6 Swap
- b18b intake manifolds
- ecu codes
- help main relay?
- HELP!!!! With my b16 swap
- Purchasing a 1g crx: Why or why not?
- eg seat question
- ecu code???
- Cat Convertor and Ignition Coil Question
- Looking for a shell!
- 91 crx injectors?
- Bedding in brakes
- head gasket/overheating question
- d15b2 Help
- do I need a new alternator?
- underside plastic covers...what are these called? how many are there?
- radiator/oil cooler question
- Ghetto 4-Pt. Harnesses with stock Si Seats?
- ek rear seats into ef?
- Help ! 88 Civic LX. Codes 4 and 8
- Really quick, really weird electrical question
- How much for a D series tranny install?
- Performance Alternator?
- motor Fra HMO.
- CRX and EF HATCH/SEDAN FENDERS THE SAME???
- engine bay is prepped
- relocating battery
- Please help with o2 wiring obd1
- NO Spark.
- crx b series help
- CRX rear seats? and wire tuck...
- SOHC ZC motor questions....
- htf do you fix code 15
- sub harness wire problem?
- 88 trans in an 89 si?
- b16a swap into 90 hatch .....NEED WIRING HARNESS!!!!! ANYONE ?.....
- what muffler?
- bullfrog SOHC vtec
- Now i've seen everything (may be old but not to me)
- D16Y7 FUEL RAIL
- no fuel
- look at what i found....whats it worth?
- HELP 88 CRX Si wont start
- best exhaust for hp gain
- Timing belt question
- Map sensor intechangeable?
- Hey anybody from San Mateo or San Jose area? i need help lookin for this shop
- What tools will i need to swap out a head?
- CRX + b18c1 + 94 integra axles work?
- ATTN. ALL CRX HF OWNERS
- b18 wont start
- Bosch 5 wire for wideband?
- Unknown drop on my 90 crx
- Help, Tire Size!
- zc mzp sensor.
- will a 90 crx si hood fit a 88 civic
- help - suspension techniques rear sway bar bracketry issues
- What Gets More MPG, Turbo or Supercharger?
- im relocating my battery, i have a few questions....
- which front shocks fit?
- 89 civic injector problems. Need Help!!!!!!!!!!!!
- exhaust question
- Mud guards on the EFs
- Not getting any fuel!! HELP!!
- 90 civic si muffler
- Code 37? pr3 ecu
- Engine managment question!
- varied performance?
- Sound deadening removal with liquid nitrogen - Movies Inside
- can i put a d 15 out of a crx dx into my crx si that has a blown zc?
- rsx brakes, hubs, etc on crx?
- b16 head on b18a question about wiring
- Some one has to have seen them... Headlight question
- B16a..did they come with tubular manifolds(headers)
