View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Looking for Jdm front
- too much camber?
- need all of these?
- 88-91 Hatchback Cat Back fit 88-91 CRX ?
- Something i've been wondering for sometime...
- Broken axle issues
- Gas milage
- Place Racing X-member
- Turbo D16Z6 w/ HKS SSQBOV... backspin?!?!?!
- Has this happend to you?
- Question about the d16z6 with a Skunk2 manifold...
- Very Detailed Cluster Problem-Yea, I searched.
- spun out and damaged my civic... help!
- Zc Question
- got a forum question
- Single VTEC swap dizzy
- [__Want vtec__]
- 89 STD radiator 2 inches shorter then 90 crx dx??
- Milestone Mileage
- does the rex have a warning beep for when you leave you lights on?
- seat rails
- is this car worth the price...........
- Royal blue?Turbo crx
- D15B swap into a 1990 CRX DX, grocery list....
- 1990 Si Hatch
- b16 running rough
- I WANT TO DO REAR DISC BRAKES ON MY 1990 CRX HF?
- Will a??????
- Torque specs for b16a head?
- what gasket set and rear main seal >b16a1
- vss issues
- Anyone here install a del sol radiator?
- extra ca$h
- can someone post up there REAR lower tie bar...hatch prefrably
- My New(old) 96 Civic Hatch Is Having Some Problems! Help!
- 1.6 turbo
- Big problem for me!! help
- factory speaker size ?
- 91 clutch cable
- Car sputters after warm up. Why? And how can i fix it?
- Does anyone know of or have any pictures of a CRX with the EVOBody Kit questions
- CRX Paint Job
- Sole USA Mugen distributor
- Hatch rattle or creak any1 have this or know howto fix
- Jap spec crx
- buying a knock sensor from the dealer
- I dont get it
- Ls/vtec help
- Crx Upper Reinforcement?
- Chassis Code
- GC and Koni Yellows: is 450F and 350R a god spring rate?
- Odd sounds??
- Here's my setup so far!!!!!!!!
- Plug wires
- I got jacked last night!
- axle help
- car will go if i barely give it gas if i give it gas it dies b18c1 crx hf
- PICS
- FMU Install 94 h22a1
- which cams?
- Possiblilty to change dx gauge cluster to si ...with the rpm gauge
- door panel interchange -- CRX to Hatchback
- 91 b16a in hatch: what a/c belt?
- ripped cv boot
- double cutout stereo trim
- Waterfall on my head?
- ITR or Skunk2 IM ?
- 91 teg lights,bumper on 90 crx possible?
- what car is this from?
- b18-a1 ef swap almost done but runs like hell
- Motor and auto to 5spd conversion in a crx dx
- timing question i'm a noob
- B16 head/k20a manifold can it be done??
- any idea how to get broken lug nut off?
- Legend V6 into 89 Civic Hatchback
- '86 CRX Idle problems
- what to do with my A6
- question about b18 sensors on back or block
- Carbon Fiber Hood?
- trannys for zc?
- LSVTEC'ers, need a few Q's answered.
- 1991 Black CRX Si
- HELP!!! Fabricating wire harness for B16a into DX/STD model
- what crx si parts are useful on the crx hf?
- 88-91 seat belt swap
- suspension
- Whats the best fmu to use on a stock d-series turbo kit
- std hatch with crx hubs
- 1991 CRX Si Shell for sale/ OBDO LS and OBD0 B16A Long blocks for sale.
- V-tec...
- Crx/Civic front bumper turn signal dual conversion
- Anyone ever have work done at Hondamans in Pasadena, MD?
- that dry ice intake...
- Scorpion Cat-Back Exhaust
- Door lock question
- my crx with sohc vtec got faster...1/4 times inside.
- distributor , ign timing advance for DOHC ZC?
- Need help trying to install jdm 88-91 Sir (EF8/9) Gauge Cluster
- these strut bars
- piston slap ? what is this noise in my ED ??
- dohc ZC into 89 4 dr ef
- what should it run
- b18c1 crx hf cooling fan isnt working couple questions.
- suspension problem
- Affordible 2.5" collector 4-1 header for B16 ONLY...........................where?
- 90 rs cluster swap
- wagovan hoods and hatch?
- Car wont start...im stumped!!!
- Squeaking problems and a header question
- 97 J-spec ITR motor, missing between 4.5-5k in 3rd and 4th
- race rocket rust bucket%$W^ getsa header
- down to two motors for my car... B16A vs. B18A1, what do you think
- crx door
- torgue specs ona b18a1
- chikara header problems
- looking for fenders for 89 crx hf need help
- Startup issue
- Do you think that with the right tools and the right smarts, a crx can be concerted to AWD with a lo
- Engine bay fuse box?
- Looking for this wing
- My wiring problem for my distributor
- Rear Disc brakes on 91 rex
- will koni yellows from an EK fit on a CR-X?
- ELD sensor help for noob?
- Bad distributor or bad sparkplug /wires?
