View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Battery dying almost instantly
- code 1 (o2 sensor) problem
- Exhaust set up help......
- A6 parts on Z6
- will a 92-95 clutch fit in my 90 hatch
- Manifold Help
- 91 crx Si no spark
- obd question
- Not idling right/dieing
- gears wont go in when ...
- part interchangability caliper/caliper brackets
- crx shifter
- Starting from scratch. Want your opinion!
- Door open/seatbelt buzzer freakin out
- 88 crx harness
- How much can I get for this CRX, Ebay?..
- What wheel is this?
- NEED FOG LIGHT DIAGRAM
- R.I.P CRX......> =(
- b18a into 90 hatch questions
- turbo crx want start please help =(
- any products out there to removed 2 years of caked on dirt on window?
- A little resto job!!
- D15B2 Head gasket placement???
- wierd coolant leak. please help!
- distributor help
- Is it legal to drive with no side mirror?
- timing belt help
- oem equalizer question
- b16a smokes. all the time!
- Harness Mount Bar
- 88 CRX Problem :(
- '90 si engine harness
- B16A2 head swapped to OBD1 whats needed?
- my ef civic
- Transmission and axles
- b18c1 swap woes
- batterty reloction problems
- cherry bombed b16?
- need some help with a swap i just got
- Is a b18a1 dizzy plug and play on a 89 civic si?
- b16a problems
- ebay dpfi to mpfi motor harness
- Just got me a CRX.
- 1989 Honda crx running like crap
- multipoint problems
- 88 ef suspension problem
- obdo ecu's
- crx instrument cluster id
- Any oem springs to lift wagovan?
- A6 vs Z6 timing belts
- tokico blues
- d16z6 problem
- d15b2 to d16a6 what do i need
- 91 crx si with JDM d15b wont start
- LS timing gears
- 91 crx si b16a bogging code 6,9,10
- CRX suspension Gurus
- Brightest/Whitest 9005/9006
- Random idle issu's
- Dizzy problems
- obdo to obd1 dizzy help
- b18 swap in 89 si hatch wont start, but same motor ran fine in a 91 si hatch
- my ef was killed today
- y8 into ef sedan wiring questions
- f22/f23 crx
- intake and exhaust advice
- D16Z6 Swap help
- B Series Swap 89 Civic
- Harness Swap Question
- my EF Hatchy build.
- I THINK MY CLUTCH IS DONE????
- need help please
- d15b2 starting problems...!!!
- Need help with CRX wiring
- after MPFI swap.. codes 4,8,9
- My 91 hatch project
- 90 EF 4-Door Front Passive Seat Belt Issues
- over haeating issues...
- I'm needing some help identifying these vacuum hoses! (pic)
- bye bye ef :(
- What is this piece on my coolant hose?
- LF: DIY Ek sideskirts on a ef
- need advice on swapping D15b7 inside my hatch
- 90 hf with d16a6 runs for 2 sec and dies starts after and keeps doing the same
- Oil Restrictor Question, non V/T block + V/T head
- EF sedan project
- OK Radiator Repair
- Bisimoto & ANR header question
- b20 in a 88 crx si
- engine overheating? smoke from manifold area
- sohc zc non v-tec
- what to do what to do
- ? about ef sedan side skirts
- No acceleration...surging
- i need help
- EF sedan DX vs. LX vs. EX trim Q?
- need help with engine motor mounts
- Temp gauge help!
- need a picture of a honda part.asap
- si/dx engine wiring harness
- Del Sol seats into '88 Crx.
- 91 DX CEL/Misfire
- Please help…does anyone have pic radio wiring diagram?
- Quick inquiry: Speedo question
- D16A OBD1--Can I wire my injectors directly to the ecu?
- d16a6 weird cooling system problem
- need help with ecu
- Question about bar'ing and ref stations
- Weird Noise when trying to start my car
- I'm in need of some help.
- newb intro
- harness issues?
- Suspension bushings
- '90 Civic Wagon (hatch lift supports)
- help! only running on 3 cylinders
- oem radio / equalizer question
- MPFI swap problem
- car dead after washing motor. need help.
- just finished swap.. not getting fuel? 89 crx dx mpfi swap
- 90 ef hatch h22 project COMPLETE!!!!
- trans question
- finished zc swap, but engine stays at 2500 rpms while idleing.
