View Full Version : Honda CRX / EF Civic (1988 - 1991)
- oil catch can
- Changing hard fuel line to braided steel?
- jj's civic project thread.
- Cusco strut bars for the EF
- crx design
- tune
- leaking hatch
- E-brake light will not turn off??
- trying to get new motor
- My new Rex
- need price check plz
- Synthetic manual transmission oil ok to use?
- PICTURE REQUEST - DC2 dash in ef & 90-91 crx front end on hatch
- 91 civic si build
- Seat swap in CRX
- Which hose is this?
- 1989 Civic HB - Help!
- why are si models heavier than non-si's?
- crx
- sway bars
- 60-80 MILES FOR A FULL TANK
- EBAY exhaust
- idles on crx with SOHC vtec
- EBAY seats on the EF?
- New daily driver
- really lose shifting.
- Aftermarket stereo install kit: 90 Civic HB
- Expert Opinion Needed (Stroking a ZC)
- tpic request of ST 88 ef bracket
- Radiator mounts for half size radiator?
- check engine light
- sway bar sizes
- 90 civic just died
- New Paint (56k Take a hike)
- 89 civic 4 door project
- hybrid intake
- suspension opinion
- d17a2 into a 91 lx
- B16 Mystery Motor
- i am getting 70 to 80 miles to a full tank of gas
- How loud is a garret t-25 when it starts to spool?
- sohc 1.7 crank
- RHD SWAP
- Is there any 1984-1987 forums
- project clean the leaf collector EF hatch
- Repair manual
- Lubing E-brake cable
- what possibilities tranny with a d16z6 engine?
- Need Help. 91 ls seats into 89 std hatch
- piston slap!
- RHD SIR CRX with ITR 5 bolt Hubs
- FEW QUESTIONS
- d15b7 from 95 dx with dpfi beating 91 SI's
- an ONGOING crx build
- need help with ZC SOHC......
- supercharger
- pounding out the inner fender wells?
- wiring
- control arm
- ignition output signal
- DA master cylinder ? please help
- question for the ef/b16 swapped heads...
- st swaybar on hf. same swaybar as si? need anything extra?
- b18 TB to d16y8 IM
- Can I mate a GSR head with a B18a?
- pacesetter exhaust ?
- B tranny gearing
- obd1 problem
- (visibly unnoticible) weight reduction?
- hey who is down to connect my gsr cluster in my crx..
- help bogging really bad
- PIC REQUEST - 1/2 Rad Turned Towards Passenger Side. Whos Got A Pic For Me!?!?!?!
- How To Wire Your Fuel Pump To a switch?
- VTEC speed check
- D16z6 swap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Header & gas mileage?
- car wont start
- weird problem
- Crx Si Transmission
- tirez.net??
- Upper Control Arm (searched with no luck)
- b16 tranny
- crx
- Main Relay Not Clicking Help Please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- charcoal canister removal question???
- b16 or lsvtec?
- fuel pump problems!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- EF or DA search to buy
- Rims
- How to tell if tranny is from a ZC?
- s2 newb questions
- ECU Question
- Serious Stereo, needs serious alternator
- Fuel injector issue: plastic tip cracked, injector bad?
- SNOW DAY
- need help!! 91 civic hatchback sohc zc swap
- D15B2 performance parts
- D16z6 swap Now Car wont start!!!!!!!!!!!!!!!!!!!!!!!!!
- shaking in the steering wheel.
- How to know if your getting a Si Tranny?
- timing belt loose
- extended code on pm6 meaning easilly chippable?
- Seat question CRX =)
- Primer The Hood
- good web site?
- crx vtec leather seats on ebay. the ones that came in the vti
- coil over quest
- what exhaust system or muffler should i buy for my hatch??
- Weird vibrating/rumbling sound/feeling....
- propotion valve question.
- flowmaster on d15B2
- engine swap trouble
- trans question for noob install
- clutch replacement costs
- Wiring harness
- My car should not be this slow. (B16 CRX)
- do ebay CAT work please help
- car wotn start!
- CRX B16 Questions
- fast one.
- PACT Man finally gets a Project too...
- What OEM seats will work in 89 STD Hatch? PLease Help!!!!!!!!!!
- How to determine which engine with a quick look
- MPFI SWAP .. codes 4 and 16
- b16a question
- car just stoped starting!!!
