View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 91 CRX Si Build- CoCo
- 91 CRX Si Build
- Removing the Stereo in an '85 CRX??
- D15b piston question
- I'm looking for a b16 or b18c valve cover with breather and catch can if any one has
- Check engine light comes on after 45-50mph
- 89 DX Starter Motor
- Overheating still even parts been replace
- Sputtering!!! help !!! Please!!!😢
- Automatic Seat Belts
- 89 hatch swap help and questions needed
- EF2 B20 Vtec thread
- 1988 civic EF sedan clutch replacement
- 89 civic mini me NO check engine light but throwing code 8
- Fuel Sender Unit
- 91 Civic mpfi swap surging on light throttle
- Help! Obd1 b20 swap engine light
- wheel cylinder
- 99 Civic Si cluster into CRX question
- Oxygen sensor and ELD problems
- JDM Crx seats
- ef6 1st Gen DOHC ZC swap HELP!
- cluster wiring issues
- Civic Ef headlight problem
- axle seals
- Does anyone have experience shipping Ef RHd conversions?
- Seats that fit
- auto 2 manual wiring prob
- 91 civic dx signal light issue
- Axle question...please
- 91 cluster swap into 88 sedan
- 1989 Civic DX complete new manufacture/aftermarket knuckles?
- ef sedan dx rear disk conversion
- 1990 Civic Hatch dash lights
- 91 ex sedan rear disc conversion/DA integra RTA questions.
- Iacv voltage?
- B18CR Swap dies while driving, starts back up though
- Quaife LSD for edm ee8 crx
- B20 swap wont start with ignition
- 91 Civic - no crank problem (solved)
- CRX vibrates under acceleration only
- 91 CRX Vacuum Question
- unidentified gauge
- Trunk head lining leaking down to c-pilar leak
- wiring issue plz help.
- Crx power window help
- sedan trunk lights dont work
- CRX Lower Door Molding Clips
- 88-91 Crx Si front rotors and pads same as Std/Dx/Lx?
- iacv coolant lines?
- Axle issues
- Mini me swap code 4 need help plz
- Cargo capacity adding weight? Check the wiki
- Best engine swap for an automatic 1988 civic sedan?
- 1990 CRX Left/Right Blinkers Stay ON Solid (wont blink)
- Iacv 3 wire to 2 wire conversion
- 91 Civic where does this ECU/ECM wire go?
- D Series Mini Me Swap Help!!
- B18b1 motor mount conversion
- Wiring obd1 to obd0 in an ef civic
- creaking sound while turning steering wheel in hot weather
- 91 hatch shifter linkage problem
- My CRX si Died can you HELP?
- Push button ignition
- aftermarket tach
- Extended ball joints in stock somewhere?
- Anyone know what this part is called? EF Auto trans
- Sort of Noob here. Send help!
- Interchangeability - Si and Std Clutch/Flywheel
- 91 honda civic hb si bumper to replace oem 89 honda civic hb bumper
- Losing Coolant and loud THUNK
- 89 honda civic 4dr 1.5no crank no start...
- Honda Wheel Bearings and Hubs (Where to Buy)
- imported CRX....help
- fuel tank modification to reduce fuel slosh & cavitation
- New to Hondas. Would like some opinions for my EF Civic Si
- boring a 1.5
- 91 civic sedan stalling and/ or dying when coming to a stop
- I smy flywheels any good? (pics inside)
- B2/z6 mini me swap help
- 89 CRX dash vents arent working
- Clutch won't engage!
- Idle issue and awful mpg
- Front caliper help stat!!!
- walbro 255 not pumping below 4 gallons of gas?
- Jim Sir CEL
- 91 Civic Wagon Z6/A6 issues
- B20b build help
- Measure bore size with regular caplier and bore gage
- Easiest way to rust roof my civic
- 89 Civic DX Starting Relay
- Weird Electrical Issues
- 91 RT4WD subframe damage: weld or replace?
- Code 8 TDC Sensor
- The $300 CRX -- Electrical Work
- How to add 12V outlet? The easist way...
- A6 to Z6 Swap; Vtec doesnt engage and car bogs when warm - Lemons Race Tmr Pls Help!!
- need some help on d15b2 build educate me lol
- Door Glass Stopper R/R
- Annoying Problem: Tach Showing Zero at Idle (PLEASE HELP!)
- Lsd compability for y2 gearbox (edm crx)
- Need EF Hatchback Parts
- Fwiw: rocket bunny s13 front flares will work on an EF.
- No spark 88 civic dx
- Anyone know of a NEW OEM replica EF9 lip available!?!
- Crx door trim!!
- Need help! Ef build b20b swap
- EF B20vtec ecu help
- transmission wont budge off
- Help ignition timing
- Need help!!! EF Brake question
- Need a crankshaft pulley bolt DOHC ZC
- 91 EF hatch Speedo issue
- Quick Steel For Gas Leak
- D15B1 engine bell housing bolt size
- 88 CRX pulling at HWY speeds
- Best air intake for b16 crx
- 89 DX Auto Transmission Install
- 1990 HF Exhaust Replacement
- Anyone Here Ride on 16's?
- !! HELP !! Just B16A swapped my EF, throwing codes 4 and 14
- Cooling system acting very weird
- ls b18a1 crx transmission - hard to shift
- CEL relocation?
- Help with pedal removal
- What distributor will fit on a JDM OBD0 B16A?
