View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Si door Panel repairs
- need help please read
- Need help hooking up turbo timer
- Automatic Modifications
- Suggestions on 1988 CRX DX Engine Drops
- Zdyne One-Wire Ecu Conversion....FOR or AGAINST?!?!?!
- my car is messed up....please help....!!!!!!!!
- 1" drop ST coils in a '91 Si hatch; do I need camber adjustment plates?
- 92-up Civic Fluidyne -- I DID IT!!
- Our Moscow Honda meetings.
- shiftlinkage cut and weld how much for b16a swap
- what would i need for a gsr swap in my EF?
- wiring diagram for a pvot vtec controller
- Power window switch placement?
- honda high performance handbook?
- JDM EF9 Crossmember
- spring rate calculator? strut dampening calculator? what are some formulas? road race setting.
- Car keeps overheating....
- 88si tranny on d16y8 motor
- 2000 si in a 88 hatch civic
- ZC or B16A1?
- wanted: 90-91 crx si ebrake cables.
- crx meet in old town fl
- civic question
- I'm rebuilding
- How different is an '87 si and any newer year. I'm looking for a body kit and it looks like a got th
- hey guys are 88 starters different than 89-91?
- question about the SiR..
- Help: Master Cylinder Problem
- sir frontend conversion
- Info on droping a ZC into a 91 CRXsi
- front camber kits....what cha got???
- console
- Need Help Installing B16 into '89 Civic
- whistling noise in engine when accelerating
- what RPM does your speed limiter hit?
- cheapturbo.com
- How much is my car worth? ;/
- Hey guys? Tranny codes?
- zc compression?
- LSD question
- Fuel Guage????
- DOHC Timing belt, Cam Gears Lines Question
- 3rd Gen Civics
- Can 88-91 civic Si/CRX seats fit into a EK civic?
- questions on my ef...
- Which model EF hatch came with the factory sway bar?
- 194 car pile up on 710 freeway. so cal.
- fuddrucker meet nov 9
- Look at what just showed up in my garage....
- do you know these ppl?
- Need gauge cluster pics ASAP
- h22 swap into 88-91 crx
- 87 crx si
- weird stalling problem on '89 hatch
- Trail arm bushings
- turning my 91 dx auto into a manual
- h22a4 in a crx?
- b16a1 and emissions
- water pump problem?
- Help with seats for 89 dx
- minime help
- Nor Cali Honda meet tomorrow Nov. 3
- turbocharging a B18C1 crx?
- 88 and 89 gauges different???
- Gotta love fall!
- car wont start and making a weird noise
- steering
- check out my newest addition to the wagon
- 4 door civic cool sleeper or just plain dumb??
- Group Buy: AN-R N/A Header!
- Help!! Have question about D16Z6
- I need everyones opinion thanks
- B16a Turbo? LS turbo? or Z6 turbo?
- EF rack and pinion* need help
- ZC Blockr & 89 Teg Head??
- skunk2 exhaust
- Wrong thermostat = Blown head?
- Which do you prefer?!?!? d16z6 v.s d16y8?!?!?
- ecu help
- CRX Si Motor
- adjust oem fpr?
- Thermistat? heator core?? -_-!
- yep good day!
- Center console from teg
- looking for b18
- HELP!!!! OVERHEATING engine!!!!!
- Sir prices...would u buy...
- dynamo wrecked
- bent valves mini me?
- Does tranny fluid get bad/old?
- any mechanical engineers here?
- 90 civic i acting weird
- O2 sensor?? Which is primary, secondary?
- Laguna Seca - The 2nd best time ive had in a car ever!
- anyone have alignment specs from their aligntment?
- any one selling a SI?
- Timing Light
- wicked green crx with turbo featured in magazines
- Can't fit speedo plug in my Si Tranny
- Short shifter thread pitch...
- Can i use the TB from a 2000 civic d16y7 on a d16z6 intake?
- hatch antenna replacement problems (this really sucks)
- Main relay problems after fuel pump upgrade.
- exhaust question
- Where in Canada can i get a JDM front end???
- cluster...
- Name That Part! D15B2
- timing belt b16?
- Car wont start
- Damper fork question.
- exhaust sizing question.
- Info on how to install Autometer gauges
- "Simple' clutch question...
- zc aftermarket pistons? will any D16 forged piston work?
- Looking for d16y8
- CRX B16a Swap instructions, +vtec wiring "how to"
- types of gauge clusters for 88-89, not jdm
- Exedy Organic Racing Clutch vs. Exedy OEM Clutch???
- Question about machining my zc flywheel.
