View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Car runs really rich
- So my friend got an obd0 b16a...
- Idling problem with my d16y8 hatch
- swap
- FAQ: Replace / Remove Radius Rod. Solution for crank pulley rubbing inside
- should i hone my block and if i don't what will happen
- OBX intake manifold
- need help with brake specs
- I got my gsr leathers tonight but I need Install tips
- Got any tips or tricks up your sleeve? Please Post.
- Idle up, Idle down.. Temp sensor?
- Convert cable to hydro
- Hf, SI srings the same?
- does this sound right? 90 civic si, putting in obd1 sohc zc
- wat kind of camberkit for my crx 89si
- crx walbro fuel pump users***LOOK HERE***
- wtb bumper lights
- does a Z6 valve cover gasket fit a A6 cover
- d15b2 to d15b vtec
- wont start up
- jus curious..about my engine temp
- valve clearenc on a 91 hatch si d16
- almost stall when i smash the gas
- where is my plug? iacv
- Switching from Cable B16 Tranny to Hydro GSR Tranny, what is needed?
- carbon fiber hood for a 4-door?
- Where to get a B16 Tranny rebuilt
- what does this tranny code mean?
- wheel alignment
- Is this what I need?? (Brake Related)
- 4-wire 02 sensor installation
- CEL 41
- CRX Sunroof options
- Possible Fuel Pump problems
- Plugs on Distributor Broken. Were can i buy some? (pics included)
- Swap questions
- need suggestions
- Goodbye B18a Hello JDM B18C...
- Rear window trim problem
- rebiult makin a wierd noise from head
- built heads....
- OEM or Aftermarket Gaskets
- Difficulty of DFFI to MPFI?
- Trany re-build kits?
- crx...integra rear disc brake conversion???
- CRX Si seat recline adjuster problem.
- DIY '90-'96 300zx seats in my EF
- Looking into getting a 90' hatch SI with ZC swap
- edm spoiler?
- Dissassemling clutch in B16A1 (looking for "How to guide")
- FPR
- 12 piece bodykit????
- CRX SiR Spoiler
- Timing Belt Snapped?
- Aftermarket seat height
- timing a b16
- Full Throttle
- MINI ME Y8 stage one cam?
- who here on honda tech knows obd2 stuff ?
- D15B2 planning on going Turbo
- Covering seats
- air in cooling system
- unknown rear strut bar
- turbo h22 crx setups
- SKUNK2 PRO SERIES MANIFOLD FITTING ISSUES
- 91 Hatch....loud as hell
- Confused as hell!!!!
- i have 600 bucks for crx swap
- quick Q about tailights
- Door locking nuissance (searched)
- quick exhaust guestion
- which injectors will fit?
- SOHC OWNERS
- 88-89 4 DOOR PARTS
- obd1 firewall mounted map sensors?
- civic hks sport exhaust on crx?
- Vehicle Speed sensor on a b16A (1st gen)??
- jdm side markers
- '88 CRX CEL intermittant code 16
- SOHC ZC motor mount ???
- axels for crx?
- is a s1 a b16 tranny
- Question about using a Automatic instead of a 5 Speed PR4 ECU???
- Oil Leaks from headgasket
- jdm b16a axles
- about CRX A/C ?
- weather guards for 90 4dr
- b16 from hell help please
- Putting a clock in my Std.?
- FUEL PRESSURE FOR MINI-ME
- car wont start, help me get to work in the morning!!!
- rocker arm slop
- New bumper way better than old huh? Rice to nice....
- Im looking turbo charged crx w/ jdm front ends
- My project CRX, so far
- D16Z6 IACV and D16a6 Harness/Clip - Will It Work?
- crxers eat ur heart out
- How many Quarts of Oil in a b16?
- 99 si cluster in 91 crx?
- s2k seats
- SOHC ZC in my 90 si
- code 13 after wire tuck.
- PARTING OUT 89 CRX SI
- how to adjust outside handle door opening?
- Strange problems at idle...not jumping
- Projector headlights [Pic Request!]
- help on dohc zc
- 92 si with a cx motor smogable ?
- cars idling at 4k. wtf's up??
- Need a 91 crx hf driverside door window
- Newbie to HT
- Looking for a part number...
- another wrecked crx!:(
- oil pressure is very high and the oil jet is out?
- zex 57200 cam ?
- Best way to replace Valve Cover Gasket
- SiR front bumper
- Tranny Release Arm
- Got 3 grand, what to do....
- fuel rail question- tiny screw under the plastic cap that holds fuel line from fuel filter - 90 crx
- how much should i drop my crx 89
- My DX has a sunroof!
