View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 10 Sec SOHC CRX
- shocks springs headers and hi flow cat i need to sell asap need money for a car
- Y8 vs Z6 cams
- Front end shimmy
- Write Up: Installing gauges in the DIN slot.
- Engine serial number lookups. Stolen or Not in California
- error code question on d15b swap
- Lost my service bolt for fuel filter!
- wiring harness
- Precise differences in RHD vs. LHD clutch cables?
- clutch cable?
- Cluster help?
- need help
- Latvian CRX
- 89 hatch stollen in bear deleware
- CRX Rear tail lights?
- need some help plz?
- b18a1 in 91 4d civic
- stock redline for singlecam ZC?
- Where to get this interior piece
- EV swap with D15B...!?
- ef d16z6 vtec turbo CLEAN (not running)
- cracked rear crossmember....
- Meets
- b16 or b18
- jdm cluster ?
- quik question
- broken axle noise
- CA Smog...failed.....again
- D16Z6 MPG?
- need a little guidance
- transmission Specs
- DIY rocker arm removal
- IDLE PROBLEMS
- Front Bumper removal 89 Civic Si?
- No Spark with my DPFI to MPFI 88 DX Civic w/ B16
- sohc si head on zc sohc block
- More wobble issues at >50mph
- iratic tach
- jdm headlights
- 5th gear throws reverse light.
- need wiring performance diagram civic '95 Si
- question about shocks
- DA front spindles wont fit vx wheels.
- b16a1 tranny help
- just help me before i cry
- harness help
- Charge warning light wiring route?
- fuel problem...???
- Crx engine swap f22
- Does anyone
- Fuel line question with illustraded pic.
- Motor Problems
- awd drive civic
- Shakes At Idle
- OBD-0 to OBD-1 Conversion problem ***please help!***
- ZC Headlight Adjustable motor wiring help
- B16a 1st gen exhaust has black flakes
- 1990 honda civic lx timing
- G-mans Build Thread
- Shout out to innovative mounts for an excellent deal, motor mounts, traction bar
- question about suspension?
- loose intake
- i need some help
- i'm lost
- how do u go about ajusting head lights
- Picture of an underhood fuse diagram
- help looking throttle body 91 ex
- car shakes
- b16a axle
- anybody ever take their vtec solenoid apart? HELP!
- REQUEST: EF BRAKE GUIDE
- obd0-obd1 question/swap
- pm6 ECU help
- master cylinder upgrade
- Need advice on brake MC after a few upgrades......
- vehicle speed sensor question
- need help b16a
- Emergency brake light staying on!?
- PGMFI.org is dead or something - need PS9 ECU help!
- help! FPR question, other random questions
- car shakes, but only when giving gas wth!
- ecu question, not much of a obd0 guy
- problem
- brake problems tried everything HELP
- couple of questions mini me swap
- Need help, crx b20 check engine light on
- SHOULD I SHAVE REAR WIPER?
- help code 20 mpfi swaped DX 91
- Crx motor problems
- ECU Code 22 - JDM B16A, '89 CRX SI
- NEED TIMING BELT HELP ON MINI ME
- EF check engine light code 9
- ECU Fuse blows when ignition is turned on...
- crx steering wheel???????????
- URGANT!!!!r
- when my car warms up it turns off
- QUESTION ef cluster to a eg cluster is it posible
- manuel trans problemo
- No harness, no ecu. What ecu should i run...?
- runs for a few then dies
- CRX front end conversion SIR
- 1994 civic hatch no cat
- wiring a walbro fuel pump question
- Failed Emissions Test (WA)
- Any EF's on bbs' rms?? post em up
- should be a simple wiring question
- ELECTRICAL HELP PLZ!
- engine swap
- ZC axle seal
- timing for 1990 integra ls
- DX EF need help WIRING!
- question
- obd1 engine harness?
- ROCK Brand Gaskets?
- Clicking noise inside my transmission.
- B16 SWAP INTO 88 CRX SI
- d16a6 running rich
- horrible mpg!!!!!!
- wow never seen that before, Altenator fire!
- STEERING WHEEL REPLACEMENT
- h22a4 or gs-r 95?
- help bumper filler lip on 91 ef
- Harness Guide Bar ?
- Strange noise from timing belt cover
- omni full coilovers on ef
- question about runing a pm6 with a jdm zc sohc vtec obd1????
- i need help
- im looking for a pic of this guys ef on here have YOU SEEN HIM help me find a pic
- my crx stalls when i come to a quick stop
- no heat???
