View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 89 front bumper on a 90 civic hatch?
- T3 on stock B16A2 internals?
- CRX Bumper 89 and 91 the same?
- Sig Test
- What would you trade your CRX/civic for?
- Emissions Abomination
- d16z6 swap
- may be moving up in the world
- obd0 cap
- map censor?
- Help! Crankshaft Pulley
- swaped hathc for 2500
- Ebay CRX's crack me up
- looking for a crx si in reno or yerington for sale or woould like to trade for hatch
- Starting problems
- help guys!!! my car wont start!!!
- code 1 oxygen sensor tried new one didnt fix problem come help me figure this out
- problem with my car!
- Partial throttle surge/jerking problem
- 89 crx dx !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- problem .....
- Axle questions.
- 89-90/91 doors interchangeable?
- recommended build for 90 Si?
- Some newbie questions
- A few fitment ?? for those EF owners with boosted b-series motors
- CRX TRUNK
- EF Hatch & CRX owners with 4dr power windows. I need your help!
- Vibrating CRX
- Is it possible to buy mounts for automatic civic to make it automatic to manual?
- Vtec Problems !
- Sportlines squeaking
- turn signal not blinking problem
- PCV valve stuck HELP!
- Engine parts battle: D16a vs. D15b2
- help with energy suspension tie rod boots
- 91 CRX Si - was the stereo optional?
- Clutch Torque specs SEARCHED
- crx dies when i stop (if u know anything aboult a zc pls. read)
- sohc zc in 89 hb need help
- AWD and AWS crx
- HELP!!! 2000 hatch seats in 89 hatch?
- 90-91 Civic Hatch Guage Cluster in CRX?
- SHould i buy this?
- 88-91 CIVIC hb headlight question!!??
- Code 15?
- a theif got what he deserved
- NO START
- My Sunroof Sticks on my 91 CRX Si
- is a 4 door cluster the same as a hatch?
- Another seat swap question!
- Sun Roof Options. Benefits, Costs, and anything else you can think of! Share your sunroof knowledge
- Honda CRX Insurance quote
- Im stumped and Im asking for help
- 15.2 @ 89 B18A1
- will a b16a1 fit a 91 civic hb automatic
- d16a6 "head code" relevance / difference
- Do you guys have a habbit of Melting Distributors?
- b18c1 crx done....Overheating issues
- any one have crower cams in there b18a/b??
- cluster question (searched)
- mini me swap vs turbo
- kind of a ricey quiestion
- where CAN I get crx part
- exhaust advice
- tapping the head for LSVTEC
- D16z6 Swap Into 88 CRX DX...CAR WONT START
- How To: Check main relay.
- Need grommet part #, frame leaking water at hatch where wiring comes in.
- What's the biggest intercooler that would fit on a JDM front end (CRX)?
- h23 mounts?
- Engine problems
- anyone with header on their crx..
- towson maryland meet anyone?
- anyone had a problem swapping a d15z1 into an `89 hatchback
- IAm so confused please help me out
- streetimports motormounts
- what do i need foe a mini me swap
- CRX B16A1 swap wont start up again once hot
- Oil in my cylinders... HELP!
- JDM LINKAGE
- cable to hydro conversion questions
- CRX bolt on exhaust question
- żD-series alternator on B-series?
- my civic got owned
- HELP Need VTEC pressure valve color of wires? and pinouts b16a
- K20 CRX
- CRX HF rear springs vs SI,Civic,etc CANT SEARCH FOR 2 LETTERS
- oil leak, b18c
- EGR Valve Bypass
- jdm zc gauge cluster question
- NEED INFO SOON! 96 ITR on 91 EF?
- anybody using hasport b-series shift linkage + hydro tranny? what shifter bushings do you use?
- help out a newb! please.
- does any 1 have a good idea ....for the headlight issue
- 8K or 12K headlight bulbs
- D16A6 cylinder head value ?
- Need help with my hatch PLEASE!!
- Replacing headlinght lense
- boosted crx ?s
- how much is a z6 head worth with 200k+ miles?
- 91 hb
- which is better?
- engine building
- Catch can (I have searched)
- 105 octane --> $1.80
- Carbon fiber hood
- Gauges!!!!!!!
- DPFI to MPFI Problem need help!!!
- how much will it cost to fix this..
- Stupid radiator coolant leak
- whining noise please help
- block guard
- d15 rods who makes them???
- cant find a timing belt to fit!!!!! help!
- how do i swap del sol seats in to my crx hf 1991????
- mpfi injectors
- What does this relay do?
- rear disk brakes
- wheel/tire combo
- 88 HONDA CIVIC HATCHBACK THROTTLE ANGLE SENSOR CODE
- B-series swap in 88-91 civic
- Having CODE 23 come on ECU.
- My 90 Crx si for sales
- how to find TDC on each cylindar?
