- F*ck bearings
- Altinator Plug wiring HELP!
- Pics of What Santa brought!
- usdm car jdm doors
- alternator wire?
- car died need help
- anyone know anything about distributors?
- TERRIBLE Gas Mileage - n/a B16a obdo, probably 02 sensor?
- fuel gauge stuck?
- mounts???
- O2 sensors and cap and rotor for OBD0 B16A from WHAT CAR?
- Car starts when it wants to?
- Fuel Pump??
- More axles questions
- B16 Swap issues... axle too long?
- fan switch on ls/vtec
- Quick question about bumpers
- valve covers
- CRX SWAP FOR THE PRICE?
- upgrading front brakes calipers
- ATTENTION ATTENTION EF STOLEN______
- Idle Problems...
- check enging light warning on b16
- Rota Slipstream - What's the right offset?
- vauum line help for obd0 b16a (i already have the sir pic)
- How much would you pay for this CRX?
- Which alternator to use w/ obd1 gsr swap in 90 crx si
- B16a hesitating at cruising, part throttle
- question suspensions
- camber kit?
- o.k.......WHAT THE HELL?
- doing b16a swap in my obd-0: .. HELP !
- b18a1
- 91 Civic DX check code 16
- rear disc question. *searched*
- mpfi swap
- b18 (ls) swap into a 1989 HB
- b20 (ls) swap into a 1989 HB
- WHAT IS A GOOD DROP FOR
- O2 SENSOR
- I am finaly presenting my self....
- 1990 Civic Hatch Si....front end conversion to CRX
- obd2 USDM B16a2 in my CRX
- 1972 honda 600 AN
- European Cluster
- PROBLEMO!
- obd0 - obd1
- I NEED HELP!! FOR AN 87 CIVIC
- Switching Driver and Passenger seats
- axles on a angle??
- New guy - couple of questions
- OK....Issues when turning left.
- D15b2 engine swap, left over parts.... heheheh
- my interior
- Stripped Ball Joint Stud?
- help with sohc ZC code 5
- what would be some reasons?
- does any body know
- Were plugs into all these openings on my manifold? (See Pictures)
- Ignition lock Question??
- DA roll bar
- PASSED!!!!!!!!! W00T W00T
- Are there back seats in a CRX?
- I NEED DPFI TPS PLZ HELP..
- Difference in internals of different generations of b16s?
- mini me help
- a6 or y8 throttle body
- timing belt d15b2
- Z-Dyne, (for a turbo D16zc)
- Codes and need HELP
- Rear Seat for 2nd Gen CRX
- 4th piston problems
- help with timing
- HELP!!!!!!!!!!!!!!!!!!!!!!!!!!
- can anybody explain or draw out a diagram for me?? i am a bit confused about this.
- CRX Pirahana????
- In need of some D-series guru advice
- 5-speed engine used for auto Daily driver.
- Sterring wheel/rack lowering?
- what mounts?
- when i launch i hear....
- NEED HELP... ENGINE TROUBLE.
- B/D series Thermostat interchangeablility
- Where can i find amber bumper lights for EF Hatch
- CRX interior in a Civic Dx Hatch Back
- b18a1/zc head !!!WTF!!!
- pm7 ecu question
- exhaust fitment
- subs in speaker ports..
- is there any way to clean a catalytic converter? need to pass tomorrow
- I C U P JDM MEET (EL MONTE)
- double din?
- putting in a b18!
- Extracting lower ball joint from steering knuckle
- air bag tray for RIGHT Hand drive EK's
- A good shop for harness installation on a '91 CRX? *Southern California*
- 90-91 CRX CLUSTER & CLIMATE CONTROL BULBS SIZE/ #
- HELP WITH MY 87 CRX SI!!!!!
- strut question
- alternator ?
- New header install.
- Body shop in SoCal for glasstop install?
- what to do with a faulty throttle position sensor
- 88 crx body parts on 90 crx?
- new CRX baby!
- What Motor?????
- I need a working PM6 ECU very badly.
- OBD0 injector RESISTOR BOX QUESTIONS (not OBD0 -OBD1 conversion)
- Suspension noise: CV Joints or Balljoints?
- coil over bumstops
- vote crx
- 88 si cluster into a 91 si
- picked up a 90 hf with a b16 in it..
- fuel problem... HELP!
- Different crank pulleys have different markings?
- trans id searched...how 1st gear?
- Failed again! (eyes are sore from searching)
- SAFC wiring
- anyone need some 1/4 panels in Missouri?
- NEW Motegi FF5 17" For Sale
- Fuel gauge not working?
- I NEED HELP CRX WONT START!!!
- Front Spindle / Rear Trailing Arm
- clutch sensors
- Whats the difference between vtec and vtech?
