View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Spoon Carbon Wing Mirrors
- WHICH TIRES ARE BETTER? ADVAN, FALKEN ZIEX-512, OR AZENIS SPORTS?
- Do OBD1 spark plub wires run on a OBD0?
- Adjusting Coilovers
- parts list for d16sohc v-tec swap for 89' ef
- what would make my fuel pump. not prime?
- engine heat killing starter?
- i did 88-89 to 90-91 gauge wire pinout
- sidemarker question
- a6 help
- check light engine on after extending wire on o2 sensor to dc 4-1 header.
- Use DA rear LCA's in order to mount DA swaybar in LX?
- vtec and redline
- one more quick question
- Cluster question
- where to get steel braided lines
- rebuilding for turbo need help
- CEL (SEARCHED)
- OBD question
- B18C into an ED
- buying crx
- DOHC ZC swap, no spark still!!!
- es muffler
- B16 Dizzy Question
- knocking and popping noise? lsd diff or tie rods?
- crx si cabin harness in dx hatch question
- b18c1 into 90 crx - utilizing stock oem gsr intake manifold dual runners
- SOHC ZC head swap - anyone in CA do this yet?
- Sedan/wagon seat belts
- Megan Header for a 94-01 Integra?
- d15b vtec into a 90 DX CRX
- which crank pulley for ZC engine??
- MAP sensor bad?
- 1\4 miles times
- Camber Problems
- what does crx mean?
- which bumper support for ef9 bumper?
- Jacking point in rear quarter
- TIRE SIZES FOR CRX~~~~HELP~~~~~
- D16 Head on D15 block....
- Whats the best why to port Intake mani for bigger t.b. ....
- I want to swap to obd1 and I am getting a new Intake Mani, AEBS prolly will it be direct bolt on..?
- battery relocation in ef questions
- does fan push or pull
- how can i make my 90 crx hf lighter
- Bolt Size and thread pitch for CRX Tow Hooks?
- Jackson Supercharger question
- Oil is leaking out of my distributor
- speedo jumping
- Anyone know what this is?? Found it in my CRX Si.
- Tried searching for a whole day... Need a picture/drawing or schematics of HF Engine harness
- car stalls unless i apply throttle and hold it
- EF hatch SIR spoiler
- Are these Junk?
- turbo/engine suggestions needed..
- ef love
- d15 LX sedan won't start?? symptoms inside, help please!
- TURBO OR ALLMOTOR?
- weird idle problem?
- Rear Speaker wires? 89 civic Hatch.
- Can You Say S2Sedan?
- ef side molding...differences??
- E-brake light problem...
- Any Writeups with pictures on wiring a b18c??
- ODB0-ODB2 Dizzy help I think. Alot of work that isnt right
- what does this mean??
- gauge cluster question?
- engine damper *searched*
- Best CIVIC Catback Exhaust...Vote Now!!!
- jdm power mirrors: what would YOU pay?
- my new rex..let me know what u think..throw some ideas
- will the d15b pass smong in a 93 honda civic coupe
- d15b2 turbo
- Strange idle/throttle response I DARE you to figure it out
- Car that had B-series vtec swap but now just a shell that im going to put a D in, wiring?????
- OBD1 b16 in a 91 si?
- B16a
- s2k seats into a 90 ef si
- code 1 o2 sensor.
- Anyone intersed in Guage faces?
- Apexi WS2
- quick question
- what would cause my battery to drain?
- whats the catch to these silicone coolant hose
- HELP! ! ! Coolant leak, couldnt find in search or manual!
- water vapor injection
- rough idle and driving
- mini me question
- b18a1 stock flywheel
- My 91 Crx Dx build.
- anyone from spokane in here?
- Need advice on buying a civic
- Pretty much done with my Wire Tuck. Heres a few pics!
- Cam gear on d15b2 ?
- Y1, S1, J1 Tranny in Crx
- anyway to test stock antenna? awful radio reception
- wiring on the tail lights
- rear disc brakes
- suspension question
- Anyone in New Jersey...
- Hood Fitment
- directly wiring gas guage
- mpfi, obd1 d15b2
- it runs!!!
- dizzy maxxed out 15 degrees BTDC
- Center Console Swap
- crx with integra brakes info?
- engine rotates but no start?
- has anyone ever had an ingles camber kit slip on them?
- CRX front end on a Hatch ?
- What can you take out of the engine bay, that you dont need....??
- Code 4 @ 4000RPM's in 5th gear.....your opinions, please?
- molding question
- Wiring Question B-series swap
- need opinions on the first thing to buy (motor wise) for a dseries turbo
- scrapped window
- Help with codes please.. 3,4,6,16
- fuel pump ?
