- help wanted
- no ignitor pulse
- 91' Civic Hatch problem...
- Y8 Mini-Me
- struts off a 90 accord on a 89 crx
- spc balljoints
- 91 4 dr civic 4 sale cheeep
- What One Piece CRX HeadLights Are These?.
- Truly in Love
- itr suspension parts on ef
- boost and juice
- Oil leak in ED Civic distributor
- what Spark Plug Wires do I use on my D16Z5 EDM CRX?
- axle/hub differences
- crx???????
- B16 tranny acting up in my Ef.
- What Tranny for a GSR CRX???
- exhaust leak
- DPFI Gone wrong
- new to the EF world
- need help with thermostat ground.
- questions on stock b16 on boost need some advice
- coments on ssautochrome t3/t4 turbos anyone?
- how can u tell the difference between d series/bseries injector
- Considering D15B VTEC Swap
- 91 civic si hatch 86k miles, mint mint mint, should i go for it?
- need a motor
- body question
- idle issue
- where can u buy amber corner lenses that look good?
- sohc ZC......need info
- ignition switch??????
- Paint my steelies?
- Fuse help
- Getting Pr4 w/vtec to engage vtec correctly
- Where can I order Bumpstop
- Dpfi to mpfi fuel efficiency change?
- Hasport H22 CRX only ran a 14.1?
- EG knuckle assembly in EF?
- looking for a QUIET exhaust for my CRX
- fifth gear (searched)
- Integra Half Shaft Intermediate
- I NEED HELP WITH A BUMPER COVER REMOVAL FOR A 1990 CIVIC HATCH CX!!!??
- fuel pump location
- 89 CRX Si, wierd code being thrown
- thicker headgaskets
- B16 timing
- wierd starting problem
- Air Conditioner Dryer problem?
- Pistons Question
- a/c problem
- hydro tranny in a crx w/b16a
- check out my new hood!
- value?
- ssac Bashers
- i'm doing b16 type r internals
- Made a tint appointment...talk me out of it...?
- what do you guys think
- OBX LS LSD
- Corner light harness/connectors/hardware - where to find?
- Quick question..... new to the crx and ef civic.
- Car shut off no oil no spark....
- D16A6 Question
- dizzy on stock motor
- What do you think?
- B16
- sprint extreme springs with a drop of 3.25" F - 3.00" R - is this them... pic
- hey remember the b-20 t-66 civic here it is!
- My A/C is... weird.
- transmission leak
- charchol cannister/ purge soleniod
- O.M.G just ran a 11.5 in a 91 si
- Autoweek states new CRX for 07 model year
- Installing a trailer HITCH on a HATCH.....
- conveting from OBD-0 to OBD-1
- 3200 rpm cut out
- convert to obd1 or stay obd0?
- Big brake kit and 15" rims?
- my motor for my 88 four door
- Are ZC engines realible engines (D16zc) from uk 16i-16 135 bhp ?
- crx si with civic si engine? straight swap?
- Building quiet turbo Exuast, need help.
- CRX WEIGHT 88-91
- s2000 seats in a crx?
- where is the injector relay on a 91 civic si
- FS/FT: 1991 civic sedan w/b16a in WA
- hydro pedal assembly
- 88 si clutch options
- Engine won't start
- NEED HELP FAST: SLAP MAIN RELAY PUMP PRIMES...but no spark????
- spoon civic specs
- removing the front bumper and replacing the windshield
- Need help after swap
- v tec dizzy help
- Blox Intake Manifold Yay or Nay on Regular Stock B16???
- Whats your favorite mod???
- How would a bad/failing FPR show itself?
- 88 hatch to 91 CRX Si mirror block off plates
- can you drop a b18c1 in a 91 crx si
- 89-91 HF and SI crx
- CEL code 17?!?
- Low End Power
- Fuel Pump problem, starts pumping whenever it feels like it!!
- How to test alternator?
- D.I.Y. / FAQ - OBD-0 --> OBD-1 Pinouts and Conversion Help
- what timing belt?
- Do I need to change the drivers side mount bracket on my b20b??? please help asap.
- omg!!!!! i need some help asap with my car its about to piss me off
- EF B-series axles -- recommendations?
- new to HT
- zc with d16y8 head
- CRX DPSI TO MPSI how do i do the wiring
- need help or instructions
- EF 88-91 civic/crx H22 mount kits available!
- '88 crx has code 20 and 1. runs but don't idle
- PICTURE WHORING: my 88 dx is gettin a new heart (56k unfriendly)
- help ignition switch problems
- Chopped an ED up into a Front Clip and back half
- accesory additional obd1 switch
- GSR into a CRX info
- 89 dx swap
- THANK GOD..... I LOVE MY HONDA THEY FOUND HER
- Help with code 4 on MPFI swap - crank angle sensor
- fuel rail important
- jdm side moldings?
- SEATS FOR REX.... TEG? YEAR ? BETTER ?
