Squealing - what is this
Old Aug 10, 2015 | 01:45 PM
whitef_'s Avatar
Default Squealing - what is this
I have a 91 EF hatch. Just put a fully rebuilt d15b2 in it and turned it on and there's a loud high pitched squealing noise. Thought it was the tensioner so replaced that but it's still making the same noise. Then I thought it could be the alternator belt but I took the alternator off and it's still doing it. Tried tightening and loosening the timing belt but the noise doesn't change. Then I spent 2 hours searching for a vacuum leak but can't find one anywhere. What could this be??
Old Aug 10, 2015 | 02:18 PM
whited's Avatar
CRX God
Default Re: Squealing - what is this
Go away or change your name.
Old Aug 10, 2015 | 02:19 PM
whited's Avatar
CRX God
Check that the time belt isn't rubbing against the cover.
Old Aug 10, 2015 | 02:27 PM
whitef_'s Avatar
The cover isn't even on right now, and dang that wasn't even intentional lol that's my Instagram name
Old Aug 10, 2015 | 02:34 PM
whited's Avatar
CRX God
Even the bottom cover us off?
Old Aug 10, 2015 | 02:44 PM
whitef_'s Avatar
Yup
Old Aug 10, 2015 | 03:46 PM
whited's Avatar
CRX God
Did you try taking off each belt and running it without them. (leaving timing belt on of course)
Old Aug 10, 2015 | 03:47 PM
4drEF's Avatar
Keyboard Humorist
Have you driven it at all?
When you listen to it, does the sound maybe come from the transmission side?
Old Aug 10, 2015 | 04:27 PM
whitef_'s Avatar
Yep, I only have two belts, timing and alternator and I took the whole alternator out and it was still making the same noise. Then I tried to tighten and loosen the timing belt and nothing changed
Old Aug 10, 2015 | 04:29 PM
whitef_'s Avatar
I haven't driven it yet because the axles aren't in, and it's possible but the sound is obnoxiously loud so I can't tell where it's coming from
Old Aug 11, 2015 | 11:42 AM
4drEF's Avatar
Keyboard Humorist
Could be that you installed the clutch wrong.
Old Aug 12, 2015 | 11:30 AM
whited's Avatar
CRX God
Can you post a video and some pictures?? I know question what sound of squealing it is now. I would assume it was rubber squealing.
Old Aug 12, 2015 | 01:41 PM
whitef_'s Avatar
I found out what it was, I changed the intake manifold gasket and it stopped. Thanks for your help everyone!
TehGhett0P1mp
Aug 7, 2008 06:13 PM
GSRpoweredSI
Jun 20, 2007 01:13 PM
