View Full Version : Honda CRX / EF Civic (1988 - 1991)
- JDM front end question (?????)
- questio on my b16
- Tranny Problems
- Wiring question
- b18c5 swap. sane or insane?
- Walbro fuel pump, which model do you have??
- Civic Vti guage cluster??
- HP figures for a mini-me swap?
- harness mounting in crx
- Fast Idle Adjustment...
- Need help with intake...tried search but it was disabled!!!!
- is my crx "JDM"?
- Question about transmission..
- DC Sports Exhaust for sale!!!
- 88-89 si cluster into 89 std.....wiring info needed
- is shipping wheels expensive?
- B-series mount kits.. which one?
- How to keep A/C in 91 hatch with B16A?
- done mpfi swap but idles SUPER high ??? please help!!!!!!!!!
- air idle control valve
- new project in the ER
- Which Trim Pkg (Decypher my VIN pls).
- ------>>> b18 swap going on here... SHIFT LINKAGE ??? PLUG WIRES???
- Best Tranny Fluid for a 91 crx si!!!?
- Urgent - need engine harness connector pinout
- attn: ZC/tech people... need help with starting issues/distributor problems...
- REAL directions to install a GSR Cluster in your EF!!!!
- JDM d15b Vtec?
- opening a wholesale account. want somethin?
- Anyone want a dirtbike?
- mufflers??????
- Did any one in here b20v their Crx???
- what color does this come frm??
- MPFI conversion question
- forums for g3 Civic GTi
- yay, got my car!
- ... swap options... 89 crx dx... (seached recent, archive still disabled)...
- I need to know proper bleeding technique...
- Anyone have HCP mounts w/HAsport shift linkage setup?
- 2 a.m. CST and I'm now officially Mini ME'd
- Is this supposed to happen?
- Place Racing Wiring Diagram DX-SiR
- itr 5-lug conversion..... should I add the abs too?
- Please help me with my bouncy suspension problems. I hate driving my car!!
- Ugh I got sent the wrong throwout bearing, I need a part number
- my cluster is smoking...ground problem maybe?
- How do you tell what head you have?
- Water Trouble
- anyone have a p28 ecu i can borrow sunday?
- vtec activation in swap????
- y1 vs. j1???
- D16A6 horsepower/torque curve chart?
- Can I use the eclipse O2 housing with place racing xmember?
- Speedo cable wont stay in.. help
- URGENT - electrical problem - in the middle of a swap
- whats a good cheap header for D
- Car wont start!! another typical topic but i'm stumped!
- best exaust & intake for a 91 civic hatch
- Hi, New owner of a Rex
- transmission help!!!!
- looking for Civic/CRX gauge cluster plug layout???
- AEM intake for b18c swap???
- Need Help
- Zdyne + 450cc Injectors + boosted ZC at 8 pounds of boost= BAD ASS!
- B18A and B16A
- OE replacement catylitic converter
- JimFab Crossmember with 92-95 civic rad???
- Please help me! Emergency!!!
- Wich timing belt to use on JDM d15b vtec?
- auto to manual conversion: what about the reverse lights
- question about usdm and jdm tranny
- 90 hatch muffler
- 90-91 CRX bodykit ?????'s
- Need help ASAP!! in middle of D16Y8 swap
- Coils or shocks and springs
- magnaflow exhausts
- What part is this?
- b16-18 oil pickup
- ww rs kit with SiR front end conversion
- *** Wanted 2000 Sir Rims ***
- Anybody using the Crane Cams ignition Cap /Rotor external coil setup?
- difficulty in swapping entire car harness from crx si into dx hatch?
- JDM B20b???
- d15b2 with a6 cam
- Mugen flare kit where to get one any pics
- Best Cat-Back exhaust for a 91 si CRX!
- Need Help in Pa!
- pics wanted
- did you drain the RAD before mpfi swap ??
- WTB Rear LCA for 90-91 si?
- wide body kit
- help please
- rear disk swap done
- how can i get rid of rust?
- would anyone actually pay 11,000 for this crx?????
- Swap Near Pics and Comments Needed Anything that would Help During B16a SIR II in a 4th GEN DX...
- need help ASAP. D16A6 problems
- b16a shuting off at 7k wtf
- Civic dx 89
- Distributor bearing???
- My car is clAcking.
- New Fuel pump for B16 swap into CRX HF? ITR Pump?
- zc throttle body question
- B16a for JDm b20b
- what are ur b18a/crx times in a 1/4 mile?
- need parts 88-91 crx si
- Urgent how to remove the CD player
- speedo cable loose??
- Off the Wall Timing after dizzy fix
- Jdm ef9 spoiler?????
- Highway speed sucks on jdm S1 tranny!!!!
- 91' crx SI gauge cluster question.
- My brothers ef track times
- o2 sensor replacement question for pre obd b16a for EF9
- Hydraulic tranny in 89 civic?????
- burning alot of oil
- crx to d16z6 v-tech swap ? i need help
- first pics of my rex si (56k i dunno)
- ...how do I remove/replace speedo cable?
- Pilot Bearing B series or in general
- crx b16a problem!!!!!!!!1
- brake booster and MC question...
- some help withheated 02 mod?
- _-*need advice*-_
- Comptech Race header...............
- whats the lug pattern on an 88 crx?
