Rod bearing question
Old Sep 24, 2015 | 09:19 AM
NWDyno's Avatar
Default Rod bearing question
Replacing the rings in my ef and figured I'd throw in some new rod bearings at the same time. So I got the color of the bearing sizes I need but when I go onto ebay/king/acl...whatever aftermarket size, it just asks if I want standard or oversized bearings.
What is the thickness of standard bearings? The crank has never been turned but still curious as to what the thickness of these standard rod bearing size is.
Old Sep 24, 2015 | 01:34 PM
jlicrx's Avatar
Default Re: Rod bearing question
for D-series
Rod bearing thickness by color:
Blue 1.510-1.507 mm 0.0594”- 0.0593”
Black 1.507-1.504 mm 0.0593”- 0.0592”
Brown 1.504-1.501 mm 0.0592”- 0.0591”
Green 1.501-1.498 mm 0.0591”- 0.0590”
Yellow 1.498-1.495 mm 0.0590”- 0.0589”
Pink 1.495-1.492 mm 0.0589”- 0.0587”
Red 1.492-1.489 mm 0.0587”- 0.0586”
Old Sep 24, 2015 | 02:40 PM
NWDyno's Avatar
Yeah I got that information. I'm wondering what the thickness of the standard sized bearings? When you go on for say ebay, and look at bearing kits they come as standard (or oversized) I'm asking what the thickness of the standard is?
Old Sep 24, 2015 | 07:37 PM
v4lu3s's Avatar
RTFM
you would need to measure them or call teh manufacturer. Standard is usually sort of close to green. if you want to go with the colors you go to honda.
Old Sep 24, 2015 | 08:15 PM
NWDyno's Avatar
thats what i was looking for. id rather just order from honda. thank you guys
Phoenix5
Honda Civic (2001 - 2005)
Dec 23, 2013 11:07 AM
boydsc33
Mar 1, 2011 03:27 PM
TurboKneeGrow
Mar 18, 2008 07:22 PM
bunnyrabbit
Mar 29, 2004 05:20 AM
CivicNewbie
Jan 24, 2002 10:42 AM
