View Full Version : Honda CRX / EF Civic (1988 - 1991)
- need some help!!!!
- just bought a 90 civic hb beater...have a question...
- Hood Pins installation...
- Not enough room to heel-toe...?
- b16a vs sohc vtec turbo
- Anyone got a Walbro fuel pump?
- kyokugen lug nuts
- I need help with wiring for a crx
- orderd a first gen b16 from osaka!!!
- eg sleeve coilovers fit 89?
- compatibility of JDM S1 gearset in LS transmission?
- help on removing a block
- Stock PM6 ECU or Chipped PM6 ECU for MPFI swap
- D16 headers comparison site
- civic sunroof on a crx
- Carpet
- VTEC Wiring Using 95 CX Harness (Diagram would be great)
- anyone know of any good sites selling 15" rims fairly inexpensive?
- My CRX got hurt =( 4 car accident in a parking lot!
- is the gear on rhd car the same as lhd car?
- dumb ass question
- JDM ITR lower control arms
- NEW OBD conversion harnesses $135 shipped
- some new parts are in...
- Anybody that wants/needs a motor or parts
- were did you get your swap from?
- Car seems to be bogging
- car running hella rich, .75 volt o2 reading, and it bogs in low end a lot...
- Anybody have the link to the CRX that converted to the CRV AWD system?
- Will LS distributor fit on sohc head??
- does any body use this muffler
- Alternator
- anyone use blown90hatch jumper
- Type R CAI
- considering buying an 88 hf
- Installed the Delta 260 cam this weekend. D16A6
- B16 guru's I need your help..........
- S1 tranny was not made for highway cruising!
- Positive battery terminal is almost touching my CAI
- Srs Light
- check out my web page
- ZC Distributor
- clear corners
- b16 timeslips...not good :(
- Anyone have a picture of their fuel rail they can show me?
- B16 Feels weird kind of boggy under light throttle
- changing out clutch
- ZC Sales?
- Car wont start when its HOT outside
- uca question
- WTB: 88-91 SI parts...
- What synchros fit into the JDM S1 Tranny?
- How much would you pay???
- hydro to cable tranny conversion
- dumb questions??
- gauge problem
- Need D16z6 installer/engine in LA area
- major b16 problems! please help!
- attn: STD and HF 4th geners w/ swaps, i need your axles
- headers for my zc
- timing belt change ?'s
- d series header (92-95) question re: DOHC ZC
- moving hood-latch release?
- People Who have Tuned Sohc V-vtec (Y8 or Z6) With a V-AFC L@@K!!
- How can you decipher which tranny? (ZC)
- will a clutch for a 92-00 civic fit my 91 crx si??
- 91 b18a into a 88 CRX
- having a few problems
- d16z6 swap wont start
- B18C5 in 89 CRX
- wireing up an OBD2 Distributor in an OBD0 crx
- Got my trans apart tonight....damn
- To turbo or not to turbo...gimme some thoughts
- axles
- fuse blowing problem, please look
- To the ppl with crxs
- CRX B16 axle question
- B18a into CRX questions
- CRX muffler fitment question
- doing rear disc brake conversion on my 91 civic hb which cables
- DOHC ZC redline? More questions..
- advance timing on mini me
- code 43.... fuel system?!? how do i tell if thats the problem
- timing help
- opinion's on what parts to use for lots of hp 1genb16a1 all motor??
- Need Help Please! Gauge Cluster Swap Question
- Hey My Friend Needs Help!
- Possible tranny issue?
- Oilpan gasket change!! Please give me some tips
- please help with rear disc??????????
- multiport/dualport
- Help us settle a bet!
- looking for feedback on "Japan Direct"
- ++++door pilar help!!++++
- Shite Question
- gas smell inside the car...
- cutting steel?
- ZC Timing?
- wheel hubs: 91 integra hub fit a 91 civic ?
- idle surges after throttle body change
- Code 47, 89 DX hatch, stock motor
- zdyne 1 wire
- Tein HA's on EF
- 4 spd dx hatch?
- 96' type r suspension
- could and bad tranny cause this?
- The stock motor in a USDM 1989 Civic LX sedan is?
- How do I make a 89 crx hf motor harness fit the 1.6 si cabin harness?
- best cat-back exhaust system for crx
- does code 7 trigger check engine light?
- 90-91 corners on an 89 hf
- LCA bushing removal
- Who sells internal tranny parts....
- Installing b16a into HF question
- excessive shaking
- how hard is it to put in power steering?
- mini me!!!!!!!!!!!!!
- Which axles and midshaft, B16A into 90HB
- o2 placement on turbo setup
- B16 engine parts
- TURBO OR ALL-MOTOR B16A??????????????
- B18 non-vtec worth it?