- Hey guys need help fixing my hazard lights on my 1991 civic
- 91 crx si clutch issue
- Starting Issue
- Custom crx ef8 exhaust piping: 2.25 or 2.38"?
- My 1991 Honda Civic Hatchback need to pass inspection at DMV..Needs proof of "airbag"
- 1991 Civic Dx needs to pass inspection at DMV to get my car on the street
- B series swap to my 1990 Dx help!
- Automatic Transmission Questions
- Mounts ef hatch
- Should i B swap my DX?
- New owner, Worried about engine. Help me please
- kanji
- Testing fuel pressure regulator
- MPFI swap still having issues.
- Lower Fender Garnish Molding Skirt CLIPS?
- 88 CRX Questions
- 1991 Civic hatchback stock 1.5 L..gauges are not working on my dash, only my speedom
- is my old/bad CRX Master Cylinder worth any value?
- What CRX's are carborated and which are direct injection?
- CRX engine swap
- Its Hot and No Air Conditioning...HELP
- MPFI swap won't start.
- JDM D15b dual carb idle misfire
- Use axles from prelude in CRX with B-swap?
- Possible valve damage
- CRX spring rates for street driving
- How hard to transfer all AC components from one EF to another?
- Exospeed Cams
- Wilwood Dynapro on EF8 crx
- Dc2/ek/eg invidia exhaust on EF8 crx
- 90 crx lock cylinder replacement.
- Failed smog 15 mph HC (PPM)
- EF manual
- 1988 D15b2 Distributor
- EF Distributor - Did I fried anything?
- Ef b20 swap code 16
- Bisi header B series fitment/pointing up
- What seats are compatible for my 88 EF seating rails?
- Need help identifying a part #, door lock rod clip
- 91 EF hatchback tranny
- Iacv?
- Rough idle
- crx clutch safety switch wiring
- Will em1 seats fit on 88 hatch seating rails?
- B16a2 knocking
- 89 crx si wires into 91 civic hatchback
- DOHC ZC Exhaust Manifold in EF
- What is the benefit of silicone radiator hose? Just cool look?
- Emergency Brake
- Honda civic D15b1 throttle body different than b2
- internals of s80 fits on y1 / y2 tranny ?
- Remote start on a EF?
- 89 Civic Wagon need a little more horsepower
- Jdm b18 gsr?
- 91 ef si swap
- RPMs drop, oil light, temp gauge rise with headlights ?
- New head gasket time
- bogging/hesitation/misfire on slight inclines
- ECU issues? CEL on, no codes.
- 1988 Civic AC
- Front Upper Engine Mount for 1989 Civic DX
- Innovative traction bar install help
- 91 civic crank won't start, ECL won't come off
- Injector/Ecu issues 89 hatch OBD0-OBD1
- Help Civic Wagon RT4WD to LSD/Fwd
- Door Part Name Needed
- IAC question
- New to honda's Have a 91? civic si need some help
- 89 hatch dohc zc swap reset timing but coolant tank gettin hot bubbles after turn off
- Curt hitch on Ef hatch
- Rear shocks
- Disc break conversion (searched but have more questions)
- crv-tec swap in an EF HX HB
- 91 civic brake lights won't turn off.
- Distributor wire
- Couple Noob Suspension Questions
- 1990 electrical issues
- Oddisey PC680 Battery in crx ef8 sir
- Awd using mitsubishi components
- Dash lites stay on
- D15b7 top end radiator hose
- Clock test
- Sh*t kicker hondabox
- Wagovan conversion help
- 91 Sedan seat rails
- 91 dx hatch - B20 crank pulley hits radius arm
- Need USDM obd1 b18c1 (GSR) Engine for my CRX
- EF Sedan Wheel help
- trip meter quit
- 89-91 Civic Si Hubcaps (wheelcovers) and steel wheels
- 90 civic hatchback - CEL on steady
- 1991 EF takes a few crank to start up while cold, does it mean fuel pump getting bad
- Possible to swap D15Y3 from 04 civic into 88 civic sedan?
- 89 wagon dx cabin harness same as dx hatch??
- 91 Wagovan - replacing cut A/C lines
- mild track car build (Canada)
- crx vtec b16 turbo (350 hp) - How do I strengthen my transmission?
- Smoke/overheating 91 Civic HELP
- Can anyone tell me what I'm looking at?
- 90 Honda Civic Fuel Relay
- Swap b20b into 91 civic hatch - Having a hard time figuring out my harness situation.
- BWR subframe brace, sway bar in the way
- 90 honda civic si - Crank no start, no fuel, no spark
- Looking to get back in the EF game, need some advise.
- Crx front bumper support
- 89 CRX DX barn find with history. no start
- 1990 CRX SI - CEL Code 1
- Need some opinions here! cat converter
- Simplified Chassis Harness ?
- Bypass main relay Civic 91 Si
- CRX, no crank - Check the...
- 89 Crx Si - Troubles finding purpose for dash wire
- Snapped bolt on LCA
- RT4WD wagon - Do you think the smog test tech tried to rip me off?
- CRX Si ZC D 16 1.6L SOHC 16v cam spec
- I can't slam my ef!
- Civic 91 crank, but no power to dash or ecu
- Help with swap ideas
- 88-89 civic edm/jdm clusters dimmimg
- Stock 89 civic wagovan no crank
- Project War Wagon!
- rear bumper support for 90 civic si
- The dowels
