View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Hood won't close!
- 1986 CRX Si Turbo Project
- light on 89 crx si
- Timing Belt argument (me VS. my friend) ????
- video request.
- Cobalt Brakes, pads crumbling, rotors warping, excessive heat. Please assist.
- A plee to open the wtb/fs thread
- just bought a 91 hatch dx need some help please
- Need help importing a CRX
- IACV!! Can I bolt on a D16z6 IACV? (Z6 mani on my A6)
- thermostat not working?? please help
- which crx brake kit
- oil light at startup and a few seconds into idle
- integra center console bolt on
- needf advice. should i buyu this?
- NJ
- Hondata S300 is out
- pr3 ecu.........need pin scematics............somebody.....anybody......... ..
- Fuel rail nut on mpfi interchangeable?
- Car Acting Up
- stupid ? but still need help,everybody says something different...............
- what is the fuel pressure for a b16a1 in a 91 rex??????????????help please.......someone
- 90-91 Civic cut out on Freeway any ideas?
- i need some ideas, looking for better sound
- pg7 on a d16a6?
- How do you use this form
- exhuast
- K20 IN A CRX IS IT POSSIBLY??? LET ME KNOW ASAP
- New Member from OZ
- 92 lx motor in 89 civic si not starting!
- HF Transmission VS. Si, Custom gearsets?
- bought a crx today!
- b16 into my 88 crx si
- what does it sound like to you?
- O2 sensor not working?
- EG hydro diff into L3 tranny?
- CTR Cams Vs. Skunk2 Stage 1 Cams?
- question whats the timing/head torque on a d15b? sohc vtec
- b16a vs b16a2
- ECU HELP
- b16a swap 91 crx si cali ecu question
- difference in power ??
- EF exhaust? where cheap??
- ac condensor and lines question with turbo
- Hf CRX Timing Mark
- cel light have no idea what it could be
- Clutch to hard!!!
- carb choking
- techie help needed on 90 civic si
- ecu questions?
- Windshield wiper fluid motor issues.
- performance parts questions
- tranny for b16
- tire clearence
- PISTONS FOR D16Z6
- Ok more tranny question zc tranny??!!
- d15z1 swap versus mini-me
- all disc's suspension?
- Whats my crx setup worth?? and if you have any comments feel free to post
- axle not flush wiith transmission case
- B16A motor build questions
- Electrical problem, batt light off!
- 1991 civic wagon suspension
- how much should i ask?
- same crap
- problem(pictures inside)
- need d series si tranny
- 87 CRX question
- Where can u find a Stand alond Fuel Mangement Sytem ???
- thinking about gutting my car out
- tranny problems
- quick b18 question
- Anyone need any junkyard parts? Send me your requests.
- New Full-race clevice on traction bar (and color)
- crx with a jdm d15b
- JDM RPM gauge into USDM cluster.. has anyone done this?
- Oil light on...strange symptoms...helpppppp
- NEED HELP wire tach to crx
- overheating on freeway, hot day, weird temp reading fluctuation
- ZC won't spark, HELP PLEASE
- What Causes a head to get Warped?????
- 89 CRX CAMBER KIT
- Need HELP!!, timing adjustment jumper.
- MY ZC HATES ME Please help.
- OEM Optional CD player from 1990? Any info?
- Wrong part number ( auto zone ) std axles, 1.5 hatchback
- A/C Issue
- What in the hell did Mahdavi Motorsports do to that NSX powered CRX?
- i hope a fellow HT got it.
- 1.6 soch vtec?
- Nashville, TN Area Shop for B16A EF Swap - For a Military Friend
- crx headlight
- 85 crx si stumbles at acceleration
- need help with suspension/ alignment issues
- How can u tell if u have a SI or HF transmission?
- 1989 CRX FOR SALE-JERZEY
- where can i get an ef9 front clip in canada
- b20a5 or zc dohc in my civic si
- throttle plate and winshield question.
- Stupid but need some input.
- burning oil...but great compression...?
- Suspension question!!!
- Yellow Bulbs for high beams?
- almost done with my build up
- shift link removal
- 86 crx si D16a1 swap, need help!
- 1990 or 1991 crx bezel
- does muffler matter for emissions? '87 1.5 carb D15A2
- HF hubs/b16a swap
- i need some information
- SCAMMED: ordered b16 shortblock and engine is torn apart
- 1990 crx master cylinder ?
- Optional Parts for an EF Wagon???
- good offset
- do crx's run a little rich?
- i have a 87civic 4 wheeldrive that needs a new clutch how do you install a clutch is this car? i thi
- i have a 87 civic si i need to put a new wheel bearing how do you do that
- can you use 89 crx si Axles on a zc
- i got a crx 89 si i just got a new zc motor can i use the clutch from my si? the clutch for my si is
- EF to EG suspension conversion
- cel light need help!!!!!
- is a crx headlight socket different from a hatch?