- APC vs Matrix
- are '88 headlights from a 4-door the same as my '90 Si
- If looking for swap
- Got my ZC Swap Running G00d
- dont u think we should have a west east midwest canada etc forums
- ZC's
- Orlando Meet, Saturday Nov 9... Details inside...
- Attn: Western Canada and Northwest U.S. folks
- ls engine
- How to make my factory fogs yellow? (CRX)
- Do 88-91 Lude Lights fit right into 4G Civic`s?
- 90 ls engine b18a
- Idle on sohc ZC?
- Some SOHC ZC swap questions
- who knows where to get a b16a distributor in japan, australia, etc.
- civic type-r
- Coilovers on eBay?
- window problem!!!
- Coverting tro OBD1 what do i do for........
- 90 crx worth it?
- Broken
- 91 Hatch jdm parts
- Rebuilt ZC Motor Possibly for sale soon. All new seals, Main bearings, Piston rings, etc.
- I need help real Bad Tranny Problem!!!!!!!!!1
- should i buy???
- Rearbumperlip?!
- Rumor or true???
- ATT: Question For JDM CRX Guru's out there. LSD question
- PR4 ecu wire color code
- wanting tp put a 91 CRX Si engine in my 91 LX sedan
- Who has a performance rebulit SOHC VTEC motor and how much did it cost??
- catback that comes out the other side.
- B16a1 performance
- Give me your opinion.....
- throttle sensing
- Need some help from CRX owners...
- CRX or EG?
- MMRUSA.com fiberglass dash
- JDM crx console pics?
- shift linkage on B16a CRX
- gude head
- What does this problem sound like? Supsension maybe?
- b20 crx?
- WidBody
- Has anyone hooked up Autometer guages in a 89 CRX SI
- CRX headlights?
- CRX meet this Saturday at old town in Olrando, FL
- CF Hood
- MT/AT Gauge cluster differences?
- Ho wmany CRX owners autocross??
- how do i take off all interior pieces??
- Emissions HELP =(
- Tranny fluid problem.
- ZC weight.....anyone????
- Should i sell my rex?
- Power steering removal...
- b17 swap anyone?
- ZC HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Brake conversion
- car rattleing???
- weird idle. how to change O2 sensor
- ITR intake on a 4th gen?
- Help~axles
- Car "stalling" @ 6700 rpm's...
- dropped QTR ET last night at sacraceway
- B16 CRX peeps (help)
- should i buy a 87 crx si?
- LSD and final drive preferences?
- ECU question
- HCP linkage, CRX SI knuckles, rear mount bracket, cheap, chicagoland suburbs.
- Type of Tranny?
- Clutch issues
- Nice inboard muffler?
- How much to pay for this???
- Damn theives got me too!!!!!
- CRX on Vice City?
- B18C5 on 91 crx si
- Clutch alignment tool???
- Getting her next week
- Received my 3" Thermal exhaust. Wow... it's BIG.
- Air box with motor swap...
- IDLE dips way low when coming off the throtte!
- USDM B16a2 into a 88 CRX DX?
- Tranny question... I know its been ask alot before...
- Z-10 cross member with mount???
- Bad throw out bearing?
- thinking of selling my rex...
- o2 guestion
- Location of PCV valve please
- Could I put 91 CRX SI seats in 91 civic dx?
- Blew a coolant line, replacment procedures
- DC suspension into the EF chassis??? can it be done?
- how much better is a ys1 tranny then a j1??
- hondamotorsports (now Hmotorsportsonline) online poll
- Help me w/ a ZC D16
- how much hp out of d16z6 engine?
- B16a into CRX swap guide?
- anyone here weld their diff?
- how much was your exhaust?
- Speedo needle question...
- b16 civic crx swap guide and shop manuals
- Civic wagon question...
- DOES 87 CRX have springs in the front wheels?
- HELP!!! what will fit and what won't
- Changed the head gasket...now...
- anyone have a straight set of CRX/hatch upper control arms?
- suspention bushing kits?
- B16A into 91 CRX SI
- F/S 1989 Civic DX 4 door
- Question
- anyone running a side mount i/c with their turbo setup??? post pix!!!
- jdm tranny question
- 92-95 Civic Radiator
- turbo????
- Wiring B16 02 Sensore
- almost done with swap
- Which Head Gasket for ZC??
- About Members
- VAFC on PR3 (VTM signal)?
- clutch install complicated????
- z6 - a6 bottom end differences?
- Removing Rear Bumper on Hatchback
- LSD makes noise when making slow turns?
- CRX Axle Strength
- Cable Vs. Hydro
- Can someone help me out with this
- Info Needed : Buying a 1989 CRX want to SWAP!!!!
- 88 Civic rear strut confusion
- looking for fast, free white face guages?
- love for the EF? how much is it worth
