View Full Version : Honda CRX / EF Civic (1988 - 1991)
- nessesity of LSD
- dead battery already
- Socal Anyone know where to find
- Dumb ? about post count???
- Tie rod bolt, which way ?
- Anyone here use a GTECH ???
- Why Lexan And Not Fiberglass?
- Breather Chamber?...
- Over Heating?
- Crx Stolen
- Buying my LS swap today
- Transmission Info
- Compressor replacement: should I replace receiver/drier, expansion valve, ect..
- how much could a d15b2 go for
- vtec controll help
- Is there any pre '88 crx's...
- i have a problem my 4-1 header doesnt give me enough room
- can you guys tell me what my car is worth?
- Anybody converted to an inline fuel filter?
- Anyone got some good info on wagon suspension? rear sway bar maybe..
- Best Stock Radiator....???
- Bigger cams? Power increase?
- Installing a D16Z6 but I need a computer
- gsr master cylinder
- DC Sports header For D16Y8 on D16A6
- b18 cams
- ignition coil's
- What other OEM fuel fiters can i use (EG/EK/DC.......)
- What company makes LCA's for CRX's?
- 87 CRX?
- still have an axle question
- Rear speaker pods
- motor mounts
- Where is the oil jet on the SOHC VTEC head?
- Having trouble with my swap
- front brakes tomorrow, any pointers?
- rear suspesion wont go any lower?
- 1986 CRX Si B20 Swap
- what am i doing wrong with replacing my front brakes????
- Will these parts from an eg fit on a ef?
- man i screwed something up
- Grinding noises; 90 civic
- stuff for sale
- Problem with distributor
- Roll Cage question
- Emission testing
- DOHC ZC: ECU QUESTIONS'
- question for hondata users, with with the launch control option
- Who Knows How To Adjust D Series Vales?
- hatch struts
- 1987 Civic head gasket replacement, 3-layer fit?
- Rings gone?
- Help needen with axels for B16A2 swap...
- Need help wiring Vtec
- thinkinng about what shouid i put in the crx !!!
- no start!! HELP!!
- 88 clutch swap? and fuel pump
- THIS IS INSANITY AT ITS HIGHEST!
- head gasket replacement
- gsr swap into ef.... GSR IM= what throttle cable?
- P54 del sol ac bracket
- 90 Day project UPDATE! Port N Polished
- HELP with buddy club
- Joing the CRX Army 88 Si
- ALL CRX EAST COAST DRIVERS
- 90Civic makin some grinding noises...
- CRX CRISIS
- this is strange?
- crx with mini=me set-up
- Opinions: Which is better SOHC or DOHC ZC?
- approx how long should it take to change 1 set of piston rings in the first cylinder on a b16?? in a
- 4 grand for a motor... whats the best??
- CRX Quarter panels new....WHERE can i get them?
- E) and i forgot to tell the guy at the motorcycle shop how big of a gap it needs so i was hoping ya
- pricing on a crx...
- JDM Clear Corners on EF9
- Anyone Ever PopRivot Sheetmetal Under The Car?
- boosting stock d15b2 with d16z6 head
- Injectors Clicking? Never heard of it before
- CRX Quarter Panels new....where I can get them?
- crx cat
- thinkin about turbo... dohc zc
- Engine Swap question
- Overheating in traffic???
- Canadian 4DR civics question?
- EMERGENCY EF guys help FAST.. doing swap right now!!!
- suspensin q's
- b18a swap question (axles) (ps: i did search but couldnt find)
- Help me with my seatbelt
- Need help removing pistons
- Are Brake Pads all the same for 88-91 Crx? Will the fit any other EF's ?
- crazy idle
- code 10 14 after mpfi-and mini me
- New problem....loosing oil like crazy
- 4x4 civic
- OBD2 to OBD0 Conversion
- EE8/EE9 hod
- Progress report
- Civic/CRX upper control arms the same ?
- The lack of Air Conditioner is killing me.
- s80 or y80 tranny with LSD...
- hydro tranny in crx what do i do.............
- How much does it cost
- does any one know where to get a fiberglass one piece front end?
- whats up newb here
- CRX Exclusive Paint code?
- air condition conversion costs; r12 to r134
- where to get parts for a dohc zc
- need help fixing my windows
- C&R Radiator Install Complete *FIXED PICS*
- I also got a new toy wOOt wOOt
- Is this worth fixing, or am I just beeing lazy??? **PICS**
- 90 hb water leaking problem
- Sohc Zc (non vtec) Valve Lash Spec Help
- Engine help
- CRX interior
- slight hesistation and bucking at 2000-2500 rpm need help
- MPFI TPS
- Alignment problem...... a little advice needed
- Need Help with car boggin
- what kind of price should i ask ? 91 crx dx
- Passenger side cv shaft on a CRX B16A1 engine
- planning a b16a1 swap
- what does code 19 mean for a d16a6?
- stock 90 civic hb standard help
- Clutch Question!!
- 92 dx spindle/knuckle on 91 lx 4dr? will it work?
- LS or rex si
- My new crx
- just checking if i have everything for B18C1 swap into 90 crx si...
