View Full Version : Honda CRX / EF Civic (1988 - 1991)
- High Flow CAT: crx with a gsr swap and suspension.
- EDM guage cluster
- Help...91 a/c system compatible with 88 civic lx?
- Cricket-like sound from the engine at idle
- Need Help.. Car stop running
- Just bought my 2nd Honda.
- fuel pump problems
- what kind of ecu for dpfi to mpfi swap....please help
- so my jdm front end was stolen off my parked crx in san diego...
- obd0 to obd1 engine harness??
- Official EF/CRX Jacking Points
- OMNI POWER coilovers
- OBD 0 to OBD1 need some help
- do i need this for my swap?
- Headlight / Lightbulb Question?
- Energy Suspension Steering Rack Bushings
- need help on replacing cam seal...
- Help on this crxwith a 1994 vtec swap PLEASE REPLY
- where do i jack up the car from the rear
- Problem?
- Minimum wiring required for D15B2 w/ecu
- Anyone ever put a d16a6 head on a sohc zc block?
- DX to OBD1 Swap, No CEL,no start
- EF9 Radiator swap problem?
- PM3 clearance question?
- b18 timing belt issue
- D16A6 and D16Z6 intake/exhaust bolt patterns???
- Are the rear crossmembers/steering rack's the same between the hatch and sedan?
- Changing an o2 sensor
- Throwing many codes at different times first 15, then 13 and 5, then 15 again, and now 1. 91 dx ZC d
- complete harness swap? from ecu to engine...from a 92 si into 91 dx
- 89 civic si ecu fuse keeps popping
- who makes the best thermostat for the ef?
- Need help on swapping in a b20 into a crx
- axle question
- PW:JDM and their "SiR" hubs...
- Sputter at 3100 rpms??
- What defines the need for the injector resistor box?
- 2 broken rims and a possibly bent spindle
- new to 88-91 civic/crx.
- spark plug/oil?
- vtec hookup question
- Replaced fuel filter and now its leaking slightly? What happened?
- Need help ASAP!!!
- Which one pulls better?
- Fuel injectors
- Can i do a block off plate for FITV ?
- Is this a weird problem? Alternator related
- ST rear sway bar on 90 crx
- turn signal clips
- Removable V/C baffle
- Another CRX fuel pump Question
- half size radiator?
- Just bought a 90 civic hatch
- Reverse and Tag light issue
- how much will it cost to get my window to function right?
- crx 1990 uk v-tec, (creeking from front drivers side corner????)
- Yellow tint bumper lights
- engine issues
- My friend has a crx
- exhaust helpp
- 91 civic 4dr project
- *exhaust length*
- JDM pole switch
- what can i do now?
- ZC SOHC Non-vtec version question.
- Water mixed with oil residue from exhaust
- EF (dx) upgrading brakes from DA (gsr)
- ? New to honda's just got a 88 awd civic wagon
- MPFI/OBDI rywire conversion harness problems
- changing clutch.. ran into a problem..
- new to honda tech!
- Suspension Help?
- wheel stuck
- crossmember differences
- jdm front bumper fog template?
- driver door doesn't lock/open
- Swaping a stock 91DX 4DR for a B18C help!
- PIC Full Coilovers... yah or nay?
- Wanting To Start A Gas Saver Project - I Need Advice Please
- itr in crx. injectors shooting out gas
- D15B1 to D15B8 civic base
- Swapping b16a to b20b - got some questions, need help asap.
- no power to main relay
- are ef civic door panels and crx door panels the same
- OBD0 B16A injector O ring
- are ef cvic hatch drivers side windows the same as a crx?
- 91 CRX wont start
- Ebay Motor mounts?
- Is the ECU test harness needed for an 89 civic SI?
- iacv noise
- Road trip
- which cables
- B-series axle questions
- ys1 tranny problems !!!
- info on a honda
- ef seat base...
- I need your HELP
- gsr cluster in EF hatch. Searched.
- Hello
- dashes the same?
- Sticky Gas pedal
- innovative mounts/hasport linkage.
- A Few CRX Si Questions
- ef9 with 99 ls swap problems?
- what size head bolts???? need help!!
- I'm back...yay
- 1.5L, 1.6L differentials
- tps problem
- Removing Door Panels
- hey i got a 1991 honda civic ef sedan for sale..
- I gave up on the search for a crx si.
- 91 civic dx running problems
- apc muffler or OBX Twin Loop Muffler ?
- what ecu
- car sputters and cuts off
- A few questions about my engine(featuring pics)
- honda-tech wont let me log out
- D15 help
- cutting stock springs?
- Radiator
- Fixed my popping suspension!!! Could be your problem too (camber kit)
- Help tire wasting fast !!!!!
- Where's the best place to mount my oil pressure sending unit for my gauge?
- cv axle question
- will a 89-91 civic si distributor work on a 1.5 civic dx i think
- ef9 cluster
- brake light reverse light and turn signal all at once?
