View Full Version : Honda CRX / EF Civic (1988 - 1991)
- bouncing idle problem
- crane cams b16 stage 2...good?
- ARE ALL NON OBD INJECTORS THE SAME????
- Advancing Ignition Timing?
- u-turn cause clicking sound ..help?
- CRX Si brakes same 88-89 and 90-91??
- best alarm
- tdo4 stock psi
- need to order an oil pan for my B16a
- does anyone have?
- whats a better deal??
- whats better?
- Did 5 speed and mpfi converstion now key wont come out
- ENGINE SWAP! B16A1 into 91 Civic DX
- VIS carbon fiber hood latch question
- Rota Wheels
- Where Can I Find?
- Which Timing Belt?
- Who here has power locks?
- Do CRX's lose kick after 200k miles
- Who in Northern VA area sells Hawk brake pads?
- DOHC ZC downpipes
- suspension question...can u guys help me out please??
- question concerning wiring harness.
- How Tough? And how much $$ To swap Dual Point to MpFi?
- I didn't know Enterprise rented riced out CRXs...
- want to check timing, timing marks aren't visible
- What 2 do?
- H22 into EF hatch - need info.
- b16 ef's launching techniques?
- obdI conversion (inside harness) anyone do this?
- FWD drifting vid, EF doin' the dayum thing!! Straight from the mouther land . JAPAN
- please help..... my car is dying
- My most useless mod yet (ECU LED)
- d16a6 turbo
- anyone tried a delsol lip on a usdm crx?
- Never Used Tokico Shocks
- Who's got this monster civic?
- Best exhaust for EF?? whats your opinion...
- Glass Top for CRX
- 89 si sunroof?????
- 89 CRX oem head light Vs 91 head light
- Anyone have a built up ZC for turbo?
- parting out some parts for my 89 civic si
- CRAP! I need some front engine mount bolts :( and a wiring diagram
- Dyno;d teh CRX.. impressive for a honda!
- FS: CTR Intake B16 B16a
- MPFI swap possible on an auto?
- diy icebox on crx/ef?? anybody
- 90-91 DX CRX vs. 90-91 CRX SI brakes
- CRX lot for sale
- Mixed up stories need truth about Distributer Q's
- were to get siR skins to hid B18A1
- Wings West RS CRX kit
- 92-95 mugen lip fit on a 88-91 HB
- Mini-Me probs
- what will work ?
- Need advice on street car suspension
- car idle?
- 88 civic help
- ring terminals for grounding wires
- H&R Race Spgings
- using timing light on '88 Civic 1.5L hatchback?
- Bushings are turning to dust!!!
- Rebuild question
- steering collumn or rod and pinoin need help!!!
- Code 1 - Oxygen sensor
- 1991 Crx parts for sald cheep!!!!!
- Need to know this, so i can tell my buddy whats up
- obd0 to obd1 harness
- 4000rpm idle
- my std hatch can i use the name brand cat back exhuast companys offer on it?
- How Do you Wire up a EF non SI with the 2 extra Injectors???
- pm7 ecu W/ SOHC ZC VTEC
- 1990 Crx DX Brakes
- problems distributor or timing ?
- Seat brackets wont line up...bolting alternative??? Please help!
- Will the A/C from a 88 CRX HF swap directly into a 91 Si hatch?
- Radiator Hoses
- tranny
- That Spaghetti snarl of Vacuam lines on this 86, 1.5
- tranny situation
- b18/b16 dilemma...
- 3 inch cat??????
- Fair asking price for a 90si with greddy turbo + suspension goodies?
- EXHAUST FOR 91 HATCH
- zc spark plug cables
- advice please on building up my engine
- b18a wiring harness
- I need some help ASAP. PLEASE LOOK!
- who here has experience shipping bumpers?
- HID in CRX!?
- turbo zc list
- project: dc2-r trunk wall bar...
- fs:
- link to my WTB: vss cable and clip
- Running on 1 cylinder after motor swap
- vacuum diagram
- Code 86??
- ZC DOHC Timing
- how much does it usually cost..
- CEL comes on intermittantly....??
- HOW MUCH CAN I SPRAY?????????????
- Need help putting this together
- DelSol Seats In CRX
- No O2 Sensor. Possibly Faster???
- DX sway bar v. HF sway bar
- Door hinge messed up (I searched)
- Header Headache, What's your ZC dohc Header?
- CRX b16 in AZ for sale 3,700
- CRX Lowering Springs.
- Crx Short(er) shifter? Want a shifter that the knob actually sits lower ??
- Headlights!
- oil in dist cap....
- Engine Swap
- Thought you all might get a kick out of this
- SiR gauge cluster?
- Swap questions
- Where can I get a IACV
- did search couldnt find a good answer can EF's use a Crx Si lip?
- DA to ED trim question
- looking for someone to burn me a chip
- VW owner looking into ef honda platform, any advice?
- Should i remove my heater?
- Engine running funny
- ZC LSD for D16a6 ?
- Side Exit header for Civic or CRX??
- What do you like better? (Cams)
- Pics of my all motor crx engine...enjoy
- code 10 intake air temp sensor?
- TICKING/BUZZING noise near my feet area... I'm going crazy!