- just bought crx rough idle cant keep highway speeds
- tranny locked up?
- hose hookup help...
- need some help deciding
- 89 civic si steering wheel
- In need of HARNESS
- will my turbo work on a b18c
- Lucas Oil Stabilizing Experiences
- HF head swap
- etelephone pole in reversefrom an EG to an EF? WTF?!?! (56k no no!)
- Custom Ecu tune??
- knocking noise from engine
- Rough Idle
- B16a OBD0, what EACV should be used?
- I have a problem please help!!!!!!!!!!!!!!!
- eng quest
- good deal?
- more suspension ????
- car rides like crap
- Need Proof, Canada CX Hatch got the D15B7...
- a "Stiffy" on CRX?
- B18a CRX Stalling, Help Please
- Skunk 2 short shifter question
- wierd problem/question
- New sleigh - 1991 Honda Beat (PP, not an EF!) - Lots of pictures.
- caliper and rotor question.
- fuel pressure
- code 5
- Side marker help
- Hondata IM gasket feedback and opinions???
- HELP!! MY axle nut keeps comming loose ???????????????????????????
- cars finally done
- civic weight
- d16 swap
- Will Mini rims fit on a CRX, what u guys think of these rims?
- Knocking in an 89 crx si
- Wiring my fan
- springs
- O2 sensor help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
- D16z6 swap with 91 dx tranny, clutch?
- Rain go away!
- Need help w/ crx cluster
- jdm ef9 bumper on USDM front
- Question about BAR
- CEL on after going over a bump
- how to put 95 integra guages in an 88-91 civic
- radio confusion - new to crxs
- 94 hatch rear disc conversion
- JDM EK9 civic type R pulley....what belt size?
- no mph please help
- 400 dollars later, heres my new ef
- convert p08 ecu auto to manual ?
- b20 v in crx
- car surges at idle :-( and cant figure it out...
- boosting how much PSI on Stock DOHC ZC
- CRX center console?
- EX brake m/c
- LS seats in 89 STD? NEED HELP?
- 4WD ZC
- which msd setup should i do on my B16a2???
- Running problems with civic hatch
- B16a axle issues
- How Much?
- Removal of Climate Control
- vafc help
- car wont kick over
- what do i need for this swap?
- Problem with fuel line Leaking, got pics...88 HF with 90 Si fuel tank.
- JokerX's progress pics on getting JDM D15 cleaned up and ready for my Crx
- engine mount question
- cable tranny interchangeability help????????
- Buying CRX Today - Quick Help Needed
- YS1 into EF8
- rear disc conversion
- ??what is the problem??
- CRX noob
- USDM FRONT LIPS
- Help ****Searched
- NEED help!! spark plug wire gaskets
- forum question
- please HELP!! electrical problems??
- Axles on 89 civic dx
- 240 for JDM BUMPER???
- Restoring bumpstrips
- New Want to say Hi. And ask for some help?
- code 20 ?
- need pic
- High idle on 87 CRX
- difference between HF and SI intakes?????
- license plate
- i need help asap!!! window problem!!!
- d16y8 wiring for 89 Ef hatch. Need info!!!!!!!!!
- info needed
- zc tranny or 88 crx si tranny on my d16y8?
- Seat/ sensor problem?
- Coolant Temp Sensor Question??
- seat swap
- anyone got stock exhaust pics for 88 rex?
- ls-vtec vs ls nitrous
- whats code 20?
- header question
- jdm bumper light screws
- What is a good top mount manifold for a b16 ef hatchback
- WTB: CRX SI 90-91 engine and body harness
- engine problem
- crx project pics
- The motor is in
- question about supercharger fitment
- my d-swap save the sohc
- no fuel no spark
- jdm ef paint schemes!!!!!!
- looking to buy a crx
- racing seat bracket questions...
- heat problem
- quick question about b16 swap
- single cam vtec help,
- Free and easy rust removal with sodium carbonate? Has anyone tried this?
- how to tell OBD?
- dohc zc ? what is the thing on the side of head on the exhaust cam and where to plug it in
- code 5 keep getting and car wont idle...
- Trying to get a CRX for dd
- can crx get you girls?
- Ignition problem, starts but sometimes doesn't; Help a brother out.
