View Full Version : Honda CRX / EF Civic (1988 - 1991)
- seat harness install help
- Nintendo car?
- Eh? sensor? not on a d15b7 but on a d15b2
- Hatch issues...
- a little play in the hub
- Car Died on the way to work, Checked known causes.
- Car Died on the way to work, Checked Know causes.
- pics of stock arm rest
- I have a d16a6...interchangable axles?
- tans convertion
- 91 ef problems
- swap bars
- cleaned crx EGR valve and now car is idling with a putt putt sound?!
- my ED9 to EF8 build
- EF Sedan exhaust question
- B16A2 in a CivicSI NEED HELP
- OEM Honda part pros, PLEASE HELP
- 97 b18b swap
- HELP! vaccum diagram or pic needed
- weird idle issue?
- b16 swap code 16 fuel injection
- Will JRSC off of d16y8 work with a d16a6?
- Idle/IACV issue
- unique starting issues
- Driving and my crx died
- help with tranny id whether its usdm or jdm and chelp find clutch to fit
- intake manifold porting????
- k-frame help
- Need some Advice HELP!!!
- Half radiator help!
- idle problems
- Weak vtec???!! ***FIXED***
- rev gadge crx
- Wiring Issues
- crank angle sensor
- Help help 88-91 eibach anti-roll kit sway bars help *****please**
- which is the right K&N filter replacement?
- IACV Issue
- Civic Si smoking - need opinions
- crx swap b18 or b16
- change bumper support?
- Will a civic wagon clutch cable work on a 91 civic sedan
- how to diagnose ignition swich problem?
- Headliner?
- 89 crx finder ?
- B16 B18C header fit B18B?
- What intake CAN I use?
- D16Z6 Question
- question?
- Will J1 Tranny Fit?
- axle problem few Qs here need to know ASAP PLZZZ
- How do I open my 91 CRX hood??
- Stutter at 4k and 6k
- Engine Diagnosis - Need some help
- Changing auto tranny to 5 speed
- RMPs going Crazy Please help!
- big spline, small spline...
- vtec, obd1 conversion, no start, makes no sense
- VSS question
- h22a info
- Cluster swap.
- b-series crx crank pulley
- Turbo Camshaft wanted
- My ED7 Rebuild - USDM to US/JDM Dribble…
- OEM CD Player Wiring Question
- Koni/Ground Control Installation(did a search)
- B16 help....
- Noop
- Scan tool on my ED7?
- A/C Clutch? Any one Know
- Swaping the B16 for the H2B setup.. what do i need now
- EF Civic Hatch build from New Zealand
- lug conversion
- car runs with no key in ignition....wtf?
- 89 DOHC zc swap info.
- quick question..
- Distributor rotor vibrates loose?
- Timing belt shredded while I was parked...help me please
- cant pass emissions!?!?!?
- i need an exhaust for my hatch!
- What engine next for my crx?
- Need help car will not start or turn over
- guys dont kill me just seeing if my pics work
- CRX Wiring issues
- I need help!!
- BAR question
- 91 da gs to 89 crx hf
- HELP!!!!! obd2 dizzy obd0 ecu
- looking for pictures of the heading/vent system
- sticking throttle body in a crx w/ b16a swap
- dashboard question
- Can Head go on without cam installed
- hasport shift linkage question
- help plz. obd2 dizzy to obd0 harness
- coolant leak
- BAR a jdm b16
- zc tranny question
- i need help asap plz. obd2 distributor on ef
- my headlights dim
- Surge when hit gas help!
- JDM Rear Seat + OEM honda parts
- cracking/grinding noise when turning?
- quick VSS Question
- WTF a crx trike??
- Rear bumper questions
- Honda spec pics
- obd1 distributor questions
- 20 mpg??
- will a 88-89 transmission fit 90-91
- Fluttering Crx
- Suspension Advice: PIC Selects or Koni/Ground Control
- cant decide
- DC knuckles on a CRX ????
- emissions removal
- my 1990 dx build.... practicaly from scratch..
- Loud Click when turning
- ef sedan and ef hatchback filler and bumper compatibility ???????
- May 3, 2009 AUTO SHOW
- Failed Smog with High HC.
- need help taking suspension off !
- Idle adjustment not working, what's the culprit?
- EF Sedan Lights not working
- how do u remove stuf under dash please help
- da rears
- ► ► for sale / would like to buy 88-91 crx/civic parts only ► ►
- Which Head Would Be Best For My D15B7
- little help needed
- Civic Si Slight Jerking When Taking off Low RPM
- Need help!!!!!!!
