View Full Version : Honda CRX / EF Civic (1988 - 1991)
- looking into d15b vtec
- Ok to remove cat heat shield?
- 91 HF-B16 Swap-
- where can I to buy oem pistons?
- Hatch Tail lamp Mod??
- b18 swap ideas
- What would you pay for this?
- ??Rear Disc Brakes on 90 CRX DX??
- Crx troubles all hittin me at once
- injector problem
- Upper Balljoint Raplcement-
- Option needed. asap.
- Go To Riverside Ca. Hill side pick-a-part !!!!!!
- Damned transmissions
- yellow headlights
- EG front end on an EF (1991 CRX specifically)
- Shop for leak down in San Diego?
- H22a into DX harness help needed!
- Ebay Radiators.....
- Vegas people, need help
- My HB is a rattle box
- hf--> si bumper reinforcements
- engine misfire problem ????
- what needs to be done for motor swap into DX crx
- Wheel Bearing Guidance
- fuel smell, driving bomb
- what part of harness
- Driveshaft trouble
- AUTO METER OIL PRESSURE GUAGE
- What intake manifold gasket for a DOHC ZC????
- is this safe
- Lighting Problem...please help
- 86 Civic Hatchback Si?
- b16 heat gauge and idle
- Few Questions About B16A2 Block in a Crx, Take a Look.
- did compression test, look good for boost?
- The ZC Strikes Again..
- Crx swap opinions-please
- Boosted Sedans? Few turbo 4g4dr's?
- b16a knocking hmo
- which clutch....NKK or XTD
- where/ what is my throttle plate? (notchy gas pedal)
- 86 civic thermoswitch??
- Starting Problems 89 civic d15 motor
- 90-91 crx dash into 88????
- ZC 350$???
- Help need Dpfi Wiring diagram!!!
- fuel pump
- Tach problem, light wire where to?
- Crx Idles at 3k
- Ys1 Install
- please help me!!!
- New Hatchback Owner
- Vitesse EF? Has anybody done it?
- HIGH REV AT START UP!!
- Need an alarm recommendation
- check light problem
- 91 crx..what rear brake disc will fit
- EF wiper design = SUCK
- I finally found out the problem, but how do I clean this part w/o messing things up?
- thread pitch of ECT sender?
- CRX doors
- mini me swap probs....help
- Wide body (good laugh)
- Compatibility of Hatchback suspension and CRX Suspenion?
- Cleaning injector outside of car?
- will a crx b16a1 fit in an 88 prelude
- Code Problmes Help PLZ
- codes
- Do I have to have the timing belt cover to set timing right?
- question about jdm crx vtec center taillight?
- autozone clutch?
- shift linkage is fat
- crx hatch question
- clutch noise
- burning a quart of oil a day?
- im the 40th owner! picture time line of my car
- DOes honda put in helicoil for stripped threads???
- New here................. CRX si w/ gsr swap
- car will not start
- f**king o2 sensor!
- WHAT THE HELL IS THIS HONDA PART??????????????????????????????link to pic inside
- Clutch trouble?
- all motor b18
- H22 into a Ef?
- Which Header should I buy with a JDM B16 in a 90' CRX????
- Mini Me swap questions
- si cluster in a dx auto?
- carbon hatch??
- how do u put a new heater core in a 89 crx si
- Anybody with around 500 whp what type of tires are working for you?
- 1 Broke crx si injector what cam i replace with??
- Please Help !! I am a Rookie / Headlight removal
- Need LMA Installation Guide for a B16
- hasport hydro kit efb2, cable adjustment problem
- Aligment for 1989 Civic DX
- crx vacuum hose size
- whats the best intake for my b16 swap in 91 civic si
- Irratic Tach..... ?
- No spark no fuel no start
- newbie tuning, pearls of wisdom needed!!
- Si Rear LCA, I need someone to measure something
- Turbo Timer
- Inside of car smell like shit during freeway driving after ebay testpipe install.
- MEdm >jdm
- ebay strut bars
- B16 Swap problems/questions...in the MIDDLE of the swap..
- Are civic and crx oil pans interchangeable???
- how to identify zc camshaft
- CRX front end on Civic hb?!!
- Need Help 3 problems...all realted?
- Centerforce dual friction weights?
- The Many Things I need for my Civc (Rant)
- New 91 Hatch Owner....
- how realistic is 300 hp?
- "Rebuilding My B16A, What internals Should I go With"
- d16a8???
- AEM V2 intake for crx?
- jdm sir wing pics before and after
- gsr in a 4th gen
- obd0 to obd1 is this the kit that I need to convert all the wiring?
- d15b7 into 88-91 dx
- will a6 oil pan fit on a z6
- what year tranny do I got
- Energy suspension bushings question
- crx trouble bad...
