- May be a Dumb Question, suspension related
- brake rotors and pads question!!!
- Pressure plates
- Getting D15B3/4 to run without harness (it's carbed)
- Three questions on my 89 civic si
- ef hatch pr windows
- 89 and 90 Si clusters
- power loss problems
- Exhaust Leak Downstream of Cat Affecting Emissions?
- My 91 ef
- Rear drum assistance is needed inside!
- 88 CRX Wire Harness Issues!
- random puddles?
- relocate battery in trunk
- dpfi to mpfi won't start
- coilovers
- crx wont start code 16 no fire
- newbie saying hello
- Aftermarket front and rear bumper.
- Firing order help!
- dohc zc dizzy
- automatic crx motor mount question
- Help with 91 crx si taillights????
- Automatic Crx Problem
- quick question
- 93 O2 Sensor Fitment
- What spindles for B16 swapped 91 hatch
- 91 crx with b16a swap, distributor question
- annoying seat belt problem
- crx shocks
- .... help ... what is my EF worth?
- need help changing front bumper???
- Serious Valve Train Question b16a
- PCV valve location on a DX
- Fuel Pump Question
- b16 trans
- axle wo need help
- my crx wont start
- HELP. I NEED NEW B16! where should i order from?
- car starts then dies help! plz
- aftermarket header question
- need help baring pbd0 to obd1 in my ef
- What wire for the autogauge tach????
- just picked up a ef9 sir front end need help!!!!
- Inside crossmember thread strip help!
- 02 sensor problem
- Quick wire question
- GSR going into my EF tranny question
- hatchback door windows
- 88' crx?
- Quick question on my EF
- simple brake question
- crx si seats vs. hf seats
- engine harness quick question.
- HELP!!! car struggles before vtec and runs really cold!
- Help!
- pcv valve woes
- how to fix cams and cam gears for perfect timing
- Solid poly motor mounts too noisy
- 1991 LX Seatbelts
- timing belt slipped while cranking bent valves?
- b16 pop after shift
- Sometime vtec....
- were ef9's sold in canadian domestic market
- Need help installing Knock off type R seats!!!
- Getting Ready to Start MPFI swap.
- anyone got a dash wiring diagram for a EF?
- HELP. B16 is going to die!
- What does this connector go to?
- 91 sedan going for "touring" ride
- What is this, and where does it go?
- Transmission HELP
- will stock eg springs fit on ef
- OEM Honda keyless entry unit in crx???
- Wiring hell-p.
- Idle circuit out of Whack after cleaning TB and IAC
- Lock actuators for a CRX?
- legend brakes
- need help obd0 obd1 almost done just need a few things
- h23 frankenstien
- Lock issues
- Floor vent from a DX
- anyone got a dash wiring diagram?
- z6 wiring question?
- What clutch for dohc zc?
- swap question for d16z6 or y8
- ebay clutch question
- cluster plastic front
- 91 EF hatch...
- Engine removal help
- Door panel disassembly?
- d16z6 swap in 89 hatch?
- ecu question
- car idle question
- Got My car smogged today and guess what.
- Slack in the clutch pedal??
- need some help SL3 cabel tranny
- obd0 converted for b series harness - alternator problem
- chiltons-style reference website?
- balancer pin
- Help identifying ECU and possible solutions for..
- DPFI to MPFI???????????
- b20 ef swap help
- d15b2 cheap/free power?
- radiator and fan
- EF Hatch. How to spend money
- mpfi question....
- Getting no fuel or spark
- obd0 injectors??? boost Q..
- wagovan swap!!!???
- ukininam
- lowering seat height
- I have a Ef sedan.. Changed the Chassis harness..problems
- tachs ??
- Can the FITV & IACV issues cause...
- D16z6 swap help!!!
- Is it possible.
- quarter panel question
- I need a D-series guru!
- Alt help
- squeaky rear window?
- b16a boost
- JDM Front...
- D15b2 spark plug wire order
- WANTED: NorCal CRX HF for Automobile magazine feature
- wheel offset!?