- Battery Braket
- DOHC ZC - D16A6 crank pulley question
- anyone have a 80-83 civic cvcc manual? i need help!!
- Will this hood clear a ZC?
- 1gen with triple or 3 beam head lights check this out help please
- Mini me help (injectors)
- Will a complete CRX passenger door fit inside a crx?
- Look at this vid of some mofo getting owned, or why my civic has seat belts
- mpfi swap goes vroom vroom
- HELP!! Hood Wont POP!
- Need to know what im getting into here
- Where to buy 14" rims under 12Lbs.
- Found a CRX For Sale
- wiring differences b16a v b16a2 in an 88 crx si
- coilovers..... dropzones? bad/good/horriable?
- any black JDM front ended cars with amber sidelights?
- Car acting wierd...
- Mini ME in 88 Std hatch (Searched) Dizzy Question
- Need a Recommendation on rotors/brakes!
- The Woes of an LS/VTEC CRX owner.
- WHERE CAN I FIND AN EXHAUIST for my 1St Gen CRX?
- Lights and blower pulsing WTF?
- What brake calipers are same as SiR calipers?
- Civic SiR rear disc question
- Anyone with a Crx ever use a 92+ Short ram without moving your battery ???
- Quick question. Do CRX oem rear speaker mounts fit Civics?
- Mugen Limited-Slip ZC Differential???
- will rota c8 15x6.5 + 38mm fit my crx?
- y8 swap qeustion, will an auto y8 throttle body work on a standard intake manifold ??
- carbon fiber interior trim peices
- Cam gear with a mini me???
- 2G DSM Fuel Pump Install in a 1989 EF Hatch *PICS*
- Wheel spacers?
- Special Edition CRX Color?
- opinion on price, ls motor
- b16a in 89 si
- I need to see a MUGEN spoiler pic
- $600 tranny
- Steering Rack Question
- clutch? tranny? linkage?.......I need help
- how much lighter are 88-89 doors than 90-91?
- battery light on???
- UPDATE....Stolen rex in AZ.
- Tail light poll (CRX)
- Funtion Lever for Climate Control Broken- HELP!!
- 93 LS AUTO IN A 86 CRX?
- head lights on a 1 gen crx
- NEED HELP ASAP PLEASE ANYONE!!
- 88-89 Civic Hatch Projectors???
- Need help finding STOLEN CRX and parts
- B16A PROBLEMS HELP
- AUTOMATIC Tranny, How many Litres of fluid?
- Code 3,5, and 10 after d16z6 swap please help
- progess on my crx
- can a SI TRANNY be bolted onto a standard motor using the stds axles?
- do 94 and up front brakes/knuckles work on an ef with a cable swap?
- What would be better to build all motor car out of
- axles wont go in all the way! zc crx swap
- swappin d15 for d16z6
- s1 tranny?
- cheap five lug conversion!
- Anyone know a good website to buy d16a6 rings for my pistons?
- HELP< CAR NOT WORKING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Mini me is done. Car started, but my tach isnt working now. Someone help...
- how much would you pay for this crx w/these parts on it
- 2nd Gen integra seats in 88-89 hatch?
- engine picker mounting points
- Searching for rims
- alternator problems
- Cable - Hydro Conversion D-Series???
- might have a big problem (suspension related)
- fit ona civic front endfront bumper ?
- I NEED AN 88 LS COMPUTER!!!!!!!!!
- Key Lock...
- WTB 1988-89 CRX HF
- F22 fourth gen? anyone have any info
- tie bars?
- 88 CRX springs, will 91 CRX springs fit?
- LS VTEC
- Finding a Torsion Bar
- any differences between civic/crx PM6 ecu & rt4wd civic PM6 ecu? (90-91)
- I have a zdyne but.......
- Thermostat?
- OFF the wall JDM Questions
- cheapest place to get spoon-like mirrors for EF
- 90-91 Civic Dash clusters, do these all have VSS function in them
- Crx Mount Removal
- Building a d16a6 questions...
- Need help! How do you get the inner door linings back into the doors????
- 89 Si gauge cluster
- Newbie help
- Who has racing seats in thier '88-89 Civic Hatch
- ls axles
- MK3 GTi Lip on CRX pictures
- 4 dr dx 2 si gauge cluster
- HELP!! Swap troubles with ECU
- JDM one piece headlights for EFs
- bored throttle body
- 91 CRX Bumper Question..Please help
- can i fix a plastic radiator???
- Shifter question ...
- Can i use 94up rear integra disc brakes on my 90 STD?
- d15b6 with d16a6 head.....
- What axles for ZC tranny?
- what parts do i need to do this swap???
- Taillight lens
- Anyone have MAGAZINE articles about ZC or other Honda engine swaps?
- 85 crx speaker sizes?
- I need to know whats wrong with my hatch?
- zc cali reg
- Engine stand mounting locations for D16A6?
- ZC - timing cover hits the hood on EF hatch?
- Crx ef8 front end from passwordjdm.com
- tach install problem
- HELP PLEASE..... DPFI TO MPFI gone wrong!!!!!
- ***PROBLEM! HELP tech heads
- Question bout installing a dc sports 4-2-1 -> EF8
- PIC REQUEST: concord blue civics!!!
- new drums?
