View Full Version : Honda CRX / EF Civic (1988 - 1991)
- timing belt issues
- code 17-speed sensor?
- mpfi complete
- O2 sensor
- b16 starter problem
- just got back from the track:( (kinda long)
- PM7 Stamped All Over ZC What ECU To Use
- Where to buy Hatch lift supports?
- alright, search search search.. now help me find a mint condition complete ef8 front end conversion!
- 88DX & a B18
- FREE engine in NewYorkCity!!!
- idea: CRX hatch - No glass, just carbonfiber. video rearview
- obd 0 to 1 harness
- Any1 have stock side skirts 4 92-95 CivHatch?.
- OBD0 or OBD1?
- speed sensor????
- Anyone want to defend this guy?
- Carbon Fiber Altezza's on 88-91 hatch. PICTURES?
- CRX to Civic and vice versa part compatibility.
- SOHC vtec into a 87 possible??
- Tuner Showoff Oct. 26th in Atl for charity!
- zc hood/ sir hood
- anybody order a ef front end conversion from honda motors online?
- Does anyone have the old style b18 hasport motor mounts for their 88-91 crx??
- seatlle people.. need your help
- Anyone have pics of a burgundy EF?
- What do i need to pass California state ref with 89 crx dx and a b18a motor????
- help neg. battery terminal
- fair asking price???
- Anyone have some 90-91 crx corners?
- cheap bumpers and FREE hoods!
- Cheap but good CRX header?
- FL import shops
- Stuttering
- part time job opportunity
- i need a complete d16a6 head ASAP
- Help.....Crx idling low/surging, car running hot and sometimes will not start.
- best mods, swaps, cheap stuff etc. for Rex?
- Cable Tranny Adjustment
- a/c fan for crx w/b16?
- Removing Exterior Molding?
- What is needed for a japan spec R ITR swap
- Exedy clutch/flywheel choices
- Chroming my valve cover and I.M.? where to? Seattle area or online?
- V-TEC & Turbo?
- Money Money Money
- HF longblock w/ Si Head
- ecu code help: code 22-vtec oil pressure or vtec system malfunction
- ZC with ZC ECU
- 88 integra ingectors
- bent valves=new distributor???
- 87 pg7 does it work
- is my crx gearbox LSD or not ??
- Type R suspension.
- EF Hybrid clusters?
- need a stock ring gear for a b series tranny!
- front bumper and head
- O.K. Ive seen ef's w/smoked headlamps. Anyone done there corners?
- I got a 1991 Civic Hatchback for 700 bux :D :D :D :D
- Part question????
- few Q's about b-series parts
- where you put feeler gage for valve adjustment?
- altnator removal help!!!
- Some ?'s on 1st gen Integra D16A1
- Mugen ECU upgrade for PM7?
- question about engine swap
- Zex nitrous question
- error code 7 on pm6 ecu
- Should i replace my engine mounts?
- spark plug wires
- anyone ever fix there rust ridden wheel wells?
- quick question
- how about this under your x-mas tree????
- Brembo Rotor Question?
- CRX power mirrors and power retracting?
- can I run a 90 teg ecu?
- Little Red CRX is now even smaller - wrecked
- alittle help on my smog problem ?
- MY Civic
- I need a 1.5L engine for my 95 cx...Jap or used?
- jdm cluster
- disc conversion
- New Crx Owner
- Need some pics of DX/HF roof
- Car wont start!!! Please take time to see if you can help.
- Which struts for my CRX
- Need your opinion
- aftermarket parts question
- about front turn signals????
- VSS - 1st gen CRX B16
- What bumpers are these?
- idle problem
- wtb: y8 or z6 head
- I need CRX Splash guards...
- Just did a compression test....
- which cam?? i researched it....
- Choosing a Engine......
- Question.....About cams? I searched
- clicking noise when i brake
- Looking for the ECU Pin out for a 89 CrxSi??????
- 1st Gen B16a iming belt question
- need help on center console
- Rotor in dizzy keeps melting! Help please!
- integra and crx sway bars?
- some problems with the rear brake caliper
- How-to change floormat color? Help
- blower motor
- looking at rebuilding a b16a
- supercharger in crx
- JDM rear bumper installed
- 89 Hatch parts on CRX
- Mount points for different engines?
- V16 engine???
- running error codes?
- skunk2 exhaust
- o2 sensor question
- Wiring the D16a9
- anyone use the koni coilover sleeves before?
- Apexi mount pics!
- Injectors or fuel pump?
- dual carbs on ZC
- Spring rates for Tokico springs (from their kits)??
- Gauge Cluster-REDLINE
- bay area meet
- 88-91 ecus.....
- What's the gas mileage for a stock 91 CRX-Si?
- Anybody running an Under-LCA style exhaust in an N/A EF??
- How hard to turbo a ZC?
- I traded brake pads for head.........what a deal!