- Lights stay on
- I broke the rex :(
- 89 civic hatch d15 dualpoint sputtering
- Ls in crx bogging
- returnless fuel system
- Need Help Clutch Problems???
- crx omni power drag launch coilovers
- Auto to manual
- Reluctor wheel swap from obd2 to obd0
- Is this a good 1/4 mile time for my setup?
- front shock removal help
- ZC single cam or dual cam??
- taking an ef across the border
- Engine mounts help
- ef coilovers
- O2 Sensor....?
- stock crx si w/ jdm b16 ecu
- Nervous steering....
- broken trany mount weld
- Starter question
- in need of help with tophats! please help!
- Rear jdm fog light install.please help
- timing belt
- D series sohc VS. ZC SOHC
- Mpfi.
- Please help!!!
- can I run a 0bd1 distributor of an obd0 set up???
- idle problem
- crx not starting
- Starting problem after DPFI to MPFI swap
- 92-95 civic seats in a ef
- Check Engine Light question
- 92 GSR transmission Identification
- s2k seats
- 91 Civic dies after 20 mins
- 91 HB SI Gauge cluster in 91 HB STD?
- Please help, car cranks but no spark!
- car wont move
- converting 90 crx to obd1...
- Rings are shot....
- Dont neglect changing your pcv valve
- switched cluster and tach wont work
- would a wiper switch from a 93 ej1 fit in a 88 civic dx hatch?
- lowering spring question...
- 89 crx si oxygen sensor question
- tranny ID
- stripped headlight adjustment screw
- B-Series question?
- How did you mount your slim fan?
- crx dash in civic
- b16 swap help
- car sways side to side HELPP
- Door speaker pods
- greddy sp exhaust
- P/S rack vs. manual rack
- crx starts and has red light steady on ecu
- CRX no longer available parts thread
- 1990 lx auto harness into a 91' lx manual
- Crossmember Bolts n Nuts Question.
- 1990 honda civic HB Si
- alternator belt
- I need a pic a pic of where and how...
- obd0 harness with a obd1 alternator
- Clunk..only when it rains?
- theft proof crx???
- smog HELP
- head gasket help on a dual point
- HF Bumper Supports all the same for 88-91?
- what A pipe for B16a on crx
- I dont know how to install my throw out bearing!!!!
- Windsheild wiper question
- Oil Weight for stock 89Si
- 91 Civic with Code 1 problem
- Piston & Rod differences: D16A6 vs. ZC/D16A9
- cant search! loose timing belt
- Hood not staying full closed???
- match up a hatch ebrake cover to a crx console?
- Just bought an 88 crx si.
- Hasport clutch master adapter help
- a couple bay area night pics!
- Idle issue, bouncing.
- Largest diameter 4x100 rotors.
- Help!
- exhaust help
- ef civic/crx crews
- 1990 honda civic DX headlights
- Where to mount front tow hook on ef
- Where is the starter relay located on my 89 si?
- ZC DOHC swap qustions
- Help! on MPFI Conversion
- Quick Question, please help!
- j's racing front bumper???
- subframe issues how to take out steering rack?
- teg 1.8 in 89 crx??
- 91 civic hatch with mpfi having problems... help
- Any EF with power steering?
- Relay Problem
- found somthing in oil pan
- 91 Dx Hatchback...Swap Options, Budget, Opinions Needed
- help with lights
- Question about increase in CRX stock weights
- crazy vibration when braking
- Car randomly dies
- jdm crx sir front sway bar and end links
- wiring diagram for gauges
- Obd0 B16a new swap-Wont start
- Car will no longer start.
- Where to get pass. mirror block off?
- which on is the molding
- car warms up and then shuts off
- Headlight Question
- Will a Z6 head...
- Any other EF MySpace pages out there?
- gauge problem...odd one
- HEater control swap
- crx sir2
- will DA cluster work?
- Stainless brake line question, what fits
- What is wrong with these pictures?
- d15z1?
- Turn signal indicator question
- b18a1 starter and alternator
- crx tach goes crazy at 3G or above
