View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Will a b-series ac compressor fit?
- need help with timing belt
- Signals Don't Work
- D17A2 in place of a D15b2 ?
- EF color question
- CF lip
- stock head built block...ok?
- i need help with my 89 hb si
- P08: B16 OR D15B?
- cramming a V2 intake into a CRX
- HASport EFB2 Kit questions?
- ?s for my new b16
- Power steering on a 91 crx si?
- Wiring Issues
- Green dust/mold all over interior of CRX?
- how well will a 88 crxwith ZC, turbo and maybe nitrous run
- HELP!!! Need help w/ B16 1st Gen TB's
- Please welcome our new Moderator, EL Vap133
- crx keeps frying main relays
- d15b8 in 91 si ?
- brake caliper dilema (integra upgrade)
- Anyone w/ JRSC GSR/ITR?
- Exhaust question?
- need d15b2 BADLY
- rex pics
- 91 crx w/ b16a and many mods... baseline DYNO graph
- Pics of my CRX Rebuild
- who has shipped a body kit, i'm looking for a rough estimate on weight and dimensions??
- I need help with a minor exhaust problem!!!!
- Anyone know the difference between 89 CRX SI / '90 Civic SI wiring harness?
- is this a good deal ? legit ?
- need help wire up my 4-wire oxygen sensor
- where can i find the iab solenoid valve and the the knock sensor
- I was just wandreing how much a crx si shell is worth????
- auto ecu on a manual car
- CRX MPFI ecu manifold confusion
- What do I need to complete a b16a1 swap into 88-91 CRX/Civic?
- What Fuel Pressure w/ PG7 on sohc set up?
- does hasport make diffrent motor mounts
- Took my hatch for it's first drag strip passes in 2 years tonight...
- ecu questions.....
- Looking for opinions on an LS tranny in the CRX
- Injectors not working any ideas
- going from turbo ZC to b20 supercharged
- HELP! How do I remove paint from carpet?
- jdm b16a will not start........wiring problem
- Radiator Porblem (WTF?!?)
- Difference Between Greddy MX and SP2, Sound and Performance?
- std clutch
- pics of SPRINT HART CP center caps/stickers?
- Wheel Offset...
- Brake Lights Won't Light up
- stiffer motor mounts?
- Putting a 16v Si head in an HF???
- price of jdm crx fog lights??
- crvtec
- Will CRX taillights fit a hatch?
- idling problems b16a, typeR mani and jg 65mm
- ECU codes
- Civic/CRX Front Bumpers Swappable? (Filler Peice)
- 13 Sec all motor B16 CRX vs B18C5 Delsol
- what rear seats fit in the EF?
- Air conditioning woes
- need help with code six
- D series auto to manual wiring
- 12 piece wide bodied black widow kit install and paint. 56 k beware
- crx bone stock - at what price?
- Integ GSR seats in 7th Gen Civic?
- pg7 in my 91 Si (Help)
- Another "whats my car worth" post
- performance rear drum brake pads / shoes?
- What wiring harness for LS swap into EF?
- Got some money to spend!! What should i do????
- need help wiring up VTEC on Y8
- where is the thermostat? 89 DX 1.5
- 88-91 civic hb exhaust
- yea every on tell me what u think of my civic
- Sedan Part Numbers
- moved to CO idle seems to have problems?
- civic seats in crx?
- What's he doing?
- i think i lost my car
- my car is really pissing me off...
- who know how to fix code 20
- Parking brake light stays on... wtf. Anyone have this problem?
- will this ecu work?
- Ignition Problem(s)
- Overheating Crx ;/
- What happens after you drive over a 10inch thick metal pole?
- Brake Problems
- rough startup and black smoke
- TRanny swap question
- crappy idle, wont idle if it does.. checked everything. searched for days
- importparts.com
- 12v Igniton wire locate in picture
- wheel baring question!
- ecu question
- Need some help with B16A V1 into 88 hb
- Spoon VC-5E ECU
- Quick ? about a 95 intake manifold with injectors
- Shinchan CRX Type R
- Black and White CRX Si Seats?
- My header is peeling??
- Hard cornering + high revs + low on gas...How bad is that??
- shifter falls to the floor
- Wanna Carbon Fiber Body Kit on my CRX Si '89
- WTF is wrong w/ my CAR?!!?! Aarrgh!
- Sensor question??
- anywhere else that sells EF9 front conversions??
- anyway the Wings West RS kit would fit CRX if it's made for hatch??
- obd0 ecu code?
- 1991 prelude seats into 1990 CRX Si?
- FS: B series MUGEN cover , carbon f hood, Roll bars, more goodies: LINK inside
- yay or nay...lsvtec for $1200
- Loosing antifreeze but don't know where it's going! help
- camp1320.com swindler
- Turbo Std
- Removing FREON Tool?
- Need help just did a swap and car won't start
- will 88-91 CRX carbon fiber hood also fit 88-91 Hatch ???
- how to ?
- questions about JRSC on b16's
- turning hf motor to dpfi
- will 91 civic si axles fit non si models?
- Olde with noob questions.