- 2000 si rear disc on 90 crx hf
- 88 Sedan Build
- It's that time of year for my CRX to be VIOLATED!
- Civic hatch differences
- B16A rocker arm adjusting nut comes loose
- !!!!!1WTB crx hasport b series mounts!!!!
- b16a vs zc dohc
- swap 96-00 HX D16Y5 into a CRX HF?
- wats the best size tires for 91 HB?
- back deforst doesnt work
- 88-91 AutoToManual Starter Swap???
- What axles do I use?
- Have stock suspension not working for me............
- Which rims? any ideas?
- WHats the deal with es tunning mufflers?
- how do you tell trannies apart?
- I woke up and found this
- wiring question
- Motor idles
- Traction bar installed. Still have wheel hop.
- cross bracing for fork towers
- how to install a blitz turbo timer
- vibration at speed
- NEED HELP CRX DPFI TO MPFI CONVERSON
- how can i tell if i have blow bye
- I NEED HELP WITH MY CHASSIS
- TPS combatibility question
- bad engine mount?
- crx body/interior differences
- will a two inch hole in the block make my car run bad???
- what do i need for a sir front end?
- CRX B18 Swap Shift Linkage mod
- My car bogs after using seafoam
- cel 7 & 16 (searched)
- 90 dx
- 91 BOOSTED CRX FOR SALE!!!!!!!!!
- ZC Wiring: Need some help! (Pics included...)
- Have you ever seen this TPS??
- 4 GSR KNOW IT ALLS
- no power second cylinder??
- can I or can't I? Help!
- b18b on DOHC ZC
- what rims to buy....
- Can I Get A Single Cam ZC Reffed?
- solid motor mounts yes or no any opinions???????
- Low Idle, so I adjusted the Idle...
- Help! No more turn signals and no RPM
- Throwing code #14 help!
- Do 88 Integra Rear disc fit EF?
- help
- crx HF mini-me possible
- *Does eg lca fit ef?*
- my civic.... any suggestions?
- Any one got pics of a sumped tank in a crx
- E-bay amber corner lights.....
- how to add trans fiuld to a 91 si 5 speed
- 91 civic cutting out on bumps
- Warp block?
- tranny question
- Wheels, who's runnin what?
- Does this look weird? (NOT MINE!)
- buy my car
- Stock fuel pressure????
- PICTURE REQUEST: Carbon Fiber Fenders with matching Hood
- hasports h22 mounts
- How to wire highbeams for daytime use / daytime running lights
- lug bolts
- sohc vtec swap code 6
- sohc E.C.U's
- b18a1 90-91
- need ef8 front bumper
- I need 1990 HF info
- CAS on ZC motor problems
- crank pulley grinding away at the trailing arms b18a1 swap
- Curious what HT thinks this CRX Si is worth?
- What brand tow hook are these?? PLEASE HELP
- dx mpfi help
- EF3 Taillights
- Distributor removal question
- a question on lsvtec
- JDM EF Bumper
- 89' Honda Civic DX hatchback. Manual/starter questions
- I need help with emissions test!!!!
- Question about converting to 88-89 door sills...i have a 91!
- TRANSMISSION BEARING FOR B16A1
- eg rad help
- 87 HF interior parts
- short shift
- Explicit Speed Performance H22A mounts - good or bad?
- need help
- b-series on d-series
- $%$$ing bolt!!! STUCK!!! GARRRRRR!!!!
- Out with the old! in with the new!
- Dashmat?
- ecu
- preparing to win book
- idle problem
- new throttle body
- Did a ring job, car problems help get a crx running
- Z6 Head on A6 Block
- OBD0 DPFI to OBD1 MPFI (Issues with My Auto)
- Seats in HB
- CRX Rear Front X-member removal
- password carbon lip on 90-91 US crx front
- can't fix my code 1
- Anything to protect the oil pan and header?
- brakes
- 84-87 afermarket motor mounts
- Custom made mounts?
- 90 crx project pics!
- code 9
- my old cr-x
- wrecked from the passenger seat
- b17?????
- Electric Fans
- 91 honda back fires d16
- is my ecu fried?
- flashcode #9 cylinder position???????????
- c14
- wire conversion
- 1991 Crx Autocross/Street
- Wheels sticking out
- ZC = Civic Si?
- why arent my headlights working...
- help removing throttle body (DPFI)
- Fake OR Real?
- i need performance
- i have a 91 hatch si an a d16 an a 5 speed an i have the front steering nuvks
