View Full Version : Honda CRX / EF Civic (1988 - 1991)
- My Hatchback was broken into
- 90 Civic Si - "Rio Red" or "Phoenix Red"?
- Head Gasket Torque specs???
- mods to an 88 automatic?
- homemade turbo question
- starter question for a b16a
- A6 intake manifold on DOHC
- jdm crx front end question
- MY 89 CRX Si - 92 1.8L LS motor inside FOR SALE!!!!
- problems with the rex
- CRX (88-89) Armrest
- Thermostat installation help needed
- Wiring diagram for apex vtec controller in 90 civic with b16
- Rounded off tensioner bolt?
- which replacement axles?
- Starting problem
- anyone have a pic of hydraulic tranny with mount and a cable tranny with mount
- crx neuspeed springs?
- a DX distributor wont work in a Si will it?
- B18c in CRX or B16
- CRX-to-Civic part numbers??!?!?!
- #1 cyl pos. code
- quick question
- d16a1 in a first gen???
- pm3/p03 pistons in a d16a6
- crx 4x100 lug?
- Replaced fuel pump and it still wont....turn on?
- Doing a brake conversion on my 90 SI with parts from 92 GSR ?
- Fmu setup
- b16a valve job?
- another weight ??
- timing belt to get for jdmb16......and water pump?
- Axle Replacement-What brand do you guys recommend?
- lil problem with obd1 conversion on a 91 rex
- hey tell me your opinion
- thinking about buying a crx or crx shell...
- how do you take off the throttle body and intake manifold?
- need a link to ecu codes
- gettin 91 crx -- swap question
- Supercharger in b16a CRX.....will AEM CAI fit? exhaust size?
- auto tranny in a 90 dx hb
- B18b into a crx
- Need Help....Broke a fuel rail studs & need gromets, where can I get new ones?
- crx si
- what full coilovers are available for 88 civic hatch?
- key stuck in ignition, any idea what I need to do?
- b series tranny part 2
- Older Honda Wheels...
- Magnaflow Mufflers
- d-series throttlebody fitment
- progress springs?
- HID on a CRX?
- anyone have a CRX for sale in good condition
- help, PR4 code 43
- Just for H-T: New info on 11" brake upgrades
- "backseat" compartment lock
- anyone have replacement crx carpeting?
- how much to ask for my
- FOR SALE: 1988 honda crx si
- Looking for a convertible CRX
- ZC head question.
- 91 CRX Question
- eibach road race?????
- help me
- 94 civic ex, up for trade for a swapped crx.
- HID kit on an ef???
- How much do you guys make and how much do you spend???
- New to the board
- testing clutch?
- 90-93 teg axles for sale on ebay, currently $150
- sohc v tec? 93 civ. si
- where can i get ef9 jdm back seat???????
- Anybody know the weight of an '88-'91 si trans?
- batteries, ignition, and battery relocation questions.
- chassis code?
- is anyone here... i need help
- Can anybody decifer a VIN for me?
- What JDM Civic are my taillights off of?
- Would my vss cause me to fuel bog? b16a~!!
- just finished my swap
- suspension questions - springs
- a/c removal -- the part inside the car
- Greddy sp exhaust
- ls/vtec and FI
- Name that flywheel....
- Parts for 5 Lug Conversion!!
- what is a good price for EF9 SiR tailights center section
- b18b in a civic
- Do you like your koni Yellow's
- New EF owner coming soon....
- Installing coilovers and struts, any advice?
- $4,900 usd too much for an 89 crx si?
- got the crx shell and going d-series boost probably, couple of ?'s
- Kuhmo or Bridgestone?
- A new home for my B20.
- What is the exact power of SOHC ZC?
- D16A1 Integra motor-will it fit in 91 CRX???
- Does this sound about right?
- B-series..should b stand for "buddy"..well please help me out b-series b16a!~
- Car wont start. "AGAIN"!!!!
- Powder coating prices: Valve Cover, exhaust manifold cover, etc.
- interchangable steering wheels
- Need a new exhaust, does this look good to you?
- 88 HF rear brakes, can't get parts here in canada.
- Will 95civic ex complete front assembly fit crx? please help!
- JimFab X-Members?
- EF Hatch - Common problems?
- mini me setup...hard?
- running rich...
- how do you post pictures??
- where to get dohc ZC motor for cheapest?
- What do i need to run boost????HELP
- ls vtec with CTR pistons--review?
- !!!!$1,200 ZC CRX SI!!!!
- fuel pressure ?
- need that website that list all the zc stuff...
- crx
- How will a magna flow cannon stye exhaust sound on a 91 dx
- Is the EF worth the money and time
- seatbelt buzzer
- want to redo interior on a budget
- vtec troubles with mini me.. tried search.
- wheels turning when in neutral
- Fuel Economy
- lost my links... anyone help?
- replacing the 13" alloys on my '88 civic hatrch with 14" from crx SI; need new tires?
- Seats
- hydro tranny in a cable ef body
- 91 prelude seats into civic?
- My car threw a code help...
- What kind of suspension does 87 CRX have?