- What causes power windows to roll up/down slowly?
- Code 14 woes...again...and again
- quick swap question.
- HELP! Need a B16 Cable Transmission! ASAP
- Bushings
- rear crossmember
- ls swap wont start
- climate control in your crx other then stock??
- Radiator Fan Relay
- AXLE PROBLEM!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?
- Here's a wierd turn signal problem...
- throttle body to fuel injection?
- 88 HB spoon mirrors
- Can anyone verify DA carpets in EF Hatches?
- 93 Civic LX Intake on a 88 CRX DX?? Need to know if it will fit.
- hf ecu on a d16y7
- axle problems in my 89 civic dx hatchback with a 90 crx hf motor and tranny
- locked keys in the car
- engine / trans grounds ... missing one?
- door open beeper WHERETHEFUCKISIT
- crx swap wiring problems
- swap's done, car won't start (searched)
- No oil pressure on rebuilt d16z6,HELP!!
- Exhausts (sorry I know its been done)
- Crane Hi-6
- Vss Sensor????
- Handbrake Light help!!!!
- 89 Civic Hatch Condensor Fan Relay....Where is it?
- how to control boost on a built in waste gauge? turn to the left or to the right for more boost?
- best place to find rare jdm parts
- Seat Belt Buzzer - Need to disable
- offical niagara meet n10 post
- Engine Flooding?
- Cleaning up my engine bay!
- d15 and d16 head's the same?
- body gaskets
- BORDER 304 speed!
- vis carbon fiber hatch for crx
- Ran my b16a CRX vs. friends 97 CX hatch, with new b16a2
- Advice For Possible Repair Of Blown Headgasket?
- Adding more suspension travel...pics!!
- my crx fmic
- window on ecu ?
- Coolant Temp switch question
- What to do next........
- busted tranny...shift linkage not able to secure to tranny!!!!
- mods
- obd2 distributor compatibility
- Differences in EG and EF
- Is this a good deal and should i do it?
- Difference between obd0-obd1 distributor.
- Boosted Question! please help!
- RUST! it gets you all the time!
- "Shaved" side moldings
- another before and after post
- Need help please look...
- Here's some pics of my turbo crx project
- tranny on a zc
- CEL... code 4 (crankshaft postion sensor)
- B16a Swap All done but Bad Ecu???????????
- 90 Hatchback Si with a GSR swap what intake do i use?
- Crush washers, who else sells them ?
- i don't think my b16 had a woodruff key in the crank pulley.. ne1 got a pic?
- How to enable the v-tec for JDM D15B and what ecu
- will a 205/60/13 fit my stock crx wheels 13x5.5 I think
- can you explain this
- b16 axles *Quick Question!*
- 90-91 Crx Si Clutch onto a 88-89 Crx Si Will it work?
- help with head gasket dowel pins
- odd sound come from eng.
- crankpully help asap (long)
- Converting automatic PR3 ecu to manual...
- can my b series swap have to long of axles? becaus my wheels wont roll.....
- tranny bad?
- anyone ever seen the ef factory audio console?????
- About to upgrade some of my suspension, need to check something.
- Which 13" Drag Wheels will fit over 90-93 Integ. Rotors?
- type r valve cover
- B20 head Vs. B16 Vtec head.
- DOHC ZC vs. D15B VTECH
- Thermostat Plug for B16A
- ZC recommended oil
- replacing rings with block in car
- Flywheel ?'s
- CRX OWNERS! I Need HELP, I NEED A FUSE BOX DIAGRAM FOR 88 HF!!!!!!!!!!!!!!!!!
- Great compression, but still burning oil HELP!!!
- Odd Suspension Problem
- Pillar Problems
- Black and wiht crx?
- 91 crx HF w/92-95 jdm clock?
- Engine progress...(56k modem warning)
- how much is the ef jdm rear seat worth??
- obd-1 into 90 civic Si
- GSR V2 CAI with b18a/d16y8 intake manifold.....???????????????
- I need help
- Weird vacuum problem in head
- What Clutch should i get for a boosted c-rex?? Act 6 puck or 4 puck?
- How much boost can a stock 92-95 dx engine!
- CRX EF SiR Front End Conversion on 1988 STD Hatch??
- quick question to confirm swap
- FS: ROADRACING PURPOSE.CRX91SI.LOTS OF MODS.SEE SIGNATURE.
- b18b1 swap ?
- H22 in a 88-91 crx
- New axle now no brakes
- si seats with tears.... seat covers?
- How do i know what kinda starter i have???
- 88 - 91 crx power steering?
- What OIL PAN fits a JDM B16A1??
- question on first gen crx
- Whats your INSURANCE on your CRX/EF?
- H4H....I give up, want to upgrade to HID's.
- hasport or hcp shift linkage question
- JDM Auto Air Conditioning / Does anyone have???
- need some advice on damage done?
- what are must haves for b16 swap?
- Radiator Removal
- Who says are cars aren't collectable?
- Raising suspension, more clearance, 1987 Civic wagon 4wd
- I NEED HELP WITH ELECTRICAL SYSTEM
