- How to tell if a block d15 or d16?
- hatch side moldings on crx ????
- ef hatch no spark
- need head bolt tourqe specs d16z6
- 90 civic steering rack install...
- quick question.....
- D16 Rod/Crank Specs
- need help with my alignment on lowered crx si
- need help with Vtec?!
- b series dizzy
- having distributor trouble...
- b18b1 venting
- MACHINE SHOP WORK questions
- anyone have rear bumper bar removal pictures ?
- da motor mounts?.....
- 89' Honda Civic 4dr WAGON interior parts questions??
- HFP Fit Wheels 16x6.5 - 55 offset
- any other pistons besides CP pistons?
- b18a1 swap crx backfiring and hesitating when at idling temperature
- NE1 find a clear glass sunroof yet?
- 88CRX b18a1 question
- my crx is still boggling? what can it be need help pls
- I dentify this arm rest
- LS crx hard to shift?
- 90 civic trans
- WHAT JDM BUMPER IS THIS
- Hatchie doesnt start up as quickly as I would like...
- "The Little Rex That Could"
- OK GOT A PROBLEM WITH MY 91 CRX
- WTB: 13's steelies and other parts
- swap question
- Brake Light On . Everything Works Fine ????
- crx brake problems
- Fuel pump problem
- having problems with my ef9 help
- FS-/-my 89 ef
- wtb: EF9 partss..
- 91 honda civic production numbers
- 6666 Customs Bumper....
- what header should i use with b18a1
- 91 civic dx 1.5
- Oil Question.
- Seat swap help
- seat brackets
- H23 Swap Problems please help
- TT on rex ignition
- Help needed. Rear bumper picture in repair manual
- jdm b16a oil leak
- b16a vtec
- blown fuse
- 88-91 tranny different
- Civic Start Issue
- Building crx/mpg monster
- DIY: H.I.D Retrofit using OEM parts into USDM Headlights
- Parts for EF and some for DA
- ANYONE IN CENTRAL FLORIDA? machine shop Q's
- Intake manifold "SENSORS"
- civic clutch hole
- Brake Caliper listing for all you hybrid brake fellas
- 91 civic gauge swap need help
- 88 hatch all motor street/strip project. 2 updates with pics!
- Are the 90-91 civic and crx cluster covers exactly the same?
- Valve Springs Q!!
- any one ever???....
- Password:jdm power chamber intake
- BMW "Bottle caps" on ef?
- does any one know how to stop quarter-panel rust!!??
- 1988 honda civic truck
- New to Hondas, bought a CRX.
- 91 Civic engine swap
- DOHC ZC replacement part questions...
- Kaminari CRX body Kit
- Hatch suspension questions?
- Seat pan swap revisited- Civic hatchback 1988-89 to 1990-91 upgrade.
- new shoes
- lhd crx sir??
- headers wont seal right
- B16 into CRX help
- Water everywhere....
- swapped 91 civic si
- Prelude182's 91 Si Hatch
- OEM p29 vs NPR p29 are they the same?
- LS swap issues
- Hasport Cable to Hydro Conversion
- VQ35DE in crx?
- LS-V or LS-T
- Jdm crx hood on usdm hatch, will it work?
- should i stick with my EF or just get a DA
- Troubleshooting help - 88 Civic dx.
- b16, axle loose
- Throttle body Question
- will rsx booster n MC fit?????
- Header swap problem
- Connecting tachometer to check idle speed
- Need help with turn signals/hazards
- fuel pressure issue
- 1/2" steel plate behind the heater core?
- Anyone ever use Blackworks coilovers?
- B16 swap into 91 STD question
- mpfi swap
- d series valve covers?
- HAPPY THANKSGIVING EVERYONE
- how to tell what year the motor is?
- whats need to do a R12 to R34 ac upgrade?
- DA integra carpet in EF hatch???
- map sensor?
- Rough/Low cold idle, Fuel smell, wont rev past 4500
- question.
- Need a how to pleaaase?
- Carbon Fiber Interior
- 1991 Civic Motor to 1989 Civic swap
- steel wheels for crx ee8
- Tranny swap.
- 88 crx tail light/brake light problem
- anyone repin a 91 si dizzy to a y8?
- Help where to mount my hasport cable to hydro kit!!!!
- Are d15b2 and d16a6 cams REALLY different? Proof?
- help! auto trans going out???
- Brake booster question
- Tranny problem now!
- CRX Leaking Water
- No spark, no injectors, no CEL. but pump is priming
- Trouble starting and a couple other issues...
