View Full Version : Honda CRX / EF Civic (1988 - 1991)
- D-series alternator interchangability?
- Hey Guys
- HCP MOUNTS???GOOD??? Lifetime warrenty??
- a stupit question on how to drive
- Si cams into a d15b2?
- flywheel question (search=down)
- 88 four door project still in the works
- Are all OBD0 sohc distributors the same??????
- Bumper Support
- What kind of gas milage does a b series swap get in a crx
- 89 civic gauge cluster
- "Shaving Rain Gutters"
- 92-95 Prelude seats?
- oil pump/water pump
- how does the dizzy go in, does it matter?
- traction bars
- crx radiator
- Apex-i World Sport Exhaust
- coolant bleed screw piece
- 90 Si EF hatchback STOLEN! in COLTEN, CA.
- 4 Large Coolant/Water Tubes (under t/b / iacv) WHERE DO THEY GO! D16a6
- need help on how to..
- whos got roll cage with interior
- engine rebuild kits?
- Painting Mouldings Yes or No?
- d-motors need input
- Friend Kyle's EH2 Civic.
- mini me swap manifold question
- Transmission service question (search is down)
- conversion
- B16b with cable Trannie????
- Swap to a DX or Si Gauge Cluster
- Brake Bleeding help...
- search is down, quick swap question.
- Cars drives itself into my refrigerator
- Tranny problems, need help/advice?
- my reverse lights turn on in 5th
- starting problem with ls crx
- what is the best brand for cams and cam gears?
- ECU HELP!!!!
- White smoke out of my 91 si?
- 91 crx HF vs SI
- oil pan gasket
- integra front suspension
- Mini Me on a 91 CRX HF
- Front knuckles
- Need help w/ speedomter *search server down*
- fog lights junk yard find
- for your b16 swap did you have to get a new throttle cable?
- can a d16a1 fit
- Worth it to do this work?
- I bent them again... WTF
- i need new shocks
- Looking for an EF squad sticker any luck...
- 88 CRX door panels and dash fit into 91 EF?
- would a 88-91 underdrive crank pulley fit a 96-00 d16y7?
- Pully issues PLEASE HELP
- 4gcivic.net
- hmotors / passwordjdm question
- crx/civic quarter panels
- need explanation of #34 in parts diagram, goes between outer and inner tierods ???
- It's official, I'm a ricer. VIS JDM UBER USDM HOOD - OhSNAPZ unPimp yer Ride!
- Machine specs for LS rods in ZC
- brake fluid leak from piston
- Need some advice for tuning
- CRX w/ b16a suspension poll.
- code 16?
- need 89 civic ecu wiring diagram
- Add Air Conditioning to a Civic
- wtf this ever happen to a fuse in your car?
- Which intake for......
- Honda crx B16A engine, rattling, tinny noise when driving, any suggestions??
- Anyone swap '92 integra dash into their EF???
- New rex, any ideas? <=puts flame suit on
- buying a 91 crx with 91 b16 jmd motor
- can i... and how... can i chip a pm6
- Axle boot broke and got grease on inside of wheel
- Noob question about saving the environment
- Re-did brake lines....fluid only goes to 1 wheel??????
- Anybody Running a B Series w/ Power Steering?
- New Owner, have a few Q's
- Parts Question - '87 HF
- mini me???? what head is better
- B16 head/B20
- What kit is this?
- b16 clutch in a b18b1?
- A couple OF questions about my swap
- JR supercharger on d16a6 stock?
- Exhaust question.....
- what would be funner
- Bodywork question...
- AC conversion
- brakes..... very spongy cuase?
- AC Doesn't Work After Swap!
- crx siR core support.
- hey can some tell me step by step how to relocate my batter
- engine harness
- crx dx and a d16z6
- swap shops
- hehe any one got a driver side fender?
- help please
- a few questions
- need LR lca
- UpDaTeD EF Build 89 hatchback :)!!!!!!!!!!!
- D15 VTEC swap question?
- will this trans fit
- dohc zc trannies fit sohc d series?
- suspension help
- what usdm honda trans will work with b-series swap?
- how do u change pads on my integra rear disc breaks
- AC help plzz
- Guy I need help i have a rywire harness
- ebay cat
- Crank sensor?
- rear disk breaks parts Q:
- sfc-vtec controller
- vacuum lines?
- Guestion about coolin fan not working after swap.
- code 9 CYP even after a new dizzy
- what Short Shifter ....searched
- Scary steering/handling.
- fender question!!!
- Air intake for ITC Civic
- I need stock engine mounts for my d16a6
- swapping b16 longblock
- Is it possible to make a v-tech controller?
- Quick HF questions?
- All original 1990 EDM CRX VT on eBay
- JDM siR front end
- heads up display
- Idle jumps between 1k and 2k PLEASE HELP ME!!!!!!!