- 91 EF w/B16A has idle issue NEED HELP!
- stage 1 sliping?
- best place to get new oem pistons
- Fitment of AEM Cold Air Intakes for CRX w/ D16y8 manifold or D16z6 manifold
- rear suspension tech
- ls/vtec
- DOHC zc or d16
- how to break a motor in
- A/C not working
- More Dizzy Questions*really need help*
- what do i need
- please help!!!!
- eibach lowering springs
- my sohc ZC with its head taken off, blown head gasket.
- speedometer cable
- Anyone tried acetone in their EF gas tank yet?
- alternator for B16A
- camber kits what work with 1988 to 1991 civics
- JDM ZC SOHC NonVtec
- Torsion Bar Adjustment ?
- RS*R exhaust + ITR header+ omni test pipe = NO FIT
- HELP: bought an 88 lx - has 94 dx motor
- HELP Please....Engine problem
- searched...i need quick answer
- WHAT'S bEtter for my ek9
- Under Dash Wiring Question
- all u smart honda Guys can u answer this
- mini me swap
- New clutch
- guys with a B16A crx
- header on crx with 1st gen b16a
- Injector cleanng setup?
- I think my Diff is fubbared... :(
- PWO or PR3? im getting a new ecu...
- i need help what to do
- mini me dizzy...help me pleeeeeze
- engine idle problem
- NEED HELP ON SWAP SOCAL (951)AREA
- need help with codes
- How to Remove insulation under carpet????
- d15 clutches different HELP!!!!
- shift linkage problems
- Axle on CRX w/B16 is tweaking... Need help!!!!
- Survey Says... need opinions or someone to talk me out of this...
- code 20 help
- vtec problem HELP!!
- strut/shock question
- crank angle please HELP!!!!!
- Engine Won't Start...HELPPP!!!
- WTF is going on with my crx?
- what can i expect
- Swedens First K20 CRX
- distributor stuck in head!
- brake caliper clip
- I need suggestions on a Coilover Kit other than Tein.
- My EF3 Si ZC DOHC Turbo project
- b18a into 88 civic question
- Ef rear fogs.
- 88 integra 4 dr sway bars
- installing a JDM cluster..
- Strange Issues (searched)
- Does anyone have Hydro Hood Props? like tein or anything?
- Finally getting civic back. Fresh rebuild, what you guys recommend for break in?
- 1989 CRX SI FOR SALE!! ONE OWNER!! PERFECT RUNNER!!!!
- TroubleShoot: 1989 Crx Si Doors + 1991 Crx HF
- intake manifold swaping, DX to HF
- Parts compatability Ef Vs CRX / also is a 91 crx Hf dual point or multi?
- to cam? or not to cam? input plz
- Tsudo Catback N1 Exhaust Pictures
- what do you think i will be able to run in 1/4
- engine problem
- b16 obd0 timing belt cover, what can I use?
- Air/fuel ratio gauge on 1991 si hatchback
- need some help from HT'ers
- On the subject of keyless entry?
- fan switch on a 0bd0 b16a
- how to prolong cv boot life
- b16 block with b18 head???
- ctr cams question
- 86 crx b18a1 swap??
- where do i put the side markers at???
- seat question
- Hydraulic clutch set-up in a CRX
- 86 Civic
- directions on suspension install
- 1.5 5speed conversion to 1.6 what do i need?
- Will 92-95 front Upper Control arms work on a 88-91 ?????
- MPFI swap w/o MPFI dizzy
- d16a6 into an 88 hf crx
- HELP PLEASE!!! CLUTCH CABLE BROKE
- Fuel pump relay
- how much boost can i go to
- Map Sensor Codes....still having issues
- b16a into a crx?
- cable to hydraulic conversion need help pls
- 93 integra seats on a crx ?
- *SEARCHED!* hatchback axles vs sedan axles?
- Want to do away with.........
- what model is good?
- D15b Which Transmissions fit?
- Question on camber
- voltage drian in CRX Si
- LSD of CTR in serie-B cable trans??????
- what does this cam timming mean ??? on ZC engine?
- Racing Harness
- ITR/EF suspension
- d15 in 89 civic hatch si
- New dyno numbers for my turdbo 1991 Civic Si.
- Car cuts off, need quick help, please
- help: cable for hood latch broke!!
- have you seen this pic of the 2007 crx ?
- Are CRX fans pusher or puller fans?
- Slow Brakes HF CRX
- get b16 head or gte valve job on b18c1
- sohc zc header
- throttle body
- The Consequences of blown shocks.
- Do these look reusable ?
- b16 engine noise
- shifter and clutch pedal problem
- b16 is missing
- Best Harness Belt?
- MPFI....I searched I swear....
- A/C with a b18c1 in a CRX?
- b18c into 91 dx wont start help searched!!!!
- parts cars sitting around sea-tac area??
- B20 SWAP INTO HF
- can someone please help