- should i get a new car or just a new motor a B18B LS / RS for my ef
- What rear bumper support?
- HELP
- motor help!!
- zc motor....my cousin screwed me..i need help!
- Feeler Guages for valve adjustment (which work better flat or angled) ?
- Crx revlimter
- motor swap, car not starting with key
- need to find the o2 sensor on the ecu harness inside the car
- Paint/Bodyshop Costs
- JDM EF9 SiR bumper lights
- my damn heater wont work.....
- 91 HB swap to B16A
- Wheel picking for 90 hb
- Does Anyone Have A Good FULL Write-Up Of How To Swap A D15?
- alright
- ls/vtec
- JDM OEM parts information
- what the hell is a dizzy??
- I Almost joined the club too!!!!
- 84-87 crx b16a swap
- crx no start
- little wiring... err phonomenon
- help 89 civic si
- where to get door pins?
- gsr.in sedan civic 90ex
- column cover question
- Heat Not Blowing! ITS COLD! Not Going Where It Supposed To
- GM Synchromesh Question
- template for ef civic.
- rusty bolts.....wat to use to replace?
- Gauge Cluster Cover
- I officially hate brakes
- swaped obd0 b16a into 90 dx crx. how do i wire the dizzy
- Rage header doesn't clear jimfab crossmember
- EX brake upgrade - what'd I do wrong?
- 88 vs. 91 map sensor location???
- civic hatch si roof
- Pic Request: D16a6 intake manifold on head with all lines hooked up.
- Gauging JDM Crx si-r hood interest.
- distributor king WITH rotor screw?
- Clearing issue installing Ingalls front camber kit
- insanity
- swap ls need help
- Another starting issue
- d15b vtec 92-95 civic..and my ef
- ecu question
- OEM CRX Convertible?
- D16a6 Stock Sleeves on Boost?
- need help asap thanks with item picutred in thread
- i can't find the main fuel pump relay!!!
- adjustable shocks
- Okay, planning to swap my front end to JDM Spec :-) Anyone want to lend me a hand?
- side triming?
- concept crx
- need help: with b16A swap into 90 crx dx what shifter bushing do you use
- bumper mounts for fog lights
- Whats the name of the piece the calpier bolts to?
- whats the quickest and easiest way to change the alternator?
- AC in an EF with B-series swap
- b16a questions..already in the car and running but just a few questions
- hmm tachometer off?
- simple question
- should i change these parts?
- Brake problem, need opinion.
- hunting with electrical load.
- perfect drop
- axle nuts torqued, car wont move
- i neeeeed serious crx harness helppp!!!
- Help can't message or reply to posts
- 88 crx HUB
- ball join hitting frame
- I bought this hatch for 1700 let me know wut u think!!
- Check engine light after setting ignition Timming???(code 8/16)
- D16A6 buildup......need help to find part # for this o-ring.......
- d15b
- battery relocation. 1991 hb
- Front Cross Member problem?
- im out fagots
- Where can i get the rubber cushion gromet thing on the bottom of radiator
- launch rev limiter?
- zdyne ecu work with y8 head swap onto a6
- What ECU will fit a 89 civic single cam ZC motor
- light pulsation problem?
- bad misfire/running on 3cyls at low rpm only! (srched)
- Progress report. Lots of pics and a few sound clips inside.
- what to save from old engine?
- D-series with equal length half-shafts
- Will 91 Crx bumpers fit a Hatchback???
- tps question
- b16a into 90 dx crx will the 90-93n integra passenger axle work?
- 5-lug+gsr rear brakes.
- Integra E-brake
- cluster question
- half size radiator for crx
- rear shock
- 1st build and have questions
- best pipe to get for a 89crx?
- swapping a d15b into a crx dx
- cheap civic
- Failed emissions
- help this CR-X HF 1991
- Tranny Question??????
- how to do timing without mark on crackshaft?!
- EF suspension thread???
- Lower control arm question?????????????????
- b16 coolant line help
- ek type r lip onto ef?
- rex wont rev over 3500rpm
- How many "Ef/ED" have you owned? Not tech related I know..Please dont flame me
- how much should I worry about cleaning the channel in IM under PCV?
- need crx help with hanress???/
- Idle Problems! Parts Replaced STILL NOT WORKING!YHELP!
- EF hatch fenders on a CRX???
- rear brakes locked up
- JM motor w/ usdm harness
- 89 civic si check engine light on help
- 90 Si front bumper vs 90 DX front bumper
- exhaust leak
- I'm new!
- sir-usdm comparison questions
- Swapping a B16B EK9 into a Crx B16A Sir
- Buying a crx.
- cleaning pcv vs replacing
- header wrap and cat temps (yes searched)
