View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Tranny problems
- Well, my project car is done!
- OT: i just bought a gsx!
- vtec question
- Brake Lines to upgrade with rear disc swap?
- zc valves
- 97 gsr cluster going in
- Car is squeaking like a mouse!
- B16 02 Sensors
- Toe in problem after RD conversion
- Front and Rear Interior Pieces???
- R.I.P.
- The right spark plugs......
- type r short shifter
- is this release bearing ok?
- ECU code question
- how is this for a EF/b16 header?
- electronic load detector!any ideas?
- Feedback on Zum01
- The beater finally runs ...
- Anyone here with a supercharged engine?
- Spark plug specs
- could someone run a Carfax on this shell?
- spark plug removal...
- Do you have anything from an intake for sale?????
- thinking of buying a 88-90 Civic HB...need info please
- Suspension-handling problems
- I have a carbon fiber fiber images hood.
- jdm side moldings
- Seat swap
- Si motor
- Suspension Build-up
- short ram to CAI question
- removing dents and dings
- how do i get access to back of door panel?
- JDM rear tail install
- Question on ES bushing set installation...
- b16a, what to look for?
- Cant get axle in.
- oil cooler???
- Flywheel Questions
- crx 90 swap
- anyone selling just a crx sun roof panel? Bay area preferred!
- Does anyone have this?
- Might Be trading the 89 HB for a 92 HB
- 1991 crx si from germany
- MPFI in a DX hatch???
- nova rexers page? any comming up meets??
- B16 running slow after Dizzy change
- who can find me a d16y7 cam???
- bad service BEWARE
- Is this a good deal on a Civic Si?
- ZC tranny, and Si final gear.
- If you remove A/C what about second fan
- First Time @ The Track!
- Does a 89 crx si have an alternator light?
- can i put on new performance shocks, but still keep my old 150k springs?
- Do any OEM honda lips fit on 88-91 CRX?
- Quick question about my Y8 head - how tight do I tighten these bolts??
- 88 Civic SE hatch rad
- help....h&r sport springs..
- 1st Gen CRX Engine Swap Questions Help!
- Parts Car in East Tennessee?
- newest pic!
- apexi n1 exhaust
- Civic/CRX Cat
- CRX Front Speakers
- D16A1 Pistons
- time to give up on car :(
- flywheel out
- help locating this part!!!!
- va/dc/md...need a distributor A.S.A.P!
- tranny q's
- Help....need help badly....
- What is the motor D15A6 or D16A6 ??????????
- XWhich EF?
- value cover 911!
- charcol canister
- Rear Disc Conversion
- mount kits b series in 88-91
- mapsensor
- di6z6 converters- i have a quetion concening the driver side motor mount
- I think I may be detonating help me trouble shoot
- Will SI throttle body work on ZC swap?
- Vacuum lines with ZC swap?
- Pics of my 1985 CRX SI Autocrosser (E-Prepared)
- B16A pistons...
- valves knocking....
- ZC cams?
- need a diagram/pic of crx/civic unibody
- what is an HF
- Ls-Vtec motor blow up
- Sfmu install?
- Best tire/tire brand for EF's
- FINALY....My Junk Yard Turbo Build Up page.....
- ZC oxygen sensor; will Si work?
- will a itr tranny work on a b16a cable
- CRX seats in a Hatch?
- HELP! I failed smog twice...
- master cylinder brace
- Why is my rex so bouncy???
- Noob w/ center console ?
- need cat for smog cali area!!!
- need help
- meet in md!!!
- d16a6 firing order?
- 88 crx si b-16 driver side axle
- ZC Camshaft regrinds comments???
- aem cai into a crx w/b18c1
- green hatchbacks
- What color wire should I look for to wire something to 'ignition'?
- D16Z6 Wiring Harness q's.
- wrapping my header
- tranny case??
- Anyone ever stripped their CRX? got some questions
- what size exhaust on d16z6?
- Seat swap 1gen to 4gen
- I take back my previous remarks ......
- chipping pr3 ecu?
- Swapping ZC and Tranny.
- Anybody ever have a broken hood hinge?
- Which Would You Choose?
- How difficult is this?
- Has anyone ever registered a JDM vehicle?
- how to do a mini me swap?
- props to J spec
- what head and cams
- Anyone know where I might find a jdm double din stereo bracket for my crx?
- hmmmmm............
- Death of a CRX
- Driving CRX in the winter? Body precautions? General info needed?
- VIN on motor???
