View Full Version : Honda CRX / EF Civic (1988 - 1991)
- problems with b16a1 91 crx
- What RPM Do You Turn?
- Can someone help me with some parts for b16a1
- Header swap question....
- Need a diagram of wire ups for Fields Boxer Series Vtec Controller for a CRX!!!!
- Can I have Sunroof instead of moonroof in my 88 CRX Si?
- Climate Wiring diagram.
- JDM cluster Fitment issues
- Edelbrock D16 turbo kit in EF hatch
- tranny question
- wiring problem, temp gauge is acting funny.
- D16Y8 into my CRX? What else will I need?
- How much hp gain from port/polishing D15B2 with HC pistons?
- will jdm eg6 disc brakes fit on crx?
- Check out my new muffler
- What you guys think of these Ebay ef civic APR mirror replicas???
- b16 error codes
- is the crank pulley on zc a right hand thread or left hand thread
- Where do I post me ef civic for sale
- tranny fluid
- DIY EF engine bay paint. Your neighbors will love you for this!
- biggest wheels on an EF civic?
- who drives the lowest EF?
- dropzone coilovers
- yep, another check engine question
- My arm is tired.
- OT: How do people treat you in your EF/Honda
- GSR in a CRX???
- Y8 mani Mpfi swap question
- Problem fitting a Koyo Aluminum Performance Radiator in my 89 CRX!
- JDM EF headlight question.............
- how do you remove 91 crx door panel?.. can't figure out seatbelt
- New meaning to the term "sunroof"
- SWAP ISSUES, B16 to CRX
- SHOW ME YOUR ROLL CAGE SETUP PLEASE!!!!
- wtf is this ?
- tranny swap questions
- How much does my stock 1989 Civic 4 door sedan dx weigh?
- b series swap in a 5th gen
- PLEASE HELP ME. Need auto-seatbelt schematic
- Installed JDM Rear Speaker Tunes !
- Injector Problem >=O
- What woud happen?
- 88 crx dx BUYER
- Dyno Results: 91 CRX GS-R 2.0L Stroker Motor
- What do i have?
- Where to buy heatwrap?
- should i trade
- 90 Civic Si fuel pump
- D15B2 to JDM D15B Swap worth it?
- Just a little thought.....i'm bored......join in my boredom.
- pix of my d16z6 just put in this week
- 89 Civic Dx intake
- Umm sorry to ask this...vx wheel price?
- axle seal???
- 3" exhaust (sleeper style)
- What to do next
- What's wrong with my alternator/car?
- d16z6 swap into an '89dx problems
- knocking sound at slow speeds? axels or tranny?! help
- Problem installing JDM ITR Wheel...
- Best Upgrades for a 91 Civic Standard hb
- Ignition Output ECU Code . . HELP!
- b16 or gsr?
- black crx with orange trim peices
- exhaust for b series in ef hatch??
- JRSC B series Vs JRSC H series
- loud clanky noise :(
- where can I find the sensei CR-X front bumper nowadays (searched)
- Rubbing Issues
- car won't start, HELP!!!
- should i paint the fat 5's
- ZC Engine HELP!!!
- steering woes
- *Low idle problem??
- $ to anyone who can come here and help me fix my fuel pump problems
- 88-91 or 92-95 axles? PLEASE HELP!
- Taking off molded front bumper.
- problem reading ecu codes
- N10.9875 The Half-Meet
- turbo issue
- fault codes
- car won't start. Getting codes 16 and 17
- High Idle after installing a Type-R throttle Body onto a b18C Skunk2 Manifold
- What would it take?
- Whats the width of the stock 13" steelies
- has anyone ever priced the rear upright cargo panel in a crx from honda?
- Non oem paint colors?
- someone chip my p28???
- DX front disc brakes on an HF
- resgistering a non-op car in california..
- Can 96-98 Front fit on CRX Si? :::Question:::
- B16 with LSD tranny....
- ARP Head Studs for a D16A6
- Your opinions on what i should do
- dx with doh zc non v-tec?
- non v-tec bottom ends
- Master cylinder upgrade questions..
- '83 Civic Hatchback
- i got a problem an i question
- Fabricating DA into EF hatch seat rails
- what..where did the lights go...
- jigzer seats in rex
- broken radiator, what should i do ?
- WTB: Complete mpfi swap
- replacing the upper control arm and ball joint
- Differences between DX and STD hatch?
- Need help identifying a part and a plug
- new rex yay
- use old mounts on y8
- I can start my hatch without pushing in the clutch.
- obd conversion ?
- need diagram
- Where to buy parts aside from classifieds/ebay?
- thieves
- clutch question
- how hard is it to pull a motor
- Need help on a head gasket...
- towing a jetski
- New clutch...cant get the cable just right.
- Cracked exhaust manifold on 92 Si
- Anyone near indiana that can help me do a engine swap on my ef
- Fuel Pump? Lines? Something is FUBAR!! Help!
- manifold swap gone BAD!!!!