- stock head gasket vs H.G. spacer on turbo crx
- Axles???
- D16y7 swap in '89 crx hf..a few problems. help.
- Bad blower motor????
- guage fucked up
- d16y7 into 86 crx, does any one know
- b16 Injector wont close. Searched.
- Quick MPFI question (searched)
- question??
- Tie Rod End Advice
- Not Allowed to post
- carbon fiber hatch on CRX???
- ecu questions
- Car swerving slightly under accel/decel
- Axles for zc
- ebay civowagon.
- exhaust leak???
- Glasstop anyone ?
- need brake swap help
- Need help with motor mounts
- Auto MPFI swap on CRX DX completed - PICS
- Oil leak need help asap gotta drive it 300 miles in 5 days
- tuning b16's on gt4
- What oxygen sensor to use for b16a1 engine in 1990 CRXsi
- neuspeed springs
- tach wiring diagram
- front bumper will not come off
- B18c Big turbo
- 2005 Seats in EF
- water pump question
- crx smoking from too much oil in it?
- Another DFW Turbo Project
- Tips and Helpfull links for most hondas
- Discovered an odd oil pump difference. (d16a6)
- Throttle Body/Charcole Canister Question
- Full B16A Swap For Sale
- Wiring for D16 Dizzy
- 90-91 crx bumpers on to an 89 crx??
- Need Help Car bogging
- I can't Rev past 3000rpm... ...grrrr
- sunroof help
- block reinforcements
- Code 43 issues: any help is appreciated
- tranny leak
- JDM B16a transmission options
- code 7 and 20 with pm7 ecu
- These prices are high, arent they
- d15a1/d15b2 motor swap
- Help Ignition troubles
- Weight Difference Between a '90 DX Hatch and '90 CRX DX
- codes 1and 16 help what r they
- Installed a turbo... now what?
- Cusco Cage
- Distributor Replacement for pre OBD b16a
- How to fix sticking Ebrake?
- ZC QUESTION
- Autoweek article: K20 CRX in 2007
- 200$ crx wont start any ideas welcome
- VSS Required
- Sohc Zc Vtec help..
- Really loud rattling sound?
- intercooler spray...
- :Question about interior: Will DA8 Seats fit my 90 civic lx ?
- Crank pulley change over
- Rare Civic EX parts?
- Just picked up a 88 HF CRX, DOHC ZC Swap Question??
- Need some help!!!
- will this manifold fit in a 90civic si?
- ZC Cams
- spring adjuster problem
- how can i tell if my fuel injectors are working?
- Next Mod??
- Black smoke help
- I already searched!!!! 89 Civic ls non-vtec to vtec conversion.
- Code 20?
- 88-91 to obd-1 conversion
- What's the 4040 prop valve off of?
- Anyone know anything about the Accel Blue air filters?
- B16a worth how much?
- CRX rear speaker cover cloth?????
- B18C1 to EFs, just small details
- dyno results after installing a DC Sports 4-1 header in a B16A1
- oil in sohc zc
- Cruise control brain storming. Wondering if this will work or not.
- LSD question?!?!
- Need help with sway bar bushings
- 02 civic question
- obd1 injectors on a obd0 harness
- Bisimoto or An-R
- What are symptoms of a faulty gas cap?
- Ebay Crank Pulley. Anyone have any experience with one?
- Explanations would be nice !!
- dpfi injectors the same as mpfi?
- Just did Rear disc convo and now the tires stick out farther in the back than in the front
- b16a1 car bogging
- anybody likes the UKDM momo steering wheel???? pics
- engine/tranny knocking???urgent please help!!
- 89 crx si battery light?
- Green hatch gone........new project for next spring...
- d series question, getting pissed off at anti import ***
- Grinding into third all of a sudden
- wierd ass problem
- SEDAN AUTO SEATBELT HELP
- how to make a custom short throw shifter
- swap question
- 1989 CRX Vtec Problems
- EF is cranking, but it wont start'
- Exaust DP to CAT gap.
- 91 crx hf ... bumper reinforcement
- CRX big brake suggestions?
- gauge cluster options? 91 crx hf with b18a
- my wheel cylinder is leaking...
- might buy a crx need info
- mpfi swap (need help)
- unlocking a crx with a lcence plate
- tourque specs on b16a head
- DC Headers Comparision-Stainless one piece/ceramic 2 piece-both 4-2-1-fitment and gain?
- Ball joints
- need help, keep going through starters on b16
- Throttle Cable LUBRICATION????
- It's Me Again.. =[
- f22a1 Vteck head any good
- carbon fiber lip 4 my four door
- iat sensor
