View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Trouble with tranny mounts
- Cluster swap
- Zanes 90 Civic Project: Venom
- seat questions
- Help with fitting a DA lip
- ed/ef meet colorado springs co
- obd0 ls problems
- A couple crx questions
- 1991 crx
- HELP!! Car will not start!!
- 89 civic wagon RT 4wd (swap)
- b16a2 all motor build
- popping 23code KNOCK SENSOR HELP ? ALSO low rpm power loss ?
- Swapping trans, can I keep my drivetrain components?
- Power steering in a hatch?
- I need some help, this is Interesting...
- zc question???
- EF rear disc swap camber question...
- 90 sedan cluster question
- NEED HELP FINDING BODY PARTS - OEM & CF
- First Honda and noob status my ef project
- crx motor mounts
- D16Y8 swap in my EF help
- radiator
- OBD1 Injectors B.S.!!
- crx si/ std harness
- z6 tranny into d15b1
- a6 turbo piston help
- i need some help with my 90 honda rex
- b16 clutch on s1 transmission
- Engine bogging at acceleration on Dohc ZC
- rywire dpfi to mpfi question...
- cyp code in b16 swap
- horrible gas mileage with my d15b1
- FITV Problems
- Hi, I have a question that has been bugging me all week. SOS*
- civic goes into limp mode after redline.. any ideas?
- weird scratching noise?
- hatch suspension
- ls swap, need help ASAP!
- transmission problem
- Question on multifunction switchs
- My first CRX: First Mod's...
- JUST BOUGHT A CRX !!! B16a2 swap !!
- Noob: My first Project...My first CRX
- Do rear DA shocks fit on a Ef?
- No spark, OBD0 B16 in EF CRX
- in need of odd swap help
- ECU help
- Help w/ 90 Civic lx d16y8 help
- Side Molding PART# help
- Check Oil Light and Car Dying
- Rear windshield wiper
- ek auto vss
- Cooling fan not turning on!!!
- SH!FTS MASSIVE BUILD THREAD/CAR HISTORY(MASSIVE PICTURE THREAD 56K GO HOME)
- DSM injectors. Intake Manifold Question
- where can i buy amber or clear corners for my 88 civic wagon??
- 1985 CRX Si
- S1 cable tranny problem
- Suspension help...
- 1989 civic d15b1 tranny
- Hatchback JDM Bumper with USDM Bumper Support Help
- HELP!! CRX SUSPENSION PROBLEM
- picked up an EF hatch traded it for my ef sedan
- question on starter
- 91 crx fuse box issue??
- dpfi to mpfi mystery
- b16 cams
- surging throttle while not changing the angle
- what kind of ecu do i need
- RHD conversion how-to. The method that keeps the stock v.i.n. and windshield
- Is it worth a boost?
- anyone running a d15b7 obd0
- ls swap into 91 civic si
- pr3 codes question
- Need Help! JDM D15 v-tec useing D15B dissy
- Help DA cluster in USDM 91 Si
- b17 swap in a 91 4dr... need help!!!!
- Help with valve lash
- tranny question.....
- Clogged injector
- ecu problrms
- B18 swap
- seat foam rebuild
- speedometer not working but everything else does
- CAR NOT STARTING AND STRANGE HUM
- ecu
- engine not running right
- Transmission question
- transmission year?
- **SONEM EF Hydro Conversion Reviews & Custom Set-ups **
- CRX FRONT END ON CIVIC HATCHBACK?
- ef lx sedan b16 swap can i keep the p/s?
- fuel pressure
- Bisimoto "typo" error on website... wtf?
- just a few pix of the sedan
- how do i angle my headlights down?
- 1991 CRX HF Manual Transmission Swap
- rear drums locked up?
- 10 dollar bumper make over
- caster problem
- HOW TO:tips and tricks on detailing your engine bay/misc
- weird power loss problem
- 90 to 93 teg cluster in ef
- NEED HELP. Car will start then dies
- 91 std thread
- Gsr intake manifold question !
- crx dies stalls out when in neutral..
- civic acting funny
- eg throttle cable
- Motor only kinda fires
- cam seals
- avid motor mount trouble
- need some pointer on a crx
- b16 iacv leak
- 88 crx need some help
- d15b2 cylinder head swap!
- folding mirrors ef9
- Temp needle shoots up but no overheating
- Head question
- whats the result of mixing up the white wires on a dpfi to mpfi???
- Tranny wont go in gear unless its jacked up
- D16A6/ZC single camshaft... Are they the same????
