View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Ef Sedan, what other rear seats can i put in?
- Moderator: please read!!!!!! cant instant message yet so i had to make this thread
- vibration when make left curves
- 97 Civic A/C Problems
- 90 SI WIRING SCHEMATIC
- 91 Civic SI, Ckeck valve location??
- 90 CRX Transmission HELP!!
- 89 civic si with d16y8
- 91 CRX HF WITH DX HUBS.....WHICH IS BEST BRAKE UPGRADE FOR B16???
- CRX S2000 CLUSTER SWAP COUNTER....HOW MANY OUT THERE HAVE IT??
- Code Error 9
- Which cam?
- Interchangeable EF Hoods by part numbers. **Add to Sticky**
- 1989 hatchback racing seats, any suggestions?
- My question
- State Reff
- rsx 5 lug on crx?
- i have some eg(92-95) coilovers and shocks, will they work for the ef.
- Si axles into ZC tranny
- 91 CRX ZC Swap problem (Crank Position)
- slim fans and stock fan sizes
- Need Help '88 crx
- Anyone run nrg seats, in 90-91 HACTH, where did you get your brackets
- help wierd running 90 crx hf
- Question on hesitation(weird)
- clicking noise when i turn??
- anyone got pics of a 91 civic hatchback on ls webs?
- Need help, CEL code 17 (VSS) 91 Civic STD...right after swapping to 89' LX gauges.
- Side Skirts
- how to - sir cluster / ghetto vss
- B16A siR swap
- lighter=faster
- check engine code.
- A-Pillar gauge pod for sedan?
- also sorry <zc question?>
- ZC hybrid????????help??
- Ground Wire + Voltage Stabilizer... Does it work??
- cel 19
- mpfi swap
- 90 crx door panels in 89 civic hatch?
- Anyone else running skunk pro coils?
- HELP: snapped VC bolt.. can i use an LS stud on my D?
- Progress B-series Springs review (pics)
- what is the length of a catalytic converter ?
- Help finding a good performance shop in California
- help wire a cd player
- b20 question
- motor wont start dont know why..
- i have a ?
- intake manifold
- s2k seats in crx?
- help on swapping a d15b7 into a ef hatch
- IACV/EACV,questions about sensor!!
- help!!! Knuckle question!!!!
- IACV water lines
- b16 wont start getting spark and fuel wont start.??
- help on a zc engine!!
- Car is going nuts. WIRING PROBLEM
- from 2 to 4 injectors
- just a quick question, don't laugh!!
- auto to manual conversion. are tranny mounting locations different in frame?
- OFFICIAL info on CABLE TO HYDRO CONVERSION!!!!!
- What valve cover gasket to get for a DOHC ZC???
- brake oil keeps running low
- Need expert help to ID this header
- Should I remove the idler pulley on my k20?
- DC integra seats into a 90 dx hatchback.
- zc dohc engine miss at 4500rpm
- zc mounts custom made
- Spark plug order
- B16/crx going to REF. What intake to use?
- Map Sensor on firewall. Need a pic of resistor box.
- b series goin into ef linkage question
- Add a cigarette lighter plug...
- How to build a poor mans type r
- EF8 cluster in ED9 CRX
- help
- looking for pics of the installation of the intercoolers
- clutch
- Help with Engine swap
- C5 into a crx already has A1 mount and axle q's
- JDM B16 with J1 tranny VSS question-which electronic vss fits??
- brake help.....
- b18a1 obd0 block obd1 head?
- 89si harness in 90si both hatches will i have to mod
- What parts from other cars will fit on an EG
- check engine light
- Thought you guys might enjoy this..
- bluish white smoke coming out the exhaust..
- intercooler help..
- where to get performance stronger motor mounts?
- what spark plug wires ?
- Another question about how to tell si trans true or false
- photoshop this please???
- 90 civic hatch using 4dr da integra brakes
- after swap...seat belt retractors dont work?
- How can you tell if your wheel bearing is going out?
- 93 Civic fuel pump in 88 Crx..
- will a 90-91 teg main harness work in a 90-91 si hatch
- Shifting Problem
- cel 16?? not one flash then 6 fast ones. its just 16 quick flashes wtf??
- Looking for name of a part (rear glass covering center brake light)
- LOWERING SPRINGS!!!
- CRX/Civic subframe reinforcement
- CRX 88 will randomly idle HIGH
- axle question????????
- jdm front bump.....is this a good price
- valve cover gasket?
- LS Into A 91' Si?
- Ls/vtec wont hold idle
- This my ED7 plz look
- TURBO PROBLEM
- please help no spark
- Cable tranny problem
- cooling fan won't turn on
- HELP!!
- which engine should i get
- How to remove paint off taillights?
- itr motor
- my b18b cable tranny not goin in 5th or reverse!!!help please
- what axels are needed for b-series into a ef.
- Choices when ordering Bump Stops
- can obd0 ecu read obd1 dizzy?