- My car is smoking alot....here are the symptoms
- cv joint??
- please help
- 1rst gen B16A valve lash same specs as B17A?
- dx - si conversion
- Anyone getting Spammed from Hybrid-motorsports.com?
- Helms manual questions
- Who knows where to get turbine turned to ball bearing?
- car won't start - main relay?
- I need help getting a rust free crx
- buying a crx...
- 1 piece headlights
- DSM 450cc injectors. How hard to install?
- How do you adjust the Ingall's Camber Kit?
- D16A6 needed!!!!
- color code of wires for 91 crx si
- its almost done:)
- Ball Bearing??? 16-14
- si cam into std
- ZC tranny!
- big plans big questions
- adjusting valves.....how much?
- How to build the perfect motor
- getting the yellow out of head lights
- just did a motor swap and wtf???
- VIDEO!!!.....me doing some ass kicking at HS drags....
- where do u et LS BLOCKS
- fuel injector resistor box
- Will this Set-up work?
- 99-00 civic si cd player in 91 crx hf?
- need opinion on selling price for a CRX
- Camshaft upgrade
- nos??
- 87 teg TB...will it work???
- car starts and then dies
- No more rice for me!! I'm going JDM/DFH style!!
- Va/Md/Dc area Looking for a motor!!! stock si!!!
- how many liters of oil in Si tranny??????? 1.9 quarts is how many liters?????
- apexi dunk?
- How bad dose nos mess up your engine?
- radiator hose help
- car won't start
- please help me quick car died while driving and now cranks but no start!!! any ideas???
- how to adjust my fuel pressur on a b16
- Some times I wonder.....
- Ai yah! Muffler's got a hole in it, need a low-budget fix!
- Next set of mods for noticeable power gain
- HTH do you get the crank shaft pulley off????????
- Best engine for 90 Civic HB DX? (Auto, yes, auto!)
- T-belt inspection
- high comp and nitrous?
- any1 here using 92-95 (EG) forks to fit newer struts in the front?
- How do WW Mid-Wings or even JDM Mid-Wing attach to the car?
- Lifetime Alignment places?
- help with swap?
- im getting pissed w/ my car
- EF squad or are there any EF's that meet anywhere?!
- Looking for ZC Timing Belt Cover
- Tailights and dash light.
- best way to route my 4 wires for my b16 swap
- jdmhondaparts.com, respectable?
- CRX-ZC code 5?
- Crx Body kit (T. O. peeps)
- MIni-me mid swap problem
- code 7 and code 16, need help
- CRX weight reduction
- hood problem HELP!!!!!!!
- Quick lug question
- differential rebuild - should i?
- 4th gen with B16...
- Question For You 91 CRX'ers
- traction bars ready
- d15b7/d16y8
- hydro locked
- O2 pin location on ECU...
- CTR Pistons in a 1.7 DOHC VTEC
- The gerbils have died finally..........Now what engine do I put into my '89 CRX HF?
- My car runs! and drives!
- Anyoone /run PanaSports on Their EF/ED? Found Some Rota Knock-Offs!
- Bouncing Tach needle
- Do you guys know of anyone who sells Type S pistons?
- strapped my car on the dyno today.....
- Stupid Questions!!!!
- crx header on y8 engine...
- emission testings in maryland, help here
- My mind is made up!!! H22 in my EF will come soon!!!
- what are some good universal mufflers
- 4g wagovan rt4wd
- Wierd car not Firing/starting problems????????
- D16A6 injectors
- 88 CRX Dx dpfi vtec
- Anti Honda Club... a photo journey
- EF CRX Si lips? What, where, how much? (pics wanted)
- b16a
- d16a6 turbo project
- my crx threw a CEL today
- need help finding problem
- How do you deal with your leaking hatch?
- my weekend
- will 91 hatch fender fit on my 89 CRX DX?
- 88 civic questions
- want to make a head swap!
- Deer ran into the side of my car! pics
- cant take my tires off..please help
- Any one interested in turbocharging an EF for cheap?
- Tight suspension bolts!
- Magazine articles about efs?
- Headlights turned on = reverse lights turn on????
- using only middle head gasket?
- stock rim size for crx?
- Couple parts questions
- Help me! Took off emblem...need some help
- Anyone running a Thermal R&D cat back on their CRX?
- Low idle will not go away!
- Where to get a B seriers motor???
- Anyone wanna help? WTF IS MY FUEL PUMP!!!???
- installing shocks
- can i make these fit? need response!!!