- need help D16a9 in a 91 civic
- tell me what it's worth
- My car starts then dies halfway up to idle.....Main Relay???
- Moving fuel filter
- wiring harness
- Help with Speedometer and VSS
- help me out more starting issues :(
- In need of 90-91 crx headlight assembly....
- HELP! DOHC ZC in and D16A6 out but my ZC isn't running right
- ZC axle? ZC experts needed
- HF 13" wheel too narrow for 8" wide slicks?
- dohc zc allmota
- need a new clutch dont know what to buy
- dash light not working
- 88 Civic DX Sedan....gauge problems.
- Auto Pr3 Ecu into manual ef
- what sizes intercooler for my 91ef??
- gsr swap
- aftermarket clutch cylinder to ease clutch pedal engagement?
- glass top
- NOS dyno #'s
- Newbie Question: How to tell what engine type is in CRX?
- QUESTION QUESTION QUESTION!!!!!!!!!
- Problems with Swap b16a
- honda-tech vinyls?
- SiR HOOD AND VIS MUGEN BUMPER?!
- what distributor to use on 90 hatch woth jdm b16 obd 0?
- HAVE oil in piston...need help
- question on crx sir engine
- I want to tuck my 91 Si.
- itr's?
- What Color Rims Would Look Good With...
- Need wiring diagram for obd0 b16
- Blinking ECU woes after swap...
- d15z1 Vtec E revvin help PleaZZ
- brake light problem??
- b16 crx headers problem
- my poor crx
- confused. cant figure it out.
- '99 Civic Si CD Player in a CRX...searched
- 90-91 License Plate light question
- help how do you do a cable to hydro swap
- B16B Valve Adjustment
- VACUUM MESS *Cluster FTuck* How Do I Get Her Hooked? A6/Z6/Venom
- chipped p28
- V-Tec Head?
- Pinch bolt on shock fork not coming off
- SOHC ZC work.
- TROUBLE FINDING EF9 SIR PARTS
- B16 or B20 w/VTECH?
- Pic request of intake manifold and map sensor
- Help with B16
- Filling the Tranny
- How to tell the difference from 88-89 and 90-91 crx gauge clusters?
- how hard is it to swap a b16a1 in a 89 civic si?
- another ef civic saved!
- Questions on A/C Install into CRX DX with a/c to begin with
- lug spacing?
- converting to vtec
- what wheels wolud be the best choice for my EF??
- Anyone have Omni Power for their CRX/EF?
- Vtec oil pressure switch
- does any one know were i can get a wiring diagram for OBD0 b16a vtec help pleazzzzz
- !!!Help please!!! ???Ignition problem???
- NO VTEC TO VTEC ????????????????????????
- QUESTION??? would a 88-91 d16a6 intake manifold fit a 84-87 crx??
- where can i get a glasstop roof in canada for my crx
- manual to auto trans...
- 85 crx si AFC install map is different
- Rear trailing arm bushings...
- OBD1 Conversion, wiring in 4 wire oxygen sensor
- 91 civic si thermal exhaust
- D series alternators interchangeable???
- Vtec not working??
- DA rear discs brake line hangin down.....
- Fuel pump not working. Please help.
- Is my alternator/voltage regulator going bad?
- EG DX motor into EF DX...
- help fast please
- Axles breaking
- WTF......I'm no mechanic, but something is wrong with this picture...:(
- rpm
- interior help
- Ef hatch with DOHC ZC swap Axle Question
- Need opinions on which CF hood.
- Transmission fluid leak..
- d15b2 in a 91 crx si, what all is needed to do the swap?
- turbo crx exhaust
- Emissions SUCK!
- 15" Space Saver Spare Tire?
- lookin for better brake on '91 civic si
- Help leaning air fuel ratio
- Help: Swap a first gen jdm b16a to a 1989 crx si
- SiR Headlight Options
- ecu question?
- noise suppresion for the EF
- Building up the HF
- Im curious if the Y-49 curse applies to this car as well?
- Started making CRX bass tubes (pics)...
- shaking when i get on the gas
- boosting problem!!!!
- b16 running like shit please help
- where to mount external fuel pump?
- 1987 Honda CRX + B16 motor??
- Can integra a/c system be swaped into a crx
- Can someone tell me what my transmission options are for my EF???
- 87 Civc/CRX questions.
- Electrical problem with 91 EF!?!?
- distributer king question
- stuters when i hit 3500 rpm help
- headlight problem (searched)
- Rotten Egg Smell = Catalytic Convertor gone bad ?
- Checking the three grounds... Where is this one?
- need some opinions on some cheap springs and a camber kits
- READ THIS AND HELP LOWER GAS PRICES!!!!!
- Need help with problem with B16 swap
- ZC mini-me, sohc?
- Quick Release Horn help.
- Will the 1988 Crx Si Suspension Fit a 1991 Crx Lx