- Chargespeed lips for EF at groupbuycenter.com!!
- $50 through paypal if you can help me!!!
- pics of da 4 door....wow and to think i bought it for 500 bucks....
- d15 vacuum diagram asap!!!!
- B16 worth it?
- D16y8 AIT sensor placement
- How Nice Do You Think This Si Looks?
- install a si cluster
- dx - si - same?
- if the head gaske is blown....
- Anyone know a sight to help replace a head gasket?
- n00b need some help please.
- what parts to buy for a CRX B18 swap
- computer chip???
- Exhaust for a 89 hatchback, what all cars can i pull the exhaust from?
- NEED HELP 88 HARNESS INTO A 90 CRX SI??????
- crx hood for sale(socal)
- What is your fuel?
- hood hinge screws
- Problems with B16, ECU and clutch cable
- 89 not cranking over...help!!!
- 15" Steelies on CRX/Civic?
- Difference between 88-89 and 90-91 cluster
- dpfi -> mpfi w/ hf FI?
- power range?
- Electrical Issues (No Power) B16
- fibreglass front end or simalar? for 89 shape CRX
- Oil Porblem please help.
- hesitation/bogging ??!!
- 37820-pr3-901 Automatic or Manual
- Would this flywheel wourk
- What clutch should i buy
- SOHC LSD on Ebay
- Integra Brakes conversion, brake lines question:
- 89 TURBO PROJECT
- wich motor mounts inserts fit into the ef8?
- 1g talon injectors in b18
- hazard lights
- crx parts - header panel and/or front driver fender
- anyone have a z6 i manifold on a a6?
- Gas Tank Drain Plug. Will Every Drop Be Removed? SUGAR!!!!
- Need avice/opinions-Thinking of selling my CRX (I hope Its OK to post this here)
- B16 turbo discussion
- IMPORTANT NEWB INFO (REQUIRED READING)
- {how much is this worth?]
- Thinking about buying a CRX HF to save on gas. What kind of MPG do you get from this car?
- Looking Into a CRX
- paint code for biege and huge ding
- Hidden treasure!: I bought an 89 SI tonight!
- Best place to buy a OEM muffler?
- ZC oil feedline?
- HB exhaust on crx???
- ROLL CAge Question
- Well it was running again...then
- Just starting out...
- budget engine upgrade SMOG legal......
- will 90-93 integra coilovers work on my 91 civic?
- are crx hoods the same as civic hatchback hoods?
- 91 crx 4 sale great buy
- rear engine 84 civic
- Code #1 help
- How to install a new Speedo Cable in CRX?
- engine light on?
- small gas leak with tank full
- How much for new head gasket? What kind for turbo applications is best?
- 90 civic lx, crank but no start
- Arizona Area " Where is the best place to get my self a Roll Cage" On my EF !!
- broken bolt
- HOW DO I PUT 91 CRX Si SEATS IN A 90 Si HATCHBACK
- fuel upgrades
- O2's sensor question !!
- 91 hb suspension fit 89 civic 4dr???
- How to check fuel pump?
- Suggestions on intake for a b18c5 CRX?
- hey cute guys
- Boost ? ? ? ?
- p29 in d16y8?
- My hatch is dead!
- mpfi to dpfi automatic question
- Tranny help
- leaky valves
- Turboing the d16 in the crx
- need some suspension help
- Has anyone put an aftermarket steering wheel on a cruise control hub?
- F*ck!! Now I have a leak in my crx!!
- intake questions
- girl with a rex
- What do you think of this wheels
- ZC Crank same as any other?
- key on, no fuel pump kick on?????? electrical gurus, i need help
- alluminum or steal
- 404 crowler cams
- I FINALLY got her running again!
- z6 swap
- B16a 1/4 mile ?
- b16a compression
- second gear sucks!
- D16z6 and Nitrous?????
- Is MIA the best place 4 racing?
- Turbo Help on a B18a1
- Arizona owners please read!!! CRX JDM rear seat going cheap!!!!
- Transmission weights
- Clutch Troubles
- si distributor
- Koni/GC setup questions, and other install questions
- NSX Seats into 91 4 door 4dr EF / ED3 Sedan
- Need help D16a6 w/z6 IM
- what size is stock CRX steering wheel?
- does anyone have 450cc injectors for sale and a safc or hondata
- Ideas for mounting Sparco Evo
- little help on JDMb16a specifications
- clutch cable
- water in my oil
- Cigarett Lighter? Is it possible?
- should i get this thorttle body pic inside
- custom cluster question
- carbon fiber parts
- Meaning ov VTEC
- b16a1 in a 1991 CR-X Si...what is needed???
- 1987 crx si swap?
- will i have to do lots of wiring if i swap a jap zc in my 87 crx si
- Tried searching WEIGHTS OF CRX EFS
- PW0 ECU 88-91 B-series
- What kind of seats are you guys using?
- new paint!