- d16z6 block d16y8 head timing info
- ecu question?
- vtec in my dx hatch
- Cranks but won't start, but it WILL run
- b16a swap
- 88 wagovan
- ef hatchback w/a singlecam zc
- need to know 91 si ef
- steering wheel. 5 bolt pattern
- My 88CRX Daily StreetBeater Build/Progress Report
- mysa ef ...the beginning...
- still want crank please help
- automatic b16 swap into 1988 civic
- exhaust piping size question?
- b18b ef idle problem? help needed
- 89 CRX Si With no Bumper support?!?
- NEED HELP! turns into a how to take apart your tranny :(
- 89crx si w/ mini-me 2k rev 3 codes I need a PRO's HELP!
- Slim Aluminum Radiator for CRX
- lsvtec
- 1990 4 door civic b18 swap
- need some help with my heater wire
- civic 1991 suspension question?
- sir spindle bearing
- sohc zc having gas/mile problems
- 90 sedan custom exhaust question
- wassup new in here need some help
- mini me coversion on d16a9??
- can you explain why my search for a jdm cr-x manual has been locked?
- Need some help on my ef!
- Thinking about an EF...sedan! (need help).
- Question: does integra DA rear seats fit in ef hatch???
- 4 disc brake swap
- Bad Vacuum Leak
- Unknown wires at cluster plugs
- Nitrous main line Question
- dual point to mpfi? and how would i do it and ect..
- 88 civic z6 swap issue need some advice
- tranny 20 splines or 21
- 88 civic hatch part-out
- head studs?
- NEEDED EF STARTING ISSUE HELP
- Write-Up: DIY Front Wheel Bearing Replacement
- Idle adjustment 1990 Civic DX
- Boost gauge
- cel codes question
- hf and si..SAME DIZZY?
- Should I make a DIY Wheel Bearing Write-Up?
- spark issue
- broken tranny mount
- BackSeat (Lock Broke) no cant fold down
- b16a shift linkage problem 2
- Shift Linkage Problem - '91 CRX DX
- 91 CRX DX engine help.
- diet plan...
- the rise my reliable DD
- california
- CRX Glass Top Install
- interior lights and corner lights wont turn on?
- crx is boggling?need help
- b18a1 swap crx bogging when warm
- pm9 question
- B18a1 Timing
- 91 EF Si usdm mud guard question...
- what wire to cut?
- NEED HELP my gsr swap in my sedan
- VSS wiring problem
- crx misfire HELP PLEASE
- b20b
- help me
- CEL Codes 47 & 94 need help
- full gasket kit confusion
- stll no spark need help fast
- 1989 HF Wire order
- hf engine harness
- starting problem
- denso plug what is it? plz help
- Headliner...
- need help on DOHC ZC valve spring.
- Looking for an JDM Cr-x Service manual
- Going rate for CRX's?
- NEED HELP - installing USDM rear speaker pods for ef hatch
- hey 90 hb si need ideas
- D16 89 civic si temp gauge...Issues
- My $80 Dollar 88' Crx Si.
- Heater doesn't blow that hot. Why?
- what do you guys think?
- Different MPFI swap
- Honda CRX Blower
- P2J-1 head
- quick mpfi swap question
- Instrument Lights HELP!
- Little help with the swap
- cel help?
- need help code 9 and code 10
- b20b block clean up
- for MPFI conversion can i just swap the hole harness instead of modifying
- suggest a good suspension upgrade for my 91 crx sir
- y8 mini-me zc pistons, will not rev over 3.5k
- question
- No spark??
- EK console into EF?
- got a Y8 head and wanted to make sure my list is current and correct
- pg7 ecu ?
- Trouble with EF B16A Swap...please HELP
- JDM Maplight Dimensions Here
- what causes bad camber if no camber adjustment?
- 90 Civic SI H23 wiring Help
- Engine temp
- Help me build an (automatic) CRX.
- intermediate shaft question.
- wiring nightmare!
- need some help guys
- valve and piston contact SOCH ZC
- Need help: 1990 honda crx HF with b18a1 swap
- 93 LS into 90 sedan
- 91 civc need help getting fustrated not getting fuel
- HELP-Mini-Me in 90' CRX Si - NO VTEC - Help Please
- DA front subframe on a EF
- VSS on D Series?
- b18a into ef WITHOUT conversion mounts?
- 89 CRX Trouble.
- Car Dies\Idle Problem Maybe?
- ECU/suspension/tune questions
- Misfire in my crx
- looking for help
- Brake line ? regarding fitment with drums or rotors