- HELP! pulled my dash and now i have 1 connection i don't remember where it goes!!
- code 13 how do i fix
- H22 or B16a in 91 civic hatch
- how much does a y8 mani help?
- Cam seal for the b16a?
- Anyone have a stock ITR intake in there crx?
- help stripping a rex
- how come my battery drains so FAST!
- ENJO mount kits
- Si head on D15 block
- crx parts for sale
- Seat Dimensions for 88-91 civic seat brackets
- B16 trans popping out of 5th gear.
- what to swap in my crx shell?
- cheap/ghetto all motor d16a6 questions
- 98 Civic DX Y8 manifold and GSR/TypeR TB!!
- Attention... this is the Owner Of Honda Havok Civic
- D16vtec, b18a???
- antifreeze problem????????
- mirrors
- Which header for B18A
- ? 88 motor in a 90
- LSD??? tranny???
- Anyone I could talk to????
- Received my Fastbrakes kit today...
- Went to Dyno 2 day
- b18 vtec valve cover on non vtec b18a?
- Some Easy B16 Questions
- Whats the mm measurements on 88 teg tb
- rear LCA
- Question about getting a exhaust for my Ef.......
- mounts dont line up on D15 swap
- what harness for b18a?
- Any Body Wanna See An AWD Crv-VTEC Turbo Crx Bad Ass???????
- how to wire this up??????
- what will compression be in my car if i do this????
- 1991 Honda CRX Si FOR SALE
- How many years do we smog?
- I have another project. *pics*
- Is 86-89 Integra throttle body same as 88-91 Civic/CRX Si?
- So I'm putting my pressure plate on and i realize...
- knock sensor???
- what do i have to do (hf 88 crx) in the wireharness to make it fit for a b18a
- Weight Differences
- Crx.. Si.. Where to go for 600$!?!?
- will a hf trotle cable work on a b18a?
- Look at this rex
- vafc install
- anybody with a b16 swap from hmotorsonline
- coilovers are not what I thought!!!! what do i do???
- need sum help!! Cars not accelerating to well
- Where is the Map sensor on the CRX Si motor?
- Solution to faded ABS black plastic parts, thanks to resource.crx.org guys...
- I need HELP!!!!
- axle problem
- Pre MPFI swap Qs (search disabled)
- ???? on shocks and springs
- New brake setup on EF/EE9
- Will a PM7 ecu work for a B16 swap.....
- car smokes on decel
- rear 4dr. handles on crx
- were to get B18c5 ????
- need info if u have helms manuel??
- Get this!!!
- where do you buy your parts online?
- What type of headers are you guys running on your ZC's ??
- Is this a crx fender? Can someone tell me...
- adjusting lights
- How to change pedal bracket?!
- What type of headers are you guys running on your b16a's ??
- oxygen sensor question.....
- What seats will fit into a 88 Civic Hatch?
- Do you have a helms.....if you do look here.
- 96 GSR Rear Discs Conversion, would it fit???
- Do you need to put loc tite on the flywheel to crank bolts?
- timing question....can SOMEONE help?
- crx Si engine.. would SOHC ZC ECU benefit?
- usdm b16a3 whats its worth
- d16a6 w/o wiring changes
- Odometer Swap Info!!!
- adding a sway bar on a 88dx
- Is my motor handicapped?!?! HELP!!!!!!!!!!!!!!
- Fuel Pump?
- 5 Lug conversion
- Have you guys seen these? EDM 155 mph Gauge Cluster...speedo
- getting my b20z ... what to do to it?
- ST Anti-Sway Bar Endlinks Install w/ Pics
- Prelude MC upgrade - Installation with Pics
- Homemade turbo on jdm d15b...
- Steering column bent
- how much can i get for my 91 si
- Spoon or Skunk2 strut bars for EF CRX?
- What should a ZC motor run?
- What's a good HALF size aluminum radiator for a CRX?
- Flowmaster exhaust any good?
- Woooot Woooot! 2 1/2 weeks Till 88-91 Civic CRX Meet in Pa
- cut bumpstop or not?
- Bigger fuel pump on N/A engine? Lack of fuel to my CRX...fuel problems
- bought a hatch yesterday, have some question
- gonna turbo my zc need help
- WARPING AND OVERHEATING..anybody experience Spoon calipers/ITR rotors???
- crank scraper for my D16?
- anti-theft tips
- trannies....
- still have issues with a code 14
- how to tell the difference between usdm and jdm hood?
- hood wont open!??
- b 18a swap not so smooth???
- before and after..thoughts/comments?
- looking for dc header....
- manual to auto tranny swap, are the mounts on the car the same?
- how do you tighten the transmission cable on the 1991 crx HF...?? ASAP!! please
- Domestic Turned IMPORT?! WHAT? Help a v8 head look at a CRX.
- b18c gsr engine??????
- crx or other car???????????
- Code 17 Vehicle speed sensor
- 96 Civic Common Swaps?
- 4 Swaps to do by next Weekend
- quick axle question
- Photoshop Gauge Templates?
- b18c4?? on ebay. a euro spec sir? is this true?
- Got new exhaust for my CRX. Opinions welcome, and wanted.
- Exaust
- 205/50R15 Falken Azenis on 15x6 GSR Rims, rubbing problems??