- Head gasket replacment...now cam is out!
- nitrous vs turbo or ??
- D15B2 Help!!!
- MPFI swap, Code 16
- DPFI Cleaning time.... Tips ?
- noise help!!!
- Hood Modification...Word!!
- word on a da
- CRX door skin replacement
- Best Looking Rims For a Black CRX
- stupid question
- CEL 4 - CKP.. lost
- quick question about dpfi>mpfi & hondata s300
- what does this sound like?
- dpfi to mpfi help!
- NRG quick release horn???
- Blower motor not working properly??
- Transmission Codes and Help
- obd0 to obd1 distributor sub harness
- 1988CRX Starting Problem
- Question: DPFI to MPFI with D16A6 MPFI Parts
- DStuning.com EF Floor Mats not able to print Honda logos anymore?
- HELP igntion problem!
- JDM CRX EF8 headlight conversion
- How do you make the hood open more?
- undecided B16 or B18
- traction bars
- I am Fail...Location of PCV on DPFI motor?
- Intercooler won't fit
- d15 with z6 head....boosted???
- JUST BOUGHT A 88 HF! whats the cheapest way to hit mid to low 12s?
- timing belt and dizzy question
- 0bd0 to 0bd1 step-up diagram
- ecu chip
- d17 in 91 civic ef
- EF9 Turbo with Yellow square fog lights
- EF9 Factory Intake Filter Replacemt
- Help w/ choosing good offset for lowered hatch
- Were is the fuel fitter on the CRX???
- gauge cluster swaps?
- Civic 91 spark plug wires keep popping up!!??
- Pillar Seat belt swap?
- Wet nitrous question on B16a
- CRX rear seat release knob compatibility?
- does 91 dx starter fit 90 si tranny
- crx b16a milky oil on valve cover?
- my 1989 hatch has wiring problem???please help!!
- SONEM EF bolt-in hydraulic clutch conversion
- Seat Swap - Pillar Mounted Seatbelt ---> Pillar Mounted Seatbelt
- d15b6 or d15/16 sohc vtec zc?
- d15b hydro tranny
- Where is this crx thread?
- EF Sedan vibration and loud revving
- Rear Speaker Grill/Pods For A Sedan
- my number 4 spark plug
- s2000 oil filters on d series.
- how much do you need to worry about hydrolock
- code 14
- question about BLOX parts...
- Need jdm ukdm crx automatic window diagram
- swaping out engine and interior harness was wondering whats compatable
- crx si motor
- Sound Deading Removal
- ls vtec crx no power when key turned
- power steering in usdm crx
- Weird Kits
- JDM B18B engine...what headers do i need?
- Does your CRX Wheel stick out?
- Gas gauge random issue
- my car doesnt start! plz help
- do all HF's have the up shift light?
- brake problems
- 90-91 prelude fogs on 91 Bumper
- door panels
- Does Anybody Know?
- how much n2o?
- Ignition Switch Problem
- What Console / Radio Surround is this From?
- Many questions?
- Need Help B16a Oil Leak
- quick questaion
- Question about changing bulbs in Teg cluster??
- Cold Blooded...HELP!
- Picture Request: Green gen2 CRX
- d15b2 to d15z1
- black housing headlights!!!
- Running light issue, to do with parking brake switch
- My ee8 crx jdm front bumper? Look again....
- Benen Rear Lower Tie Bar
- dohc zc?
- 92-93 GSR ECU. good for lsvtec??
- HELP!! I know a thread already exist!! Let me have it Please!!!
- how much is it?
- 1991 Ef hatch dies when i give it gas???
- Install?
- steering wheels issue?!
- New, and one question
- CRX swap confusion: T-bracket
- Whats up guys!
- starter issue
- couple questions
- proportioning valve
- vibration over bumps
- 90 civic si drivers axle to short problem
- vtech prob
- 96 civic intake manifold, in a crx, need help with hoses!
- California state ref
- new crx
- Honda Civic CRX Thrust Bearings
- coolant temp sensor.
- difficult to repair sunroof on 90 crx si?
- What causes the IACV to go bad
- hood latch problem
- mini me in a ef?
- b16a loses power?
- where can i find these clips?
- b16 springs in a b18a1
- Head Gasket...how to prep to reinstall
- Let me see em.....
- Turbo'd rex's
- got a ????