- tranny help
- New to Honda-Tech
- D15/D16 Intake Manifold Question
- DPFI To MPFI
- what was the reason for the fuel pressure jump in 91??
- Mixed answers. HF MINI-ME?!?!?!
- hf harness install in ex crx
- 88-89 base HB weight difference
- o2 sensor no cel
- EF Squad/Crew?
- ef9 window glass
- my new crx
- quest for camber(91 std ef9 project!)
- selling a obdo motor question
- DSM low impedance injector question
- Question on pedal assemblies
- OBD0 to OBD1 resistor box question
- B16a obd0 to obd1 swap resistor box question
- d15b2 head swap!
- D15b2 head swap!
- texas problem
- Post Roof Rack on your Civic!!
- rear right suspension making noise
- How to: Killswitch write up
- What did you buy for your EF today?
- itr brake calipers on 2 a crx
- how to take bumbers off
- head swap hose question
- Do aftermarket '88 lips not exist??
- no dial indicator to get TDC
- wiring problem for dizzy on d15b vtec
- Dreams of an autocross CR-X
- Civic -89 HB gauge lights - LED swap.
- D16Z6 Block+ D16Y7 Head= Disaster Timing???
- h22 in EF electrical problem
- need a new fuel pump.
- si head on dx block?
- rear crossmember mount .....
- Found the swap I whated.
- 87 and 88-91 crx parts interchangable?
- I Don't Need No Stinkin' Fog Light Brackets!(JDM Fog Install-Bracket Free)
- h22 clearance in crx
- dizzy problem
- 91 Civic Wagon
- what is this?
- RPM Shudder/Jerk in First Gear
- racing seats question
- MPFI Swap, code 16
- Trying to find the right price for an DX swap
- 88-89 hf weight difference
- 88-91 Honda Civic/90-91 Acura Integra Engine Swap Matrix
- VIN # Identification
- 89 sedan b18b1 will not start help plz
- B-series header
- Buttonwillow Raceway Sept. 26th and 27th 2009
- FPR
- 1991 crx auto crx converted to manual
- vacuum hose help
- NEED HELP!! how do i take the front bumper back bumper and the side moldings off
- Guages dont work
- How much battery voltage/amp leakage allowed?
- still confused but I can finally explain...
- hose from intake to head
- mpfi conversion?
- OK here goes! CODE 20?
- 3 questions, please help!
- b16 w/ itr IM+TB
- SOHC ZC vtec? or non
- obd0 to obd1 wiring
- help, my car just took the ultimate sh*t!
- DOHC ZC OBD1 Conversion?
- civic si hatch 89. will a non power steering rack fit instead ov powersteering one
- 1988 honda crx bent front subframe
- A few dizzy questions
- My project
- code 14 obd1
- h&r race springs with stock suspension?
- dpfi to mpfi
- 96 Black Leather GSR SEATS IN 89 EF HATCH????
- 91 crx d16a6 wont start!?
- DOHC ZC in a si want ac
- 89 CRX Si Brake Calipers....OMFG.
- My new CRX, Tell me what is Weak on build! Please
- vtec wiring into ef hatch
- Weird issue
- 91 ef hatch speedsensor trouble
- My Turbo B16 91 CRX (56k warning)
- Crx B18 Cv Joints
- Hydro to Cable Clutch Spline
- which one is the right diagram
- cable to hydro conversation
- Question about GC sleeves and what struts?
- 1990 Civic DX Wagon -- Intermitently won't start, not start!
- crx trouble
- Need help for K20 into EF9 Civic
- Rain+Honda=Motor Problem
- My d15 won't start! Please help
- Speed Needle is below 0?
- Yet another engine choice thread.
- whats the diff between wagons
- 90 crx question
- JDM B16 DIZZY HELP
- crx chassis harness ?
- please proof my engine harness labels
- what is this red hose for?
- what sensors control the injectors??
- cant figure this out
- Antenna, Dipstick, lens plate turn signal (right)
- how does axle come out of trans?
- NEED HELP PLEASE!! DESPRITE
- 1991 CRX no spark
- Need Help with gsr swap!!
- my crx lsvtec build
- megan racing coilover sleeves
- LS running rough
- Where can I purchase a direct replacement for trans drain plug?
- B16 90crx si too much fuel
- CRX radiator support fit onto 91 civic hatch?
- who has the energy susp. mount inserts? I am CONFUSED.
- hf's and DA's?
- my ed3 civic sedan what think
- I cant figure out whats wrong with this D16
- Exhaust for ef 4dr?
- Blinker Issue
- Car start problems. Maybe fuel?
- Vtech head on D15?