- SLS mini log fitment issues?
- headlight removal?
- d16z6 timing
- Need Torque Specs
- HELP ON CHOOSING COILOVERS FOR CRX!!!
- 88 Honda Civic Auto, tranny problems
- help with code 17
- dizzy question! need help!
- EF8 dropped B18C type R, drive shaft needed.
- Dust ring
- map sensor
- voltage stabilizers
- nos octane booster?
- short shifter
- EDM glass headlights
- 4 wire o2 hook up
- wont start in warm weather??
- i was bored..some new pics of the whip :thumbup:
- B16A swap parts list
- B16 Ecu
- zc bearings
- Are the 90-93 Integra knuckles a direct bolton?
- Heater Core Removal and Hose Looping
- HELP!!! B18c1 block with a B16 head
- Important: What should I tell the DriveShaftShop? I am doing a B16a swap into an ED6.
- A/c with a b18 in a civic si question...
- correct firing order
- cable to hydro tranny help...
- crx lip
- First time CRX owner
- Falken CAI?
- NEED HELP WITH MY 89 EF!!!
- 88-91 Autopower Roll Cage for hatch fit CRX??
- ef with no 5 lug swap but....
- Vacuum Problems...
- A/C question with b16 swap. Not the typical, sorta'
- Anyone have trouble w/ ebay b series mounts?
- Neuspeed rear sway bar owners...pictures of yours bolted up (no instru & pile of hardware)
- Testing for LSD?
- Rollcage question - ED/EF Civic/CRX
- any1 knows who makes a hi-flow cat for 91 civic dx
- dizzy question for obd1 non-vtec
- b-series tranny for rex
- D16Z6 mounts? WTF?
- no spark... dont know what to do
- More and more problems, please help..
- Aftermarket JDM D15B parts?
- CRX TECHNICAL HELP NEEDED b20/b16 swap wont work right.
- b16a and b16a2? are they the same?
- water temp gauge
- Thieves...
- iacv
- How can make my bumber lights stay on??
- crx needing help wonderinf if anyone is having this problem
- Hesitation Problem
- 02 rsx steering wheel? fitmento
- Brake Disengagement Problem
- ***Need Help becoming permanent Honda-Tech member*** NOOB needs Help
- length of Catalytic Converter?
- civic starting problems
- Vacuum Line Size
- d16 d15 trans need to be sure
- puting a msd 6A box on a b16a
- getting my clutch replaced on my 91 civic today have ?'s
- OBX, Skunk2, and everything NA
- pr3 wierd problem
- vtec oil pressure question
- will a civic four door bumper fit my dx crx
- anyone around
- CRX's in South Africa
- widebody kit???
- what is the stock rim width and tire size for an 89 civic hatch?
- Lucky break on a bad break
- it died on me today.. hopefully no biggie..
- estimated power?
- lowering..camber kit???
- arizona h tech members
- d16y8 into 89 civic si?
- F20C into a EF9?
- high idle
- h2b kit for 88 ef? is it worth it?
- HF LCA's
- DOHC zc on boost
- car wont start been sitting 6 months
- 2 step rev
- Need diagram for 94 integra manifold
- OMG !!! SAME problem ... HELP !!!
- 1990 honda civic a/c
- Low rpm shutter, or miss (b16 crx)
- my car decides to take naps?
- motor difference
- ecu chip help
- is it true 88-00 civic headers fit eachother?
- D16A6 owners, Crank pully bolt diffrent sizes?
- help!
- dohc zc rods+slugs into d16a6????
- Fuel pump removal question? Jumper wire, whys it required
- MINI ME
- Can a crx catback be used on a civic 3dr hatch, what is the difference (88-91)
- crx stalling? (sounds flooded)
- d16a6 question....Car suddenly cut off...low on fuel....now my oil smells like fuel.....any HELP?
- Factory Helms manual online link???
- this has me scratching my head..
- rusted sunroof?
- Battery relocated now keeps blowing starter fuse in distro block
- JDM D15B Sporting B16 Goods?
- Low Idle.
- Project Crx and Rotary Friend
- Alpine CDA 7987/fantom face question
- Difference in 90 civic vs. 90 crx??
- Still cant pass an e test!!!!
- engine quest
- caliper brackets?
- EFB2 Hasport Kit
- how much parasitic drag does the alternator produce?
- Dpfi to odb1 Ls wiring question
- DA master and BB, which strut tower brace?
- Lowering spring problem
- PLEASE HELP --- GAUGE CLUSTER INFO
- Have some questions about knock sensors and what this plug goes to?????
- Help please
- 87 rex torsion to spring over strut conversion
- Need some help for my sohc zc ef9!!
- quick questtion about ls vtec
- Tranny advice
- zc tranny shifter forks?
- B16a1 into 91 dx crx rotates, sparks, but injectors do not fire!!!!!!!!!!
