View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Search came up empty- anyone have Rear speakers on 88-91 hatch??
- ZC questions? Mini Me ?
- Finally getting an engine....MAYBE!!!
- Help with Carfax pls!!! Trying to find out if I'm buying a rebuilt car?
- ecu question
- need engine, but which one??????
- Need all info possible on installing an b18b in 1st gen crx si!!!!!!``
- both DX's have trouble starting up sometimes....
- offset for 16 inch rims in crx?
- Want to trade my x integra.
- motor swap guide?
- how much can the stock fuel pump in a dx take?
- Hello, New EF member.
- gsr exhaust on crx????
- Cheap Auto Zone muffler???
- More Problems
- bumper lights on rs bk
- help im stressed
- I need some answers here people!!
- B20 or H22?
- Strut bars really necessary for drag racing?
- Consequences of a ported head ?
- B20 or H22 in an 89 Hatch?
- How much did you spend on your B20 swap???
- Anyone got a 4G si Harness? Need one asap!
- why wont my d16a6 head some off.
- Integra ECU PG7
- crx good or not
- I cant adjust my idle...and car is sitting at practiculy 0 rpms???
- Anyone running Skunk2 cat-back exhaust for 88-91 Civic HB? Pipe size in mm?
- crx clear corners.
- What do you think of these rims?
- Car won't start. Please help.
- CRX tranny question. please take a look.
- What to do about LSD ????
- lsvtec piston q
- d16a6 rt4wd tranny performance parts
- will y8/z6 exh manifold/header fit on a a6 ??
- b16a1 valve adjustment as i type... need some help
- 5 min crank pulley removal
- All motor ZC
- Has anyone ever hit a curb?
- wanted!
- 92-95 si engine..in 90 civic std?
- bumper lights.........
- ZC engine
- D18Y8 intake/manifold fit to CRX 88 Si???
- Code 9 B16
- upper ball joints
- help 1st gen B16 in my hatch I broke a valve cover stud and need to find out torque specs
- Stock Side Skirts
- New pis of my car
- 89 CRX Si to B16A swap
- Civic Sunroof
- pics of K1's on hatch?
- Y8 Intake Manifold
- This Sucks intercooler not fitting on ZC turbo :(
- Snapped off front wheel stud
- 88-89 Integra pistons???
- timing belt broke help me please
- where can i find this stuff?
- What injectors to use with 92 b18a1 ?
- anyone make a black 8mm spark plug wire?
- still need info
- 89 crx + 91 rear disc / 89 ebrake lines? will they work?
- all motor d series
- b16a engine error code 9 and 19
- alright uh i have no idea.
- headbolts?
- Place racing crossmember finally in
- ZC Piston Replacement?? Help
- very litle oil in my engine after trip.
- Some quick Q's on engine build --->look d series or mini me experts<---
- just making sure on oil jet squirter ?....
- B18A swap questions
- What injectors have a Higher Flow Rate?
- more axle help plz!
- new Civic Coupe
- Ever hear of a Civic Value trim?
- civic ex brakes: compatibility w/other parts
- Where can I find a JDM distributor rotor?? I'm stumped!
- fuel system problem
- what valves to use for b16a1?
- How difficult is it to install your own shocks/springs?
- serial number on b16a1
- d16z6 timing...
- Distributor problem??
- CRX w/JDM B16A swap question
- D16A1 DOHC? ???
- COLD AIR INTAKE = bad for rain and snow???????????
- HELP, ZC Throwin Codes, strange/loud knocking/tapping from cam gears...
- for you road race crx racers...what's the best brake upgrade?
- 1st gen b16..how to install skunk2 manifold?
- ZC Head Removal
- 88 DX CRX engine in 94 DX coupe?
- big brakes and bushings, where to buy?
- annoying whistling noise coming from throttle body
- going to a junk yard today
- Car won't start.
- I got a leak....need help fast!!!!
- MAP sensor difference between CRX and B-series motors???
- Major Motor Probs HELP!
- has anyone ever attempted the 4 dr power window rails in our cars?
- installing a JDM front end, professional installation??
- Clutch shudders when engaging
- correct offset and tire size for 15 inch rims.
- Every Item I need for D16A6 changeover?
- Fun ? for all you Honda Motor Gurus... Making Power with HONDA factory parts...
- What shift linkage pin and other misc. parts for 91 b16?
- crank pulley
- car wont start!!!!!!!!!!
- distributor rebuild?
- HELP, major brake problem on 88 crx si
- question about transmissions...........need reply ASAP
- nos
- Overheating problem.... HELP
- My driver side door is annoying me...
- JDM front end
- MAP relocation! (firewall to TB)
- exhaust, piping intake manifold wiring harness
- How much ?
- Overheating saga continues? Lights on = H! Help me? Weird probs.
- JDM/EF 88~91 CRX..different LCA?
- And the stock DX front anti-sway bar is...
- New to the board and have some questions on my car.
- More Rear Disc Brake Questions!!