- which cam is bigger and better???
- Emergency can't remove oilpump from block. ****
- switching dx wiring to si got some questions
- help please
- Upper balljoint removal spc install
- Quick Dizzy question
- jdm d15b header questions?
- fender brace
- Eibach Sport/Pro System Plus or best option?
- wanting to go to v-tec!
- cant find dizzy
- Single cam vtec swap to an ef please give pros and cons about it thanks
- window ?
- Plastic front end cover
- Hytech Tri-Y replica header in B-sereis EFs with stock crossmember?
- crx si
- b16 on crx
- Got a harness from monotech, plug is missing. (will it cause a prob?)
- car shut off and wont start up again!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- thinking about parting my crx
- car will not turn over
- clutch
- resistor box question
- Ever have domelight problems? Turns on while driving. Here's the solution /w pics!
- ROOF LINER
- question 91 civic 4dr swap smog emissions
- can't pass emissions ef swaped ls
- NEED HELP! ON 90 HATCHBACK
- CRX: H22A with A/C
- Got an exhaust problem
- 2 problems with a dohc zc and b18 both r in hatches and flasshing......
- Crx hatch problem
- VACCUM LINES
- Crx w/b16 cooling fan question.....
- cheapest way to get my car running n/a again...
- I need help with my crx(smog test)
- edelbrock intake manifold
- need help someone please help?
- What kind of rims are these?
- Help: What's wrong with my car?
- WHERE CAN I FIND A CRX?
- cam question
- 1990 civic with zc, won't start
- crx bumper on a ef hatch
- C Pillar tiebar Questions
- clutch issue
- intake question
- Just installed new fidanza flywheel and exedy clutch now it vibrates 1st and 2nd
- stolen: 91 crx
- My Civic won't start!!!!!!! HELP PLEASE!!
- spark plugs order
- problems with master cylinder
- car wont stay running
- Sunroof Motor and installation.
- DIY CRX JDM B16 Vtec solenoid gasket change
- a weird prob with my axle
- Integra LSD in CRX?
- help me decide what to do with my motor?
- wtb parts
- setting ignition timing - cant find jumper plug
- Water Leak
- gas leaking from fuel rail...new washer or sealant?
- My 900 dollar crex
- HIDs or high/low beam bulb mod?
- Fuel Pump
- ZC? that's it? its a DOHC so is it a B-series? i need some tech info
- Nippondenso or Mitsuba starter???
- integra rims on ef?
- Half Shaft/Axle
- jdm zc in 88 crx hf
- water leaks
- B18C Exhaust system
- b16 swap failed emissions! :P
- Ever wondered whats inside the fuel filter? Pics inside
- replacing Main bearings and connectiong rod bearings..
- electrical problem! Weird!
- battery relocation
- door skins and dohc zc valve cover
- Y8 motor with 89 Si trans
- Best Motor Oil for B16A
- 91 crx trouble with fuel injection
- bumper for 89 hatch i need it
- My First Honda
- help please..
- Help with replacement steering knuckles
- DPFI to MPFI wiring
- JDM front end conversion
- i want this...
- Generic Rear hubs/bearings on ebay.. which ones are good? Fit EF8
- Engine turns over,but wont start
- b16 in my 4 door ef
- *How much does a b18 block hang*
- rough idle (did search)
- replacing bushings on my 4dr
- jdm cluster help
- Tokico Hp's 89-91 all the same even 4 door?
- HOOD STUCK CLOSED! Need Urgent Help
- d16 block lbs? did search and couldnt find right answer
- D Swap into CRX Need to make Speedometer work
- Painted engine bay help!
- failed local emissions testing (aircare) need help
- Left front tire Hitting the rear of fender. What bent?
- need to know bolt size man tranny mount holes to block
- READ THE RULES, READ THE RULES, READ THE RULES
- WOBBLE NOISE IN DRIVETRAIN, HELP!
- help wit my EF hatch
- Need help wit a dash swap /OBD 1 wiring harness swap
- i have a mini-me swap Y8 head on a b16a2 bottom end
- dizzy leakage question
- 91 power steering
- ecu pr3
- SiR front bumper on sedan
- CRX dash
- CAM SHAFT ????????????????????????????
- oil smells like gas and oil has burned away
- weird problem.
- proplems when start up
- 4dr EF rear seat swap? looking to change mine
- Doing a brake flush and want to use my air compressor. Quick flush or oily mess?