- Buddy Club front bumper....... cant find bump lights!!!!!!
- Mini-me
- no spark, igniter?
- ac install questions
- Has anyone (besides hasport) sucessfully swapped a k20 into an EF?
- B16 parts for H22 swap?
- new user question
- D16Z6 Distributor Wiring/Question
- billet throttle body wanted
- obd0 to 0bd1 with peak and hold injectors
- Tein Basic Dampner
- Has anyone installed an RMF Narrow header?
- fuel pump swap
- cams and tuning ?
- Steering wheel vibration.. perplexed
- fuel pump troubles!!!!!!! HELP!!!!
- CRX PRO Super Turbo Kit
- Couple of questions- Mid swap
- Rust issue on crx
- S1 vs YS1
- gears swap?
- Getting a PR4 chipped for my mini-me need to know certain specs.
- <--- new CRX owner on here
- zc block with b18 head?
- Where can I find door pillars for my crx???
- 88/89 L2-1 Transmission Or 90/91 L2-2 Transmission/ 20 Or 21 spline?
- Considering buying these seats. Question about rails.
- Tail light issues
- CRX HF stock shift light
- difference between crex 88-89 & 90-91 HF bumper support?
- jo tech?
- Simple clutch fork has me stumped
- Help me decide on a header
- do u think i need a new gas pump
- im looking for a b16a block $$$
- semi-overheating? rad. cap?
- 90 crx furl pump schematic?????
- 89 Civic Si b18c1 swap ... no fire or fuel from injectors....
- car is shaking itself to death
- Auto tranny VS Hp
- are the JDM EF 88-91 Civic hatchback tail lamps (3pc set) DIRECT REPLACEMENT?
- 1 sick EF check it out! ! ! !
- JDM EF8/EF9 airbox filter replacement?!?!?!?
- FUEL CUT OUT AT 3200 rpm (searched)PLEASE HELP
- question t3/t4 garett turbo into a 91 crx hf from ssautochrome need some advice
- repelicas of the mugen cf48 rims
- '87 CRX Si
- Ctr pistons
- Codes Question
- Since no body really answer my question abt lowering springs
- Need fuel line for MPFI swap - dealer only item??
- 89'si hatch ls swap
- Drive train upgrade question: appx cost?
- need huge favor from 88-89 hf crx owners
- it's the most wonderfull time for me SMOGING :crook:
- Is a B20B Crank Pulley bolt reverse thread?? Need Help ASAP!
- turbo kits
- can anyone recommend a trustworthy swap shop in southern california?
- fuel pump no power too much power
- wireing question.
- Rapidly flashing engine check light?
- transmission change
- Nor Cal/My 88 hatch for sale
- FS: 89 Civic Parts Car
- What is this
- For people with ZC trans and no Int. shaft. @@@LOOK HERE@@@
- Brake lights constantly staying on.....
- Swap Shop - Central Florida
- fuel gauge goes down fast and hesitates on full throttle?
- Intermediate Shaft
- Oil leak PROBMLEM!
- distributor wiring
- Dry shot or Wet shot nitrous
- S 2000 motor in a 91 crx is it possible
- B18a1 compression ratio 92-93 ?????
- DX to B16 wiring??
- CRX gauge cluster ??
- axle seal leaking??
- calling all experts ECU Missing ROM???? HELP
- What is this called???
- quick engine question
- Installed the DA front sway on the CRX today
- eg brakes on ef hatch ?s
- New car dilema
- PGMFI info (lots of sensor and sensor testing info)
- Exhaust
- 5 lug itr conversion on 91 hatch?
- help losing power
- sed16a6 mods?
- Shifting problem
- if your motor is still running, but runs like crap is there still plently of life left in it?
- Noob with a broke 91 HF crx
- HELP-All the sudden car won't start??? pump primes, then silence...
- Help Clutch troubles
- Is this a fair asking price?
- ITB's
- How Much Quarts?
- cRx:what racing engine should i swap with?
- planning for the head
- Temp. Gauge Not Working?
- UKDM CRX rear wing...?
- HELP!!!!!!
- need help repinning dizzy for obdo-obd1 searched!
- bumpsteer eliminator kit
- need help...searched
- Will 5th gen Trannies fit?
- civic si 91 wanting to run 13.75
- Emissions finally passed-thanks homedepot :)
- Bigger B16A1 intake manifold
- ECU Trouble Codes 89 4-DR DX
- Door Panels
- Broken wheel studs
- CRX - With or Without Rear Wiper (For Wing Design)
- looking for exhuast....dont know which to get
- HELP!!!! car wont turn over, and i have to be at work in 2 hours.
- coolant problem on b16
- Project finished!! (LS-Turbo) (56knoway)
- JDM front bumper "Testing the water"
- obd0-obd1
- vtec kickin in too early?
- 89 crx si b18b engine swap
- Jumping A/C compressor?
- transmission problem--86 civic
- Flush the tranny out