- B16A owners - what RPM are you at @ 65 MPH?
- everyone running a t25 or 14b turbo... downpipe pics please!
- should i replace this?
- ef9 w/ itr suspension???
- CRX EF exhaust compatible?
- Is it me or?
- Crank pulley removal
- What is the Canadian SiR?
- Civic pinging/rattling real bad all of a sudden.
- D series trans how many quarts?(manual)
- what kinda exaust do u have?
- low to one side help
- Removing a Crx steering wheel ?
- Gas Mileage 88-91 Civics with Swaps b16a, b18c/5, b17, b18, ZC ....
- FS: PM6 ECU 88-91 Honda Civic CRX SI EX 5SP 1.6L
- yet another crx fan
- exhaust question
- FS B16 CRX
- mabye a stupid queston but i need to know
- engine won't stay on!
- Just bought 88 Si w/modified B16A
- installation of JDM front end EF9
- oil pan torque specs???
- idle drops bad when car is cold
- what starter do i need
- hondas suck
- Flashing Seat Belt light?
- So is this injector junk?...
- Need a used catback exhaust for my CRX Si '89..
- Is this for real?
- dohc zc oil preasure
- mugen bushing question
- Manual steering rack question 88-91????
- broken timing belt update
- Dash removal?
- Pic's of my project driver.
- after replacing the termostat on a 1989 crx dx d15b now it won't star ?? wtf need help
- hydro tranny problem
- b18a or b18b crx, have obd0 or obd1, what to do
- b16 or zc swap?
- Is anyones hasport shift linkage loose?
- main fuel in hose
- A few cost questions for a CRX
- Door handle damage question
- What Distributor Cap?
- rebuilding hybrid b series cable tranny
- 90 Civic LX 4 door Swap????
- Tranny in Cable B16?
- skunk2 short shifters - single or dual bend - which is your choice?
- sO CoNFuSed!!! Help (searched for an hour
- Should I Save it or Sell it? My 88 Rex
- In need..: Pictures/Information of how to install new hubs/knuckles on Crx Hf with B16 Swap.
- WHATS BETTER???
- Code 13 Help
- Suspension Gurus. Will this solve my problem
- 1990 CRX Si engine hesitates during acceleration
- No A/C = Need Solution
- gut my car?
- (New) have a question? will a LS fit into a EF Hatch?
- VTEC CRX
- My first attempt at welding...and ABS progress pictures
- 90-91 Si seat recovering
- Ignition and steering column.. how do they attach?
- y1 or ys1
- need help asap PLEASE HELP
- AAAHHHHH i threw a rod
- MPFI swap with my z6 swap help
- Hey, need to see flat green(army green) CRX's
- Have u seen this!? pitce of shit to me.
- need help and fast
- Will a 92-95 civic lip fit on a CRX?
- Wow, is my MOMO wheel this ancient?
- Picked up a 1st gen CRX...
- is it worth it?
- JDM 4 DR??
- wow! sooo many leaves/grass in my interior!
- Rear Main Seal Part #?
- i've searched allready... just tell me!!!
- Some one help, trying to sell slicks
- What should i do tonight about my car?
- HELP AHH!!! zc sawp SI tranny question.....
- need help wiring up a switch
- b16 swap thatr will not start (searched)
- Quick transmission Question
- hey there !
- Just got a 91 civic hb si need help.
- shop in maryland, to isntall first gen b16a in crx si
- 1st gen. JDM B16a into 91' Si CRX....
- Anyone have any idea on around how much it will cost to replace the catalytic converter on a 1990 ci
- A6 cam in a D15B6?
- Doing y8 swap soon
- Realtime 4WD
- CRX BACK SEATS
- Just got the Skunk2 catalog
- how to salvage a car(the process @ DMV)...
- B16 in 91 Rex....hesitates / boggs
- help me turbo my hatchi
- maybe a stupid question... but here goes
- Wiring Q's for a 90 Hf
- Question about ef
- Harder VTEC Engadegment
- What are the advantages of a P30 over a P28 ecu?
- 89 crx w/98 vtec head wont start
- Thinking about getting a CRX...
- Wiring
- alinement problem EF Gurus look inside
- doch zc
- making a T in the vacuum hoses
- Motor mounts for my dual cammer ZC
- i completed the MPFI swap but have a problem.
- Rear CRX brakes question.
- Need reference pictures dealing with SiR Airbox etc
- Z10 block girdle?????
- will a vtech head fit on a 1.6?
- Painting the CRX - additional question
- Replacing Synchros....
- [FAQ] How-to Set your Idle, Idle speed, Idle Adjustment (search friendly)
- code 16>?
- sprint extreme springs...
- DOHC ZC VTEC
- people with revhard turbo kits, post here
- Gettin That Back Seat Outa There
- The Beaters steering wheel vibrates above 40???
- Major Bog! Is the Fuel Line Clogged?
- wheres the starter at
- Where to buy real Mugen Front bumper for CRX (searched already)