- wondering 1/4 times for 4doors EF
- Apexi Groupbuy
- 86 Civic CRX and a D16a6 Turbo........
- anyone using a teg LS map sensor on an EF??
- WTF ever happened to the Spoon replica lip project???
- Part time job opportunity
- stock SI exhaust manifold
- what kinda oil filter?
- car dies at hot starts, or a couple mins after cold start after cam install
- Just picked up a 89 CRX Si!!
- DPFI to MPFI. what to do???
- buying a ef-8 conversion without rad support?
- Headlights are ON all the time?????
- ttt
- N20 b16 crx
- my swap
- Where can i find a Kombat Body kit
- supercharging a b16 in a 91 crx si
- Engine code
- b16a internals
- test pipe inquiry
- 161822??
- Best B-series tranny for LS/B20??
- 1990 civic dx dpfi help
- Has anyone swapped their HCP mounts to HAsportmounts?
- 90 crx si with b18b want to go to a b20
- SOHC Blocks.
- hesitation problems 88 crx si
- Best setup for sohc zc on crx dx??
- h22 in a crx
- Rex Axle question for the wise?
- anyone have the STANLEY front turn signals??
- car running like sh@#!!!!!
- has anyone been to Sears Point Raceway (Infineon raceway now) on Wednesday nights???
- Anybody have to go to CHP for their salvaged car?
- '88 CRX (ls/vtec) si for sale
- questions about 88-89 and 90-91 guage cluster
- Toronto members, lets try this again...........
- Why are my tires getting chunked on the sides?
- Wanted B Series Clutch......
- Sears Point Raceway
- d16y7 Block with D16a6 Head? Comp Ratio?
- Attention Toronto, On, Canada Members * October 17th Meet "ROLL CALL"!!!!
- I am at my wits end!!!!!! code 22 on a pr3, no vtec, someone help.!
- winter prolect. b18bturbo how hard in a old CRX/Civic?
- ZC fuel pressure
- FS: 1989 Honda CRX Si $1700 obo
- ZC bogging
- Odessa CRX.. ran into a 300ZX.. you on here?
- what's the li nk for crx w/ b16?
- Need to Change Cluster Bulbs
- HELP with SiR bumper!!!
- crx seats in a hatch
- CRX/Civic by night
- New "olsskool" shop open in Arizona!
- What could be the causes of my terrible compression.
- ZC Tranny Code?
- more torque or what?
- headlight cleaning
- 90 cluster w/tach into 89 hb ????
- vacuum diagram for 89 dx
- Changing my CAT
- disc brakes
- Hasport Billet motor mounts for the 4th Gen Civic...
- Anyone going to Firebird raceway for Sport Compact night this thursday?
- NJ, PA,DE Cruise Night!!! King of Prussia PA Thurs Nov 7!!
- boring??
- $350 LS motorand ECU, EF swap parts--chicagoland area
- Question about installing a Skunk2 intake manifold on a B16a CRX Si
- cranks???
- Timing belt jump a tooth or too
- Celestail Blue CRX
- Questions regarding EF turn signals. . .
- WTB: radio wiring harness (male side) 88 civic
- DSM SMIC is in!!!
- Which Throttle Cable?
- Are there any front bumper lips available for the ef hatches???
- code 9 and smoking engine bay
- Just bought a 1989 CRX HF
- Installing a Auto Meter tach!
- which a-pipe??
- Grrrrrr! When will I be set FREE???
- aftermarket EF front lip?
- ok i found more on my problem....
- Have 3000 and a dream of 13 seconds or lower.
- LOL. How do I answer this CRX Email?
- 91 CRX Si
- im building a 89 crx
- Canadian Sir..
- I have a stupid question.
- 2wd Wagon suspension any different?
- hey can you help with this?
- ***maryland meet***
- transmission problems in 5th!!!!!
- ZC lsd
- OBD-1 vs OBD-0 Distributors
- CRX sunroof problem (no power/bad motor?)
- how to wire h4 bulbs???
- Do I have my o2's right?? B16 (Big pic inside dial ups beware)
- Dustboot for Koni Yellows/GC Sleeves with 88 LCA
- did i get an automatic ecu for a b16?
- 92-95 Civic lip on CRX
- eryone I'm just curious.....
- Brake upgrade
- any sights for old school civics? like 1976?
- Anybody have an extra ecu for zc???
- 88 CRX rear disc brake conversion
- how much would a b16 crx hf weigh, and other questions?
- Suggestions on a good Fuel Rail/pump combo
- pr3 Vafc wireing help
- Scraping noise when I drive
- battery tie down
- any differance between auto and 5spd LS longblock?
- looking for an ef, some questions....
- taillights CRX/Civc HB
- FINALLY solved skunk2 manifold probs..pics..
- EK9 dashboard in EF (plus engine), possible?
- code 43 HELP ME PLEASE !!!!
- 88 coilovers
- will eg mirrors work on my hatch?
- b16a & b16b