- 1990 Civic DX B16 swap
- zc compression good for turbo?
- gauges
- charcoal canister
- d15 vtec
- Autopower roll bar fitment?
- 2 cams quetions
- Need Help ASAP , car keeps shutting off
- OBD0 to OBD1 dizzy wiring...
- guages for 90 crx dx
- Need help on Brand and Interior paint color for EK arm rest install
- 1.5L distributor VS 1.6L distributor
- 2nd Generation Civic
- Heated mirrors on 88 hatch?
- Vtec Oil Pressure Switch Help
- dash mounted gauges???
- New wheels, will they work?
- A tug toward the dark side.....Jackson Supercharger question
- wiring fan to run all the time
- can i use a crx dash in a hatch
- Rotor Question
- Keyless entry
- 91 civic hatch rear speaker question
- Will Tein Flex will fit a CRX ????????
- PLEASE HELP! What the hell did i do?
- it
- Chassis Blueprints
- 4 wire o2 sensor
- building my crx...reliable??
- Crx Cluster Will Work on my 89 Dx Hb?
- Wide Body
- where can I get wide body fenders
- hatchs headlights on a 4dr?
- Anyone used this tranny oil?
- Saddest post I ever had to do: Saying good bye to my One and Only 1st CRX
- headers?
- 1.6l head on 1.5l block
- Question on hood release
- Climate control unit
- Did I get ripped on my new battery
- sir front end suggestions
- 89 CRX Si with DOHC ZC wont stay running
- Need websites with complete SOHC swaps, please.
- bumper support
- acceleration sputter...
- zc ?
- Radiator fan question.
- battery in the back
- 1988 crx dx brakes dieing
- si trans on sohc vtec
- Distrubutor Cap...can this ruin gas mileage? (D15b2)
- need a new clutch for a z6. which year do i buy it for?
- Front tranny mount
- jdm bumper????
- having hard time launching at proper RPMs?
- C1 head with B20B bottom?
- chassis code?
- Car goes back to idle too slow from revs
- 91 Civic HB w/ B16A Swap....AC Belt Change
- check engine light on code 1
- HF Tranny with SOHC Vtec setup
- Cobalt SS s/c?
- Integra distributor on 1990 zc
- Need Help with seatbelt indicator beeper/lights.....sporadic issues
- iacv leaking coolant
- adjustable cam gears
- parking lights randomly come on when brakes are pressed
- Injector Resistor Box for 88-89 teg
- vtec.....
- engine project
- Axle problem ?
- have a question that needs to be answered!
- smog laws and referee question b16a
- fuel issue
- CRX sunroof cap??
- Possible to Bypass MAP on OBD-0?
- Repainting a hatch need some help.
- 91 civic wagon 2wd weird things happening!
- CRX Si question
- Traveling questions????
- throtlle cable sticking
- VSS??
- thinking of turboing my crx
- tranny wet with oil
- CEL???
- K24A2 crx??
- ..another crx build!! Tucked and stripped!
- ECU Question
- linkage
- Valve cover gasket.
- does my crx come with power steering?
- ignition
- aluminum flywheel question
- car wont idle right after valve lash adjustment
- Jdm crx hood where can i buy one
- lower radiator hose with swap
- std: wire harness b16 ? ls/vtec? how to clear hood
- what ECU?
- My EG radiator in an EF thread
- Need help...CAR NOT STARTING!!!
- speedo cable on a b16 crx swap
- Time for a traction bar...need help picking one
- Is this safe?
- Glovebox gauges....
- anyone with a crx sir or europe crx vt?
- fuel injecotors
- cutting interior for rollbar, any tips?
- Help with AC install/problem plz :P
- Swap posterior brake DC2 -> EE8
- Will a D16Z6 vtec solenoid fit B16A1???
- I am searching for new taillights for my ED civic from Denmark
- B18a1 to crx si
- Swapping in a motortranny question?? It's an easy one for someone who knows!!
- b16a1 distributor cap?
- rywire customer service
- question about my vafc controller? programming n how to use?
- o2 sensor on dp, necessary?
- front brake questions
- I have Acura TSX HID Kit. I need Help installing it...PLEASE HELP!!
- BRAKING PROBLEMS... MANY HOURS OF BLEEDING.. STILL SLOPPY.. PLEASE HELP
- turbo on k20 in ef
- need help with...
- What year civic will..
- exhaust
- Will this engine harness work with the swap? Help please!
- CRX VTEC Tuning
- Emissions smog and 1G B16 setup FYI
- Need GSR Axles! Anyone know the cheapest Place/Site???
- Civic swap-which model/year is best for B series swap?
- D16A6 to obd1
- SERIOUS ISSUES
- D16a6 mini me with turbo