- need some help with bar'd
- NEED HELP WITH LOWER CONTROL ARMS
- getting no power to the ecu
- 89 crx si d15b2/y8 z6IM (wont stay on)
- TURBO??????ZC sohc engine
- Question about sport seats railing.
- Temperature Sensor Problem
- 1990 crx dx sputtering at high rpm
- Si tranny on Z6
- Can I use 91 civic sedan front doors for a 91 hatch?
- rear disk swap
- Roof mouldings
- ? ground control sleeves?
- axle vibrate
- fender gap different, lowered 89 hatch???
- swap help
- Which starter for zc?.......
- Happy Hallooween....show sum pics of cosutmes! only EFerzz
- It just dies?!
- obd2 jdm d15b into 91 crx hf
- Distributor timing for max performance
- Is this a easy fix ??
- Hunting for my old EF/ Northern VA black civic..
- odd problem. z6 into ef - obd1, mpfi - CEL'S
- Do i have the correct shifter?
- help`
- irritating multiport problem!!!
- swap question
- PLEASE HELP!! DPFI TO MPFI WITH RYWIRE HARNESS NEED INSTRUCTIONS
- 87 crx si motor swap into an 1989 crx hf, Please help!
- EDM rear wing question
- gsr head in ef????????
- will the obd1 dizzy be the same as the y8 dizzy?
- OBD 1 conversion harness help!!!!
- OBD-0 Distributor on OBD1 Head
- Obd0 b16 throttle body gasket
- will a 4dr ef windshield fit a hatch ?
- HELP. 0bd2 GSR but i want to be OBD1. VAC lines?
- ef 4 door exhaust question
- small dilemma....
- trailing arm bushings HELP
- TO THOSE OUT THYERE WITH A DOHC ZC...
- 88 crx doors onto a 91
- Big brake question
- help!!!
- My new Momo steering wheel is off center, how to fix?
- d16z6 - heating/air.
- CRX HF or EF DX
- First EF Hatch build Thread
- which seats can be installed into crx.
- throwout bearing help
- Ignition lock cylinder stuck ON?
- OBD0-OBD2 swap
- wiring/dizzy issues
- toda flywheel on b16
- dpfi to mpfi
- New Crx Si Decision
- How much...
- Auto Issues, 90 EF
- ef sedan drumped spring rate question
- wrong place lock this sorry
- D15 ENGINE UPGRADES
- Just bought a 90' Civic Hatchback, questions
- Where to buy trunk weather stripping
- Did some work on the 4 door this weekend
- hf crx engine harness
- HELP NEEDED 91 b16a to 01 GSR
- Need Help on deciding which rims for EF9
- i need help with my color choices
- CRX High Idle
- roll cage???...from hatch to sedan
- should i buy this for 550 ???
- wheres the what did you do to your EF today thread?
- question about dpfi to mpfi?
- front end issues?
- spongy brakes
- ZC mystery motor
- Ignition Switch problem
- ~*'90 CRX DX STOLEN*~
- 89 bumper not fitting..
- Coil problem
- D16y7 head on d16a6 block.. help!
- can you make the corners blink the same???
- power folding mirrors
- Another crx hf d16z6 post!!!
- Removing B-series tranny same as D-series?
- got into an accident sell or keep?
- cant get the TB bolts off?
- Help leak in ef pass floorboard
- Wire harness question..
- One cylinder down! Help!!
- Question on Clutch
- wrong section
- HF mods?
- Bluish/blackish smoke
- rear lip question?
- RT4WD Offroad build
- good questions about 88 civic
- how hard is it to install - CIG Lighter and Clock in a STD hatch.
- front lip question?
- HELP
- starting issue...not the main relay
- DA knuckle swap question.
- What is in between the alternator and the battery?
- ef wiring issues
- Edm Guages in a usdm rex
- 91 si seats in a 1990 si
- Odd problem?
- rattling struts
- doing build need help!
- my mini me build
- wheel noise and alignment issue
- questions about ef9 jdm bumper
- help w/ skunk2 intake and throttle cable
- Clutch and Flywheel upgrade 88 Sedan
- What did I break?
- help plz
- crx / civic hood insulator
- RHD power window switches into LHD (CRX).
- hood bra dimensions
- DPFI to MPFI cel code troubles
- HF Egr valve
- civic pedal assembly question
- crx w/gsr swap
- ZC tranny with LSD
- low voltage at fuel tank wiring harness