- Will DA Struts + Springs fit on a 89 Si?
- ef hatch w/ b18a swap...wiring plug Q's
- ys1 tranny question. need help asap!!
- turbo SOhc won't rev !!!
- quick ECU pin question, need a few replies to confirm
- How do i wire up my 4 plug oxygen senser to my 91 civic si
- b18a1 vacuum pics
- 1992 civic si front suspension on a 1989 std-hf
- mini me help!!!!
- SWAP S2000 gauge cluster in CRX it is real?
- 90 EF hatch...What else works (interchangable)
- 88 tranny + clutch on 91 flywheel?
- vtec pressure switch problems
- d16a6 head on d16z6 block? obd1 questions?
- a6 intake maifold
- The CRX and Civic Si's run on the same engine I take it...
- I need help!!! 90 civic
- What do i need to do to put a 89hf in a 90dx
- Need Help with buying lowering springs!?
- nitrous
- 1989 Honda Civic
- Cylinder 3 dead..
- about how much for Tein HA's for the EF?
- z6 intake manifold
- what ZC dohc tranny fit on????
- dohc zc half shaft
- d16z6 swap, need help with some stuffs, coolant switch?
- No spark, tearing down the wiring harness
- Cutoff switch crx..?
- How do we get upgraded from a trial user? n/m
- anyone swap dash on your EF??????
- cluster question
- How to swap?Steps?
- 89-91 SI and DX L3 tranny the same?
- Just bought a 90 civic std for $400
- Just bought a CRX have question?
- more B16 swap Q's
- INTRO
- Complete Z6 Swap In 90 CRX si help...
- sohc zc wtf ?
- CEL 21. Vtec solenoid! Help. b16ef
- engine install problems
- what plug is this for?
- OEM CRX/Civic steering wheel and S2000...
- Hood fitment problem.
- Tie bar for 89-91 same as 88?
- YEAY! My car finally lives!
- Extra plug on wire harness
- F/S: CRX lowering springs.
- help with a fuse blowing problem /walbro pump
- SAFC with d16a6 and chipped PM6 ECU?
- PLEASE: Few Suspension Questions, Need To Know Stuff, save me money
- Need Help On Geeting My Distributer Plug From Si to Dx
- Help with code 9?
- 90 dx civic - 4 lug to 5 lug conversion? Hard?? Anyone? Anyone? Bueller?
- apexi vafc wiring for a pm6
- building a dohc zc was wondering what parts i need to get from what cars
- teg cluster in 90 DX 4dr ?
- Can't Poll yet, need opinions!
- DOHC ZC = Pain in my ass. pls help any one
- odb1 or odb0
- clutch not disengaging
- b18a1 into 91si....dist question
- transmission studders into gears.
- b series motor mounts
- need advice/info 14b turbo +d15b2 90 hatch
- Engine light on
- motec tuners
- b18a1 trouble
- Max bore for d16a6
- How do I check my 5 speed trnas fluid?
- Any ideas for a console/cup ho;lder for my 89 DX?
- any ef's for sale in So Cal...i'm desperate!!!
- Help!! How do I drill out the rear tranny mount bracket for a B18c swap?
- Got a tach cluster... Now what?
- Electrical Dash Problem, Tach/Turn/Gas Guage...
- double DIN in a 90 civic 4dr ?
- Crx idle is low when a/c is on? IDEAS?
- overheating on highway
- is si motor quick
- Running rich ideling high
- wheel play (front radius rod?)
- Newbie interior questions....
- Speedometer issues
- Braking system
- removing carpet
- My bud claytonsmith needs to make an offer on a 90 si hatch
- What SECURITY Protects Your EF From Scum *everyone chime in*
- Tools Needed To Strip A Crx?? Special Parts To Remove??
- 20 days still nothing... WTF?
- Removing axles via LCA : A pain in the ass.
- during tuning, my sohc zc made 118whp.
- changed timing belt, now car wont start
- gsr turbo
- What do I need to know about the CRX?
- b16/vtec question
- wrong manifold?
- Lots Of Questions
- lookin to do an LS turbo set up in a 4-door ef civic soon!
- mpfi HELP
- more stupid questions...
- 89 crx si ignition timing HELP
- Plastic IM gaskets re-usable?
- Tach hardly works
- what can you do to make a 89 civic si really fast with a sawp
- what are these hoses by speedo cable on a b18 for?
- CAn you turbo a 89 civc si with out blowing you eng?
- dose anyone have a full gsr sawp for sale in the calgary area?
- how do i use stock speedo with b16 swap
- Can't seem to find problem
- Tranny Codes .. How to tell what is what ?
- replacing feul injector o-rings
- talk me into a buying a crx
- Sway bar differences
- brakes for my REX
- RSR header problem. need help dont know what to do.
- Injectors:peak and hold or saturated?
- CRX problems please help
- How to identify a ZC tranny
- adjusting distributor
- rear gets slippy @ 160km/h
- HELP!! where do i relocate this plug?
- Quick mini me question HAVE SEARCHED
- have the 3rd-4th shift grind blues!!!!!!! (need parts)
- trailing arm bushing question