- Transmission fill plug
- What is wrong? Why is it doing this?
- EF Civic/CRX Transmissions
- Gas Tank Size ???
- obd2 d16y7 into crx
- door dosen't open from inside or outside. WTF?
- LS VTEC 88 EF, BUILD NOW BUMP LATER.......need some help
- sohc vtec vs non vtec...
- 88 civic hatch
- first step forward
- d16z6 swap transmission problems please help!!!!!!!!!
- help identifying my sohc head
- help me figure out what this plug is for.
- sloppy linkage
- Need help quick! Can I sauder my alum. rad?
- b16a started, backfired, and now wont start
- crx invidia cat back exhaust
- no gas flow.heeelp
- b16a cable transmission Q's
- 91 4dr ls
- B16 trans mount problem
- 89 crx no start
- Help me identify the purpose of this part (Rear Engine Mount Part)
- need help with motor swap
- how do i shut up the seat belt bepper???
- gas gauge not working!!!
- Ef-Fit
- Transmission for 400+ WHP build in Crx,Other Questions
- how accurate is the oem tach?
- Cable To Hydro?
- Front Crossmember Bushings. Are they worth replacing/upgrading (polyurethane)
- flywheel/pressure plate won't clear tranny?
- what seats will fit
- Need Wiring Help With B16 Swap ASAP
- help!!!!!!!!!!!
- Rear Quarter Panel Removal
- need template for side markers
- problem replacing lower ball joint (upper ball joint)
- O2 sensor ?
- Which intake for a GSR CRX?
- nClutch release bearing return spring keeps breaking... Cause?
- Where to find d15b vtec solenoid??
- building up D16A6 (disregard DX to SI topic)
- taking a look at a CRX tomorrow tips?
- CRX missfire - tune up?
- help!!!!!!!!!!!!!!!!!!!!!
- the best swap
- Loud pop....like gunshot
- Master cylinder.
- d16z6 adjustable cam gear
- 1990 Base Model Hatch Engine options?
- mini-me swap question
- 91 CRX MLS Head Gasket - Does this look smooth enough?
- EG/DC beaks rear lower tie bar on CRX?
- Tandem Valve Control Solenoid
- PG7 ecu
- I need help with my swap
- Dizzy
- ef honda si rear seats good condition
- code 7 TPS bad
- i got a new 91 hatch looking for an engine????
- fuel pump wiln't prime need halp?!?!?!?
- KL-14 and KR-14... what hubs are these??
- wiring question d15/16
- No Brake Lights No horn - God bless Honda tech for the EASIEST FIX EVER
- d15 vtec head on d16a6 block
- Quaife Quick-Ratio Rack and Pinion...
- 1g crx hf stock aluminum rims?
- NEED HELP EF8 JDM FOG LIGHT INSTALL
- 90 Civic Ex axle replacement (where to buy)
- ? WHICH PISTON & RODS SHOULD I DROP IN CRX ?
- need help!!!...just put the b-16 in my car having problems
- Ef went sput sput dead! Whatcha think I should do?
- B-Series Sensor Confusion
- BIG PROBLEM Cant find original car owner to sign release im worried HELP!!??
- Help with radio wiring in 88 crx to a jvc universal plug
- 91 civic si brake booster compatability
- Getting code 43 - Fuel supply system error, what should I do?
- Automatic Second gen B16a sirII??
- No need to set Ignition timing - fact or myth
- JDM Glass roof CRX!
- CAR IS TRIPPIN
- tokiko and suspension questions
- b series pistons
- need help!!..just put B16 v-tech in my crx...
- steering wheel
- What's up with my brakes?
- b16a swap onto a Ef sedan wiring help please!!!
- need help! crx b18 question!
- 91 Hatch Starter...
- engine bay
- advice help
- Help a fellow EF'er
- OBX LSD for a 90-91 Si tranny?
- tokiko blues for any EF....
- Si radiator in a crx
- short shifter problem....
- Spark plug blew out of the Head
- Ls V-Tec Head Gasket Leak
- dpfi to mpfi b16 help me out
- fastbrakes 11 inch size from hub cebter to outside of caliper?
- engine mount/ CRX jdm
- Timing Cover Missing How to Set Timing?
- D-series SI 5spd
- ef si rear seats for sale good conditions
- b16a swap into 4door EF. Resistor box questions.
- 89 civic - dashpot soleonid diagram confusion???
- Engine Diagnostics Cylinder leak down test, idle adjustment, also Camber issue
- what color for my mugen?
- b15 / d16z6 minime
- lsvtec plugs? quick easy qustion
- Front Shock Fork info needed
- spring question
- D15 Starter Clicking
- ecu light ????
- wiring diagrames
- Piston set for D15B
- 90 Civic Hatchback Engine Swap, Performance Parts, ect. HELP
- blox lca's and stock si sway bar
- need help!!..just put b16 in my crx.....
- Need a little advice