- Dc Install = 02 SENSOR Code
- argh!! these axles are pissing me off!!!
- crx trade
- Toooooooooooong!
- SLICKS??? base motor?? to
- GSR seats not fitting in my 90 crx si
- Need some insights
- nirtous in my 88dx???
- ***best sway bars, and strut bars for crx??***
- hybrid shift linkages question ~
- how to remove valve cover?
- where to get all red taillights for crx?
- tires ?
- my car is running funny. please help!
- alternator rebuilds
- WHERE can i RENT and IMPACT gun in the LAX area!
- Jamming flywheel to get CRANK SHAFT OFF.. HELP I HAVE 6 HOURS!
- mount problem please help.
- Wonder how much kit at front and back cost on civic H/b ´97
- By installing a Camber kit...
- can I get IM off a 91 EX to do MPFI swap?
- Screw CRX's!! Let's have a Central FL Hatchback Meet!
- how to get rid of cai "whistling"
- where to get ecu
- 90' Civic LX questions
- Can we use a 90-91 teg brake master cylinder?
- Selling the 15x7 rims from my CRX (TSW Stealths)
- SFC-VTEC controller
- So Cal Hybrid Dog Meat(New Thread)
- FPR or FMU wich one right now.....
- Distributor Problem b16a
- A/C with home-made hf mainfold!
- Woo Hoo! Finally getting Intercooler!
- Turbo Questions d series motors
- 89 Crx SI conversion to Integra four wheel disc brakes...
- HELP! - B16 idles funny. 1k-2k jumps and 2.5k hot idles? WTF!?
- skunk2 manifold on 1st gen b16?
- dx tranny for cheap ???????
- how much for an LS swap???
- CARB Legal parts
- zc-turbo questions
- Info on First-Gen CR-X and Civic Si Hatches PLEASE?
- has anyone had b16 tps probe/codes?
- where can i find some jun racing videos
- broken wheel, sw388
- How to hook up VAFC on 90si
- front crx suspension.. .
- Mini - Me. no joke How hard to do right.
- Setting for SOHC cam gear
- 88 springs diff. from 89-91?
- zc engine
- the transformation pix of my baby finally!!!!
- What's the deal with Fields and MAP check engine lights?
- ZC hood
- my car is for sale or trade
- zc pros help, i need a crank angle sensor.
- leaky hatch
- i need to find out what this is worth and if it is worth it for me
- 88-91 civic / crx tracton bar crosmembers avalible
- How to adjust the window in the door?
- How to put Y* intake manifold on d16a6 motor?
- Leaky Doors
- EGR Valve
- Exhaust Help!
- My review of Honda Motors Online
- fuel pump and distributor ???
- Anyone have a DX -ecu and cam?
- How to take off crank shaft pulley? HELP ASAP
- CRX & Civic body swaps...
- car idles funny
- I got an idea...
- question about JDM EF front
- HEAD WORK / NOT that kind!
- rear disk price
- dynomax ultraflo welded, any good ??
- Yellow Cab Vs. 88 Reliant Hub Cap
- Rare 1st Gen CRX Item on eBay
- couple of VSS questions
- pr3 with d16z6
- ok swap in but having problems!!!
- how hard to convert EF headlights to H4??
- replacement x-member
- engine quirry..........
- Boostin Ef Cars
- How do AEM Cam timing gears increase HP? thanks
- flywheel inspection plate
- "L" bracket for b series swap??
- HF crx, d16 swap using HF ecu?Help
- How many times have you pulled your head off your car in a week
- easy question, under-hood fusebox
- 88 DX Corner lights
- 100 octane for emissions?
- Anyone ever heard of import-avenue.com?
- 88-89 rear bumper vs 90-91 rear bumper
- Problem at Cold Start
- HCP Shift Linkage
- How to replace a thermostat! Help me out.. websites.. anythin!
- D16Z donor car
- 89 civic hb bumper fit on 90 civic hb?
- forced to go rice....
- 88 to 90-91 differencesin the body?
- NEW vision for my EF
- Lets talk about Intakes....
- 90-93 teg axles pulled apart at the inner joint
- does anyone know how to adjust the headlight height on jdm headlights?
- ZC engine code
- jumping rpm????
- 89 CRX Springs On A 87 CRX
- motor is in! (but not wired)
- Are '88-'91 CRX mirrors all the same?
- TOTALLED CRX ALL INTERIOR , PR3 ECU, and other parts!!!!!!!!!!!!!!!!!!!!!!1
- fpr hides my fule
- how hard is it to put a front bumper on?
- '88 civic tach wire??????HELP!?!?!?!?!
- How much should i pay?
- ???Clogged Fuel Line???
- clear corners
- OK so I got a 88-89 EDM cluster, got a question.
- head swap............
- J's racing
- 1988 Civic - Was There Ever An Si Offered?
- Holley Integra Fuel Pump
- link inside for parts that are for sale
- CRX exhaust......Cat back or Axle back???