- Rear Arm Bushing
- arm rest in an 91 dx hatch
- mini me question
- cam gear settings
- motor mount questions
- What is required to make a Skunk2 B16 manifold work on a 1st gen B16a?
- torque, horsepower and compression
- New member
- VTEC engine
- Custom Gauge Cluster
- JDm D15 vtec or Mini me?
- Code 14...EACV..but the EACV unit itself tested good...
- Honda Progect
- B16A1 Pulley Kit
- MPFI Swap Question!
- jdm dist. for sale
- front lips for sale
- Removing rotors for turning.
- What do you guys think about strut bars ?
- how is the availability for cams for this?
- What could this be?
- C-Pillar Bars for EF hatchs
- no spark or fuel in crx swap.
- mini-me dyno!!!!
- Mugen chipped pr3 questions...
- Need a stock driver seat!!
- how many miles does your car have/had when it was bone stock!?
- Anyone here fluent with crx door internals?
- d16z6 into a 91 hatch?
- Reliable Shops in MD, VA
- crx w/gsr swap problems
- I dropped an injector and broke it :(
- tranny and torque specs
- how do i do this??
- got in an accident friday night
- CEL code8
- Grrr... new dizzy, still having problems!
- my new exhaust!!! What u guys think???
- Problem with compression!?
- Fields SFC VTEC controler info
- 2 movies thought I would share
- anyine running d16a6 with 11:1 comp or higher? what kind of times to expect?
- TPS @ WOT = 4.1v
- SiR headlights...have hi/low beams? what type of bulb?
- My break lights dont turn off....
- 3rd seatbelt?
- smog JDM b16 in 1991 civic
- opinion: 91 hatch werth 800 dollars?
- engine help, can get an ls motor but need some help
- Quick ZC Question''''
- Please Help!!! My head gasket blew and i need to find one for my ZC
- Need Engine Swap Help Immediately
- help air fuel gauge problems!!!
- SWAP QUESTION std to si common guys im almost there
- i need opinions ASAP
- Sorry but i am new to the crx and i need some help..
- do tractor batteries charge the same as car batteries?
- Questions for ZC swap...
- 88 CRX DX automatic radiator swap w/91 Civic
- Tanabe Sustec suspension?
- Will an 88-91 crx cat back exhaust system fit on my 1985 CRX?
- opinions on a big brake caliper bracket
- How many gallons does a crx gas tank hold?
- !complete ls/vtec head!
- CRX Sideskirts...Need some info/help
- Anyone with a 4door got a CF hood?
- Looking for Jun or Spoon lifters
- Autocross day and the creation that followed
- Axle question
- how many splines on 89 si axles?
- std to si swap i need help fast
- Clutch Splines question
- I need some parts!!!
- cable tranny woes
- anyone has a b7/z6 mini me??.......... i need help!!
- setting idle . (pull iacv?)
- 89' DX to 93' EX won't start..
- best exhaust setup for 91hatch
- CRX rear JDM seats.
- mini me questions.... need help!!!
- Are these lowering springs any good???
- ZC Header
- Finally found a suitable daily driver.. need some advice and opinions..
- axle nut problem has this ever happened to you before
- code 8
- help, i farked up!
- Can't beat a Prelude?
- DC Ceramic Headers losing polish?
- Main Fuel Relay Part Number
- Rubber spring wrap?
- help with shaving door handles!!!!!
- Bushing install
- how to tell JDM or USDM
- OBD1 Swap Car won't start!!! Code 41
- do you get a ticket for driving a rhd car???????
- ZC torque #'s please help...
- need help bad with my swap read asap
- zc questions that i haven't seen answered........
- b16a1 Swap tech question: THE AXLES!
- zc help
- Damn i love this b16!!!
- Stupid people DON"T READ!!!!!!!! ASAP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Strange Hesitation Issue...
- A SECURITY SYSTEM FOR 2 DOLLARS...Yea, it werks, I am gettin fawking sick of thieves
- Which intake to fit battery under hood??
- Help Please!
- EF camber kit similar to the VISION kit?
- JDM CRX Foglight Question
- My dam LS Axels don't fit on my Civic DX 91 Hatch
- i hate my car..can someone help
- HOW the Hell...
- Motor swap..... ZC ?
- Need a clutch
- changing out the diff?
- zc engine or d16a1 DOHC into an EF
- NEEDED::::::: 89-91 civic hatchback willing to trade or buy
- tie rod help (i think)?? wobbling wheel HELP
- autometer guage hook up and headlight switch question need help fast
- I think I screwed up my wheel bearing - come point and laugh!
- ITR 5lug conversion on ef hatch.
- B17 Vacuum lines in a 90 hatch
- ecu pins anybody
- cel and o2 problem
- VFAC where did you mount yours?
- Needed: Pics of SI manifold Throttle cable bracket
- What does it mean
- 89 Civic Si Rotors ???
- Dx brakes vs. Si brakes