- Vtec pressure switch
- accord front lip on a crx?
- knock sensor and vtec
- 88 Crx Si
- SPRING COMPRESSOR HELP!!
- HELP!!! check engine light
- b16 probs still!!
- Cleveland
- CRX dx with si harness
- gauge cluster swapping and melting?
- Actual gains from an MPFI swap on a D15B2?
- where is the FS and WTB thread
- GREAT VIDEO!!
- How sensitive is a B18C knock sensor? could chassis/engine vibration be detected by KS?
- Quick ZC question
- 90 dx
- damn emissions!!!
- HELP ! maby wiring or alternator problem ???
- just bought a 91 crx si, stock
- Exhaust Question???
- duplicolor wheel paint no longer in black?..now what do i get??
- B16A swap in stock '91 dx, is it hard?
- Sputtering PROBLEM! Please help?
- d15b only revs to 5.5k plz help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- ef
- RS-R Exhaust Magic for CRX
- will a gsr head bolt on to my d16a1 block
- Angel Eye Wiring. How? +++ 400WHP In A Box
- jg single cam shortblocks
- moonroof closes automatically?
- ef-8/ef-9 cluster with no plugs... will it work?
- ZC into 4wd clutch question
- DA exhaust?
- lights--making my corner's blink faster/what lights are legal
- sohc awd zc civic si
- CRX '91 dies once in a while....
- what motor stock...1990 Civic Lx??
- What clutch for jdm d15bvtec
- MY 3RD GEN CIVIC SI
- Looking for the best stock 92 CRX VTEC
- JDM CRX vs USDM
- I need help....
- Hood risers / AKA: hatch shocks for your hood
- hey guys help me figure this out real quick
- Parking/Bumper Lights Like or Dislike??? (2PICS)
- HELP!!!! ITR Cluster, b16a1 civic - need quick response! searched!
- jdm crx center console pic request
- Oil pressure problem with my ZC
- Crx 88-89 and 90-91, what is interchangable
- crx with dohc zc engine HELP!!!
- CRX with a b16
- USDM bumper support on a JDM front bumper??
- how much $$$ to have Ls/Vtec built at shop
- local alignment shop says need specs for proper alignment?
- side molding?????
- transmission leaking!!! ???
- intake question
- I HAVE A BUZZIN SOUND THAT COMES FROM NEAR MY INJECTORS???
- when braking tire rubs
- jdm square yellow fog lights???
- Quick MPFI question
- CRX HF leaking water
- mpfi automatic swap?
- DOES ANYONE KNOW ABOUT 88-91 civics???
- shopping online for parts
- Can someone help me????/
- zc motor help(exhaust cam sensor)
- HELP ME INSTALL!!!
- spline diameter...
- y7 vtec?
- 99 y7 into 88 civic lx problems questions
- JDM HOOD
- i'm installing a ls-vtec turbo in my ef9
- Help need more power from my d16a6
- 89 Civic Si torque spec?
- D15B2 (Dual Point) to JDM D15B Vtec ? why bother?
- b18c1 starts up now...now im having a new problem car axles wont spin
- FINAL PLEA: tranny resting on front x-member, axle just refuses to stay in.
- Blue smoke but good compression, I think. Help please.
- map sensor ?
- Tranny problems?
- corner lights on a 89 civic si hb
- Yah yah I know
- EMERGANCY!!! black top zc wont stay running!!!
- Timing belt broke?
- please help(buying out-of-state automobile)
- need help on suspension on a 86 crx SI ?!?!?!?!?!?
- main relay, interior fuse box, and integrated control unit same on crx and hatch etc.?
- yo my tranny is leaking like a motha. got any suggestions?
- PR4 ECU on JDM B16A?
- vtec or non
- b16a VTEC rpm
- a little help please
- 1991 honda civic EX with zc swap for sale
- Heater Dont Work, Help Me?? ::cries::
- need help with my F22C swap
- Speedo cable problem! help!
- 92 vx in to a 91 dx
- tie rod replacement questions
- ZC tranny clutch?
- what is coming out of my engine?
- Help!! FITV questions
- Why does my CRX lean soo bad?
- want cams
- how to go from trial user to normal user
- ok seriously...which distributor cap and rotor for b16a1 OBD0??
- Tranny swap on JDM 1990 CRX(SIR-B16A)
- Need Help - Looking for my Old Car
- diy black housed headlights
- 4th Gen vtec lude seat question.
- axel length
- Trouble in Paradise
- Put in new block and turbo, no codes idles really high
- JDM Fog Light Wiring and Connectors...
- Any archived or save threads on complete stepy by step LSVTEC build?
- b16 w/ type r mani. idle prob.. help ASAP
- All Ed Winshields 88-91 Swappable?
- Bought New Doors. Dont Have The Key...... Can I swap?
- how to dsm injectors?
- "Trim" question
- D15B non VTEC
- What do you guys think??
- wobble in crank pulley (not good)
- Momo Shifter Install
- Coolant Leak. I cant find it. Suggestions?