- Does anybody know HF's gear ratios?
- Will a mid pipe from a 97 dx civic fit a 91 civic si?
- DX tranny
- i need longer gears
- Odd Question (help me pass State Inspection)
- SIR 1 tranny
- It's my b-day today...
- B16a throttle cable issue... I think
- O2 Sensor Disconnected, No Check Engine LIght on...?
- Nees Assistance reading codes from a 94 H22A???
- HF manifold used as a b16 turbo manifold
- 89 civic rear seats fit in a 90-91 civic?
- how to wire dual filament bumper lens bulbs?
- best price for ingalls camber kit?
- Tossing a 97'spec R swap into my 89 CRX...What tranny to use?
- ????? Blk/Yel and Blue wire on Dist.....?????
- '91 civic accepts '95 engine, '95 civic accepts B18/B16
- Si and DX brake rotors the same?
- 88 Si and 90 DX O2 sensor the same?
- LS swap into CRX 90-93 teg axles wont fit helppppp
- Is it possible?
- Howebrew Air Intake
- ok'd buy Breaka 1_9_ - HT EF form memeber in SCC this month
- D-Series flywheels
- 94+ teg springs??
- who makes these struts and springs? any guesses?
- LS into Crx?
- Air Intake Temp re wire on 88' DX
- unorthodox pulley kit?
- D-series Tranny Gurus: CrxSI tranny rebuild-need info and guidance...
- 88-89 and 90-91 crx headlights
- Valve clearance
- what door do i have?
- vss and gsr cluster pics
- blue smoke?
- Stuck in 2nd gear tranny issue???????
- My idea for heat wrapping my rattle exhaust worked (pics inside)
- dam fog!!! i love my car but i hate the fog!!
- b16 clutch ?
- Wiring a Grey Plug B18A, into a 88 CRX Si
- OBD0-OBD1 ecu conversions
- Please help!!! Lower arm bolt stuck!!! (pics)
- Car not starting in the rain
- Unstable Steering
- Rear hub interchangibility
- b16 2 o2's or is 1 enough?
- civic charge piping
- ignitor switch ?
- AEM V2 cai applications
- my ZC needs rebuilt; help
- Anybody ever take out there moon roof????
- will seats out of a 94 civic dx fit in a crx
- hasport a/c bracket!!!!!
- Transmission problems?
- headlight out?
- 1991 STD civic hatchback to SI wiring diagram
- Which Integra (DA or DC) shocks fit '89 CRX?
- So what can I do with an HF motor to make it faster???
- ground control limited edition?
- Need Someone with a Elec. Helms manuel... 89 RexSi
- 89 RexSi, Wont start??? Turns on rev's to 2500, then KaPut....Dead????
- How much B16a weighs?
- question about 4th gens, help plz :)
- 0bd0-Obd1 conversion with SOHC distributor..fitment problem?
- my d16a6 died
- Crx tie rod ends (inner or outer)
- Fastbrakes rules!
- which CAI for my CRX?
- question about fuel pressure regulator....
- supra pistons?
- what times?
- What other Honda seats bolt on or fit in my 90 CRX Si?
- Anyone ever here of an a1 cable tranny?
- KYB AGX for 88' dx where can you find them?
- d16z6 intake manifold
- obd2 1.6 vtec (d16y8 i think) into a 90 CRX DX
- Problems witth wiring ecu for b16a swap
- 91 CRX HF climate control will work on a 89 crx dx?
- FAQ: help with this vacuum diagram!! b16 swap
- MPFI wire confusion...arrggg
- where to get the best deal on a zc?
- 88 civic dx 2-door hatch - auto transmission problems
- d15b2 w/ d16z6 head
- Fitting OEM honda/acura steering wheels
- Use ES ball joint boots?
- turbo d16a6s
- 87' CRX questions, need feedback
- for those with muffler not in center...
- Reinstalled my Front Sway bar....and i swear it handles better.
- jdm power folding mirror help
- Could you help me identify this plug?
- heater turn on when my car is on
- can you use d16a6 rings on a d16a1?
- help me out
- all d series tranny fit?(cable only)
- What is this mystery item in my engine bay?
- just bought '88 civic hatch, the underhood label is missing!
- how hard to swap 90 crx dash to a 90 civic hb si?
- CRAZY Gsr, CRV 4x4 CRX Turbo..
- temp ecu what will work
- EF Fogging?
- 88-91 si engine in 86???
- 89 civic dx swap?
- How long is the EF stock cat ?
- no spark
- Best place to ground a relocated battery?
- Crx crv awd Turbo Hybrid
- Clutch Cable Adjustment
- Where is the cheapest place to get a ZC?
- Swapping engines with wife need help.
- Thinking of building a D15 for kicks and giggles.
- Where do they go? (ES BUSHINGS)
- 90-91 teg exhaust?
- does anyone know the lbs/hr or cc/min of these?
- Taking out passenger side axel *HELMS pics?*
- b18c needs better mpg/igntion?
- How to check tranny
- Things to look for when buying a B16a1 Engine, Tranny, Ecu
- Average weight of a cat-back exhaust system??
